  3. My Slim 2AA Battery Node
498 Posts 71 Posters 598.6k Views 69 Watching
  • K Komaandy
    Still up and running stable.
    8Mhz Bootloader did the trick for me :)
    m26872M
    m26872M
    m26872
    @Komaandy Nice! Thumbs up for 8MHz (and your "dark-style Fhem" - same as I use) :+1:
    • K
      K
      Komaandy
      @m26872
      thanks again for this great idea and that you developed these fine boards !
      And by the way...
      As you are using fhem as well...
      How do you manage to reset the tripped "1" in Fhem ?
      I just added a delay and a gw.send"0" to your sketch :), but using fhem would be more sophisticated actually ...
      m26872M 1 Reply Last reply
      • K Komaandy
        @m26872
        And by the way...
        m26872M
        m26872M
        m26872
        @Komaandy said in My Slim 2AA Battery Node:
        I don't. I just use the last trip time as it's state and then notify (e.g. light or push message) on trip. I think it should be very simple to make a notify with a timer "at" to reset it after a while, if you wish.
        • siodS
          siodS
          siod
          just want to mention that I am using successfully the same Bootloader @Komaandy is using for about 2 weeks now. So it seems like my problems with freezing nodes are depending on a bad or too slow bootloader...
          still learning...
          • B
            B
            buxtronix
            All of the ducting near me is a bit too slim to fit sensors based on this, so I decided to design and print a case instead.
            Does the trick nicely, and I also chose to use proper AA battery clips to retain a good connection, as the cable-tie battery assembly wasn't holding well for me!
            On the Thingiverse page I have a link to the original OnShape doc.
            https://www.thingiverse.com/thing:2418194
            Thoughts, suggestions, etc will be much appreciated!
            • O
              O
              Oliviakrk
              Hi
              Did anyone make DHT 22 slim node with MySensors 2.0? I created one Node from modified MySenors 2 example...But I get a feeling that it is freezing sometimes (but then again comes back to life).
              mfalkviddM sundberg84S 2 Replies Last reply
              • O Oliviakrk
                Hi
                @Oliviakrk the dht22 needs at least 3.3V to function properly. See the datasheet.
                • O Oliviakrk
                  Hi
                  sundberg84S
                  sundberg84S
                  #443
                  @Oliviakrk - I did a test (which works pretty ok) with a DC/DC step up booster attached to D3 -> Vin. This way I could turn the booster on/off with HIGH/LOW from the sketch. This provided 3.3v to my sensors just fine and has been working for a while now. I dont know what will happen when the voltage drops though.
                  O 1 Reply Last reply
                  • sundberg84S sundberg84
                    O
                    O
                    Oliviakrk
                    @sundberg84 Thanks. Will try.
                      masfak97
                      Thank you for all the hard work put into this project. I have built a few door sensor nodes and have some issues. At first I had pull-ups connected as shown in previous pictures but at a logic 1, when there should have been 3.3V there was only roughly half, 1.7V. I am no expert but I take it there has to be a current leak through the D3 pin for this to happen. I have this on all my nodes. I have tried different code but still the same. When I remove the external pull-up the node works properly but instead the batteries run out in a week or so. Have I made a mistake soldering these and maybe shorted something? I have looked at them closely but can't see anything wrong.
                      Does anyone else have this problem? Any tips?
                        Did you actually check if there is continuity between the pins you said? Do you have a photo of your nodes?
                          masfak97
                          wrote on last edited by masfak97
                          #447
                          If I disconnect the battery, there is continuity between D3 and VCC with a resistance of around 20 kOhm. So when the door sensor is shut (no resistance), I connect GND through 20 kOhm to VCC. The current should be 0,165 mA. Too high by reading previous posts but still much less than what I get if I measure. Then I get roughly 18 mA! (Far from a Fluke though but has proven reliable before). Am I misunderstanding things?
                          I have tried different nodes and sketches with pull-ups both enabled and disabled but I doesn't seem to matter. I have tried different radio modules but still the same, unless I use the bigger! antenna-version. Then the current goes up to 24-25 mA.
                          I have done/am doing something really wrong although they seem to work just fine. Tomorrow I will try more radio modules to see if I can find any difference.
                          3_1504391407612_IMG_4745.jpeg 2_1504391407612_IMG_4748.jpeg 1_1504391407612_IMG_4747.jpeg 0_1504391407611_IMG_4746.jpeg
                          • M masfak97
                            m26872M
                            m26872M
                            m26872
                            @masfak97 It's not clear to me whether you've tried to run it a as pure Arduino, without radio module and without MySensors library in your sketch? (I see that you haven't the serial/FTDI pins soldered - do you use ICSP, pogo-pins or whatever to upload and debug?)
                              masfak97
                              I have thought about running it as a pure arduino and to use the debug function, but can't quite get the FTDI to work. I have used this before to upload code to arduino pros. I have a previous node that has all the pins soldered but simply won't be recognized with the USB FTDI. I have also tried switching USB-FTDI but still no luck. Is the FTDI supposed to work if all the pins are there?
                              I have also bought a USBtinyISP but haven't read up on how to use it.
                              Currently I install a first boot loader with Nick Gammons sketch running on a UNO connected to a breadboard and the 328. After that has been installed, I install the 8 MHz boot loader by Gert Sanders (thank you of it) and finally upload the code using "Upload using programmer". I currently have no way of reading the serial debug from the node.
                              I checked the node without the nrf but still power-hungry in the mA.
                              • m26872M
                                m26872M
                                m26872
                                I think you should focus on getting these basic Arduino functions working so you're in control of what's going on. Note that I recently added a few updates to the first post of this thread (under The uC - Software). Read the tutorials and use 8MHz internal clock.
                                When you get everything running, test your door switch again with a simple Arduino sketch.
                                W M 2 Replies Last reply
                                • m26872M m26872
                                  W
                                  W
                                  wergeld
                                  @m26872
                                  UPDATE 2: There have been reported issues with MySensors 2.x freezing on SlimNodes running at 1MHz, which I've confirmed. Recommended solution when using MyS 2.x, is to use 8MHz (internal) instead.
                                  This I can confirm - running at 1 MHz introduced some real oddities with latest MySensors library. Not sure what changed but my nodes definitely freaked out. Will try switching to 8 MHz - hopefully before Irma whacks us here.
                                  kotzerK 1 Reply Last reply
                                  • W wergeld
                                    @m26872
                                    kotzerK
                                    kotzerK
                                    kotzer
                                    wrote on last edited by kotzer
                                    #452
                                    @wergeld
                                    Same confirmation from my side; 1mhz boot loader doesn't work; dht22 with step up connected does always give NAN. Switching to 8mhz boot loader did the trick.
                                    //@2.2.0-beta
                                    • kotzerK kotzer
                                      @wergeld
                                      //@2.2.0-beta
                                      m26872M
                                      m26872M
                                      m26872
                                      @kotzer Thanks for sharing. But (AFAIK) the Arduino DHT22 library has never worked at all at 1MHz. And since dht22 doesn't support <3V there's no need for 1MHz anyway.
                                      • m26872M m26872
                                        kotzerK
                                        kotzerK
                                        kotzer
                                        #454
                                        @m26872
                                        Maybe offtopic, sry, but:
                                        I have Step up at dht22, so it has 3,3v to operate..
                                        But I am in wrong topic, it should be your first 2aa sensor ( https://forum.mysensors.org/topic/486/my-2aa-battery-sensor )
                                        This is what I built, and with 1mhz it doesn't work (tried with step up 3,3v and without) this wasted me many hours, because I wanted to save energy as much possible ;) with 8mhz its operating well.
                                        Greets from Germany
                                        • kotzerK kotzer
                                          @m26872
                                          Greets from Germany
                                          m26872M
                                          m26872M
                                          m26872
                                          @kotzer Infact I'm actually making a few of my first model too rigth now. I had components left over and despite everyones criticism against the dht22, I find it working very well as long as you deal with the failed readings in the sketch. And, the battery life time was pretty good too. Greets. :+1:
