  3. My Slim 2AA Battery Node
498 Posts 71 Posters 599.7k Views 69 Watching
  • O
    O
    Oliviakrk
    Hi
    Did anyone make DHT 22 slim node with MySensors 2.0? I created one Node from modified MySenors 2 example...But I get a feeling that it is freezing sometimes (but then again comes back to life).
    mfalkviddM sundberg84S 2 Replies Last reply
    • O Oliviakrk
      Hi
      @Oliviakrk the dht22 needs at least 3.3V to function properly. See the datasheet.
      • O Oliviakrk
        Hi
        sundberg84S
        sundberg84S
        #443
        @Oliviakrk - I did a test (which works pretty ok) with a DC/DC step up booster attached to D3 -> Vin. This way I could turn the booster on/off with HIGH/LOW from the sketch. This provided 3.3v to my sensors just fine and has been working for a while now. I dont know what will happen when the voltage drops though.
        O 1 Reply Last reply
        • sundberg84S sundberg84
          O
          O
          Oliviakrk
          @sundberg84 Thanks. Will try.
            masfak97
            Thank you for all the hard work put into this project. I have built a few door sensor nodes and have some issues. At first I had pull-ups connected as shown in previous pictures but at a logic 1, when there should have been 3.3V there was only roughly half, 1.7V. I am no expert but I take it there has to be a current leak through the D3 pin for this to happen. I have this on all my nodes. I have tried different code but still the same. When I remove the external pull-up the node works properly but instead the batteries run out in a week or so. Have I made a mistake soldering these and maybe shorted something? I have looked at them closely but can't see anything wrong.
            Does anyone else have this problem? Any tips?
              Did you actually check if there is continuity between the pins you said? Do you have a photo of your nodes?
                masfak97
                wrote on last edited by masfak97
                #447
                If I disconnect the battery, there is continuity between D3 and VCC with a resistance of around 20 kOhm. So when the door sensor is shut (no resistance), I connect GND through 20 kOhm to VCC. The current should be 0,165 mA. Too high by reading previous posts but still much less than what I get if I measure. Then I get roughly 18 mA! (Far from a Fluke though but has proven reliable before). Am I misunderstanding things?
                I have tried different nodes and sketches with pull-ups both enabled and disabled but I doesn't seem to matter. I have tried different radio modules but still the same, unless I use the bigger! antenna-version. Then the current goes up to 24-25 mA.
                I have done/am doing something really wrong although they seem to work just fine. Tomorrow I will try more radio modules to see if I can find any difference.
                3_1504391407612_IMG_4745.jpeg 2_1504391407612_IMG_4748.jpeg 1_1504391407612_IMG_4747.jpeg 0_1504391407611_IMG_4746.jpeg
                m26872M 1 Reply Last reply
                • M masfak97
                  m26872M
                  m26872M
                  m26872
                  @masfak97 It's not clear to me whether you've tried to run it a as pure Arduino, without radio module and without MySensors library in your sketch? (I see that you haven't the serial/FTDI pins soldered - do you use ICSP, pogo-pins or whatever to upload and debug?)
                    masfak97
                    I have thought about running it as a pure arduino and to use the debug function, but can't quite get the FTDI to work. I have used this before to upload code to arduino pros. I have a previous node that has all the pins soldered but simply won't be recognized with the USB FTDI. I have also tried switching USB-FTDI but still no luck. Is the FTDI supposed to work if all the pins are there?
                    I have also bought a USBtinyISP but haven't read up on how to use it.
                    Currently I install a first boot loader with Nick Gammons sketch running on a UNO connected to a breadboard and the 328. After that has been installed, I install the 8 MHz boot loader by Gert Sanders (thank you of it) and finally upload the code using "Upload using programmer". I currently have no way of reading the serial debug from the node.
                    I checked the node without the nrf but still power-hungry in the mA.
                    • m26872M
                      m26872M
                      m26872
                      I think you should focus on getting these basic Arduino functions working so you're in control of what's going on. Note that I recently added a few updates to the first post of this thread (under The uC - Software). Read the tutorials and use 8MHz internal clock.
                      When you get everything running, test your door switch again with a simple Arduino sketch.
                      W M 2 Replies Last reply
                      • m26872M m26872
                        W
                        W
                        wergeld
                        @m26872
                        UPDATE 2: There have been reported issues with MySensors 2.x freezing on SlimNodes running at 1MHz, which I've confirmed. Recommended solution when using MyS 2.x, is to use 8MHz (internal) instead.
                        This I can confirm - running at 1 MHz introduced some real oddities with latest MySensors library. Not sure what changed but my nodes definitely freaked out. Will try switching to 8 MHz - hopefully before Irma whacks us here.
                        kotzerK 1 Reply Last reply
                        • W wergeld
                          @m26872
                          kotzerK
                          kotzerK
                          kotzer
                          wrote on last edited by kotzer
                          #452
                          @wergeld
                          Same confirmation from my side; 1mhz boot loader doesn't work; dht22 with step up connected does always give NAN. Switching to 8mhz boot loader did the trick.
                          //@2.2.0-beta
                          • kotzerK kotzer
                            @wergeld
                            //@2.2.0-beta
                            m26872M
                            m26872M
                            m26872
                            @kotzer Thanks for sharing. But (AFAIK) the Arduino DHT22 library has never worked at all at 1MHz. And since dht22 doesn't support <3V there's no need for 1MHz anyway.
                            • m26872M m26872
                              kotzerK
                              kotzerK
                              kotzer
                              #454
                              @m26872
                              Maybe offtopic, sry, but:
                              I have Step up at dht22, so it has 3,3v to operate..
                              But I am in wrong topic, it should be your first 2aa sensor ( https://forum.mysensors.org/topic/486/my-2aa-battery-sensor )
                              This is what I built, and with 1mhz it doesn't work (tried with step up 3,3v and without) this wasted me many hours, because I wanted to save energy as much possible ;) with 8mhz its operating well.
                              Greets from Germany
                              • kotzerK kotzer
                                @m26872
                                Greets from Germany
                                m26872M
                                m26872M
                                m26872
                                @kotzer Infact I'm actually making a few of my first model too rigth now. I had components left over and despite everyones criticism against the dht22, I find it working very well as long as you deal with the failed readings in the sketch. And, the battery life time was pretty good too. Greets. :+1:
                                • m26872M m26872
                                  masfak97
                                  @m26872 I finally got to try your suggestions and loaded the Blink-sketch to my nodes. The power consumtion is then cut to ~4mA. Scrolling back through the forum, I copied the sketch from a user with low power consumption and - Finally - I get an idle comsumtion of 1,9 uA! Connecting the FTDI I can also debug and check for proper function.
                                  I do have another problem I haven't managed to solve; With an UNO and a breadboard I can easily load the bootloader using Nick Gammons sketch and then the sketch with the UNO as ISP. Using the FTDI I can read the serial stream without any problem but I can't seem to load any bootloader or sketches! I keep getting a sync error. I understand the principle of DTR going low and that the capacitor between DTR and reset and the resistor between +5 and reset will make the LOW into a low-pulse and then back to high. With the FTDI I can program a Pro Mini without any problems but it fails constantly with the nodes.
                                  I have no scope so I can't visualize the signal but with the meter I can see that the voltage on the reset is ~3,3v, the resistance between +5 and reset is 10 kOhm and the capacitor reads 83 uF although branded 100uF.
                                  I use Gert Sanders versions of Optiboot at 8Mhz and the one with 38400 NO LED (Thank you for that). I have tried several FTDIs and nodes, checked all connetions, tried to control the reset manually using a breadboard but can't get it to work. I have tried the FTDI at 5v instead (no nRF connected) and tried different boards and speeds. I have tried 1 MHz, 16Mhz.
                                  Is it possible that 83 uF is too small? Any other tips? When building more nodes it would be great to be able to program them without dismantling.
                                  • M masfak97
                                    m26872M
                                    m26872M
                                    m26872
                                    @masfak97 Have you selected the right board in Arduino IDE? (Installed MiniCore in Board Manager?) Have you tried to use baud 9600 (with corresponding bootloader of course) ?
                                    I doubt that 83uF is too small.
                                    • m26872M m26872
                                      masfak97
                                      @m26872 Thank you for your suggestions. I have now tried them (and many more) but still can't it to work. It's really not a big problem since I can program them using an Uno as ISP instead but it's really annoying that I can't get it to work.
                                      I have checked my chips, they are all at mega328P-PU and I have tried many of them with the same result. I have soldered many nodes, thinking that I didn't make the solder connect through the holes but without any luck. I have tried different sockets to make the connections better and I have traced the entire node without finding any broken connections.
                                      To get the sketch loaded I use Nick Gammons board_programmer with an Uno and use the LilyPad boot loader which enables the internal 8 MHz (Using pin 9 as clock instead of an external crystal). After that I program the Uno with ArduinoISP, set the programmer to Arduino as ISP and upload the sketch with "Burn with programmer" command.
                                      I have switched USB-cable, USB outlet on the mac, breadboards, dupont cables, capacitors (different ceramic but all show too little capacitance), Atmegas and FTDI programmers. I have tried all combinations with 3.3 and 5 v without any luck. Programming Arduino Pros with the FTDI works fine.
                                      I have tried the Mincore and Gert Sanders OptiBoot. I have tried to manually reset the chip connecting the reset pin to ground briefly when programming. I have tried lowering the baud rate to 9600. I have tried to load the Uno bootloader together with a 16 MHz crystal and 2 x 22pf capacitors and then the FTDI. I have tried larger electrolytic capacitors.
                                      Last week, when mimicking the slim node on a breadboard, I managed to get the FTDI to work a few times but can't really say exactly what I did. Now I can't get it to work anymore.
                                      All in all I have spent many hours trying to figure this out but without any luck. My nodes look just like the ones I see in your pictures.
                                      Could it be that the internal 8 Mhz is too unstable to work?
                                      Capacitors being too small? I've seen some reporting that they succeeded with larger...
                                      Bad connection somewhere > momentary voltage drop?
                                      Cheap FTDIs?
                                      Mac USB-power maxing out?
                                      Bad atmegas?
                                      Please help me solve this annoying problem.
                                      • M masfak97
                                        Cheap FTDIs?
                                        Bad atmegas?
                                        m26872M
                                        m26872M
                                        m26872
                                        @masfak97 Wow. You work hard. Of course we must help you. I'm not familiar with your programming method. So that would be my quick wild first guess. I can't read that you've verified the fuse settings? Have tried different startup times e.g?
                                        Do I understand correctly if you're able to send and recieve commands to the Atmega with your FTDI after it is programmed ?
                                          Mikepara
                                          Hi. I have a problem with my slim node with the sketch "temperature"
                                          with the slim pcb node and a DS18B20 in domoticz it does well the node presentation but neither the S_TEMP child arrives nor does it get any temperature afterwards of course.
                                          but if I mount the same sketch in an arduino nano and with power to 5v it works perfectly.
                                          please help
