  3. RFM69HW 433 communication problem
34 Posts 5 Posters 8.6k Views 4 Watching
    I'm using the mock sensors sketch. The node just doesn't get any reply. I'll try with the 17cm wire antenna.
    sundberg84S
    sundberg84S
    @gohan - I have made a second node to test the DIY antenna.
    It works good (on my bench, have not tested range) as you can see in my logs.
    • GW code
    • Node code
    Im running MySensors dev (not the latest... but updated a couple of weeks ago) with a Serial RFM69 GW (both node and GW are build on EasyPCB.
    I tried both 3.3v regulated and 5v with a voltage regulator.
    Here are some images if my build... I hope they can give you some ideas.
    (REG are shorted due to I used 3.3 regulated voltage as well - this does not affect anything using 5v).
    I would suggest you do a continuity test from all the pins to the right pins on the pro mini, just to make sure they are connected. It is not that easy to solder the SMD pads on the RFM radio as the pins on the Nrf24l01+. You cant tell if they are ok since they are not visible all the way because of the module. First thing that happened was that the radio would not initialise, and I had to "re-flow", heat the pads up again so everything connected. It was not visible and impossible to see the bad connection.
    I would also measure voltage over all important parts. Also make sure you do a continuity test from the top of your antenna to the ANT on the RFM module.
      I did continuity check on all pins and antenna, everything seems fine. It seems there is something on the nodes that can't receive or the gateway can't send
        sundberg84S
        sundberg84S
        @gohan - ok... strange!
        As I mentioned in PM, I use the W and not HW version... i dont know if thats the case, but let me order some HW modules and I will check!
        Could you upload a picture of your hardware? Maybe I can spot something?
        • sundberg84S sundberg84
          sundberg84S
          sundberg84S
            • sundberg84S
              sundberg84S
              Do you get the same log on all boards? They are initialised but then...? No reply or NACK?
              I would use the board with the least connections for GW and power the GW with a rock solid 3.3v.
              With the GW i would use the SMA connector with a bought antenna to be sure...
                Yes, they all get no reply.
                I don't have the SMA nor the right antenna at the moment.
                I am also using one of those MB102 for 3.3v supply, but nothing changes. I'll try with a beefier voltage regulator
                  sundberg84S
                  sundberg84S
                  @gohan said in RFM69HW 433 communication problem:
                  MB102
                  Should be enough... a really though one this!
                  My bet would be the antennas though... and the GW antenna is offcource the most important. I would focus on that (without I can promise that is the problem).
                    I tried the coiled wire like the one you are using, it didn't change at all. I am running out of options unless there is a problem with the rfm modules.
                    JokgiJ 1 Reply Last reply
                      I got the new batch of 4 new rfm69h but I am still getting no communication between gw and node, now I can't even get some messages received from gw. I have updates to latest development library and used pretty much all defaults values besides setting the right frequency. Unless I'm doing something really wrong, there must be something wrong in the basics. I'll have to try some more combinations with the antennas, but I am really starting to get discouraged since the nrf24 worked fine since the beginning.
                        sundberg84S
                        sundberg84S
                        @gohan - If you have 3.3v on the radio and the arduino, are sure about the software/sketch then I would also suggest trying different antennas. What are you using today? I would buy a SMA connector and a good antenna. Even though I have the DIY antenna on the test-node above, I still have a factory antenna + SMA connector on the gw.
                        • CarywinC
                          CarywinC
                          Carywin
                          I'm not very familiar with that hardware, but from a cursory glance it looks like you don't have the interrupt pin connected? Unlike the NRF modules, the RFM69s are interrupt-driven and need DIO0 connected to pin 2
                            I am waiting for the antennas and sma connectors too. Irq pin i think it is connected as it should be in the in the pcb.
                            • CarywinC Carywin
                              sundberg84S
                              sundberg84S
                              @Carywin - its EasyPCB RFM edition and D2 is connected to DIO0 pin as described in the radio tutorial so unless he is using a strange RFM module with the interrupt pin on some different place that should work.
                              • CarywinC
                                CarywinC
                                Carywin
                                wrote on last edited by Carywin
                                Right, I'm sure that node is fine, I mainly just zoomed in and looked at this one:
                                I use this same small piggyback board for many nodes and it works great with those 21mm coil antennas.
                                However, I just noticed the #define for TX power. I think the H and HW versions have a minimum of 13dB or something. Have you tried without?
                                gohanG 1 Reply Last reply
                                  JokgiJ
                                  JokgiJ
                                  Jokgi
                                  @gohan a straight pig tail antenna of about 30mm should work fine (but will not be perfectly tuned).
                                  • CarywinC Carywin
                                    @Carywin I was using the nodes on easypcb also for the new ones. What do you suggest I set the TX power?
                                      sundberg84S
                                      sundberg84S
                                      @gohan - i never messed with TX power... have a look and try my sketches above. They work for me.
                                      • CarywinC
                                        CarywinC
                                        Carywin
                                        #23
                                        I would suggest comment out the TX power setting and let the ATC control it. If it still doesn't work, try:
                                        #define MY_RFM69_ATC_MODE_DISABLED
                                        #define MY_RFM69_TX_POWER_DBM 20
                                        Edit:
                                        Maybe also try
                                        #define MY_DEBUG_VERBOSE_RFM69
                                        and see if that tells you anything more.
                                          If my headache gets better, I'll do some more tests tonight
                                          12.5k
