  3. RFM69HW 433 communication problem
34 Posts 5 Posters 8.6k Views 4 Watching
  • sundberg84S
    sundberg84S
    Do you get the same log on all boards? They are initialised but then...? No reply or NACK?
    I would use the board with the least connections for GW and power the GW with a rock solid 3.3v.
    With the GW i would use the SMA connector with a bought antenna to be sure...
      Yes, they all get no reply.
      I don't have the SMA nor the right antenna at the moment.
      I am also using one of those MB102 for 3.3v supply, but nothing changes. I'll try with a beefier voltage regulator
        sundberg84S
        sundberg84S
        @gohan said in RFM69HW 433 communication problem:
        MB102
        Should be enough... a really though one this!
        My bet would be the antennas though... and the GW antenna is offcource the most important. I would focus on that (without I can promise that is the problem).
          I tried the coiled wire like the one you are using, it didn't change at all. I am running out of options unless there is a problem with the rfm modules.
          JokgiJ 1 Reply Last reply
            I got the new batch of 4 new rfm69h but I am still getting no communication between gw and node, now I can't even get some messages received from gw. I have updates to latest development library and used pretty much all defaults values besides setting the right frequency. Unless I'm doing something really wrong, there must be something wrong in the basics. I'll have to try some more combinations with the antennas, but I am really starting to get discouraged since the nrf24 worked fine since the beginning.
              sundberg84S
              sundberg84S
              @gohan - If you have 3.3v on the radio and the arduino, are sure about the software/sketch then I would also suggest trying different antennas. What are you using today? I would buy a SMA connector and a good antenna. Even though I have the DIY antenna on the test-node above, I still have a factory antenna + SMA connector on the gw.
              • CarywinC
                CarywinC
                Carywin
                I'm not very familiar with that hardware, but from a cursory glance it looks like you don't have the interrupt pin connected? Unlike the NRF modules, the RFM69s are interrupt-driven and need DIO0 connected to pin 2
                  I am waiting for the antennas and sma connectors too. Irq pin i think it is connected as it should be in the in the pcb.
                  • CarywinC Carywin
                    sundberg84S
                    sundberg84S
                    @Carywin - its EasyPCB RFM edition and D2 is connected to DIO0 pin as described in the radio tutorial so unless he is using a strange RFM module with the interrupt pin on some different place that should work.
                    • CarywinC
                      CarywinC
                      Carywin
                      wrote on last edited by Carywin
                      Right, I'm sure that node is fine, I mainly just zoomed in and looked at this one:
                      I use this same small piggyback board for many nodes and it works great with those 21mm coil antennas.
                      However, I just noticed the #define for TX power. I think the H and HW versions have a minimum of 13dB or something. Have you tried without?
                      gohanG 1 Reply Last reply
                        JokgiJ
                        JokgiJ
                        Jokgi
                        @gohan a straight pig tail antenna of about 30mm should work fine (but will not be perfectly tuned).
                        • CarywinC Carywin
                          @Carywin I was using the nodes on easypcb also for the new ones. What do you suggest I set the TX power?
                            sundberg84S
                            sundberg84S
                            @gohan - i never messed with TX power... have a look and try my sketches above. They work for me.
                            • CarywinC
                              CarywinC
                              Carywin
                              #23
                              I would suggest comment out the TX power setting and let the ATC control it. If it still doesn't work, try:
                              #define MY_RFM69_ATC_MODE_DISABLED
                              #define MY_RFM69_TX_POWER_DBM 20
                              Edit:
                              Maybe also try
                              #define MY_DEBUG_VERBOSE_RFM69
                              and see if that tells you anything more.
                                If my headache gets better, I'll do some more tests tonight
                                  JokgiJ
                                  JokgiJ
                                  Jokgi
                                  @gohan If you are using AutoAcks and you have a combination of True Nordic based Modules and nRF24L01P clones you may have a issue. Is there a way to not use acknowledgements and see if you can communicate properly between the modules?
                                    I'm using rfm69 not nrf24l01
                                      wrote on last edited by gohan
                                      #27
                                      I think i solved the mistery... the alixpress seller sent me RFM69W modules instead of HW... I just noticed the chips are the same and in fact they work if I compile the node without the #define MY_IS_RFM69HW. I don't even know if I can get a partial refund since quite some time has passed
                                      PS :rage: :rage: :zap: :zap:
                                        sundberg84S
                                        sundberg84S
                                        @gohan - so you got communication now that is working? That is great news.
                                          Yeah... Not a good news that I got "scammed"
                                          12.5k
