  3. Can other sensors send data to my mysensors?
11 Posts 7 Posters 2.9k Views 7 Watching
    A Former User
    I am starting with MySensors and I have a question. With other networks you have an (home-)id. But with MySensor you have only an unique ID from 0 to ... If there is another MySensor in the neighborhood will it also send data to my newtork?
    Regards
    Frank
    • rejoe2R
      rejoe2R
      rejoe2
      As soon as there is no security feature enabled, the basic answer is yes, your gateway will be able to see neighbour's nodes and vice versa, all nodes and the gw. are just doing kind of broadcasting.
      As long as the nodes are not "included" (and registered by the controller), nothing will happen.
      To avoid problems, you may enable security features or use a different channel for transmission (nRF).
      • tbowmoT
        tbowmoT
        tbowmo
        in addition to @rejoe2's answer, you can also change the base address of your sensor network, by setting MY_RF24_BASE_RADIO_ID in your code
        https://github.com/mysensors/MySensors/blob/067519c500d4e1cb813c486fd34000bd8c83c337/MyConfig.h#L339
        This needs to be set to the same value on ALL units in you mysensors network
        • tbowmoT tbowmo
          ahmedadelhosniA
          ahmedadelhosniA
          ahmedadelhosni
          @tbowmo said in Can other sensors send data to my mysensors?:
          That's really cool .. When was this implemented ?
          I asked the same question 1.5 years ago before I got busy and stopped following up with MySensors community. I am glad I am back :D
          https://forum.mysensors.org/topic/3327/mixing-sensors-in-two-houses
          mfalkviddM YveauxY 2 Replies Last reply
            @ahmedadelhosni since MY_RF24_BASE_RADIO_ID is mentioned in that thread we can probably safely assume that it was implemented before that time at least.
              ahmedadelhosniA
              ahmedadelhosniA
              ahmedadelhosni
              @mfalkvidd yeah right. I didn't read the whole replies again.
              I guess this changing the base_id is a good solution as it has large scale. Changing the Fre may be needed if there was radio interference between the two nodes.
              Thanks all.
                @ahmedadelhosni It's been in there for ages: https://github.com/mysensors/MySensors/blob/4783cac945df33a84ef20572c87557087f453ae8/libraries/MySensors/MyConfig.h#L11
                (this is from 1.4.1, over 3 years ago. Can't go back any further on GitHub ;-) )
                • dbemowskD
                  dbemowskD
                  Could you not also change what channel your radios ran on, at least for nRF24 radios, if a neighboring house ran on a certain channel? Wouldn't that give some separation between systems?
                  • dbemowskD dbemowsk
                    @dbemowsk yes. That solution is also mentioned in the linked thread :)
                    dbemowskD 1 Reply Last reply
                      dbemowskD
                      dbemowskD
                      @mfalkvidd Sorry, missed that.
                      • YveauxY Yveaux
                        ahmedadelhosniA
                        ahmedadelhosniA
                        ahmedadelhosni
                        @Yveaux Oh right ::joy:
