  2. Announcements
  3. 💬 Building a WiFi Gateway using ESP8266
109 Posts 52 Posters 73.8k Views 51 Watching
  • Jonathan CaesJ
    Jonathan CaesJ
    Jonathan Caes
    Is it possible to use this setup without the nrf24l01 atached, so that i can use the esp8266 just as a sensor (not as a gateway)?
    • Jonathan CaesJ Jonathan Caes
      #39
      @Jonathan-Caes yes. Don't define MY_RADIO_NRF24 and you're good to go. It will still be a gateway, but a gateway with local sensors and no radio.
      • J
        J
        joseyapor
        Hi how many Gateways Can i have on a network?
        • J joseyapor
          #41
          @joseyapor On one MySensors network there can only be one MySensors gateway. But on one IP network, there can be many MySensors gateways. Exactly how many depends on geography and chosen transports but at the very least a few hundred. Thousands if you really need and plan accordingly.
          I 1 Reply Last reply
          • A
            alexalex
            Help! After connecting to the WIFI, I'm getting disconnected. Here's a log : https://goo.gl/fyr7ku
            Any help in figuring this out would be appreaciated!
            • A alexalex
              #43
              Welcome to the MySensors community @alexalex
              The log is missing the first lines, but it looks like the microcontroller is unable to communicate with the radio. Which radio are you using?
              See https://ci.mysensors.org/job/Verifiers/job/MySensors/branch/development/Doxygen_HTML/group__MyTransportgrp.html#details for more details about the log messages and https://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help/ for the most common problems and how to fix them.
              • Bogus ExceptionB
                Bogus ExceptionB
                Bogus Exception
                Is there a complete wiring table, diagram, or schematic? I have a working MyController/MySensors network on nRF24s, but I am adding WiFi with a ESP-201 module (white one with pins broken out for 2.54 pitch; see: http://smarpl.com/sites/default/files/images/ESP8266-ESP-201-pin-reference-v01.png)... TIA!
                "If you drop it and it breaks, it was good." ~ Mr. Lehr, my Electronics Vo-Tech teacher, on testing vacuum tubes...
                -Arduinos (UNO, Nano, Pro-Mini, Mega, ...)
                -ATTiny, ATMega, STM32
                -Geek Channel: https://www.youtube.com/TheSalesEngineer
                • Bogus ExceptionB Bogus Exception
                  #45
                  @Bogus-Exception did you see the instructions linked in the first post in this thread? You probably want the part that says "connect the radio".
                  • pihomeP
                    pihomeP
                    pihome
                    if i reboot my wifi router mysensors wifi gateway wouldn't try to connect again, is this only with me or its common issue with wifi gateway?
                    PiHome - Smart Heating Control
                    • pihomeP pihome
                      @pihome said in 💬 Building a WiFi Gateway using ESP8266:
                      This question was transferred to a new thread by @pihome. Please don't answer here, to avoid double work and confusion.
                      • folkestorpF
                        folkestorpF
                        folkestorp
                        Reporting batterypercent to Domoticz not working.
                        I have built a ESP8266 Gateway and I connecting a BME280 sensor. It report everything right with a serial gateway but with the new wifi gateway it not reciving the battery percent. I look in the serial monitor at the gateway and where is no battery data.
                        • O
                          O
                          Oleg Greengo
                          Colleagues, tell me.
                          can I make it so that hosts register on the gateway only if I press a button on the gateway?
                          Perhaps there is an example?
                          • T
                            toozinger
                            I'm receiving the following errors:
                            warning: espcomm_sync failed
                            error: espcomm_open failed
                            error: espcomm_upload_mem failed
                            I have attempted to fix this problem through:
                            *Making sure I"m using the "NodeMCU" as my board in the Arduino IDE
                            *Trying different upload rates
                            *Pressing and holding the flash button while and/or right before upload
                            Hardware:
                            PC, windows 10
                            NodeMCU from eBay link above.
                            Any help? It appears others have had this problem as well, but I haven't (yet) been able to fix my issues through their threads.
                            Toozinger
                            • blackYB
                              blackYB
                              blackY
                              ...and how to connect Arduino & MySensors & ESP8266-01 (like this one: https://www.aliexpress.com/item/2015-New-version-1PCS-ESP8266-serial-WIFI-model-ESP-01-Authenticity-Guaranteed-Internet-of-things/32574207918.html?spm=a2g0s.9042311.0.0.ytiQMF ) with ESP 01 Serial Adapter - like this one (https://www.aliexpress.com/item/ESP8266-Serial-WiFi-Wireless-ESP-01-Adapter-Module-3-3V-5V-Compatible-For-Arduino/32740695540.html?spm=a2g0s.9042311.0.0.lSVdmZ), when i should use Tx and Rx signals only?
                              • blackYB blackY
                                Welcome to the Mensors community @blackY !
                                If you're new to building MySensor nodes, I recommend that you stick with the recommended build examples.
                                It is probably possible to use the modules you link to, but it will require knowledge far beyond building the existing examples.
                                • blackYB
                                  blackYB
                                  blackY
                                  yes, I know...but if you are still staying by given examples, you don't develop yourself ;)
                                  • blackYB blackY
                                    zboblamontZ
                                    zboblamontZ
                                    zboblamont
                                    @blackY I'll just leave this here for a relative reference to that... link text
                                    blackYB 1 Reply Last reply
                                    • zboblamontZ zboblamont
                                      blackYB
                                      blackYB
                                      blackY
                                      @zboblamont ROTFL...
                                      I'm kidding. This does not solve the problem. Isn't nice or exploring too.
                                      • RajendraR
                                        RajendraR
                                        Rajendra
                                        I just want to bypass inbuilt wifi connection method in GatewayESP8266 and use my own code of SmartConfig to create WiFi connection. I'm not able to achieve this. is there any way to do this?
                                        Ive tried changing library (MyGatewayTransportEthernet) code, but it throws TSM exception. I've tested SmartConfig separately and it works fine with my Android App.
                                        Rajendra
                                        • R
                                          R
                                          RWoerz
                                          Sorry but can someone explain the differance between "Server" and "Client" modes. I got my ESP8266 working with my Vera but then I install a RPi 3 I'm using for MQTT. Do I need 2 gateways, one for the Vera and another for MQTT? Even though I'm moving away from the Vera it's still usfull. Thanks for the help.
