  3. WiFi Gateway (ESP8266) - reconnect to wifi router
19 Posts 4 Posters 10.1k Views 6 Watching
  • pihomeP
    pihomeP
    pihome
    wrote on last edited by pihome
    i have this problem: if i reboot my wifi router mysensors wifi gateway wouldn't try to connect again, is this only with me or its common issue with wifi gateway?
    PiHome - Smart Heating Control
    M 1 Reply Last reply
    • pihomeP pihome
      manutremo
      @pihome Not a common issue with wifi gateway I guess, since mine reconnects to the router with no issue. You referring to reconnect to the router and not to the controller, are you?
      I'm using a Wemos D1 R2 plus as the gateway but this shouldn't make a difference.
      • pihomeP
        pihomeP
        pihome
        @manutremo thank you reply. Yes i was referring to wifi gateway connection to wifi router.
        I.e if I rebooted my wifi router my wifi gateway do not re-establish connection to wifi router until unless i reset wifi gateway
          manutremo
          What do you see on your gw log when the connection to the router is lost?
          • pihomeP
            pihomeP
            pihome
            This is getting very odd, now if I connect my gateway to computer I don’t see anything on serial port, but i can talk to controler and get all nodes data which confirm it’s working.
              manutremo
              That's odd - I assume you've checked port, bitrate, etc...
              If your gw is communicating via IP (I guess that's the case since you mention a wifi gw), you can also "spy" the communication between the gw and the controller by telnetting to the gw IP and port 5003 (assuming default hasn't been changed).
              • pihomeP
                pihomeP
                pihome
                here is log when gateway is connected to wifi router, and then i powered off wifi router and then in few seconds powered on again, all other devicess connected to wifi router as expected apart from mysensors esp gateway. no special code in my gateway controller sketch.
                pm open,type:2 0
                0;255;3;0;9;TSF:MSG:READ,30-30-0,s=0,c=1,t=0,pt=7,l=5,sg=0:35.0
                0;255;3;0;9;Client 0 connected
                0;255;3;0;9;TSF:MSG:READ,30-30-0,s=0,c=1,t=0,pt=7,l=5,sg=0:35.8
                0;255;3;0;9;TSF:MSG:READ,21-21-0,s=0,c=1,t=0,pt=7,l=5,sg=0:21.6
                bcn_timout,ap_probe_send_start
                ap_probe_send over, rest wifi status to disassoc
                state: 5 -> 0 (1)
                rm 0
                pm close 7
                f r0, 0;255;3;0;9;Client 0 disconnected
                scandone
                no mynet-915C found, reconnect after 1s
                reconnect
                f 0, scandone
                reconnect
                f -180, scandone
                state: 0 -> 2 (b0)
                state: 2 -> 3 (0)
                state: 3 -> 5 (10)
                add 0
                aid 1
                cnt
                chg_B1:-140
                connected with mynet-915C, channel 7
                dhcp client start...
                chg_B1:-100
                ip:192.168.99.3,mask:255.255.255.0,gw:192.168.99.1
                chg_B1:-60
                chg_B1:-20
                0;255;3;0;9;TSF:MSG:READ,21-21-0,s=0,c=1,t=0,pt=7,l=5,sg=0:21.9
                pm open,type:2 0
                0;255;3;0;9;TSF:MSG:READ,25-25-0,s=0,c=1,t=0,pt=7,l=5,sg=0:20.8```
                  manutremo
                  I'm not sure i'm following you... from the low the gw seems to be reconnecting, it gets ip 192.168.99.3 after the router restarts and starts to receive messages from what seems to be a node.
                  • pihomeP
                    pihomeP
                    pihome
                    it looks from log as it is connected to wifi but i can not even ping mysensors gateway, until i press reset button on esp.
                    yes you are right gateway receive all message from notes.
                      Did you try latest mysensors 2.2 development?
                      • ThomasDrT
                        ThomasDrT
                        ThomasDr
                        do you use only the Gateway Code or is there anybody else in your code?
                        If you do anybody else you need delays in the code.
                        I think the Arduino "delay()" not the "wait()".
                        Wait do Mysensors things.
                        Delay do WIFI things.
                        regards
                        ThomasDr
                          I think you could check every minute or so if wifi connection is established and if not call the connection routine (that should be basic esp8266 stuff)
                          • pihomeP
                            pihomeP
                            pihome
                            its basic gateway code nothing else, just copy and paste from mysensors. i added that nrf
                             * Version 1.0 - Henrik EKblad
                             * Contribution by Ivo Pullens (ESP8266 support)
                             * The EthernetGateway sends data received from sensors to the WiFi link.
                             * VERA CONFIGURATION:
                             * Enter "ip-number:port" in the ip-field of the Arduino GW device. This will temporarily override any serial configuration for the Vera plugin.
                             * E.g. If you want to use the defualt values in this sketch enter: 192.168.178.66:5003
                             * LED purposes:
                             * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs in your sketch, only the LEDs that is defined is used.
                             * nRF24L01+  ESP8266
                             * VCC        VCC
                             * CE         GPIO4
                             * CSN/CS     GPIO15
                             * SCK        GPIO14
                             * MISO       GPIO12
                             * MOSI       GPIO13
                             * GND        GND
                              * Inclusion mode button:
                            #define MY_BAUD_RATE 9600
                            // i added this later to see this may be the cause as i have channel number etc in other sensors.
                            //#define MY_DEBUG_VERBOSE_RF24
                            // RF channel for the sensor net, 0-127
                            #define RF24_CHANNEL     125
                            //RF24_250KBPS for 250kbs, RF24_1MBPS for 1Mbps, or RF24_2MBPS for 2Mbps
                            #define RF24_DATARATE 	   RF24_250KBPS
                            #define MY_GATEWAY_ESP8266
                            #define MY_ESP8266_SSID "wifi"
                            #define MY_ESP8266_PASSWORD "wifi-pass"
                            // Enable UDP communication
                            //#define MY_USE_UDP
                            #define MY_ESP8266_HOSTNAME "PiHome_Gateway"
                            //#define MY_IP_ADDRESS 192,168,99,4
                            //#define MY_IP_GATEWAY_ADDRESS 192,168,99,1
                            #define MY_PORT 5003
                            // Enable inclusion mode
                            // #define MY_INCLUSION_BUTTON_FEATURE
                            // Set blinking period
                            // #define MY_DEFAULT_LED_BLINK_PERIOD 300
                            // Flash leds on rx/tx/err
                            // Led pins used if blinking feature is enabled above
                            #if defined(MY_USE_UDP)
                            #include <WiFiUdp.h>
                            #include <ESP8266WiFi.h>
                            ThomasDrT 1 Reply Last reply
                            • pihomeP pihome
                               * LED purposes:
                               * nRF24L01+  ESP8266
                               * VCC        VCC
                               * CE         GPIO4
                               * CSN/CS     GPIO15
                               * SCK        GPIO14
                               * MISO       GPIO12
                               * MOSI       GPIO13
                               * GND        GND
                              ThomasDrT
                              ThomasDrT
                              ThomasDr
                              @pihome Hello,
                              and what type of ESP8266 you have?
                              Can you try a other one?
                              I have some NodeMCU V0.9 with TCP and UDP in client mode with AVM Router and Repeater.
                              Without problems.
                              regards
                              ThomasD
                              • pihomeP
                                pihomeP
                                pihome
                                i dont have second esp8266 at this moment, i have order one
                                here is what i have and i m using it for gateway
                                https://www.aliexpress.com/item/V3-Wireless-module-NodeMcu-4M-bytes-Lua-WIFI-Internet-of-Things-development-board-based-ESP8266-for/32469441553.html?spm=a2g0s.9042311.0.0.FyzreG
                                @ThomasDr said in WiFi Gateway (ESP8266) - reconnect to wifi router:
                                ESP8266
                                • ThomasDrT
                                  ThomasDrT
                                  ThomasDr
                                  wrote on last edited by ThomasDr
                                  The NodeMCU looks like my.
                                  and your ESP8266 Arduino version?
                                  maybe there is a new version.
                                  What Router or Access Point do you use?
                                  regards
                                  ThomasD
                                  • pihomeP
                                    pihomeP
                                    pihome
                                    Arduino 1.8.3 and ESP library is all updated. i m using vodafone router.
                                    • ThomasDrT
                                      ThomasDrT
                                      ThomasDr
                                      i try to build new Gateway for my Problem and Upload the same sketch, but the new Gateway do not connect to the router. I reminded the China NodeMCU have problems with Serial.begin and with WIFI.beginn. It need a delay after.
                                      I found the WIFI.begin in the "MyGatewayTransportEthernet.cpp" file and see a wait(500). See my last post wait/delay, so I changed from wait to delay and the Gateway connect.
                                      If you can try to change it too or change from 500 to 1000.
                                      But i use the 2.2.0 dev.
                                      regards
                                      Thomas
                                      pihomeP 1 Reply Last reply
                                      • ThomasDrT ThomasDr
                                        regards
                                        Thomas
                                        pihomeP
                                        pihomeP
                                        pihome
                                        @thomasdr thank you for the info, and sorry for late reply, changing wait(500) to delay(500) worked.
