  2. Announcements
  3. πŸ’¬ Building a WiFi Gateway using ESP8266
109 Posts 52 Posters 73.8k Views 51 Watching
  • sghazaghS sghazagh
    I used the same link (pins and sketches!). Checked it 10 times!
    I think my Radios are not functional....
    korttomaK
    korttomaK
    korttoma
    @sghazagh maybe you can take a picture of the setup. Maybe someone else can see something that you don't.
    • Tomas
    • sghazaghS
      sghazaghS
      sghazagh
      wrote on last edited by sghazagh
      #31
      Good idea,
      Here is the side by side image from front and back of the PCB.
      The 'j1' marked on wrong pin ,that's why I think my radio is not working at all as it seems it's very bad replicate.
      However, I have rotated it by 180 degree and tried that as well. same result!
      • sghazaghS
        sghazaghS
        sghazagh
        Guys, just an update for my issue regarding Radio and my circuit.
        The Radio was faulty, I received the new one, swapped it and all worked fine.
        I just posted that here if someone want to use my last post image as a reference for connecting the Radio.
        The wiring all are correct.
        • jakesJ
          jakesJ
          jakes
          Hi Hek,
          Thanks for this guide... I have added an additional 433 RF receiver to my ESP8266 gateway. How can I send the data received from 433 RF to the my Home Assistant controller?
          • denisvdbD
            denisvdbD
            denisvdb
            Hello, i have build a wifi gateway and use it in jeedom.
            My gateway wifi as connection problem.
            In jeedom, in the log of my sensors node I have almost every 2 days the message: diconnected from network gateway.
            If I restart the node the communication is re-established.
            Is this a problem with nrf24l01?
            • D
              derrij
              why esp8266 gateway shows only debug info?
              when i comment //#define MY_DEBUG
              where is no any serial output.
              • D derrij
                @derrij because it is a wifi gateway?
                • A
                  AndreD
                  If put in client mode
                  #define MY_CONTROLLER_IP_ADDRESS 192, 168, 2, 9
                  I get an error. How to win.
                  Arduino: 1.8.2 (Windows 7), ΠŸΠ»Π°Ρ‚Π°:"Generic ESP8266 Module, 80 MHz, 40MHz, DIO, 115200, 512K (64K SPIFFS), ck, Disabled, None"
                  "C:\Users\DedHP\AppData\Local\Temp\arduino_build_364162\sketch\GatewayESP8266.ino.cpp.o"
                  In file included from C:\Users\DedHP\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src/ESP8266WiFi.h:39:0,
                               from C:\Users\DedHP\AppData\Local\Temp\arduino_modified_sketch_313960\GatewayESP8266.ino:132:
                  C:\Users\DedHP\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src/WiFiClient.h: In instantiation of 'size_t WiFiClient::write(T&, size_t) [with T = char*; size_t = unsigned int]':
                  C:\Documents\Arduino\ams\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:207:58: required from here
                  C:\Users\DedHP\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src/WiFiClient.h:123:36: error: request for member 'available' in 'source', which is of non-class type 'char*'
                   size_t left = source.available();
                  C:\Users\DedHP\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src/WiFiClient.h:127:5: error: request for member 'read' in 'source', which is of non-class type 'char*'
                   source.read(buffer.get(), will_send);
                  Π˜ΡΠΏΠΎΠ»ΡŒΠ·ΡƒΠ΅ΠΌ Π±ΠΈΠ±Π»ΠΈΠΎΡ‚Π΅ΠΊΡƒ ESP8266WiFi вСрсии 1.0 ΠΈΠ· ΠΏΠ°ΠΏΠΊΠΈ: C:\Users\DedHP\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi
                  Π˜ΡΠΏΠΎΠ»ΡŒΠ·ΡƒΠ΅ΠΌ Π±ΠΈΠ±Π»ΠΈΠΎΡ‚Π΅ΠΊΡƒ MySensors вСрсии 2.1.1 ΠΈΠ· ΠΏΠ°ΠΏΠΊΠΈ: C:\Documents\Arduino\ams\Arduino\libraries\MySensors
                  Π˜ΡΠΏΠΎΠ»ΡŒΠ·ΡƒΠ΅ΠΌ Π±ΠΈΠ±Π»ΠΈΠΎΡ‚Π΅ΠΊΡƒ EEPROM вСрсии 1.0 ΠΈΠ· ΠΏΠ°ΠΏΠΊΠΈ: C:\Users\DedHP\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\EEPROM
                  Π˜ΡΠΏΠΎΠ»ΡŒΠ·ΡƒΠ΅ΠΌ Π±ΠΈΠ±Π»ΠΈΠΎΡ‚Π΅ΠΊΡƒ SPI вСрсии 1.0 ΠΈΠ· ΠΏΠ°ΠΏΠΊΠΈ: C:\Users\DedHP\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SPI
                  exit status 1
                  Ошибка компиляции для ΠΏΠ»Π°Ρ‚Ρ‹ Generic ESP8266 Module.*
                  • Jonathan CaesJ
                    Jonathan CaesJ
                    Jonathan Caes
                    Is it possible to use this setup without the nrf24l01 atached, so that i can use the esp8266 just as a sensor (not as a gateway)?
                    • Jonathan CaesJ Jonathan Caes
                      #39
                      @Jonathan-Caes yes. Don't define MY_RADIO_NRF24 and you're good to go. It will still be a gateway, but a gateway with local sensors and no radio.
                      • J
                        J
                        joseyapor
                        Hi how many Gateways Can i have on a network?
                        • J joseyapor
                          #41
                          @joseyapor On one MySensors network there can only be one MySensors gateway. But on one IP network, there can be many MySensors gateways. Exactly how many depends on geography and chosen transports but at the very least a few hundred. Thousands if you really need and plan accordingly.
                          I 1 Reply Last reply
                          • A
                            alexalex
                            Help! After connecting to the WIFI, I'm getting disconnected. Here's a log : https://goo.gl/fyr7ku
                            Any help in figuring this out would be appreaciated!
                            • A alexalex
                              #43
                              Welcome to the MySensors community @alexalex
                              The log is missing the first lines, but it looks like the microcontroller is unable to communicate with the radio. Which radio are you using?
                              See https://ci.mysensors.org/job/Verifiers/job/MySensors/branch/development/Doxygen_HTML/group__MyTransportgrp.html#details for more details about the log messages and https://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help/ for the most common problems and how to fix them.
                              • Bogus ExceptionB
                                Bogus ExceptionB
                                Bogus Exception
                                Is there a complete wiring table, diagram, or schematic? I have a working MyController/MySensors network on nRF24s, but I am adding WiFi with a ESP-201 module (white one with pins broken out for 2.54 pitch; see: http://smarpl.com/sites/default/files/images/ESP8266-ESP-201-pin-reference-v01.png)... TIA!
                                "If you drop it and it breaks, it was good." ~ Mr. Lehr, my Electronics Vo-Tech teacher, on testing vacuum tubes...
                                -Arduinos (UNO, Nano, Pro-Mini, Mega, ...)
                                -ATTiny, ATMega, STM32
                                -Geek Channel: https://www.youtube.com/TheSalesEngineer
                                • Bogus ExceptionB Bogus Exception
                                  #45
                                  @Bogus-Exception did you see the instructions linked in the first post in this thread? You probably want the part that says "connect the radio".
                                  • pihomeP
                                    pihomeP
                                    pihome
                                    if i reboot my wifi router mysensors wifi gateway wouldn't try to connect again, is this only with me or its common issue with wifi gateway?
                                    PiHome - Smart Heating Control
                                    • pihomeP pihome
                                      @pihome said in πŸ’¬ Building a WiFi Gateway using ESP8266:
                                      This question was transferred to a new thread by @pihome. Please don't answer here, to avoid double work and confusion.
                                      • folkestorpF
                                        folkestorpF
                                        folkestorp
                                        Reporting batterypercent to Domoticz not working.
                                        I have built a ESP8266 Gateway and I connecting a BME280 sensor. It report everything right with a serial gateway but with the new wifi gateway it not reciving the battery percent. I look in the serial monitor at the gateway and where is no battery data.
                                        • O
                                          O
                                          Oleg Greengo
                                          Colleagues, tell me.
                                          can I make it so that hosts register on the gateway only if I press a button on the gateway?
                                          Perhaps there is an example?
                                          With your input, this post could be even better πŸ’—
