  2. Announcements
  3. πŸ’¬ Building a WiFi Gateway using ESP8266
109 Posts 52 Posters 73.8k Views 51 Watching
  • denisvdbD
    denisvdbD
    denisvdb
    Hello, i have build a wifi gateway and use it in jeedom.
    My gateway wifi as connection problem.
    In jeedom, in the log of my sensors node I have almost every 2 days the message: diconnected from network gateway.
    If I restart the node the communication is re-established.
    Is this a problem with nrf24l01?
    • D
      derrij
      why esp8266 gateway shows only debug info?
      when i comment //#define MY_DEBUG
      where is no any serial output.
      • D derrij
        @derrij because it is a wifi gateway?
        • A
          AndreD
          If put in client mode
          #define MY_CONTROLLER_IP_ADDRESS 192, 168, 2, 9
          I get an error. How to win.
          Arduino: 1.8.2 (Windows 7), ΠŸΠ»Π°Ρ‚Π°:"Generic ESP8266 Module, 80 MHz, 40MHz, DIO, 115200, 512K (64K SPIFFS), ck, Disabled, None"
          "C:\Users\DedHP\AppData\Local\Temp\arduino_build_364162\sketch\GatewayESP8266.ino.cpp.o"
          In file included from C:\Users\DedHP\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src/ESP8266WiFi.h:39:0,
                       from C:\Users\DedHP\AppData\Local\Temp\arduino_modified_sketch_313960\GatewayESP8266.ino:132:
          C:\Users\DedHP\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src/WiFiClient.h: In instantiation of 'size_t WiFiClient::write(T&, size_t) [with T = char*; size_t = unsigned int]':
          C:\Documents\Arduino\ams\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:207:58: required from here
          C:\Users\DedHP\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src/WiFiClient.h:123:36: error: request for member 'available' in 'source', which is of non-class type 'char*'
           size_t left = source.available();
          C:\Users\DedHP\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src/WiFiClient.h:127:5: error: request for member 'read' in 'source', which is of non-class type 'char*'
           source.read(buffer.get(), will_send);
          Π˜ΡΠΏΠΎΠ»ΡŒΠ·ΡƒΠ΅ΠΌ Π±ΠΈΠ±Π»ΠΈΠΎΡ‚Π΅ΠΊΡƒ ESP8266WiFi вСрсии 1.0 ΠΈΠ· ΠΏΠ°ΠΏΠΊΠΈ: C:\Users\DedHP\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi
          Π˜ΡΠΏΠΎΠ»ΡŒΠ·ΡƒΠ΅ΠΌ Π±ΠΈΠ±Π»ΠΈΠΎΡ‚Π΅ΠΊΡƒ MySensors вСрсии 2.1.1 ΠΈΠ· ΠΏΠ°ΠΏΠΊΠΈ: C:\Documents\Arduino\ams\Arduino\libraries\MySensors
          Π˜ΡΠΏΠΎΠ»ΡŒΠ·ΡƒΠ΅ΠΌ Π±ΠΈΠ±Π»ΠΈΠΎΡ‚Π΅ΠΊΡƒ EEPROM вСрсии 1.0 ΠΈΠ· ΠΏΠ°ΠΏΠΊΠΈ: C:\Users\DedHP\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\EEPROM
          Π˜ΡΠΏΠΎΠ»ΡŒΠ·ΡƒΠ΅ΠΌ Π±ΠΈΠ±Π»ΠΈΠΎΡ‚Π΅ΠΊΡƒ SPI вСрсии 1.0 ΠΈΠ· ΠΏΠ°ΠΏΠΊΠΈ: C:\Users\DedHP\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SPI
          exit status 1
          Ошибка компиляции для ΠΏΠ»Π°Ρ‚Ρ‹ Generic ESP8266 Module.*
          • Jonathan CaesJ
            Jonathan CaesJ
            Jonathan Caes
            Is it possible to use this setup without the nrf24l01 atached, so that i can use the esp8266 just as a sensor (not as a gateway)?
            • Jonathan CaesJ Jonathan Caes
              #39
              @Jonathan-Caes yes. Don't define MY_RADIO_NRF24 and you're good to go. It will still be a gateway, but a gateway with local sensors and no radio.
              • J
                J
                joseyapor
                Hi how many Gateways Can i have on a network?
                • J joseyapor
                  #41
                  @joseyapor On one MySensors network there can only be one MySensors gateway. But on one IP network, there can be many MySensors gateways. Exactly how many depends on geography and chosen transports but at the very least a few hundred. Thousands if you really need and plan accordingly.
                  I 1 Reply Last reply
                  • A
                    alexalex
                    Help! After connecting to the WIFI, I'm getting disconnected. Here's a log : https://goo.gl/fyr7ku
                    Any help in figuring this out would be appreaciated!
                    • A alexalex
                      #43
                      Welcome to the MySensors community @alexalex
                      The log is missing the first lines, but it looks like the microcontroller is unable to communicate with the radio. Which radio are you using?
                      See https://ci.mysensors.org/job/Verifiers/job/MySensors/branch/development/Doxygen_HTML/group__MyTransportgrp.html#details for more details about the log messages and https://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help/ for the most common problems and how to fix them.
                      • Bogus ExceptionB
                        Bogus ExceptionB
                        Bogus Exception
                        Is there a complete wiring table, diagram, or schematic? I have a working MyController/MySensors network on nRF24s, but I am adding WiFi with a ESP-201 module (white one with pins broken out for 2.54 pitch; see: http://smarpl.com/sites/default/files/images/ESP8266-ESP-201-pin-reference-v01.png)... TIA!
                        "If you drop it and it breaks, it was good." ~ Mr. Lehr, my Electronics Vo-Tech teacher, on testing vacuum tubes...
                        -Arduinos (UNO, Nano, Pro-Mini, Mega, ...)
                        -ATTiny, ATMega, STM32
                        -Geek Channel: https://www.youtube.com/TheSalesEngineer
                        • Bogus ExceptionB Bogus Exception
                          #45
                          @Bogus-Exception did you see the instructions linked in the first post in this thread? You probably want the part that says "connect the radio".
                          • pihomeP
                            pihomeP
                            pihome
                            if i reboot my wifi router mysensors wifi gateway wouldn't try to connect again, is this only with me or its common issue with wifi gateway?
                            PiHome - Smart Heating Control
                            • pihomeP pihome
                              @pihome said in πŸ’¬ Building a WiFi Gateway using ESP8266:
                              This question was transferred to a new thread by @pihome. Please don't answer here, to avoid double work and confusion.
                              • folkestorpF
                                folkestorpF
                                folkestorp
                                Reporting batterypercent to Domoticz not working.
                                I have built a ESP8266 Gateway and I connecting a BME280 sensor. It report everything right with a serial gateway but with the new wifi gateway it not reciving the battery percent. I look in the serial monitor at the gateway and where is no battery data.
                                • O
                                  O
                                  Oleg Greengo
                                  Colleagues, tell me.
                                  can I make it so that hosts register on the gateway only if I press a button on the gateway?
                                  Perhaps there is an example?
                                  • T
                                    toozinger
                                    I'm receiving the following errors:
                                    warning: espcomm_sync failed
                                    error: espcomm_open failed
                                    error: espcomm_upload_mem failed
                                    I have attempted to fix this problem through:
                                    *Making sure I"m using the "NodeMCU" as my board in the Arduino IDE
                                    *Trying different upload rates
                                    *Pressing and holding the flash button while and/or right before upload
                                    Hardware:
                                    PC, windows 10
                                    NodeMCU from eBay link above.
                                    Any help? It appears others have had this problem as well, but I haven't (yet) been able to fix my issues through their threads.
                                    Toozinger
                                    • blackYB
                                      blackYB
                                      blackY
                                      ...and how to connect Arduino & MySensors & ESP8266-01 (like this one: https://www.aliexpress.com/item/2015-New-version-1PCS-ESP8266-serial-WIFI-model-ESP-01-Authenticity-Guaranteed-Internet-of-things/32574207918.html?spm=a2g0s.9042311.0.0.ytiQMF ) with ESP 01 Serial Adapter - like this one (https://www.aliexpress.com/item/ESP8266-Serial-WiFi-Wireless-ESP-01-Adapter-Module-3-3V-5V-Compatible-For-Arduino/32740695540.html?spm=a2g0s.9042311.0.0.lSVdmZ), when i should use Tx and Rx signals only?
                                      • blackYB blackY
                                        Welcome to the Mensors community @blackY !
                                        If you're new to building MySensor nodes, I recommend that you stick with the recommended build examples.
                                        It is probably possible to use the modules you link to, but it will require knowledge far beyond building the existing examples.
                                        • blackYB
                                          blackYB
                                          blackY
                                          yes, I know...but if you are still staying by given examples, you don't develop yourself ;)
                                          With your input, this post could be even better πŸ’—
