  3. RFM69 sleep mode
RFM69 sleep mode
25 Posts 9 Posters 18.2k Views 7 Watching
  • FrancoisF Francois
    @hek Hi I got a new shipment of Arduino mini pro and after I did the low power hack on this Arduino I now are getting 30uA current usage. Thank again for all you support and for this great MySensor community that you started :). Now I can go full steam ahead in building more sensor for my house.
    So, just to be clear, is this an accurate summary: the full package (Arduino mni pro plus radio) sleeps at 30uA if using the RFW69 but sleeps at 3uA if using the NRF24L01+?
    Also, does it make any difference whether it's RFM69W, RFM69CW, or RFM69HW? Do they all draw the same amount of current while sleeping?
    P 1 Reply Last reply
      P
      P
      peres
      Hi, I know this is an old thread, but it is stil a valid subject to me.
      I have had success with arduino pro mini v2 and RFM69W in sleep, but not the high power version RFM69HW.
      Arduino+RFM69W sleeps at 5.2micro Amp.
      Arduino+RFM69HW sleeps at 420micro Amp.
      I have written about it in arduino forum.
      I would be glad if someone has a solution for this.
      • P peres
        manutremo
        wrote on last edited by manutremo
        Hi @peres,
        My RFM69HW current during sleep is less than 1 uA aprox, which is consistent with what is shown in the datasheet. Interestingly, this is the result when powering the device with a battery; when powering the device from the PC USB serial, it's around 6 uA - still close enough as it's measured with a "normal" multimeter.
        I'Which version of mysensors are you using? I've moved to 2.2.0-beta (due to me needing other functionalities not availabel in 2.1.1, namely ATC which btw works fabulously) and found that support for nrf69 is - although not yet 100% completed - significantly improved. Maybe worth a try to see if that fixes your sleep consumption?
        Remember adding
        #define MY_RFM69_NEW_DRIVER
        to enable the new driver.
        Let us know how it goes :)
        • N
          N
          napo7
          I have the same question, but a little bit different ;)
          I use a RFM69 with the Mysensors 2.2.0 beta.
          I don't sleep my node with the provided function, since I don't want to sleep for some time, but until a Pin Change Interrupt is triggered (via pin A0 or A1). So, I can't use the sleep() function.
          I do put my node to sleep with avr core functions (setting registers, calling power_all_disable() and sleep_cpu()...) but I suppose the radio is never put on sleep !
          Is there a function I can call to sleep the radio, and if yes, is there another function I should call before sending, to awake the radio ?
          Thanks !
            @napo7
            Here the list of the core functions (radio independant):
            https://ci.mysensors.org/job/Verifiers/job/MySensors/branch/development/Doxygen_HTML/group__MyTransportgrp.html#gab39d3b81f005e00117269d79c7b2ee4c
            should be transportDisable/transportReInitialise
            Else the radio specific functions (a layer above driver) are in the MyTransportRFM69.cpp
            • N
              N
              napo7
              Thanks !
              • F
                F
                Fabien
                @napo7 : you can use sleep with interrupts :
                https://www.mysensors.org/download/sensor_api_20#sleeping
                • F Fabien
                  @Fabien MySensors sleep only supports hardware interrupts. napo7 is using pin change on analog pins which needs to be done in software.
                  • N
                    N
                    napo7
                    That's not a software interrupt. In facts, the atmega supports interrupt on all pins, and also waking-up the device from any pin change, but the sleep function only support "external interrupts" which can only be triggered on pin 2 and 3.
                    • N napo7
                      @napo7 thanks for the clarification
