  3. RFM69 sleep mode
RFM69 sleep mode
25 Posts 9 Posters 18.2k Views 7 Watching
    wrote on last edited by hek
    I can't find myself doing anything different from the LowPower library in in MyAtMega328.cpp - sleep(). Need someone else's eyes on it.
    • FrancoisF
      FrancoisF
      Francois
      @hek I see that you have powerDown in the MyHwATMega328.cpp how do I use that function?
      void powerDown(period_t period) {
      	ADCSRA &= ~(1 << ADEN);
      	if (period != SLEEP_FOREVER)
      		wdt_enable(period);
      		WDTCSR |= (1 << WDIE);
      	#if defined __AVR_ATmega328P__
      		do {
      			set_sleep_mode(SLEEP_MODE_PWR_DOWN);
      			cli();
      			sleep_enable();
      			sleep_bod_disable();
      			sei();
      			sleep_cpu();
      			sleep_disable();
      			sei();
      		} while (0);
      		do {
      			cli();
      			sleep_enable();
      			sei();
      			sleep_cpu();
      			sleep_disable();
      			sei();
      		} while (0);
      	ADCSRA |= (1 << ADEN);
        You use it by calling gw.sleep() which initiates powerDown.
        https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/MySensor.cpp#L820
        • FrancoisF
          FrancoisF
          Francois
          @hek Hi I got a new shipment of Arduino mini pro and after I did the low power hack on this Arduino I now are getting 30uA current usage. Thank again for all you support and for this great MySensor community that you started :). Now I can go full steam ahead in building more sensor for my house.
          • FrancoisF Francois
            So, just to be clear, is this an accurate summary: the full package (Arduino mni pro plus radio) sleeps at 30uA if using the RFW69 but sleeps at 3uA if using the NRF24L01+?
            Also, does it make any difference whether it's RFM69W, RFM69CW, or RFM69HW? Do they all draw the same amount of current while sleeping?
            P 1 Reply Last reply
              P
              P
              peres
              Hi, I know this is an old thread, but it is stil a valid subject to me.
              I have had success with arduino pro mini v2 and RFM69W in sleep, but not the high power version RFM69HW.
              Arduino+RFM69W sleeps at 5.2micro Amp.
              Arduino+RFM69HW sleeps at 420micro Amp.
              I have written about it in arduino forum.
              I would be glad if someone has a solution for this.
              • P peres
                manutremo
                wrote on last edited by manutremo
                Hi @peres,
                My RFM69HW current during sleep is less than 1 uA aprox, which is consistent with what is shown in the datasheet. Interestingly, this is the result when powering the device with a battery; when powering the device from the PC USB serial, it's around 6 uA - still close enough as it's measured with a "normal" multimeter.
                I'Which version of mysensors are you using? I've moved to 2.2.0-beta (due to me needing other functionalities not availabel in 2.1.1, namely ATC which btw works fabulously) and found that support for nrf69 is - although not yet 100% completed - significantly improved. Maybe worth a try to see if that fixes your sleep consumption?
                Remember adding
                #define MY_RFM69_NEW_DRIVER
                to enable the new driver.
                Let us know how it goes :)
                • N
                  N
                  napo7
                  I have the same question, but a little bit different ;)
                  I use a RFM69 with the Mysensors 2.2.0 beta.
                  I don't sleep my node with the provided function, since I don't want to sleep for some time, but until a Pin Change Interrupt is triggered (via pin A0 or A1). So, I can't use the sleep() function.
                  I do put my node to sleep with avr core functions (setting registers, calling power_all_disable() and sleep_cpu()...) but I suppose the radio is never put on sleep !
                  Is there a function I can call to sleep the radio, and if yes, is there another function I should call before sending, to awake the radio ?
                  Thanks !
                    @napo7
                    Here the list of the core functions (radio independant):
                    https://ci.mysensors.org/job/Verifiers/job/MySensors/branch/development/Doxygen_HTML/group__MyTransportgrp.html#gab39d3b81f005e00117269d79c7b2ee4c
                    should be transportDisable/transportReInitialise
                    Else the radio specific functions (a layer above driver) are in the MyTransportRFM69.cpp
                    • N
                      N
                      napo7
                      Thanks !
                      • F
                        F
                        Fabien
                        @napo7 : you can use sleep with interrupts :
                        https://www.mysensors.org/download/sensor_api_20#sleeping
                        • F Fabien
                          @Fabien MySensors sleep only supports hardware interrupts. napo7 is using pin change on analog pins which needs to be done in software.
                          • N
                            N
                            napo7
                            That's not a software interrupt. In facts, the atmega supports interrupt on all pins, and also waking-up the device from any pin change, but the sleep function only support "external interrupts" which can only be triggered on pin 2 and 3.
                            • N napo7
                              @napo7 thanks for the clarification
