  3. Some issues about uplink available or no
3 Posts 2 Posters 955 Views 2 Watching
    sineverba
    wrote on last edited by sineverba
    Hi to all!
    Sometimes I have issues in home with gateway, that hangs until next restart.
    The nodes (several only transmitting temp/hum) seems hangs, they don't interest if I did restart or no the gateway//controller.
    I would implement some check of uplink available on the sketchs, on the loop. If uplink is available, transmit, if not, recheck.
    But... I don't know how to implement this check.
    Can you help me with this?
    My pseudocode could be:
        bool is_available_uplink;
        is_available_uplink = getUplinkState();
        if (is_available_uplink) {
            // do stuff
    bool getUplinkState() {
        bool is_uplink_available = false;
        // check here the uplink
        return is_uplink_available;
    Thank you to all!
    • S sineverba
      Hi to all!
              // do stuff
      Thank you to all!
      @sineverba you're probably looking for
      isTransportReady()
      See these threads for more details:
      https://forum.mysensors.org/topic/5745/my_transport_dont_care_mode/10
      https://forum.mysensors.org/topic/7298/get-status-of-connection/7
      https://forum.mysensors.org/topic/4899/how-add-watchdog-to-my-sensors/4
      https://forum.mysensors.org/topic/4593/battery-sensor-and-re-connecting-to-gateway/2
      https://forum.mysensors.org/topic/7298/get-status-of-connection/6
      https://forum.mysensors.org/topic/7723/car-aux-battery-monitor
        sineverba
        Thank you... But isTransportReady seems true also if I leave the Arduino Gateway with reset pushed forever. ONly get false when I disconnect the power from Arduino.
        I'm thinking to use the receiveTime method. But, if controller (and gateway) are down, what the value returned from receivedTime?
        On another words, how can I check if time is returning? Because with gateway shutdown on Serial I did not read nothing from that function (instead of time).
        Thank you!
