  3. Car Aux Battery Monitor
24 Posts 9 Posters 20.3k Views 8 Watching
  • Boots33B
    Boots33B
    Boots33
    wrote on last edited by Boots33
    We enjoy getting away and camping in remote areas whenever we get the chance. We rely on a second battery fitted in the 4wd to power our fridge and provide lighting. This second battery sadly gets little attention paid to it in between trips, though it is connected to the car charging circuit to keep it topped up.
    So I thought it time to give it the attention it deserves by fitting a MySensors node to monitor the battery voltage. This will allow my Domoticz controller to keep any eye on how it is going and let me know if it strays too far from the norm.
    This node has just one job to do, that is simply to monitor and report the voltage present at the second battery. A simple voltage divider is used to sample the battery voltage.
    As the node will be fitted to a vehicle that will spend some part of the day away from home the sketch first checks for the gateway's presence before sending the information. The node sleeps most of the time only waking for a few seconds every hour to check and send data.
    Domoticz Output
    The sketch
     /*Sketch for a MySensor node to monitor a 12v aux battery in a 4wd ute
     * The node monitors battery voltage and reports back to the controller.
    #define MY_DEBUG                             // Enable debug prints to serial monitor
    #define MY_RADIO_NRF24 // Enable and select radio type attached
    #define MY_TRANSPORT_WAIT_READY_MS 3000  //set how long to wait for connection to establish before moving on. in milliseconds
    //#define MY_NODE_ID 15
    //#define MY_RF24_CHANNEL 84                   // set channel used
    //#define MY_PARENT_NODE_ID 1                 // set the parent node
    //#define MY_PARENT_NODE_IS_STATIC             // force connection to parent node only.
    #include "MySensors.h"
    #define ID_S_MULTIMETERV 1                   // Multimeter device for voltage measurement
    unsigned long sleepTime = 60000*60;          // Sleep time between reads (in milliseconds) (Set to 1 hour at present)
    int voltagePin = A0;                         // analog pin voltage sensor or voltage divider is connected to
    int voltSenseMax = 23460;                    // set to the maximum voltage in millivolts of your voltage divider input
    MyMessage msg_S_MULTIMETERv(ID_S_MULTIMETERV,V_VOLTAGE);
    void presentation()  {
     sendSketchInfo("Vehicle Battery Sensor", "1.1");    // Send the sketch version information to the gateway and Controller
     present(ID_S_MULTIMETERV, S_MULTIMETER);                // Register Sensor to gateway
    uplinkCheck();                                       // call function to send data
    Serial.println("sleeping now");
    sleep(sleepTime);                                    // sleep until next scheduled check
    Serial.println("awake now");
    wait (50);                                           // small wait to allow to stabalise after sleep.
    /*-------------------start of functions--------------------------*/
    void uplinkCheck() {
      if (request( ID_S_MULTIMETERV, V_VOLTAGE)) {          // request the current voltage data from the controller and check that the request was succsessful
      Serial.println("uplink established");
      int voltRead =  analogRead(voltagePin);
      int voltMilli = map(voltRead,0,1023,0,voltSenseMax);  // map the reading and get the result in millivolts
      send(msg_S_MULTIMETERv.set(voltMilli / 1000.0, 2));   // Divide by 1000 to convert back to volts to two decimal places, send data to controller.        // send voltage message to gateway with 1 decimal place
      else{
        Serial.println(" No uplink ");
    The circuit
    The board
    Testing at the moment hope to fit it next weekend.
    • S
      syotos
      Have you measured the current usage? The LM7805 is not terribly efficient and if you don't use the car regularly just the loss of the LM7805 and the on board regulator for 3.3v for the nrf2401+ can drain the battery. I did a quick LTSpice simulation and even with a super light load (100uA) the circuit will draw more then 5mA. And with a stock arduino pro mini it will be more like 7mA.
      With a large battery It will probably never be an issue, but something like 3-5A drain a month is not nothing.
      Maybe swap the LM7805 with a switching regulator. In any case make sure you remove /disconnect the led from the arduino that will save you 1.5 mA anyway.
      Boots33B 1 Reply Last reply
      • S syotos
        Boots33B
        Boots33B
        Boots33
        @syotos Thanks for your comments as to current draw, and of course you are correct the circuit as shown is not the most efficient.
        There are a few reasons why it is built this way, the first of which is it was a spur of the moment project. I had a few hours free on Sunday afternoon and basically had to use what parts I had on hand.
        The ACT variant of the LM7805 while being a bit thirsty does offer a very stable 5v output which is a plus when being used in this circuit.
        The battery being monitored is a 120ah lead-acid type battery which is charged by the vehicle alternator via a 30amp DC-DC charger. This gives a boosted charge rate above what the alternator alone would supply so recharge times are very good.
        The self discharge rate of a typical lead-acid battery (Depends on factors like construction type and temperature etc.) is between 2%-10% per month anyway so a little bit more in the big scheme of things will not be too bad.
        Importantly the vehicle is a daily drive so it gets plenty of time to re-charge and i will also be fitting an off switch so the node can be disabled completely when away from home for extended periods.
        I probably should have given more details in the first post but if you have seen my other projects i tend to post early in their construction and add changes as I go. :)
        I also have an off road camper trailer with 200ah of gel batteries that i would like to monitor as well. It tends to sit in the garage for several weeks at a time so will definitely be looking at a modified 3v pro mini for that I think.
        • Boots33B
          Boots33B
          Boots33
          Ok fitted to the vehicle today. Tested the current draw and is around 9mA which is ok for this application.
          The sketch remains the same although i have reduced the time between data sends to 30 min and will see how that goes.
          I have used the roll from a plastic sandwich wrap box to hold the board. i just cut it to length and the board was a good fit.
          I have used gaffer tape to seal the ends.
          For the moment it is secured outside the battery area but will move it when the testing is complete
          The switch on the bottom of the panel turns it off.
          sinczeS 1 Reply Last reply
          • Boots33B Boots33
            sinczeS
            sinczeS
            sincze
            MySensors Evangelist
            @Boots33 Nice application. Inspired me to have a look at the charge / discharge of my motorcycle battery. ;-)
            • sinczeS sincze
              Boots33B
              Boots33B
              Boots33
              @sincze Thanks for your comment. If this node works out ok I will see if I can build a low power version for my camper, I have ordered a couple of 3v pro mini's to tinker with. As @syotos has said a low power node will be best suited to the task.
              I have now setup Domoticz to email me if the voltage exceeds or drops below my preset thresholds, will see how it performs during the week as it comes and goes from home.
              • ahmedadelhosniA
                ahmedadelhosniA
                ahmedadelhosni
                What is the distance between your car and master gateway ? Do you use any repeater nodes ?
                • ahmedadelhosniA ahmedadelhosni
                  Boots33B
                  Boots33B
                  Boots33
                  @ahmedadelhosni My gateway is in a server cabinet in the garage so the node is within 7m of the gateway when the car is home. I do have areas of our block covered by repeater nodes but this node will usually connect directly to the gateway i would think.
                  If I build a unit for my camper it will have to go through a repeater to reach the gateway.
                  • luizrrochaL
                    luizrrochaL
                    luizrrocha
                    You are my hero, man !!!
                    I have several 2xAA powered sensors that connect to a MySGateway without an UPS. Power outages are frequent in my street and when the power goes out on the gateway, the sensors eat their batteries trying to send data... Your method of checking the status of the uplink before trying to send is going to cost a little more during normal operations but will save a lot in case of outages.
                    Good idea!
                    • luizrrochaL luizrrocha
                      Good idea!
                      Boots33B
                      Boots33B
                      Boots33
                      @luizrrocha Great that you have found something of use in the code :) I have learnt a lot from others on this forum, the magic of open source! Let us know how you get on.
                      • Boots33B
                        Boots33B
                        Boots33
                        Well this has been running for the week now with the car coming and going. The node has to this point been performing as intended and is re-connecting without issues to the gateway when the car arrives home.
                        The only thing I have noticed is that the battery voltage is showing a bit lower than I was expecting. Nothing too drastic but I will need to check with a meter and see whether it is the node that needs adjustment or maybe my battery setup!
                        Still early days but I think that a low power version will be a great addition to my camper.
                        • BartEB
                          BartEB
                          BartE
                          @Boots33 thanks for sharing, this project inspired me to have a monitor for my caravan battery :)
                          I have mine up and running now and did run in a small error present in your source code, on this line
                           present(ID_S_MULTIMETERV,V_VOLTAGE);               // Register Sensor to gateway
                          The present function should contain sensor type (S_xxxx values) and V_VOLTAGE is a payload message type.
                          So i think the presentation function should look like this.
                            sendSketchInfo("Battery Sensor", "1.1");    // Send the sketch version information to the gateway and Controller
                          Up and 'running':
                          • BartEB BartE
                            Up and 'running':
                            Boots33B
                            Boots33B
                            Boots33
                            Thanks @BartE I don't know what I was thinking there!!!! I have made the change to the sketch. That's it no more drinking wine on a Sunday afternoon while working on a project. ;)
                            I think this node is a good example of how the I.O.T can be of practical use in a real world situation. Especially for items like vans and campers that can often spend months tucked away without use. To know the state of the battery is being monitored will mean one less thing for me to worry about.
                            Did you build a low power version, still waiting for my 3v pro mini to arrive so I can have a play. I will be keen to see how high I can go with the voltage divider resistors before it becomes unstable.
                            I know there have been a few posts on low power nodes before so will have to do a bit of digging through the old posts.
                            I also put the multimeter on to check this node over the weekend and it is reading very close to the mark. So it seems I have a problem with the aux battery system! I will have to check a little further to see what is going wrong. Hope it is not the battery, they are not cheap to replace. Good that the problem has come to light though, better than being caught out.
                            BartEB 1 Reply Last reply
                            • Boots33B Boots33
                              BartEB
                              BartEB
                              BartE
                              @Boots33 No i did use a standard Arduino Nano not a low power one.
                              It is monitoring a caravan mover battery with a 105 Ah capacity, i think it will last during the winter on one load :smile:
                              • Boots33B
                                Boots33B
                                Boots33
                                I have built a low power version today based on a 3v pro mini board and am so far very happy with the results.
                                On the pro mini the power LED needs to be disabled and the onboard regulator has to be removed. I followed the instructions on this page
                                To keep power draw down I have used much higher resistors for the voltage divider and have also included a capacitor to help keep it stable. In testing on the bench it has been very stable.
                                I have used an easy/newbie board from @sundberg84 which really did make the whole thing very easy :) It even already has the voltage divider layout taken care of. Thank you very much!!
                                I had to make two minor mods to the board to accommodate the modified pro mini as shown below. Please note these changes are for Rev8 boards so different changes may be needed for other revisions. Rev9 definitely has had changes made to the power area.
                                The original version from my first post draws around 9ma when sleeping which is ok for my daily drive vehicle. This lower power version is way better for my camper. In testing on the bench these are the typical current requirements.
                                Booting up .......... 19ma Pretty high but this is only for a few seconds
                                Powered up and awake....... 4.8ma That's nearly half of the original when it was sleeping
                                powered up and sleeping ...... 90ua Bingo, this puppy should go for a while on my 200ah batteries ;)
                                So the original draws 0.009A and this new version a miserly 0.00009A a very good result for long term monitoring.
                                I have modified the Sketch to suit the new node, the main change has been to add 10 reads and average the results to help keep it all stable.
                                You can see from the serial data the node wakes, takes the reading, sends the data and is back to sleep in less than a blink of the eye! (this was only sleeping for 15 seconds during testing)
                                I have used a Rev8 Easy/Newbie board
                                with a couple of tweaks
                                The circuit now looks something like this
                                And finally the sketch
                                 /*Sketch for a MySensor node to monitor a 12v aux battery in a Camper Trailer
                                 * The node monitors battery voltage and reports back to the controller. Uses a 3v
                                 * Pro mini with power led and voltage regulator removed.
                                 * Voltage divider R1 1 megaohm  R2 150 kilohms
                                //unsigned long sleepTime = 15000;
                                unsigned long sleepTime = 60000 * 30;          // Sleep time between reads (in milliseconds) (Set to 30 min at present)
                                int voltSenseMax = 25000;                    // set to the maximum voltage in millivolts of your voltage divider input
                                int sampleCount = 0;
                                int sum = 0;                    // sum of samples taken
                                int numSamples = 10;
                                 wait (5000);   // give node a chance to fully boot on startup
                                 sendSketchInfo("Camper Battery Sensor", "1.0");    // Send the sketch version information to the gateway and Controller
                                 present(ID_S_MULTIMETERV, S_MULTIMETER,"Camper Battery");                // Register Sensor to gateway
                                Serial.println("------ sleeping now ----- ");
                                Serial.println("------awake now--------");
                                   while (sampleCount < numSamples) {
                                        sum += analogRead(voltagePin);
                                        sampleCount++;
                                        delay(10);
                                  int voltMilli = map((sum / 10),0,1023,0,voltSenseMax);  // map the reading and get the result in millivolts
                                  sampleCount = 0;
                                  sum = 0;
                                  else{
                                • Boots33B
                                  Boots33B
                                  Boots33
                                  I was looking at how I would install this node in the camper and decided a permanent mounting might not be the best way to go. The camper is of fully steel construction and because it is meant for off road use when it is packed up it is sealed air tight to prevent water and dust from gaining entry. So this could make it difficult for the signal to get out.
                                  Add to this that the camper is stored in a steel garage and located around 30m from the nearest repeater which is inside the house. So i decided to make the node an external plug in accessory to give it the best chance of making a connection.
                                  The camper already has a heavy lead running directly from the batteries to the front of the A frame. This is used to supply power to the camper while travelling and also allows a solar panel to be connected.
                                  So this seemed like the best spot to connect the node. The lead is fitted with an Anderson plug so connecting up would be easy as well. i hoped that by putting the node on the outside of the camper I would be able to get a stable connection back to the repeater.
                                  The node was mounted into a small length of 50mm pvc tube, the easy/newbie board is a good fit.
                                  I have fitted a small length of cable with an Anderson plug, this allows a quick connect to the camper electricals. The finished node looks like this.
                                  Then it just plugs into the camper. I found that it can hang over the front winch mount, this allows the body of the node to swing free away from other metal objects.
                                  In testing i have the node transmitting every 15 min to get an idea of how it all goes. Unfortunately at the moment it sometimes misses the occasional send so it must be on the edge of range at the moment. Although it is not really critical that it makes connection every time i will have to see what else I can do to make it more reliable.
                                  dbemowskD 1 Reply Last reply
                                  • Boots33B
                                    Boots33B
                                    Boots33
                                    The low power node has continued to be unreliable, connecting only intermittently with the controller. It appears to be a power problem as the node works well when it is powered through the ftdi adaptor.
                                    Voltage readings on the 3v line read 3.4v when on the ftdi and 3.27v through the LE33. Perhaps the LE33 at 100ma cannot keep up with the required demand?
                                    I have added another 47uf capacitor to the nrf supply and that seems to have improved things, so to continue testing I have now installed this unit into my Colorado as well . This will give it the same workout of coming and going that the other node gets and I will be able to compare their readings side by side to see if the voltage averaging this nodes uses makes any difference to reading stability.
                                    • Boots33B Boots33
                                      @Boots33 - Im having a hard time to see exact caps on your voltage regulator. A double 0,1 (before) and 10uF (after) could improve the stability of the LE33.
                                      Good thinking about the 47uF on the radio. Sometimes a 4.7 and sometimes 47uF does the job for me.
                                      • sundberg84S sundberg84
                                        Boots33B
                                        Boots33B
                                        Boots33
                                        @sundberg84 Thanks . I have a 0.1 and 10 on the reg at the moment . I will add another 0.1 and see if that helps.
                                        I always used 4.7 on the nrf but since 2.1.1 I find 47uf works best for me now, although in this case it appears that closer to 100uf is what is needed for this node.
                                        • Boots33B Boots33
                                          dbemowskD
                                          dbemowskD
                                          @Boots33 For the radio, what if you used an NRF24L01+PA+LNA with an external antenna. you could put rubber washers on it to keep dirt out while having the antenna external to the other electronics.
                                          Just a thought.
