  3. nRF5 action!
nRF5 action!
    Which settings are key for ensuring that packets sent by the nRF24 are correctly received by the nRF5? It would be nice to leverage the versions of the nRF24 that have amplified Tx.
    These are more than settings. You have to set the Radio configuration like in Radio_ESB.cpp, reverse the addresses and handle sending ACK packages by software.
    This is a good resource to understand the OTA protocol: https://hackaday.io/project/11942-antenna-diversity-receive-and-transmit/log/39510-shockburst-vs-enhanced-shockburst-nrf24-vs-nrf5x
    I can provide a simple example how to use the MySensors transport code without Radio Head. This works for nRF5 and nRF24 modules, but its outside of that what the MY_CORE_ONLY mode is designed for.
    #define MY_CORE_ONLY
    #ifndef ARDUINO_ARCH_NRF5
    #define MY_NODE_ID (1)
    #define SND_TO (2)
    #define MY_NODE_ID (2)
    #define SND_TO (1)
    // Enable debug
    //#define MY_DEBUG_VERBOSE_NRF5_ESB
    // RF24_250KBPS RF24_1MBPS RF24_2MBPS
    #define MY_RF24_DATARATE (RF24_1MBPS)
    // NRF5_250KBPS NRF5_1MBPS NRF5_2MBPS
    #define MY_NRF5_ESB_MODE (NRF5_1MBPS)
    #ifndef NRF5
    #define MY_RADIO_NRF5_ESB
      hwInit();
      transportInit();
      transportSetAddress(MY_NODE_ID);
      // Check for packages
      while (transportAvailable()) {
        uint8_t buffer[256];
        uint8_t num = transportReceive(&buffer);
        Serial.print("Data=");
        for (int i=0;i<num;i++) {
          if (buffer[i]<0x10) Serial.print("0");
          Serial.print(buffer[i], HEX);
          Serial.print(" ");
        Serial.println();
      wait(1000);
      // Send data
      transportSend(SND_TO, "abcdefghijklmnopqrstuvwxyzabcdefghijklmnopqrstuvwxyz",32, false);
    I tried compiling it using the Arduino Windows IDE, but for some reason it complains about not finding a whole litany of .h files: socket.h, w5100.h, netdb.h.... Does mysensors.h really need to drag in all of those .h files, even if only indirectly? Or, if there's an easy way to make it find them, what is it?
    d00616D
    d00616D
    d00616
    I can compile it with Linux. What are missing is part of the Ethernet library. I don't know why it's included in you build.
    • d00616D d00616
      #984
      I just now upgraded to the current release of the mysensors development library, and the compile problem went away. :) So, if anyone else encounters the same problem, I recommend doing that.
      d00616D 1 Reply Last reply
        d00616D
        d00616D
        d00616
        I just now upgraded to the current release of the mysensors development library, and the compile problem went away. So, if anyone else encounters the same problem, I recommend doing that.
        Sorry. I have forgotten my uncommited changes. At the moment, you have to start the HFCLK in the CORE_ONLY mode. This is done in hwInit() later.
        • d00616D d00616
          ... At the moment, you have to start the HFCLK in the CORE_ONLY mode. ...
          Do you have a revised sketch which does that? I tried running the sketch you gave above on an nRF52 DK, but it immediately goes into a boot-loop, wherein in keeps rebooting itself, over and over and over again.
            I just now tried running it on a pro-mini using a nRF24, and it also gets into a boot-loop.
              d00616D
              d00616D
              d00616
              Please replace wait() with delay(). This is an issue in the transport code, which is triggered while sleep() or wait() is executed.
              NeverDieN T 3 Replies Last reply
              • d00616D d00616
                OK, made that change, and it no longer boot-loops.
                However, neither node appears to be receiving anything from the other.
                Please advise.
                • d00616D d00616
                  #990
                  @d00616
                  Since the original code didn't work, I upgraded it somewhat to give a larger Rx window. However, it still doesn't work:
                  #define SND_TO (2)
                  #define SND_TO (1)
                  // Enable debug
                  #ifndef NRF5
                    Serial.println("Starting....");
                    Serial.print("MY_NODE_ID=");
                    Serial.println(MY_NODE_ID);
                    Serial.print("SND_TO=");
                    Serial.println(SND_TO);
                    hwInit();
                    transportInit();
                  uint32_t theTime=0;
                  uint32_t loopCounter=0;
                    while ((millis()-theTime)<1000) {
                          Serial.print(" ");
                        Serial.println();
                    theTime=millis();
                    //delay(1000);
                    Serial.print(loopCounter++);
                    Serial.println(", SENDING:  abcdefghijklmnopqrstuvwxyzabcdefghijklmnopqrstuvwxyz");
                    // Send data
                  One node is an nRF24 on a pro mini, and the other is an nRF52832.
                    @d00616
                    #define SND_TO (2)
                    #define SND_TO (1)
                    // Enable debug
                    #ifndef NRF5
                      hwInit();
                      transportInit();
                    uint32_t theTime=0;
                            Serial.print(" ");
                          Serial.println();
                      theTime=millis();
                      //delay(1000);
                      // Send data
                    d00616D
                    d00616D
                    d00616
                    wrote on last edited by d00616
                    #991
                    Please add this to your setup() function (https://forum.mysensors.org/topic/6961/nrf5-bluetooth-action/985):
                    	// Clock is manged by sleep modes. Radio depends on HFCLK.
                    	// Force to start HFCLK
                    	NRF_POWER->TASKS_CONSTLAT = 1;
                    	// Enable cache on >= NRF52
                    #ifndef NRF51
                    	NRF_NVMC->ICACHECNF = NVMC_ICACHECNF_CACHEEN_Msk;
                    At the moment I prepare a new Pull Request fixing this including some small fixes and improvements for nRF5 MCUs. When it's integrated the HFCLK is startet in hwInit().
                    • d00616D d00616
                      Toyman
                      @d00616 is this universal recommendation?
                      • T Toyman
                        d00616D
                        d00616D
                        d00616
                        I think you mean to start the HFCLK. This isn't a universal recommendation. At the moment the HFCLK is started in MyMainNRF5.cpp. This file is ignored in CORE_ONLY mode. I moved any initialization code into hwInit().
                        • d00616D d00616
                          #ifndef NRF51
                          d00616D
                          d00616D
                          d00616
                          The Pull Request is available: https://github.com/mysensors/MySensors/pull/938
                          • d00616D d00616
                            That link lists changes to the files, but it doesn't seem to provide the new files. Or else I'm overlooking where it does?
                              d00616D
                              d00616D
                              d00616
                              You have to checkout this pull request: https://help.github.com/articles/checking-out-pull-requests-locally/
                              • d00616D d00616
                                Maybe I need write-access or something? Those instructions refer to a command line, and I just don't see one anywhere.
                                  Well, anyway, I added code to start the high frequency clock, and now it seems to work:
                                  #define SND_TO (2)
                                  #define SND_TO (1)
                                  // Enable debug
                                  #ifndef NRF5
                                  #include <nrf.h>
                                    if (MY_NODE_ID==2) {
                                      NRF_CLOCK->TASKS_HFCLKSTART=1;  //activate the high frequency crystal oscillator
                                      while ((NRF_CLOCK->EVENTS_HFCLKSTARTED==0)) {};  //wait until high frequency clock start is confirmed
                                    hwInit();
                                    transportInit();
                                  uint32_t theTime=0;
                                          Serial.print(" ");
                                        Serial.println();
                                    theTime=millis();
                                    //delay(1000);
                                    // Send data
                                    d00616D
                                    d00616D
                                    d00616
                                    You can do this with git on your local machine:
                                    cd MySensors
                                    git fetch origin pull/938/head:pr938
                                    git checkout pr938
                                    • d00616D d00616
                                      cd MySensors
                                      git checkout pr938
                                      @d00616
                                      Thanks for trying. That would probably work with a linux machine, but mine is running Windows. I'm surprised there's no easy way to do this from Windows.
                                      I guess I'll just wait for the next developers release of mysensors.
                                        #1001
                                        For anyone else caught in the same limbo as me, here's a more proper update of the earlier example:
                                        #define SND_TO (2)
                                        #define SND_TO (1)
                                        // Enable debug
                                        #ifndef NRF5
                                        #include <nrf.h>
                                          Serial.flush();
                                          #ifdef ARDUINO_ARCH_NRF5
                                          hwInit();
                                          transportInit();
                                        uint32_t theTime=0;
                                              Serial.print(loopCounter);
                                              Serial.print(", RECEIVED=");
                                                Serial.print(" ");
                                              Serial.println();
                                              Serial.flush();
                                          theTime=millis();
                                          //delay(1000);
                                          Serial.println(", SENDING:  abcdefghijklmnopqrstuvwxyz01234");
                                          Serial.println();
                                          Serial.flush();
                                          // Send data
                                          transportSend(SND_TO, "abcdefghijklmnopqrstuvwxyz01234",32, false);
                                        The serial output shown by the nRF52 is what you would expect:
                                        Starting....
                                        MY_NODE_ID=2
                                        SND_TO=1
                                        0, RECEIVED=61 62 63 64 65 66 67 68 69 6A 6B 6C 6D 6E 6F 70 71 72 73 74 75 76 77 78 79 7A 30 31 32 33 34 00
                                        0, SENDING:  abcdefghijklmnopqrstuvwxyz01234
                                        1, RECEIVED=61 62 63 64 65 66 67 68 69 6A 6B 6C 6D 6E 6F 70 71 72 73 74 75 76 77 78 79 7A 30 31 32 33 34 00
                                        1, SENDING:  abcdefghijklmnopqrstuvwxyz01234
                                        2, RECEIVED=61 62 63 64 65 66 67 68 69 6A 6B 6C 6D 6E 6F 70 71 72 73 74 75 76 77 78 79 7A 30 31 32 33 34 00
                                        2, SENDING:  abcdefghijklmnopqrstuvwxyz01234
                                        3, RECEIVED=61 62 63 64 65 66 67 68 69 6A 6B 6C 6D 6E 6F 70 71 72 73 74 75 76 77 78 79 7A 30 31 32 33 34 00
                                        3, SENDING:  abcdefghijklmnopqrstuvwxyz01234
                                        However, the serial output of the pro mini often seems to include a 1-byte packet:
                                        Starting....
                                        MY_NODE_ID=1
                                        SND_TO=2
                                        2, RECEIVED=41
                                        3, RECEIVED=41
                                        4, RECEIVED=47
                                        4, RECEIVED=61 62 63 64 65 66 67 68 69 6A 6B 6C 6D 6E 6F 70 71 72 73 74 75 76 77 78 79 7A 30 31 32 33 34 00
                                        4, SENDING:  abcdefghijklmnopqrstuvwxyz01234
                                        5, RECEIVED=46
                                        5, RECEIVED=61 62 63 64 65 66 67 68 69 6A 6B 6C 6D 6E 6F 70 71 72 73 74 75 76 77 78 79 7A 30 31 32 33 34 00
                                        5, SENDING:  abcdefghijklmnopqrstuvwxyz01234
                                        6, RECEIVED=47
                                        6, RECEIVED=61 62 63 64 65 66 67 68 69 6A 6B 6C 6D 6E 6F 70 71 72 73 74 75 76 77 78 79 7A 30 31 32 33 34 00
                                        6, SENDING:  abcdefghijklmnopqrstuvwxyz01234
                                        Is that a bug?
                                          @d00616
                                          d00616D
                                          d00616D
                                          d00616
                                          #1002
                                          This depends on Git installed not on Linux. The Pull Request is now into the developer branch.
                                          Is that a bug?
                                          This is the RSSI value, which is send back as ACK payload. I check what's the best way to deal with.
