  3. nRF5 action!
nRF5 action!
  • T Toyman
    @d00616 is this universal recommendation?
    d00616D
    d00616D
    d00616
    I think you mean to start the HFCLK. This isn't a universal recommendation. At the moment the HFCLK is started in MyMainNRF5.cpp. This file is ignored in CORE_ONLY mode. I moved any initialization code into hwInit().
    • d00616D d00616
      Since the original code didn't work, I upgraded it somewhat to give a larger Rx window. However, it still doesn't work:
      Please add this to your setup() function (https://forum.mysensors.org/topic/6961/nrf5-bluetooth-action/985):
      	// Clock is manged by sleep modes. Radio depends on HFCLK.
      	// Force to start HFCLK
      	NRF_POWER->TASKS_CONSTLAT = 1;
      	// Enable cache on >= NRF52
      #ifndef NRF51
      	NRF_NVMC->ICACHECNF = NVMC_ICACHECNF_CACHEEN_Msk;
      At the moment I prepare a new Pull Request fixing this including some small fixes and improvements for nRF5 MCUs. When it's integrated the HFCLK is startet in hwInit().
      d00616D
      d00616D
      d00616
      The Pull Request is available: https://github.com/mysensors/MySensors/pull/938
      • d00616D d00616
        That link lists changes to the files, but it doesn't seem to provide the new files. Or else I'm overlooking where it does?
        d00616D 1 Reply Last reply
          d00616D
          d00616D
          d00616
          You have to checkout this pull request: https://help.github.com/articles/checking-out-pull-requests-locally/
          • d00616D d00616
            Maybe I need write-access or something? Those instructions refer to a command line, and I just don't see one anywhere.
              Well, anyway, I added code to start the high frequency clock, and now it seems to work:
              #define MY_CORE_ONLY
              #ifndef ARDUINO_ARCH_NRF5
              #define MY_NODE_ID (1)
              #define SND_TO (2)
              #define MY_NODE_ID (2)
              #define SND_TO (1)
              // Enable debug
              //#define MY_DEBUG_VERBOSE_NRF5_ESB
              // RF24_250KBPS RF24_1MBPS RF24_2MBPS
              #define MY_RF24_DATARATE (RF24_1MBPS)
              // NRF5_250KBPS NRF5_1MBPS NRF5_2MBPS
              #define MY_NRF5_ESB_MODE (NRF5_1MBPS)
              #ifndef NRF5
              #define MY_RADIO_NRF5_ESB
              #include <nrf.h>
                Serial.println("Starting....");
                Serial.print("MY_NODE_ID=");
                Serial.println(MY_NODE_ID);
                Serial.print("SND_TO=");
                Serial.println(SND_TO);
                if (MY_NODE_ID==2) {
                  NRF_CLOCK->TASKS_HFCLKSTART=1;  //activate the high frequency crystal oscillator
                  while ((NRF_CLOCK->EVENTS_HFCLKSTARTED==0)) {};  //wait until high frequency clock start is confirmed
                hwInit();
                transportInit();
                transportSetAddress(MY_NODE_ID);
              uint32_t theTime=0;
              uint32_t loopCounter=0;
                // Check for packages
                while ((millis()-theTime)<1000) {
                  while (transportAvailable()) {
                    uint8_t buffer[256];
                    uint8_t num = transportReceive(&buffer);
                    Serial.print("Data=");
                    for (int i=0;i<num;i++) {
                      if (buffer[i]<0x10) Serial.print("0");
                      Serial.print(buffer[i], HEX);
                      Serial.print(" ");
                    Serial.println();
                theTime=millis();
                //delay(1000);
                Serial.print(loopCounter++);
                Serial.println(", SENDING:  abcdefghijklmnopqrstuvwxyzabcdefghijklmnopqrstuvwxyz");
                // Send data
                transportSend(SND_TO, "abcdefghijklmnopqrstuvwxyzabcdefghijklmnopqrstuvwxyz",32, false);
                d00616D
                d00616D
                d00616
                You can do this with git on your local machine:
                cd MySensors
                git fetch origin pull/938/head:pr938
                git checkout pr938
                • d00616D d00616
                  cd MySensors
                  git checkout pr938
                  @d00616
                  Thanks for trying. That would probably work with a linux machine, but mine is running Windows. I'm surprised there's no easy way to do this from Windows.
                  I guess I'll just wait for the next developers release of mysensors.
                    #1001
                    For anyone else caught in the same limbo as me, here's a more proper update of the earlier example:
                    #define SND_TO (2)
                    #define SND_TO (1)
                    // Enable debug
                    #ifndef NRF5
                    #include <nrf.h>
                      Serial.flush();
                      #ifdef ARDUINO_ARCH_NRF5
                      hwInit();
                      transportInit();
                    uint32_t theTime=0;
                          Serial.print(loopCounter);
                          Serial.print(", RECEIVED=");
                            Serial.print(" ");
                          Serial.println();
                          Serial.flush();
                      theTime=millis();
                      //delay(1000);
                      Serial.println(", SENDING:  abcdefghijklmnopqrstuvwxyz01234");
                      Serial.println();
                      Serial.flush();
                      // Send data
                      transportSend(SND_TO, "abcdefghijklmnopqrstuvwxyz01234",32, false);
                    The serial output shown by the nRF52 is what you would expect:
                    Starting....
                    MY_NODE_ID=2
                    SND_TO=1
                    0, RECEIVED=61 62 63 64 65 66 67 68 69 6A 6B 6C 6D 6E 6F 70 71 72 73 74 75 76 77 78 79 7A 30 31 32 33 34 00
                    0, SENDING:  abcdefghijklmnopqrstuvwxyz01234
                    1, RECEIVED=61 62 63 64 65 66 67 68 69 6A 6B 6C 6D 6E 6F 70 71 72 73 74 75 76 77 78 79 7A 30 31 32 33 34 00
                    1, SENDING:  abcdefghijklmnopqrstuvwxyz01234
                    2, RECEIVED=61 62 63 64 65 66 67 68 69 6A 6B 6C 6D 6E 6F 70 71 72 73 74 75 76 77 78 79 7A 30 31 32 33 34 00
                    2, SENDING:  abcdefghijklmnopqrstuvwxyz01234
                    3, RECEIVED=61 62 63 64 65 66 67 68 69 6A 6B 6C 6D 6E 6F 70 71 72 73 74 75 76 77 78 79 7A 30 31 32 33 34 00
                    3, SENDING:  abcdefghijklmnopqrstuvwxyz01234
                    However, the serial output of the pro mini often seems to include a 1-byte packet:
                    Starting....
                    MY_NODE_ID=1
                    SND_TO=2
                    2, RECEIVED=41
                    3, RECEIVED=41
                    4, RECEIVED=47
                    4, RECEIVED=61 62 63 64 65 66 67 68 69 6A 6B 6C 6D 6E 6F 70 71 72 73 74 75 76 77 78 79 7A 30 31 32 33 34 00
                    4, SENDING:  abcdefghijklmnopqrstuvwxyz01234
                    5, RECEIVED=46
                    5, RECEIVED=61 62 63 64 65 66 67 68 69 6A 6B 6C 6D 6E 6F 70 71 72 73 74 75 76 77 78 79 7A 30 31 32 33 34 00
                    5, SENDING:  abcdefghijklmnopqrstuvwxyz01234
                    6, RECEIVED=47
                    6, RECEIVED=61 62 63 64 65 66 67 68 69 6A 6B 6C 6D 6E 6F 70 71 72 73 74 75 76 77 78 79 7A 30 31 32 33 34 00
                    6, SENDING:  abcdefghijklmnopqrstuvwxyz01234
                    Is that a bug?
                      @d00616
                      d00616D
                      d00616D
                      d00616
                      wrote on last edited by d00616
                      #1002
                      This depends on Git installed not on Linux. The Pull Request is now into the developer branch.
                      Is that a bug?
                      This is the RSSI value, which is send back as ACK payload. I check what's the best way to deal with.
                        #1003
                        Good news. Thanks to the work of @d00616 on making the ESB transport available, I'm getting very good range using the nRF52832 as a receiver and a pro mini with an inexpensive power amplified nRF24 as the sender, all at 2mbps. :) Not sure if there are yet power amplified nRF52832 available (?), but if not, this does the business.
                        JokgiJ 1 Reply Last reply
                          One thing I do notice though is that the amount of time it takes to send a packet from an nRF24L01 using this ESB transport is pretty long: about 27ms passes between sending one packet and the next packet, and that's running on an ESP8266, which is pretty fast.
                            #1005
                            Looking at the nRF24L01 datasheet (file:///C:/Users/CoolerMaster/Downloads/nRF24L01_Product_Specification_v2_0%20(3).pdf), it appears that one simply needs to keep the TX FIFO full, and the radio will then send things as fast as it can (which should be a lot faster than 27ms). So, I'll give that a try.
                              Oddly enough, in the current mysensors-development release, it takes even longer: 97ms between packets.
                              Nca78N 1 Reply Last reply
                                @NeverDie isn't it because quality of the radio link is bad, and it needs to send each packet many times while waiting for the ACK between each sending ?
                                I'm not sure what/how you measure but if you have many packets in your TX FIFO the next packet is processed only when first packet is acknowledged and removed from FIFO, so if radio link is bad the delays of retransmission will add up while processing the TX FIFO and last packet will be sent only after a "long" delay.
                                When an ACK is successfully received from a PRX, it implies that the payload was successfully received and added to the PRX's RX FIFO, the successfully transmitted packet will be removed from the TX FIFO so that the next packet in the FIFO can be transmitted.
                                  JokgiJ
                                  JokgiJ
                                  Jokgi
                                  @NeverDie check out a Colorado company "Notwired". They have a 832 with a PA however I believe the PA is controlled by the softdevice. Check it out as there may be another way to contol it.
                                    d00616D
                                    d00616D
                                    d00616
                                    If "noACK" is enabled, each packet is send 15 times, which consumes ~27ms. Both NRF24 and NRF5 do the same here.
                                      #1010
                                      Well, there are these:
                                      https://www.aliexpress.com/item/PTR5618PA-Nordic-nRF52832-Module-PA-module-BLE-4-0-Module-Free-shipping/32761051086.html?spm=2114.search0104.3.8.MXhqTf&ws_ab_test=searchweb0_0,searchweb201602_4_10152_10065_10151_10130_5560016_10068_10344_10342_10343_10340_10341_10307_10060_10155_10154_10056_10055_10054_5370016_10059_10534_10533_10532_100031_10099_10338_10339_5580016_10103_10102_10052_10053_10107_10050_10142_10051_10324_10325_9947_10084_513_10083_10080_10082_10081_5590016_10178_10110_10111_10112_10113_10114_143_10312_10314_10078_10079_5570016_10073-9947,searchweb201603_1,ppcSwitch_4&btsid=40a5015f-dcf6-44e1-aba0-2ebedd393fb8&algo_expid=122380a9-0e93-4cf0-b147-38cdf7c5df53-1&algo_pvid=122380a9-0e93-4cf0-b147-38cdf7c5df53
                                      but who knows how well they work. Have to buy 5 just to find out.
                                      In time, I'm sure there will be more available with PA's on them.
                                        #1011
                                        I need to be able to send back-to-back packets from an nRF24L01 in order to guarantee waking up an nRF52832 receiver that's in a "listen mode" but otherwise asleep.
                                          Toyman
                                          @NeverDie have you tried adding ipx antennae to Ebyte module?
                                          Does it help?
                                          Nca78N NeverDieN 2 Replies Last reply
