  3. nRF5 action!
nRF5 action!
    That link lists changes to the files, but it doesn't seem to provide the new files. Or else I'm overlooking where it does?
    You have to checkout this pull request: https://help.github.com/articles/checking-out-pull-requests-locally/
    Maybe I need write-access or something? Those instructions refer to a command line, and I just don't see one anywhere.
    d00616D
    d00616D
    d00616
    You can do this with git on your local machine:
    cd MySensors
    git fetch origin pull/938/head:pr938
    git checkout pr938
    • d00616D d00616
      cd MySensors
      git checkout pr938
      @d00616
      Thanks for trying. That would probably work with a linux machine, but mine is running Windows. I'm surprised there's no easy way to do this from Windows.
      I guess I'll just wait for the next developers release of mysensors.
      d00616D 1 Reply Last reply
        #1001
        For anyone else caught in the same limbo as me, here's a more proper update of the earlier example:
        #define MY_CORE_ONLY
        #ifndef ARDUINO_ARCH_NRF5
        #define MY_NODE_ID (1)
        #define SND_TO (2)
        #define MY_NODE_ID (2)
        #define SND_TO (1)
        // Enable debug
        //#define MY_DEBUG_VERBOSE_NRF5_ESB
        // RF24_250KBPS RF24_1MBPS RF24_2MBPS
        #define MY_RF24_DATARATE (RF24_1MBPS)
        // NRF5_250KBPS NRF5_1MBPS NRF5_2MBPS
        #define MY_NRF5_ESB_MODE (NRF5_1MBPS)
        #ifndef NRF5
        #define MY_RADIO_NRF5_ESB
        #include <nrf.h>
          Serial.println("Starting....");
          Serial.print("MY_NODE_ID=");
          Serial.println(MY_NODE_ID);
          Serial.print("SND_TO=");
          Serial.println(SND_TO);
          Serial.flush();
          #ifdef ARDUINO_ARCH_NRF5
            NRF_CLOCK->TASKS_HFCLKSTART=1;  //activate the high frequency crystal oscillator
            while ((NRF_CLOCK->EVENTS_HFCLKSTARTED==0)) {};  //wait until high frequency clock start is confirmed
          hwInit();
          transportInit();
          transportSetAddress(MY_NODE_ID);
        uint32_t theTime=0;
        uint32_t loopCounter=0;
          // Check for packages
          while ((millis()-theTime)<1000) {
            while (transportAvailable()) {
              uint8_t buffer[256];
              uint8_t num = transportReceive(&buffer);
              Serial.print(loopCounter);
              Serial.print(", RECEIVED=");
              for (int i=0;i<num;i++) {
                if (buffer[i]<0x10) Serial.print("0");
                Serial.print(buffer[i], HEX);
                Serial.print(" ");
              Serial.println();
              Serial.flush();
          theTime=millis();
          //delay(1000);
          Serial.print(loopCounter++);
          Serial.println(", SENDING:  abcdefghijklmnopqrstuvwxyz01234");
          Serial.println();
          Serial.flush();
          // Send data
          transportSend(SND_TO, "abcdefghijklmnopqrstuvwxyz01234",32, false);
        The serial output shown by the nRF52 is what you would expect:
        Starting....
        MY_NODE_ID=2
        SND_TO=1
        0, RECEIVED=61 62 63 64 65 66 67 68 69 6A 6B 6C 6D 6E 6F 70 71 72 73 74 75 76 77 78 79 7A 30 31 32 33 34 00
        0, SENDING:  abcdefghijklmnopqrstuvwxyz01234
        1, RECEIVED=61 62 63 64 65 66 67 68 69 6A 6B 6C 6D 6E 6F 70 71 72 73 74 75 76 77 78 79 7A 30 31 32 33 34 00
        1, SENDING:  abcdefghijklmnopqrstuvwxyz01234
        2, RECEIVED=61 62 63 64 65 66 67 68 69 6A 6B 6C 6D 6E 6F 70 71 72 73 74 75 76 77 78 79 7A 30 31 32 33 34 00
        2, SENDING:  abcdefghijklmnopqrstuvwxyz01234
        3, RECEIVED=61 62 63 64 65 66 67 68 69 6A 6B 6C 6D 6E 6F 70 71 72 73 74 75 76 77 78 79 7A 30 31 32 33 34 00
        3, SENDING:  abcdefghijklmnopqrstuvwxyz01234
        However, the serial output of the pro mini often seems to include a 1-byte packet:
        Starting....
        MY_NODE_ID=1
        SND_TO=2
        2, RECEIVED=41
        3, RECEIVED=41
        4, RECEIVED=47
        4, RECEIVED=61 62 63 64 65 66 67 68 69 6A 6B 6C 6D 6E 6F 70 71 72 73 74 75 76 77 78 79 7A 30 31 32 33 34 00
        4, SENDING:  abcdefghijklmnopqrstuvwxyz01234
        5, RECEIVED=46
        5, RECEIVED=61 62 63 64 65 66 67 68 69 6A 6B 6C 6D 6E 6F 70 71 72 73 74 75 76 77 78 79 7A 30 31 32 33 34 00
        5, SENDING:  abcdefghijklmnopqrstuvwxyz01234
        6, RECEIVED=47
        6, RECEIVED=61 62 63 64 65 66 67 68 69 6A 6B 6C 6D 6E 6F 70 71 72 73 74 75 76 77 78 79 7A 30 31 32 33 34 00
        6, SENDING:  abcdefghijklmnopqrstuvwxyz01234
        Is that a bug?
          @d00616
          d00616D
          d00616D
          d00616
          wrote on last edited by d00616
          #1002
          This depends on Git installed not on Linux. The Pull Request is now into the developer branch.
          Is that a bug?
          This is the RSSI value, which is send back as ACK payload. I check what's the best way to deal with.
            #1003
            Good news. Thanks to the work of @d00616 on making the ESB transport available, I'm getting very good range using the nRF52832 as a receiver and a pro mini with an inexpensive power amplified nRF24 as the sender, all at 2mbps. :) Not sure if there are yet power amplified nRF52832 available (?), but if not, this does the business.
            JokgiJ 1 Reply Last reply
              One thing I do notice though is that the amount of time it takes to send a packet from an nRF24L01 using this ESB transport is pretty long: about 27ms passes between sending one packet and the next packet, and that's running on an ESP8266, which is pretty fast.
                #1005
                Looking at the nRF24L01 datasheet (file:///C:/Users/CoolerMaster/Downloads/nRF24L01_Product_Specification_v2_0%20(3).pdf), it appears that one simply needs to keep the TX FIFO full, and the radio will then send things as fast as it can (which should be a lot faster than 27ms). So, I'll give that a try.
                  Oddly enough, in the current mysensors-development release, it takes even longer: 97ms between packets.
                  Nca78N 1 Reply Last reply
                    @NeverDie isn't it because quality of the radio link is bad, and it needs to send each packet many times while waiting for the ACK between each sending ?
                    I'm not sure what/how you measure but if you have many packets in your TX FIFO the next packet is processed only when first packet is acknowledged and removed from FIFO, so if radio link is bad the delays of retransmission will add up while processing the TX FIFO and last packet will be sent only after a "long" delay.
                    When an ACK is successfully received from a PRX, it implies that the payload was successfully received and added to the PRX's RX FIFO, the successfully transmitted packet will be removed from the TX FIFO so that the next packet in the FIFO can be transmitted.
                      JokgiJ
                      JokgiJ
                      Jokgi
                      @NeverDie check out a Colorado company "Notwired". They have a 832 with a PA however I believe the PA is controlled by the softdevice. Check it out as there may be another way to contol it.
                        d00616D
                        d00616D
                        d00616
                        If "noACK" is enabled, each packet is send 15 times, which consumes ~27ms. Both NRF24 and NRF5 do the same here.
                          #1010
                          Well, there are these:
                          https://www.aliexpress.com/item/PTR5618PA-Nordic-nRF52832-Module-PA-module-BLE-4-0-Module-Free-shipping/32761051086.html?spm=2114.search0104.3.8.MXhqTf&ws_ab_test=searchweb0_0,searchweb201602_4_10152_10065_10151_10130_5560016_10068_10344_10342_10343_10340_10341_10307_10060_10155_10154_10056_10055_10054_5370016_10059_10534_10533_10532_100031_10099_10338_10339_5580016_10103_10102_10052_10053_10107_10050_10142_10051_10324_10325_9947_10084_513_10083_10080_10082_10081_5590016_10178_10110_10111_10112_10113_10114_143_10312_10314_10078_10079_5570016_10073-9947,searchweb201603_1,ppcSwitch_4&btsid=40a5015f-dcf6-44e1-aba0-2ebedd393fb8&algo_expid=122380a9-0e93-4cf0-b147-38cdf7c5df53-1&algo_pvid=122380a9-0e93-4cf0-b147-38cdf7c5df53
                          but who knows how well they work. Have to buy 5 just to find out.
                          In time, I'm sure there will be more available with PA's on them.
                            #1011
                            I need to be able to send back-to-back packets from an nRF24L01 in order to guarantee waking up an nRF52832 receiver that's in a "listen mode" but otherwise asleep.
                              Toyman
                              @NeverDie have you tried adding ipx antennae to Ebyte module?
                              Does it help?
                              Nca78N NeverDieN 2 Replies Last reply
                              • T Toyman
                                Does it help?
                                Does it help?
                                You need to move the tiny cap for that, not easy :)
                                • T Toyman
                                  Does it help?
                                  #1014
                                  Does it help?
                                  Yes, but it made no difference. NCA78's post explains why. So, I guess that connector, which looks so promising, amounts to just marketing bait? i.e. in terms of practicality, it's little more than a decoration? And if so, then which would be a good module to buy if intending to hook up using an ipx? Presumably a module that has only an ipx connector and no other antenna already on it? Which module exactly? I'd like to try it with an eye for use on a gateway.
                                    #1015
                                    By the way, with the latest library, time between packets is now down to around 1ms. I guess there was a favorable change in the library? I'm now not sure if it's that, or something I may have inadvertantly done while mucking around with it.
                                    • U Uhrheber
                                      I just received 2 of those little boards.
                                      Ideal for small sensor nodes, I'd say, but not very breadboard friendly.
                                      So I dug out the verowire, and did a little soldering.
                                      #1016
                                      Looks as though the module itself is missing the SW pinouts. Is that what the two wires you soldered near the chip are for?
                                      U 1 Reply Last reply
                                        Does it help?
                                        I did the change on a PA LNA nrf24 from CDEByte, it was a real pain especially when the module was already soldered and surrounded by connectors. In the end I lost the cap somewhere on my desk and so I replaced it with a 0603 of the same capacity. Not looking great but much easier and it works better with the ipx antenna than with PCB.
                                          From the nRF24L01 datasheet:
                                          The nRF24L01+ transmitter PLL operates in open loop when in TX
                                          mode. It is important never to keep the nRF24L01+ in TX mode for more than 4ms at a time.
                                          So, I guess I won't be able to use the nRF24L01+ for continuous transmits after all. :(
