  3. nRF5 action!
nRF5 action!
    I just now upgraded to the current release of the mysensors development library, and the compile problem went away. So, if anyone else encounters the same problem, I recommend doing that.
    ... At the moment, you have to start the HFCLK in the CORE_ONLY mode. ...
    Do you have a revised sketch which does that? I tried running the sketch you gave above on an nRF52 DK, but it immediately goes into a boot-loop, wherein in keeps rebooting itself, over and over and over again.
    I just now tried running it on a pro-mini using a nRF24, and it also gets into a boot-loop.
    d00616D 1 Reply Last reply
      d00616D
      d00616D
      d00616
      Please replace wait() with delay(). This is an issue in the transport code, which is triggered while sleep() or wait() is executed.
      NeverDieN T 3 Replies Last reply
      • d00616D d00616
        OK, made that change, and it no longer boot-loops.
        However, neither node appears to be receiving anything from the other.
        Please advise.
        • d00616D d00616
          #990
          @d00616
          Since the original code didn't work, I upgraded it somewhat to give a larger Rx window. However, it still doesn't work:
          #define MY_CORE_ONLY
          #ifndef ARDUINO_ARCH_NRF5
          #define MY_NODE_ID (1)
          #define SND_TO (2)
          #define MY_NODE_ID (2)
          #define SND_TO (1)
          // Enable debug
          //#define MY_DEBUG_VERBOSE_NRF5_ESB
          // RF24_250KBPS RF24_1MBPS RF24_2MBPS
          #define MY_RF24_DATARATE (RF24_1MBPS)
          // NRF5_250KBPS NRF5_1MBPS NRF5_2MBPS
          #define MY_NRF5_ESB_MODE (NRF5_1MBPS)
          #ifndef NRF5
          #define MY_RADIO_NRF5_ESB
            Serial.println("Starting....");
            Serial.print("MY_NODE_ID=");
            Serial.println(MY_NODE_ID);
            Serial.print("SND_TO=");
            Serial.println(SND_TO);
            hwInit();
            transportInit();
            transportSetAddress(MY_NODE_ID);
          uint32_t theTime=0;
          uint32_t loopCounter=0;
            // Check for packages
            while ((millis()-theTime)<1000) {
              while (transportAvailable()) {
                uint8_t buffer[256];
                uint8_t num = transportReceive(&buffer);
                Serial.print("Data=");
                for (int i=0;i<num;i++) {
                  if (buffer[i]<0x10) Serial.print("0");
                  Serial.print(buffer[i], HEX);
                  Serial.print(" ");
                Serial.println();
            theTime=millis();
            //delay(1000);
            Serial.print(loopCounter++);
            Serial.println(", SENDING:  abcdefghijklmnopqrstuvwxyzabcdefghijklmnopqrstuvwxyz");
            // Send data
            transportSend(SND_TO, "abcdefghijklmnopqrstuvwxyzabcdefghijklmnopqrstuvwxyz",32, false);
          One node is an nRF24 on a pro mini, and the other is an nRF52832.
            @d00616
            #define SND_TO (2)
            #define SND_TO (1)
            // Enable debug
            #ifndef NRF5
              hwInit();
              transportInit();
            uint32_t theTime=0;
                    Serial.print(" ");
                  Serial.println();
              theTime=millis();
              //delay(1000);
              // Send data
            d00616D
            d00616D
            d00616
            wrote on last edited by d00616
            #991
            Please add this to your setup() function (https://forum.mysensors.org/topic/6961/nrf5-bluetooth-action/985):
            	// Clock is manged by sleep modes. Radio depends on HFCLK.
            	// Force to start HFCLK
            	NRF_POWER->TASKS_CONSTLAT = 1;
            	// Enable cache on >= NRF52
            #ifndef NRF51
            	NRF_NVMC->ICACHECNF = NVMC_ICACHECNF_CACHEEN_Msk;
            At the moment I prepare a new Pull Request fixing this including some small fixes and improvements for nRF5 MCUs. When it's integrated the HFCLK is startet in hwInit().
            • d00616D d00616
              Toyman
              @d00616 is this universal recommendation?
              • T Toyman
                d00616D
                d00616D
                d00616
                I think you mean to start the HFCLK. This isn't a universal recommendation. At the moment the HFCLK is started in MyMainNRF5.cpp. This file is ignored in CORE_ONLY mode. I moved any initialization code into hwInit().
                • d00616D d00616
                  #ifndef NRF51
                  d00616D
                  d00616D
                  d00616
                  The Pull Request is available: https://github.com/mysensors/MySensors/pull/938
                  • d00616D d00616
                    That link lists changes to the files, but it doesn't seem to provide the new files. Or else I'm overlooking where it does?
                      d00616D
                      d00616D
                      d00616
                      You have to checkout this pull request: https://help.github.com/articles/checking-out-pull-requests-locally/
                      • d00616D d00616
                        Maybe I need write-access or something? Those instructions refer to a command line, and I just don't see one anywhere.
                          Well, anyway, I added code to start the high frequency clock, and now it seems to work:
                          #define SND_TO (2)
                          #define SND_TO (1)
                          // Enable debug
                          #ifndef NRF5
                          #include <nrf.h>
                            if (MY_NODE_ID==2) {
                              NRF_CLOCK->TASKS_HFCLKSTART=1;  //activate the high frequency crystal oscillator
                              while ((NRF_CLOCK->EVENTS_HFCLKSTARTED==0)) {};  //wait until high frequency clock start is confirmed
                            hwInit();
                            transportInit();
                          uint32_t theTime=0;
                                  Serial.print(" ");
                                Serial.println();
                            theTime=millis();
                            //delay(1000);
                            // Send data
                            d00616D
                            d00616D
                            d00616
                            You can do this with git on your local machine:
                            cd MySensors
                            git fetch origin pull/938/head:pr938
                            git checkout pr938
                            • d00616D d00616
                              cd MySensors
                              git checkout pr938
                              @d00616
                              Thanks for trying. That would probably work with a linux machine, but mine is running Windows. I'm surprised there's no easy way to do this from Windows.
                              I guess I'll just wait for the next developers release of mysensors.
                                #1001
                                For anyone else caught in the same limbo as me, here's a more proper update of the earlier example:
                                #define SND_TO (2)
                                #define SND_TO (1)
                                // Enable debug
                                #ifndef NRF5
                                #include <nrf.h>
                                  Serial.flush();
                                  #ifdef ARDUINO_ARCH_NRF5
                                  hwInit();
                                  transportInit();
                                uint32_t theTime=0;
                                      Serial.print(loopCounter);
                                      Serial.print(", RECEIVED=");
                                        Serial.print(" ");
                                      Serial.println();
                                      Serial.flush();
                                  theTime=millis();
                                  //delay(1000);
                                  Serial.println(", SENDING:  abcdefghijklmnopqrstuvwxyz01234");
                                  Serial.println();
                                  Serial.flush();
                                  // Send data
                                  transportSend(SND_TO, "abcdefghijklmnopqrstuvwxyz01234",32, false);
                                The serial output shown by the nRF52 is what you would expect:
                                Starting....
                                MY_NODE_ID=2
                                SND_TO=1
                                0, RECEIVED=61 62 63 64 65 66 67 68 69 6A 6B 6C 6D 6E 6F 70 71 72 73 74 75 76 77 78 79 7A 30 31 32 33 34 00
                                0, SENDING:  abcdefghijklmnopqrstuvwxyz01234
                                1, RECEIVED=61 62 63 64 65 66 67 68 69 6A 6B 6C 6D 6E 6F 70 71 72 73 74 75 76 77 78 79 7A 30 31 32 33 34 00
                                1, SENDING:  abcdefghijklmnopqrstuvwxyz01234
                                2, RECEIVED=61 62 63 64 65 66 67 68 69 6A 6B 6C 6D 6E 6F 70 71 72 73 74 75 76 77 78 79 7A 30 31 32 33 34 00
                                2, SENDING:  abcdefghijklmnopqrstuvwxyz01234
                                3, RECEIVED=61 62 63 64 65 66 67 68 69 6A 6B 6C 6D 6E 6F 70 71 72 73 74 75 76 77 78 79 7A 30 31 32 33 34 00
                                3, SENDING:  abcdefghijklmnopqrstuvwxyz01234
                                However, the serial output of the pro mini often seems to include a 1-byte packet:
                                Starting....
                                MY_NODE_ID=1
                                SND_TO=2
                                2, RECEIVED=41
                                3, RECEIVED=41
                                4, RECEIVED=47
                                4, RECEIVED=61 62 63 64 65 66 67 68 69 6A 6B 6C 6D 6E 6F 70 71 72 73 74 75 76 77 78 79 7A 30 31 32 33 34 00
                                4, SENDING:  abcdefghijklmnopqrstuvwxyz01234
                                5, RECEIVED=46
                                5, RECEIVED=61 62 63 64 65 66 67 68 69 6A 6B 6C 6D 6E 6F 70 71 72 73 74 75 76 77 78 79 7A 30 31 32 33 34 00
                                5, SENDING:  abcdefghijklmnopqrstuvwxyz01234
                                6, RECEIVED=47
                                6, RECEIVED=61 62 63 64 65 66 67 68 69 6A 6B 6C 6D 6E 6F 70 71 72 73 74 75 76 77 78 79 7A 30 31 32 33 34 00
                                6, SENDING:  abcdefghijklmnopqrstuvwxyz01234
                                Is that a bug?
                                  @d00616
                                  d00616D
                                  d00616D
                                  d00616
                                  #1002
                                  This depends on Git installed not on Linux. The Pull Request is now into the developer branch.
                                  Is that a bug?
                                  This is the RSSI value, which is send back as ACK payload. I check what's the best way to deal with.
                                    #1003
                                    Good news. Thanks to the work of @d00616 on making the ESB transport available, I'm getting very good range using the nRF52832 as a receiver and a pro mini with an inexpensive power amplified nRF24 as the sender, all at 2mbps. :) Not sure if there are yet power amplified nRF52832 available (?), but if not, this does the business.
                                    JokgiJ 1 Reply Last reply
                                      One thing I do notice though is that the amount of time it takes to send a packet from an nRF24L01 using this ESB transport is pretty long: about 27ms passes between sending one packet and the next packet, and that's running on an ESP8266, which is pretty fast.
                                        #1005
                                        Looking at the nRF24L01 datasheet (file:///C:/Users/CoolerMaster/Downloads/nRF24L01_Product_Specification_v2_0%20(3).pdf), it appears that one simply needs to keep the TX FIFO full, and the radio will then send things as fast as it can (which should be a lot faster than 27ms). So, I'll give that a try.
                                          Oddly enough, in the current mysensors-development release, it takes even longer: 97ms between packets.
                                          Nca78N 1 Reply Last reply
