  3. 💬 NodeManager
💬 NodeManager
contest2017arduinonewbiemysensorsbattery sensor
196 Posts 42 Posters 116.9k Views 41 Watching
  • G graham86
    @user2684 I have looked at the changes in https://github.com/mysensors/NodeManager/pull/174 which incorporates an alternative improved implementation for the _LoadConfig/_SaveConfig functions (interesting that using an intermediate union requires less code than my shifting version- presumably due to differences in the way the GCC optimiser works for an AVR target).
    I spotted a coupld of minor points and was also able to further reduce the code size.
    Firstly as we are writing C++ rather than C the declaration of the union should just be
    // Local union used to split _sleep_time into bytes
    union tLongByteArrayCombo{
    long long_value;
    uint8_t byte_array[4];
    (The typedef systax, although valid C++ is unnecessary - a simple union declaration is sufficient.)
    There is also a typo - the original had a member called byte_arrray instead of byte_array.
    You can also save 24 bytes of code by avoiding the use of a local union variable and simply aliasing _sleep_time as the union type. So instead of _load_config doing -
    tLongByteArrayCombo c;
    c.byte_array[0] = loadState(EEPROM_SLEEP_1);
    c.byte_array[1] = loadState(EEPROM_SLEEP_2);
    c.byte_array[2] = loadState(EEPROM_SLEEP_3);
    c.byte_array[3] = 0;
    _sleep_time = c.long_value;
    You can do
    (((tLongByteArrayCombo&)_sleep_time).byte_array )[0] = loadState(EEPROM_SLEEP_1);
    (((tLongByteArrayCombo&)_sleep_time).byte_array )[1] = loadState(EEPROM_SLEEP_2);
    (((tLongByteArrayCombo&)_sleep_time).byte_array )[2] = loadState(EEPROM_SLEEP_3);
    (((tLongByteArrayCombo&)_sleep_time).byte_array )[3] = 0;
    And in _save_config instead of
    c.long_value = _sleep_time;
    saveState(EEPROM_SLEEP_1, c.byte_array[0]);
    saveState(EEPROM_SLEEP_2, c.byte_array[1]);
    saveState(EEPROM_SLEEP_3, c.byte_array[2]);
    you can use
    saveState(EEPROM_SLEEP_1, (((tLongByteArrayCombo&)_sleep_time).byte_array )[0] );
    saveState(EEPROM_SLEEP_2, (((tLongByteArrayCombo&)_sleep_time).byte_array )[1] );
    saveState(EEPROM_SLEEP_3, (((tLongByteArrayCombo&)_sleep_time).byte_array )[2] );
    In my specific sample sketch I had the following code sizes
    Original NodeManager.cpp 28242 Bytes
    NodeManager with patch from pull rq 174 - 28154 Bytes (saving of 88 Bytes of code(
    Patched NodeManager with additional changes above - 28130 Bytes ( saving another 24 Bytes of code)
    U
    U
    user2684
    @graham86 I guess you are referring to https://github.com/mysensors/NodeManager/pull/217, not 174, am I wrong? Anyway, any contribution that would help saving bytes is more than welcome: NodeManager is becoming more and more complex and the situations where we are out of storage start increasing so we definitely need to save whatever wherever we can :-) Regarding what you are proposing above, keep on eye on PR #217; once a new one dedicated to this part of the code will be created as discussed there, feel free to add your own PR to that branch or just let me know and I'll do it for you. Thanks!
    • U user2684
      @vikasjee sorry my bad, I think I couldn't understand your suggestion :) Do you have an example to let me understand better? thanks and sorry again, I'm sure I'm missing something somewhere :)
      V
      V
      vikasjee
      wrote on last edited by vikasjee
      #120
      @user2684, Sorry, couldn't revert to your query earlier as i was away building a small library.
      Expanding onto my earlier post on the requested Power Management feature -
      A simple switch will complete a circuit whenever its switched ON. This allows for placing the switch on the ground return wire too. So only a single GND-ON (Switched ON) will complete the circuit (without requiring an additional Vcc-ON switch).
      Now, with a developer configured #DEFINE GND_ON_POWER =1 may be checked in NodeManager's PowerManagement functions to DigitalWrite(Digital_GND_ON_Pin, LOW)
      for a switchON effect.
      Additionally, To provide an extra current to a sensor (i.e. more than a ~10mA-20mA, a max safe current provided by an Arduino pin) an external power source (other than Arduino +5V0 OR +3V3) may be provided by that external power source (of course with with a common ground wire between Arduino and that powersource to complete the circuit.)
      Also, with the current 2Wire PowerOn methodology, the VccPowerOn switch can provide only one positive voltage (that provided by Arduino Vcc, say +5V0) but not +3V3 (say) to the sensors. If some attached sensors require the other voltage (+3V3), then, this 2Wire PowerOn method will not help. Whereas, a single GND_On power methodology will still switch the circuit thus managing the Power to those sensors too.
      [PS: Signal Voltage Levels will still need to be managed by the developer attaching those sensors to the node]
      I think this simple feature will add on to the power of the PowerManagement functions.
      Hope this clears some air ? Open to suggestions...
      U 1 Reply Last reply
      • V vikasjee
        U
        U
        user2684
        @vikasjee thanks all clear now! I'll track this with https://github.com/mysensors/NodeManager/issues/224. Thanks again for the detailed explanation!
        • U
          U
          user2684
          Hello all, just to let you know when compiling against the latest version of the mysensors 2.2.0-beta library, NodeManager will crash on startup, just after presenting the mysensors logo. Thanks @gohan for pointing this out! Root cause is still unknown but when MY_DEBUG is defined, the crash doesn't take place (https://github.com/mysensors/NodeManager/issues/223)
          V 1 Reply Last reply
          • U user2684
            V
            V
            vikasjee
            @user2684, Can we have a quick hot fix?
            • V vikasjee
              U
              U
              user2684
              @vikasjee sure, as soon as I'll be able to understand the reason why it crashes when MY_DEBUG is not defined :-( if somebody from the core team has any hit, would be really appreciated!
              • Sergio RiusS
                Sergio RiusS
                Sergio Rius
                #125
                I'm afraid that issue 223 is not a NodeManager failure. I can reproduce it in a new sketch without using NodeManager.
                Other issue with MySensors are, NRF24 doesn't link with controller.
                If MY_DEBUG_VERBOSE_RF24 is defined, it automagically works.
                • Sergio RiusS Sergio Rius
                  V
                  V
                  vikasjee
                  @Sergio-Rius, with RF24_VERBOSE on, the system crashes in 40-50 seconds especially if you're connected to the serial monitor or if your serial gateway has this #DEFINE on.
                  • V vikasjee
                    Sergio RiusS
                    Sergio RiusS
                    Sergio Rius
                    Still more strange, suddenly started to work properly on 2/3 of my testing nodes. That killed me.
                    What about the gateways you are using? And the controllers?
                    • F
                      F
                      FredRoot
                      I'm having trouble with the motion sample code. I have changed the setSleepHours(1) command to setSleepMinutes(1). I understand that the sensor will send a hart beat every 1 min. This is working fine for the hart beat, but evertime the hart beat is send the sensor sends a Trigger messages as well even though the sensor is not triggered. I thought that maybe there is a power dip and that it might cause the PIR (RS501) to send a interrupt, but I have removed the setSleepMinutes command and replaced it with a setBatteryReportHours(1) command. This command is send correctly and the sensor only sends the trigger command when the PIR is triggered. Did anyone have a similar issue?
                      Attached is the sensor debug output when the setSleepMinutes command is used:
                      40 MCO:BGN:BFR
                      REG I=1 P=3 P=1 T=16
                      NodeManager v1.6
                      LIB V=2.1.1 R=N T=N A=A S=- B=-
                      INT P=3 M=1
                      INT P=2 M=255
                      96 TSM:INIT
                      176 TSF:WUR:MS=0
                      198 TSM:INIT:TSP OK
                      219 TSM:INIT:STATID=3
                      243 TSF:SID:OK,ID=3
                      264 TSM:FPAR
                      313 TSF:MSG:SEND,3-3-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      385 TSF:MSG:READ,0-0-3,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                      440 TSF:MSG:FPAR OK,ID=0,D=1
                      2387 TSM:FPAR:OK
                      2404 TSM:ID
                      2418 TSM:ID:OK
                      2433 TSM:UPL
                      2449 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                      2521 TSF:MSG:READ,0-0-3,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                      2578 TSF:MSG:PONG RECV,HP=1
                      2607 TSM:UPL:OK
                      2625 TSM:READY:ID=3,PAR=0,DIS=1
                      2660 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                      2734 TSF:MSG:READ,0-0-3,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                      2797 TSF:MSG:SEND,3-3-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
                      2875 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                      2945 TSF:MSG:READ,0-0-3,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                      RADIO OK
                      3004 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=11,pt=0,l=11,sg=0,ft=0,st=OK:NodeManager
                      3096 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
                      PRES I=200, T=23
                      3170 TSF:MSG:SEND,3-3-0-0,s=200,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=OK:
                      PRES I=201, T=30
                      3260 TSF:MSG:SEND,3-3-0-0,s=201,c=0,t=30,pt=0,l=0,sg=0,ft=0,st=OK:
                      BATT V=3.30 P=100
                      SEND D=0 I=201 C=0 T=38 S= I=0 F=3.30
                      3418 !MCO:SND:NODE NOT REG
                      3506 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:100
                      PRES I=1 T=1
                      3579 TSF:MSG:SEND,3-3-0-0,s=1,c=0,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
                      READY
                      3659 MCO:REG:REQ
                      3688 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                      3760 TSF:MSG:READ,0-0-3,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                      3817 MCO:PIM:NODE REG=1
                      3842 MCO:BGN:STP
                      MY I=3 M=1
                      3860 MCO:BGN:INIT OK,TSP=1
                      SLEEP 60s
                      3901 MCO:SLP:MS=60000,SMS=1,I1=1,M1=1,I2=255,M2=255
                      3971 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=OK:127
                      4544 MCO:SLP:TPD
                      4560 MCO:SLP:WUP=1
                      INT P=3, M=1
                      AWAKE
                      SWITCH I=1 P=3 V=1
                      SEND D=0 I=1 C=0 T=16 S= I=1 F=0.00
                      4597 TSF:MSG:SEND,3-3-0-0,s=1,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:1
                      SLEEP 60s
                      4732 MCO:SLP:MS=60000,SMS=1,I1=1,M1=1,I2=255,M2=255
                      4800 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=OK:956
                      5376 MCO:SLP:TPD
                      5392 MCO:SLP:WUP=1
                      INT P=3, M=1
                      AWAKE
                      SWITCH I=1 P=3 V=0
                      SEND D=0 I=1 C=1 T=16 S= I=0 F=0.00
                      5429 TSF:MSG:SEND,3-3-0-0,s=1,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:0
                      SLEEP 60s
                      5564 MCO:SLP:MS=60000,SMS=1,I1=1,M1=1,I2=255,M2=255
                      5632 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=OK:1787
                      6207 MCO:SLP:TPD
                      6223 MCO:SLP:WUP=-1
                      AWAKE
                      SLEEP 60s
                      6246 MCO:SLP:MS=60000,SMS=1,I1=1,M1=1,I2=255,M2=255
                      6322 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=OK:2478
                      6897 MCO:SLP:TPD
                      6914 MCO:SLP:WUP=1
                      INT P=3, M=1
                      AWAKE
                      SWITCH I=1 P=3 V=1
                      SEND D=0 I=1 C=1 T=16 S= I=1 F=0.00
                      6950 TSF:MSG:SEND,3-3-0-0,s=1,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:1
                      SLEEP 60s
                      7086 MCO:SLP:MS=60000,SMS=1,I1=1,M1=1,I2=255,M2=255
                      7153 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=OK:3309
                      7729 MCO:SLP:TPD
                      7745 MCO:SLP:WUP=1
                      INT P=3, M=1
                      AWAKE
                      SWITCH I=1 P=3 V=0
                      7782 TSF:MSG:SEND,3-3-0-0,s=1,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:0
                      SLEEP 60s
                      7917 MCO:SLP:MS=60000,SMS=1,I1=1,M1=1,I2=255,M2=255
                      7985 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=OK:4141
                      8560 MCO:SLP:TPD
                      8577 MCO:SLP:WUP=-1
                      AWAKE
                      SLEEP 60s
                      8599 MCO:SLP:MS=60000,SMS=1,I1=1,M1=1,I2=255,M2=255
                      8675 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=OK:4831
                      9252 MCO:SLP:TPD
                      9269 MCO:SLP:WUP=1
                      INT P=3, M=1
                      AWAKE
                      SWITCH I=1 P=3 V=1
                      9306 TSF:MSG:SEND,3-3-0-0,s=1,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:1
                      SLEEP 60s
                      9441 MCO:SLP:MS=60000,SMS=1,I1=1,M1=1,I2=255,M2=255
                      9508 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=OK:5664
                      10084 MCO:SLP:TPD
                      10102 MCO:SLP:WUP=1
                      INT P=3, M=1
                      AWAKE
                      SWITCH I=1 P=3 V=0
                      10139 TSF:MSG:SEND,3-3-0-0,s=1,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:0
                      SLEEP 60s
                      10274 MCO:SLP:MS=60000,SMS=1,I1=1,M1=1,I2=255,M2=255
                      10344 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=OK:6500
                      10921 MCO:SLP:TPD
                      • F FredRoot
                        40 MCO:BGN:BFR
                        NodeManager v1.6
                        INT P=3 M=1
                        INT P=2 M=255
                        96 TSM:INIT
                        176 TSF:WUR:MS=0
                        198 TSM:INIT:TSP OK
                        243 TSF:SID:OK,ID=3
                        264 TSM:FPAR
                        2387 TSM:FPAR:OK
                        2404 TSM:ID
                        2418 TSM:ID:OK
                        2433 TSM:UPL
                        2607 TSM:UPL:OK
                        RADIO OK
                        PRES I=200, T=23
                        PRES I=201, T=30
                        BATT V=3.30 P=100
                        PRES I=1 T=1
                        READY
                        3659 MCO:REG:REQ
                        3842 MCO:BGN:STP
                        MY I=3 M=1
                        SLEEP 60s
                        4544 MCO:SLP:TPD
                        4560 MCO:SLP:WUP=1
                        INT P=3, M=1
                        AWAKE
                        SWITCH I=1 P=3 V=1
                        SLEEP 60s
                        5376 MCO:SLP:TPD
                        5392 MCO:SLP:WUP=1
                        INT P=3, M=1
                        AWAKE
                        SWITCH I=1 P=3 V=0
                        SLEEP 60s
                        6207 MCO:SLP:TPD
                        6223 MCO:SLP:WUP=-1
                        AWAKE
                        SLEEP 60s
                        6897 MCO:SLP:TPD
                        6914 MCO:SLP:WUP=1
                        INT P=3, M=1
                        AWAKE
                        SWITCH I=1 P=3 V=1
                        SLEEP 60s
                        7729 MCO:SLP:TPD
                        7745 MCO:SLP:WUP=1
                        INT P=3, M=1
                        AWAKE
                        SWITCH I=1 P=3 V=0
                        SLEEP 60s
                        8560 MCO:SLP:TPD
                        8577 MCO:SLP:WUP=-1
                        AWAKE
                        SLEEP 60s
                        9252 MCO:SLP:TPD
                        9269 MCO:SLP:WUP=1
                        INT P=3, M=1
                        AWAKE
                        SWITCH I=1 P=3 V=1
                        SLEEP 60s
                        10084 MCO:SLP:TPD
                        10102 MCO:SLP:WUP=1
                        INT P=3, M=1
                        AWAKE
                        SWITCH I=1 P=3 V=0
                        SLEEP 60s
                        10921 MCO:SLP:TPD
                        U
                        U
                        user2684
                        @FredRoot this is weird, from the logs looks like there is kind of a floating interrupt (alternatively 1 and 0). The strange thing is that the interrupt is coming from the call to mysensors' sleep() function which is returning a positive number corresponding to the interrupt linked to pin 3 instead of a negative value like it should after a sleeping cycle. Anybody else experiencing this behavior with NodeManager v1.6? thanks
                          mvader
                          wrote on last edited by mvader
                          #130
                          @user2684 can you add support for the Si7021 sensor as found in sensebender micro?
                          also, 2nd question.
                          how do i register a sensor that is onboard?
                          you ask for a child id and pin that it's on. but if it's an onboard sensor. how do you make that work? just omit the pin?
                          • M mvader
                            also, 2nd question.
                            U
                            U
                            user2684
                            @mvader for question #1, I've added it to the existing issue https://github.com/mysensors/NodeManager/issues/221. For question #2, for sensors using i2c the pin is not required despite within the code nodemanager will set a random pin (have a look at SensorSHT21 for example)
                            • U user2684
                              mvader
                              @user2684 said in 💬 NodeManager:
                              great.. thank you!
                              • U
                                U
                                user2684
                                After a few months working behind the scene, NodeManager got kind of a full review in terms of architecture and usability. The code should be now simpler to understand for new users, the memory utilization has been optimized and the overall user experience has been improved.
                                The looooong list of things that have been changed are detailed on https://github.com/mysensors/NodeManager/pull/229.
                                Please note this is only available in the development branch (https://github.com/mysensors/NodeManager/tree/development) and will be generally available only when NodeManager's v1.7 will be released (it will take I guess still a few months).
                                Since this change was blocking other pending changes, I hope now the development will be faster and feel free to submit your PRs now that the new architecture has been finalized.
                                As always, any feedback is more than welcome.
                                • R
                                  R
                                  reinhold
                                  @user2684 Thanks a lot for the architecture change, which makes a lot of sense conceptually.
                                  Unfortunately, it appears to use more memory than before. I'm working on an air quality board with eight MQ sensors, an MH-Z19 CO2 sensor and a Plantower PMSA003 particulate matter sensor. In previous development versions (1.7-dev, before today), the eight MQ sensors and the MH-Z19 worked fine, but now after your big merge of #229 the sketch appears to run out of memory after adding the child of the sixth MQ sensor. Do you see any chance to optimize for memory?
                                  Old sketch (using a previous development version of NodeManager, without the PMSA003; 155 bytes left after all nine sensors are fully initialized): https://github.com/open-tools/NodeManager_GasSensor/tree/master/NodeManager_GasSensor
                                  New sketch (using the latest version of NodeManager, plus a PMSA003): https://github.com/kainhofer/NodeManager/tree/GasSensor
                                  That sketch runs out of memory with the sixth MQ sensor (I added debug output with free memory at a lot of spots). Of course, I have commented out the PMSA003 completely to have a correct comparison.
                                  FWIW, the sketch is for this board: https://github.com/open-tools/NodeManager_GasSensor/blob/master/images/IMAG2267.jpg
                                  Nca78N mfalkviddM U 3 Replies Last reply
                                  • R reinhold
                                    @reinhold if you have high memory requirement, what about switching to a more modern architecture like stm32f103c8t6 on the famous "blue pill" boards ? It has 20k or RAM (10 times what you have on Arduino) and 64k of flash and it's supported by MySensors, in addition to be very cheap (2$/board). You will need voltage converter between 3.3V of the board and 5V of your sensors but that's not a big deal in exchange of the possibility to expand your board with more sensors in the future.
                                    R 1 Reply Last reply
                                    • R reinhold
                                      @reinhold not sure how much this applies to NodeManager, but there are some recomendations for reducing memory footprint at https://www.mysensors.org/apidocs-beta/group__memorysavings.html
                                      • Nca78N Nca78
                                        R
                                        R
                                        reinhold
                                        @nca78 Thanks for the suggestion to use the blue pill STM32 boards. I haven't thought of it (I only looked at the ESP8266, but that has only one ADC). I have a few lying around here, but never got around to trying them, as I first need to burn the bootloader. It looks quite promising, but the boards are huge, so I'll need to enlarge my PCB...
                                        The need for a 5V->3.3V regulator is no issue, as the NRF24 already needs 3.3V. The 5V analog level of the MQ sensors will need some converter (the analog ADC inputs are marked as non-5V-tolerant...), but then in turn I can get rid of the voltage dividers for the PMSA003. The larger issue seems to be the connection of the nrf24, which takes away 4 ADC pins, so there are only 6 ADC pins left, while I have 8 analog sensors :(
                                        Still, for now I have the PCBs with the ProMini, so I'll try to strip down the Sensor or SensorMQ classes for my own use.
                                        • R
                                          R
                                          reinhold
                                          @nca78 Two more things popped up with the latest development version of NodeManager:
                                          • In NodeManager.ino: function void before(): The sample code to set the child id of a child is sht.children.get(1)->child_id = 5, but that does not work, because at that point the children are not yet even generated. They are created by the node.before(); call at the very end of the function... So, currently this will not assign any new child ID and the default IDs will be used. I have not checked in detail whether calling node.before() at the beginning of the before() function and then assigning child_id to the children will solve the issue. From a quick look at the code, it might work...
                                          • I'm trying to implement an OLED display, where the node would wake up every 5 seconds, take a measurement and display it on the OLED. But the report interval to the MySensors gateway should only be 10 minutes. I thought that
                                            node.setSleepSeconds(5); node.setReportIntervalMinutes(10); would be the correct way to setup NodeManager to take measurements every 5 seconds, but only report it every 10 minutes to the network. Unfortunately, Sensor::loop(MyMessage* message) seems to immediately return without measurement if the reporting timer has not elapsed. Somehow I don't understand that logic. Why have different sleep and reporting intervals when measurements will only be taken at reporting intervals anyway? I would expect measurements to be taken with the sleep intervals (e.g. to calculate an average over the whole reporting interval) and report back to the network using report intervals.
