  3. Problems with sensor node
12 Posts 3 Posters 3.6k Views 3 Watching
    bad nrf24 modules? I've been there too with cheap stuff
    henninneH 1 Reply Last reply
      henninneH
      henninneH
      henninne
      @gohan
      Ok, Thanks for the tip, but I testes 3 different radios, even from two different sellers. Tips on where can I buy a good one?
        I ordered some from https://www.aliexpress.com/store/2077046 but they are still on the way.
        Can you post a picture of the modules you got?
        • henninneH
          henninneH
          henninne
          I bought from eBay, some from the UK and some from Germany. I will try to take a picture
          • henninneH
            henninneH
            henninne
              manutremo
              @henninne said in Problems with sensor node:
              It might be many different things but definetely related to the radio... The modules should at least initialize unless they are completely fried. Another thing is getting them to "talk" to each other but that's another story. Check that everything is connected correctly, the wires are correct, etc. You may also post your sketch ad a photo of your hardware and connections in case we can see something weird...
              You may also try to start simpler, by using some test example from some of the multiple libraries around, especially on GitHub, like this one.
              In terms of itnerpreting the log, you can use the incredibly useful log parser here.
              Additional troubleshooting: here.
                According to log there is no communication with the chip, so either bad wiring/power or chip fried
                  manutremo
                  I've had nrf24 modules of all sorts, even the blob type, and had to go through many many problems until i got them working. But all of them except for 2 were able to initialize. Of the two that didn't, one of them I fried it myself by connecting it incorrectly, and the other one had a broken track so that the MISO pin was not reaching the corresponding pin on the nrf24 chip.
                  So while I agree that from the provided information this looks like a bad wiring or a fried chip, the fact that he has tried 3 different radios from different sellers seems to infer that it might still be worth trying to help the OP go through some troubleshooting - which in turn is how most of us have learnt most of what we know today while building our first sensors.
                  By the way henninne - you have replaced the arduino board and the radio... have you tried completely replacing all the wires? I've found some of them that were not correctly crimped (even though bought "ready to use") and causing false contacts.
                  • henninneH
                    henninneH
                    henninne
                    @manutremo said in Problems with sensor node:
                    OP
                    Ok guys, thanks for all the tips so far. I checked again all wiring and tested the connection with a multimeter and yes, it looks like one of the "ready to use" cables was faulty. So I removed the crimp cables and soldered on wires and now it looks like it works at least. Now I only have the node connected to the PC (gateway is not available), so does this serial monitor print look correct? I have loaded some simple Door/window sensor sketch, why isn't the digital pin state show up in the serial monitor? Does it have to be connected to the gateway?
                    3 TSM:INIT
                    4 TSF:WUR:MS=0
                    11 TSM:INIT:TSP OK
                    12 TSM:FPAR
                    15 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    2022 !TSM:FPAR:NO REPLY
                    2024 TSM:FPAR
                    2026 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    4034 !TSM:FPAR:NO REPLY
                    4036 TSM:FPAR
                    4038 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    6046 !TSM:FPAR:NO REPLY
                    6048 TSM:FPAR
                    6050 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    8058 !TSM:FPAR:FAIL
                    8059 TSM:FAIL:CNT=1
                    8061 TSM:FAIL:PDT
                    18065 TSM:FAIL:RE-INIT
                    18067 TSM:INIT
                    18074 TSM:INIT:TSP OK
                    18076 TSM:FPAR
                    18078 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    20086 !TSM:FPAR:NO REPLY
                    20088 TSM:FPAR
                    20090 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    22099 !TSM:FPAR:NO REPLY
                    22102 TSM:FPAR
                    22104 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    24112 !TSM:FPAR:NO REPLY
                    24114 TSM:FPAR
                    24116 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    26124 !TSM:FPAR:FAIL
                    26125 TSM:FAIL:CNT=2
                    26127 TSM:FAIL:PDT
                    36130 TSM:FAIL:RE-INIT
                    36132 TSM:INIT
                    36140 TSM:INIT:TSP OK
                    36142 TSM:FPAR
                    36144 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    38152 !TSM:FPAR:NO REPLY
                    38154 TSM:FPAR
                    38156 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    40164 !TSM:FPAR:NO REPLY
                    40166 TSM:FPAR
                    40168 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    42176 !TSM:FPAR:NO REPLY
                    42178 TSM:FPAR
                    42180 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    44188 !TSM:FPAR:FAIL
                    44189 TSM:FAIL:CNT=3
                    44191 TSM:FAIL:PDT
                    54194 TSM:FAIL:RE-INIT
                    54196 TSM:INIT
                    54203 TSM:INIT:TSP OK
                    54205 TSM:FPAR
                    54207 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    56215 !TSM:FPAR:NO REPLY
                    56217 TSM:FPAR
                    56219 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    58227 !TSM:FPAR:NO REPLY
                    58229 TSM:FPAR
                    58231 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    60239 !TSM:FPAR:NO REPLY
                    60241 TSM:FPAR
                    60243 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    62252 !TSM:FPAR:FAIL
                    62253 TSM:FAIL:CNT=4
                    62255 TSM:FAIL:PDT
                    72258 TSM:FAIL:RE-INIT
                    72260 TSM:INIT
                    72267 TSM:INIT:TSP OK
                    72269 TSM:FPAR
                    72271 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    74280 !TSM:FPAR:NO REPLY
                    74283 TSM:FPAR
                    74285 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    76293 !TSM:FPAR:NO REPLY
                    76295 TSM:FPAR
                    76297 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    78305 !TSM:FPAR:NO REPLY
                    78307 TSM:FPAR
                    78309 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      wrote on last edited by gohan
                      That is correct. When the node is not connected to gateway, the rest of the code is not executed until the connection is established. If you look into examples there is a MockMysensor sketch that you can use to simulate some nodes sending data
                        henninneH
                        henninneH
                        henninne
                        @gohan
                        Cool thanks! Then I will try when I have the gateway available.
