  3. nRF5 action!
nRF5 action!
  • T Toyman
    @NeverDie have you tried adding ipx antennae to Ebyte module?
    Does it help?
    Does it help?
    You need to move the tiny cap for that, not easy :)
    • T Toyman
      Does it help?
      #1014
      Does it help?
      Yes, but it made no difference. NCA78's post explains why. So, I guess that connector, which looks so promising, amounts to just marketing bait? i.e. in terms of practicality, it's little more than a decoration? And if so, then which would be a good module to buy if intending to hook up using an ipx? Presumably a module that has only an ipx connector and no other antenna already on it? Which module exactly? I'd like to try it with an eye for use on a gateway.
      Nca78N 1 Reply Last reply
        #1015
        By the way, with the latest library, time between packets is now down to around 1ms. I guess there was a favorable change in the library? I'm now not sure if it's that, or something I may have inadvertantly done while mucking around with it.
        • U Uhrheber
          I just received 2 of those little boards.
          Ideal for small sensor nodes, I'd say, but not very breadboard friendly.
          So I dug out the verowire, and did a little soldering.
          #1016
          Looks as though the module itself is missing the SW pinouts. Is that what the two wires you soldered near the chip are for?
          U 1 Reply Last reply
            Does it help?
            I did the change on a PA LNA nrf24 from CDEByte, it was a real pain especially when the module was already soldered and surrounded by connectors. In the end I lost the cap somewhere on my desk and so I replaced it with a 0603 of the same capacity. Not looking great but much easier and it works better with the ipx antenna than with PCB.
              From the nRF24L01 datasheet:
              The nRF24L01+ transmitter PLL operates in open loop when in TX
              mode. It is important never to keep the nRF24L01+ in TX mode for more than 4ms at a time.
              So, I guess I won't be able to use the nRF24L01+ for continuous transmits after all. :(
                Looks as though maybe this nRF52832 module would not require modification in order to use the IPX?
                https://www.aliexpress.com/item-img/1pcs-NRF52832-Bluetooth-module-M4-kernel-Bluetooth-4-1BLE-module/32821473149.html?spm=2114.10010108.1000017.2.2d1f5eccJxyODh
                  #1020
                  So, I just did what NCA78 inspired me to do: resoldered the capacitor to enable the IPX connector. The results? It is an improvement, and I can see the difference at the margin, but still nothing like the 20dbi of the amplified modules. Not surprising. So, I guess I'll try to find one of those as either an nRF52832 or an nRF51822, and give that a try.
                  JokgiJ U 3 Replies Last reply
                    JokgiJ
                    JokgiJ
                    Jokgi
                    @Toyman there are both 5v and 3vdc available on the DK. You can use that to power the board. But that is not VTG line. That line just lets the DK know it has a target board out there and that the voltage is about 3vdc. (There are no voltage levelers on the board)
                      Didn't find much. So, I ordered this:
                      https://www.aliexpress.com/item/NRF51822-PA-LNA-remote-Bluetooth-4-module-transparent-serial-UART-sphygmomanometer-program/32818019202.html?spm=2114.search0104.3.16.FI9Dyt&ws_ab_test=searchweb0_0,searchweb201602_5_10152_10065_10151_10130_10068_10344_10342_10343_10340_10341_5560012_10307_10060_10155_10154_10056_5370012_10055_10054_10059_10534_10533_10532_100031_10099_10338_10339_10103_10102_5580012_10052_10053_10107_10050_10142_10051_10324_10325_10084_513_10083_10080_10082_10081_10178_10110_10111_10112_10113_5590012_10114_143_10312_10314_5570012_10078_10079_10073,searchweb201603_25,ppcSwitch_5&btsid=85a7f5aa-077c-4499-8f02-1a3a17ca6e74&algo_expid=347478fd-3b90-441e-9a58-e5018c973274-2&algo_pvid=347478fd-3b90-441e-9a58-e5018c973274
                        JokgiJ
                        JokgiJ
                        Jokgi
                        wrote on last edited by Jokgi
                        #1023
                        @NeverDie Hi, Do you know how they are pulling in the PA on these nRF52832 modules? I see many people using the device in Proprietary mode. There is no hardware line like with the nRF24L & the nRF518xx devices.. (VDD_PA) The nRF52832 uses the Softdevice to control a external PA using GPIOs.. You can see them on this block diagram from the Notwired module . There will be a PA out soon from a new company called OctoTech that has a internal RF sense switch included in the part. This will make a straight PA design much easier. 0_1507048264084_Notwired nRF52832 module.JPG
                        • Nca78N Nca78
                          Does it help?
                          Toyman
                          @Nca78 :-) it's like on Pi zero where you need to relocate an ultra tiny resistor. Definitely, beyond my smd skills.
                          • JokgiJ Jokgi
                            #1025
                            Good question! I'm assuming that it's simply active 100% of the time. Maybe that's why it's advertised as a PA module rather than a PA + LNA module. Even the silkscreen just says PA, with no mention of LNA. Or, since it's just PA, maybe it's controlled by the CE pin to turn it on/off(?).
                            I feel a bit sheepish buying it with a ceramic antenna, but, well, there's just not much in the way of alternatives right now. There was this though:
                            https://www.aliexpress.com/item/Free-shipping-NRF51822-pa-Bluetooth-module-external-pillars-antenna-CC2540-undertaking-Bluetooth-Project/32458170451.html?spm=2114.search0204.3.2.8gtlmf&ws_ab_test=searchweb0_0,searchweb201602_4_10152_10065_10151_10130_5560016_10068_10344_10342_10343_10340_10341_10307_10060_10155_10154_10056_10055_10054_5370016_10059_10534_10533_10532_100031_10099_10338_10339_5580016_10103_10102_10052_10053_10107_10050_10142_10051_10324_10325_10084_513_10083_10080_10082_10081_5590016_10178_10110_10111_10112_10113_10114_143_10312_10314_10078_10079_5570016_10073,searchweb201603_17,ppcSwitch_4_ppcChannel&btsid=bb691308-6a6f-4156-b00c-1ead48bef348&algo_expid=f9b3f79a-0b94-4799-9c7d-f9f55f552603-0&algo_pvid=f9b3f79a-0b94-4799-9c7d-f9f55f552603
                            which is maybe better in that regard.
                            I think for a gateway, it would indeed be preferable to have a PA+LNA module. I see the PA-only module as being possibly useful in a handheld remote controller that's basically Tx only.
                              #1026
                              That NotWired device does sound very nice, but at $89 each, I guess it really needs to be!
                              https://www.notwired.co/ProductDetail/CNRF52SKY66112-NotWired-CO/605602/
                              If the price were lower, I'd definitely get one. Nice to know it exists though.
                              @Nca78 How much is the OctoTech module supposed to be priced at? Any indications?
                              JokgiJ 1 Reply Last reply
                                #1027
                                This module looks quite interesting: it appears to have two sets of antennas! It claims to offer some kind of antenna diversity:
                                https://www.aliexpress.com/item/nRF52832-LNA-PA-Range-Extension-EV-Board-best-sol-for-the-coming-Bluetooth-5-0-and/32778491443.html?ws_ab_test=searchweb0_0,searchweb201602_5_10152_10065_10151_10130_10068_10344_10342_10343_10340_10341_5560012_10307_10060_10155_10154_10056_5370012_10055_10054_10059_10534_10533_10532_100031_10099_10338_10339_10103_10102_5580012_10052_10053_10107_10050_10142_10051_10324_10325_10084_513_10083_10080_10082_10081_10178_10110_10111_10112_10113_5590012_10114_143_10312_10314_5570012_10078_10079_10073,searchweb201603_25,ppcSwitch_5&btsid=893e31a3-e668-41b9-862b-ec85db388059&algo_expid=439c9797-3287-4608-b652-5bcf1936fbb5-0&algo_pvid=439c9797-3287-4608-b652-5bcf1936fbb5
                                If it performed up to its advertised specs, it would make for one heck of a great gateway!
                                • T Toyman
                                  #1028
                                  I had the same concern, but it turns out that even a clumsy solder job seems to work just fine:
                                  I was most concerned that I might create a short, so the tombstone bridge proved to me that wouldn't happen.
                                    Not sure if this thing would work, but maybe?
                                    https://www.amazon.com/gp/product/B01B94U438/ref=od_aui_detailpages00?ie=UTF8&psc=1
                                      JokgiJ
                                      JokgiJ
                                      Jokgi
                                      @NeverDie This module is based on the nRF52832 and a RF AXIS PA (now purchased by Skyworks) . I happen to have one of the first prototypes. This design worked great! . Note the blue wires attached to the 32khz crystal which was later mounted on the board.. Laughing a bit here. . 0_1507066044000_Nordic - RFX.jpg
                                        JokgiJ
                                        JokgiJ
                                        Jokgi
                                        @NeverDie I believe that the Notwired price you mentioned was for the full dev kit board with RF module.
                                        The Octotech device is not out in the market yet. I don't think they will be making production modules. Probably will have dev kits and then looking for module manufactures to produce modules with their part. 0_1507066567924_8TR8210 Product Brief RevA3.2.pdf
                                        • JokgiJ Jokgi
                                          Cool! Anyone selling it now besides Aliexpress?
