  3. nRF5 action!
nRF5 action!
    #1020
    So, I just did what NCA78 inspired me to do: resoldered the capacitor to enable the IPX connector. The results? It is an improvement, and I can see the difference at the margin, but still nothing like the 20dbi of the amplified modules. Not surprising. So, I guess I'll try to find one of those as either an nRF52832 or an nRF51822, and give that a try.
    JokgiJ U 3 Replies Last reply
      JokgiJ
      JokgiJ
      Jokgi
      @Toyman there are both 5v and 3vdc available on the DK. You can use that to power the board. But that is not VTG line. That line just lets the DK know it has a target board out there and that the voltage is about 3vdc. (There are no voltage levelers on the board)
        Didn't find much. So, I ordered this:
        https://www.aliexpress.com/item/NRF51822-PA-LNA-remote-Bluetooth-4-module-transparent-serial-UART-sphygmomanometer-program/32818019202.html?spm=2114.search0104.3.16.FI9Dyt&ws_ab_test=searchweb0_0,searchweb201602_5_10152_10065_10151_10130_10068_10344_10342_10343_10340_10341_5560012_10307_10060_10155_10154_10056_5370012_10055_10054_10059_10534_10533_10532_100031_10099_10338_10339_10103_10102_5580012_10052_10053_10107_10050_10142_10051_10324_10325_10084_513_10083_10080_10082_10081_10178_10110_10111_10112_10113_5590012_10114_143_10312_10314_5570012_10078_10079_10073,searchweb201603_25,ppcSwitch_5&btsid=85a7f5aa-077c-4499-8f02-1a3a17ca6e74&algo_expid=347478fd-3b90-441e-9a58-e5018c973274-2&algo_pvid=347478fd-3b90-441e-9a58-e5018c973274
          JokgiJ
          JokgiJ
          Jokgi
          wrote on last edited by Jokgi
          #1023
          @NeverDie Hi, Do you know how they are pulling in the PA on these nRF52832 modules? I see many people using the device in Proprietary mode. There is no hardware line like with the nRF24L & the nRF518xx devices.. (VDD_PA) The nRF52832 uses the Softdevice to control a external PA using GPIOs.. You can see them on this block diagram from the Notwired module . There will be a PA out soon from a new company called OctoTech that has a internal RF sense switch included in the part. This will make a straight PA design much easier. 0_1507048264084_Notwired nRF52832 module.JPG
          • Nca78N Nca78
            @NeverDie have you tried adding ipx antennae to Ebyte module?
            Does it help?
            You need to move the tiny cap for that, not easy :)
            Toyman
            @Nca78 :-) it's like on Pi zero where you need to relocate an ultra tiny resistor. Definitely, beyond my smd skills.
            • JokgiJ Jokgi
              #1025
              Good question! I'm assuming that it's simply active 100% of the time. Maybe that's why it's advertised as a PA module rather than a PA + LNA module. Even the silkscreen just says PA, with no mention of LNA. Or, since it's just PA, maybe it's controlled by the CE pin to turn it on/off(?).
              I feel a bit sheepish buying it with a ceramic antenna, but, well, there's just not much in the way of alternatives right now. There was this though:
              https://www.aliexpress.com/item/Free-shipping-NRF51822-pa-Bluetooth-module-external-pillars-antenna-CC2540-undertaking-Bluetooth-Project/32458170451.html?spm=2114.search0204.3.2.8gtlmf&ws_ab_test=searchweb0_0,searchweb201602_4_10152_10065_10151_10130_5560016_10068_10344_10342_10343_10340_10341_10307_10060_10155_10154_10056_10055_10054_5370016_10059_10534_10533_10532_100031_10099_10338_10339_5580016_10103_10102_10052_10053_10107_10050_10142_10051_10324_10325_10084_513_10083_10080_10082_10081_5590016_10178_10110_10111_10112_10113_10114_143_10312_10314_10078_10079_5570016_10073,searchweb201603_17,ppcSwitch_4_ppcChannel&btsid=bb691308-6a6f-4156-b00c-1ead48bef348&algo_expid=f9b3f79a-0b94-4799-9c7d-f9f55f552603-0&algo_pvid=f9b3f79a-0b94-4799-9c7d-f9f55f552603
              which is maybe better in that regard.
              I think for a gateway, it would indeed be preferable to have a PA+LNA module. I see the PA-only module as being possibly useful in a handheld remote controller that's basically Tx only.
                #1026
                That NotWired device does sound very nice, but at $89 each, I guess it really needs to be!
                https://www.notwired.co/ProductDetail/CNRF52SKY66112-NotWired-CO/605602/
                If the price were lower, I'd definitely get one. Nice to know it exists though.
                @Nca78 How much is the OctoTech module supposed to be priced at? Any indications?
                JokgiJ 1 Reply Last reply
                  #1027
                  This module looks quite interesting: it appears to have two sets of antennas! It claims to offer some kind of antenna diversity:
                  https://www.aliexpress.com/item/nRF52832-LNA-PA-Range-Extension-EV-Board-best-sol-for-the-coming-Bluetooth-5-0-and/32778491443.html?ws_ab_test=searchweb0_0,searchweb201602_5_10152_10065_10151_10130_10068_10344_10342_10343_10340_10341_5560012_10307_10060_10155_10154_10056_5370012_10055_10054_10059_10534_10533_10532_100031_10099_10338_10339_10103_10102_5580012_10052_10053_10107_10050_10142_10051_10324_10325_10084_513_10083_10080_10082_10081_10178_10110_10111_10112_10113_5590012_10114_143_10312_10314_5570012_10078_10079_10073,searchweb201603_25,ppcSwitch_5&btsid=893e31a3-e668-41b9-862b-ec85db388059&algo_expid=439c9797-3287-4608-b652-5bcf1936fbb5-0&algo_pvid=439c9797-3287-4608-b652-5bcf1936fbb5
                  If it performed up to its advertised specs, it would make for one heck of a great gateway!
                  • T Toyman
                    #1028
                    I had the same concern, but it turns out that even a clumsy solder job seems to work just fine:
                    I was most concerned that I might create a short, so the tombstone bridge proved to me that wouldn't happen.
                      Not sure if this thing would work, but maybe?
                      https://www.amazon.com/gp/product/B01B94U438/ref=od_aui_detailpages00?ie=UTF8&psc=1
                        JokgiJ
                        JokgiJ
                        Jokgi
                        @NeverDie This module is based on the nRF52832 and a RF AXIS PA (now purchased by Skyworks) . I happen to have one of the first prototypes. This design worked great! . Note the blue wires attached to the 32khz crystal which was later mounted on the board.. Laughing a bit here. . 0_1507066044000_Nordic - RFX.jpg
                          JokgiJ
                          JokgiJ
                          Jokgi
                          @NeverDie I believe that the Notwired price you mentioned was for the full dev kit board with RF module.
                          The Octotech device is not out in the market yet. I don't think they will be making production modules. Probably will have dev kits and then looking for module manufactures to produce modules with their part. 0_1507066567924_8TR8210 Product Brief RevA3.2.pdf
                          • JokgiJ Jokgi
                            Cool! Anyone selling it now besides Aliexpress?
                            • JokgiJ Jokgi
                              I wish that were so, but it just doesn't look that way to me. It seems that the dev board that could go with it is sold separately, and is another $95:
                              https://www.notwired.co/ProductDetail/CWSEPARD-notWired-co/606027/
                                Dang, I just noticed that this board has a FEMALE ipx connector on it:
                                https://www.aliexpress.com/store/product/1pcs-NRF52832-Bluetooth-module-M4-kernel-Bluetooth-4-1BLE-module/2629039_32821473149.html
                                At least the Ebyte module has a male ipx on it, which seems much more common.
                                  JokgiJ
                                  JokgiJ
                                  Jokgi
                                  @NeverDie If that is the case then I kind of limits their clientele a bit.
                                    I just received 2 of those little boards.
                                    Ideal for small sensor nodes, I'd say, but not very breadboard friendly.
                                    So I dug out the verowire, and did a little soldering.
                                    Looks as though the module itself is missing the SW pinouts. Is that what the two wires you soldered near the chip are for?
                                    U
                                    U
                                    Uhrheber
                                    Exactly. There are two pads labelled SWD and SWC, originally meant for pogo pins.
                                    I patched them with wires to the pin header.
                                    Programming with a Chinese STLink V2 clone works flawlessly.
                                      U
                                      U
                                      Uhrheber
                                      What antenna did you use?
                                      It doesn't make so much sense to replace the internal 1-2dBi Antenna with an external 2-3dBi one.
                                      Most small WiFi antennas are simply crap.
                                      Also, 2.4GHz is a frequency so useless, that not even the radio amateurs wanted it. They have 2.3GHz.
                                      At 2.4GHz, you may achieve a range of kilometers if you have a free sight, but not even penetrate a single wall with the same setup.
                                      • U Uhrheber
                                        #1038
                                        I used an antenna that I temorarily removed from an ASUS router. I don't know what it's gain is supposed to be. However, I had similar thoughts, so yesterday I ordered this from amazon:
                                        https://www.amazon.com/gp/product/B073SWWMRG/ref=od_aui_detailpages00?ie=UTF8&psc=1
                                        which claims a 9db gain. It should arrive tomorrow. It's not really ideal, because it has to go through three connections (first the IPX connection and then an SMA connection and then finally the antenna connection), whereas it would be preferable to just have one connection so as to have less insertion loss. I'd be interested if you have any suggestions for something even better.
                                        • U Uhrheber
                                          Here's a photo of it:
