  2. Bug Reports
  3. NRF24L01+ problems in 2.1.1 and 2.2.0 Beta
49 Posts 9 Posters 17.1k Views 12 Watching
    I remember there was a bug in the library for rpi2 but I can't remember the details
    W
    W
    wergeld
    @gohan That bug had to do with the chipset but that was resolved i think.
      @miljume said in NRF24L01+ problems in 2.1.1 and 2.2.0 Beta:
      ./configure --my-transport=nrf24
      ./configure --my-gateway=ethernet --my-port=5003
      it should be on a single line like this
      ./configure --my-transport=nrf24 --my-gateway=ethernet --my-port=5003
      --my-controller-ip-address=127.0.0.1 is not needed
      miljumeM
      miljumeM
      miljume
      @gohan Now I have tried compiling it with one line command but the GW still don't start with 2.1.1
      mysgw: Starting gateway...
      mysgw: TSM:INIT
      mysgw: TSF:WUR:MS=0
      mysgw: !TSM:INIT:TSP FAIL
      mysgw: TSM:FAIL:CNT=1
      mysgw: TSM:FAIL:PDT
      • miljumeM miljume
        mysgw: TSM:INIT
        mysgw: TSF:WUR:MS=0
        mysgw: TSM:FAIL:PDT
        @miljume I see alternating !TSM:INIT:TSP Fail and TSM:INIT:TSP OK in your logs.
        The fails indicate a failure to communicate with the radio module.
        Is there a pattern in these fails between software versions?
        miljumeM 1 Reply Last reply
        • YveauxY Yveaux
          miljumeM
          miljumeM
          miljume
          wrote on last edited by miljume
          @Yveaux The FAIL´s all occur with 2.1.1 and the OK is with 2.2.0 Beta. Same radio connections for both so the FAIL´s should not be connected to communication with the radio module. I have also tried 3 radios and 2 different ways of connecting them (Shield and Dupont cables) Even if 2.2.0 starts OK the problem is that it for the Ethernet GW it fails to connect
          mysgw: MCO:BGN:INIT GW,CP=RNNGL---,VER=2.2.0-beta
          mysgw: TSF:LRT:OK
          mysgw: TSM:INIT
          mysgw: TSF:WUR:MS=0
          mysgw: TSM:INIT:TSP OK
          mysgw: TSM:INIT:GW MODE
          mysgw: MCO:REG:NOT NEEDED
          mysgw: failed to connect
          mysgw: Eth: connect
          mysgw: Eth: connect
          And for the Serial GW it gives the following error in Domoticz
          2017-10-10 18:43:07.538 MySensors: Using serial port: /dev/ttyUSB020
          2017-10-10 18:43:07.538 Error: Serial Port closed!... Error: End of file
          2017-10-10 18:43:08.538 MySensors: retrying in 30 seconds...
          None of them picks up sensor reports
            Do you have a spare microsd and try a clean install ?
              miljumeM
              miljumeM
              miljume
              @gohan I have tried a clean install both with Rapbian Stretch and Raspbian Jessie but the results are the same
                Did you check if spi is enabled in configuration? Sorry for stupid questions, but I need to broaden the search for the issue
                W miljumeM 2 Replies Last reply
                  W
                  W
                  wergeld
                  @gohan, I can only speak for me but I have done the following on my RPi 2 B:
                  Changed out radios
                  Used shield for radio or just straight wiring to radio
                  New flash of latest minimal Raspbian
                  Enabled SPI
                  And various combinations of those. Maybe something broke in an update to Raspbian or some other change to the mysensors repo?
                    miljumeM
                    miljumeM
                    miljume
                    @gohan Yes, otherwise it fails already during build
                    • A
                      arraWX
                      • A
                        arraWX
                        wrote on last edited by arraWX
                        #24
                        With 2.1.1 I have the exact same problems.
                        However, everything seems to be fine with 2.2.0 Beta:
                        git clone https://github.com/mysensors/MySensors.git --branch development
                        cd MySensors
                        ./configure --my-transport=nrf24 --my-gateway=ethernet --my-port=5003 --my-rf24-pa-level=RF24_PA_MAX
                        make
                        In domoticz:
                        The result:
                        mysgw: TSF:LRT:OK
                        mysgw: TSM:INIT
                        mysgw: TSF:WUR:MS=0
                        mysgw: MCO:BGN:STP
                        mysgw: MCO:BGN:INIT OK,TSP=1
                        mysgw: TSF:MSG:READ,2-2-0,s=1,c=1,t=0,pt=7,l=5,sg=0:24.0
                        mysgw: TSF:MSG:READ,2-2-0,s=2,c=1,t=1,pt=2,l=2,sg=0:58
                        After success with 2.2.0 Beta I tried to go back to 2.1.1. However, it still does not work.
                        I am on rpi3 and use a socket adapter board for the radio.
                        • W
                          W
                          wergeld
                          So, I did a lot of re-configuring and using 2.2.0 beta when a node sends a value payload (in my case a temp/humidity/battery value I get this while running my RPi ethernet gateway in debug:
                          mysgw: TSF:MSG:READ,3-3-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                          mysgw: TSF:MSG:BC
                          mysgw: TSF:MSG:FPAR REQ,ID=3
                          mysgw: TSF:CKU:OK,FCTRL
                          mysgw: TSF:MSG:GWL OK
                          mysgw: !TSF:MSG:SEND,0-0-3-3,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                          mysgw: TSF:MSG:BC
                          This continues until I kill the process. In the middle of all of these error messages though, it also reports client PING events:
                          Other interesting items of note:
                          Domoticz says the values for temp have not been updated for 3+ hours for that node.
                          Domoticz says that node only has a temp sensor.
                          MYSController reports it having 2 sensors (temp and humidity) and it reports the values when i would expect them to be sent (ie, not 3+ hours old but updated continuously when temp changes).
                          I am at my wits end here.
                            NACK on the gateway usually means that the radio module is not powered correctly or there is a range issue (or you didn't set max tx power on the gateway)
                            W 1 Reply Last reply
                            • W
                              W
                              wergeld
                              This is getting odder and odder.
                              I am running 2.2.1 beta on my RPi2B. It is running on channel 76, with power max, and using ethernet gateway config.
                              I have MYSController running on separate laptop and it is seeing updates to temp/hum and/or battery level. However, neither Domoticz or OpenHab2 have seen a change since last night at 9pm.
                              In Domoticz - Setup - Hardware - Mysensors 2.2.0 Gateway it shows 2 nodes. First node is the gateway, of course, and the second is the sensor node. The data and the last seen times are correct! But, the Domoticz - Setup - Device list only shows the Temp sesnor and a last seen date of last night at 9pm. There are not other mysensors devices available.
                              So, what is different between MYSControler and Domoticz and OpenHab?
                                W
                                W
                                wergeld
                                @gohan This doesnt really make sense to me. This happens after I get data from a sensor and the gateway gets stuck in a loop of those messages. MYSControler shows the correct value that triggered these messages while OpenHab and Domoticz do not.
                                  Do you have capacitors on the radio modules? If you move the node closer to the gateway (3/4 meters apart) , does it work better?
                                    W
                                    W
                                    wergeld
                                    @gohan Yes, capacitors on both the node(s) and the gateway radios. Moving the nodes closer to gateway has no affect. The gateway is sending out udpates (per MYSControler at least) but Domoticz sees no new devices and OpenHab has not seen an update either. So frustrating.
                                      Try to stop the gateway and run it with debug from console and c'è if you see any NACK occurring, also on the node if you can, because probably the controller is not accepting messages with NACK. If you can, try to make another arduino based gateway and see if you still get same errors. Keep in mind that if radio modules are not genuine you have to consider they are the cause of your problems.
                                        W
                                        W
                                        wergeld
                                        @gohan unable to run my node in debug with radio attached at the moment (no 3.3v FTDI or mosfets available right now).
                                        But, that being said - the MYSControler does get the updated values. Just not Domoticz or OpenHab. So, why does one client connecting to the gateway get data while the other two do not?
                                          Myscontroller doesn't see all debug messages. Get a ftdi adapter quickly 😁
