  3. nRF5 action!
nRF5 action!
1.9k Posts 49 Posters 2.1m Views 44 Watching
    Nonetheless, I just now measured the sleep current on the cheap nRF51822 that @NCA78 referenced:
    https://www.aliexpress.com/item/NRF51822-04-BLE4-0-Wireless-Bluetooth-Module-TTL-Low-Power-Consumption-3-3V-New/32821044213.html?aff_platform=aaf&cpt=1507850033284&sk=e2Vzr3v&aff_trace_key=fa8ec197f200446fbd58fc8679ffb3bd-1507850033284-07709-e2Vzr3v&terminal_id=29bfb7ff18284b7f96acb3c3884390ce
    It measures at 5ua, which is higher than the 2.1ua of the nRF52832, but still not bad in absolute terms. I was afraid after the discussion of how some nrf51's had a 1ma bug in the hardware that they would be counted among them. Fortunately, it seems not. :)
    JokgiJ
    JokgiJ
    Jokgi
    @NeverDie The nRF51 is done on a different process then then the nRF52. The nRF52 is on average 50% lower power then the nRF51. The picture of the module shows a nRF51822QFAA Hx part which is a 256k flash, 16k Ram part REV 3. You can see all the revision number here: http://infocenter.nordicsemi.com/topic/com.nordic.infocenter.nrf51/dita/nrf51/compatibility_matrix/nRF51822_ic_revision_overview.html?cp=3_0_1
      I was just checking the nRF51 datasheet, and I don't see much, if any, PPI control available. So, I suppose that's yet another reason for preferring the nRF52....
      JokgiJ
      JokgiJ
      Jokgi
      @NeverDie You may wish to check out the nRF51 Reference guide in addition to the datasheet. http://infocenter.nordicsemi.com/pdf/nRF51_RM_v3.0.1.pdf The PPI is located in section 16.
      • JokgiJ Jokgi
        Thanks! Doesn't look as though the nRF51822's PPI allows for FORK though, whereas the nRF52832 does.
          Guys,
          Have you seen this?
          Note, that our beloved ebyte is not there, but PTR9618PA is
          It's useful. But just knowing the module exists is one thing. Finding a source for it is another.
          Toyman
          @NeverDie actually, I am suprised that many of these modules are available and at the prices lower than Ali.
          For example:
          http://www.fanstel.com/buy/bt832xe
          They claim "BT832XE is the longest range Bluetooth 5 module, 1350 meters between 2 BT832XE with used with ANT060 antenna."
          $23, shipped within US
          Not bad, ah?
          • U
            U
            Uhrheber
            One must be aware, that the gain of an antenna doesn't come from a magic amplification, but from direction.
            Meaning, the higher the gain of an antenna is, the more directional it is.
            For a sensor, let's say a window switch, that may end up in every mounting position you might imagine, this is NOT what you want.
            Neither do you want that for the gateway, that may be in the middle of the house, and should be able to receive transmissions from all directions.
            • U Uhrheber
              #1140
              @Uhrheber
              It does look like they also have a PA on their module: http://www.fanstel.com/bt832x-bluetooth-5-module/
              It's a good find, as it looks as though they have a lot to choose from: http://www.fanstel.com/buy/
              Also, as compared to the chinese vendors, I think it's more likely that they really did pass FCC, since it's based in the US. The fines to US companies for selling non-compliant stuff are pretty severe (enough to bankrupt a small company), whereas (it seems) the chinese vendors can dodge it. Hence, the joke that "CE" stands for "Chinese Exemption".
                @Uhrheber
                Toyman
                @NeverDie exactly! On top, they have very extensive datasheet with all the results
                  #1142
                  I just now noticed that fanstel is selling an nRF52840 module: http://www.fanstel.com/buy/bt840f-v1-nrf52840-bluetooth-5-thread-zigbee-module
                  That's the first I've seen on the open market (aside from the DK that is). [Edit: won't be shipping until January though]
                  I wonder which, if any, of the Fanstel modules contain the DCDC hardware? Their pinout on the 832's does not appear to be as complete as the Ebyte module, so if DCDC is not already on the module, it might be impossible to add after-the-fact.
                  T JokgiJ 2 Replies Last reply
                    Toyman
                    https://static1.squarespace.com/static/561459a2e4b0b39f5cefa12e/t/59a5a0bbbe42d6d26bd82969/1504026813812/BlueNor_BT840F_datasheets.pdf
                    Page 13,
                    pin F5
                    • T Toyman
                      Page 13,
                      pin F5
                      #1144
                      @Toyman Thanks! I'm going to order a couple of the Nordic nRF52840 PDK's to audition now that modules are on the horizon. Shall be interesting to see how the range compares in a normal home environment. Also, 256K RAM and 1M of flash sounds like such a luxury!
                        JokgiJ
                        JokgiJ
                        Jokgi
                        @NeverDie Note that all the nRF52840 based products being showcased now (including the Fanstel modules) are using the engineering silicon. There is Errata on these parts. Production devices will be available Q1-18.
                        • JokgiJ Jokgi
                          Do you advise waiting, or is it sufficiently non-buggy that it's likely to work unless doing something obscure?
                            #1147
                            @d00616 Problem #1 is that there does not yet appear to be an Arduino board definition for the nR5F2840, as there is already for the nRF52832 and nRF51822. Is that correct? Or does one already exist somewhere? It's critical path to testing code on the nRF52840 PDK.
                              #1148
                              Hmmm... Looks like there is an nRF52840 "variant": https://github.com/lpercifield/arduino-nRF5/commit/d55d54a1bdc479acc259e131f0f445c5da8e02b3
                              Would that work? If so, how exactly should it be added so that it will appear in the Arduino IDE board manager list of boards?
                                Toyman
                                wrote on last edited by Toyman
                                #1149
                                @NeverDie the main issue it's "65 commits behind master" so it's outdated in all areas except 840
                                Theoretical path is to make a fork of current sandeep's branch and then merge the changes from the repository you found. But given the above, it won't be easy.
                                  #1150
                                  Gosh, I'm wishing now that I hadn't ordered the PDK. I guess I'll just return it for a refund. Since it sounds like literally no one else is presently using the 840, I'd rather move forward on the 832. I'm more interested in the 2mbps datarate anyway (for the reason below). And I'm pretty sure PA versions of the nRF52832 will beat the range of an unamplified nRF52840.
                                  scalzS 1 Reply Last reply
                                  • d00616D d00616
                                    Now listening every 100ms yields a 10F supercap voltage measured decline of just 9mv per hour. i.e. a decline of 0.108v by the end of 12 hours.
                                    Great job. If I'm not wrong the method allows nearly 1 year of listening time with a CR2032.
                                    #1151
                                    Yup, based on the latest measurements, I estimate an average current drain of about 25 microamps. So, assuming a CR2032 has 240mah of useable current, that comes out to about 1.1 years of listening time. Or more than 13 years on a pair of Energizer Lithium AA's. Pretty cool. :) And that's listening for a packet once every 100ms. It could last much longer if it were to listen less often.
                                      #1152
                                      I looked at the fanstel modules a while ago, but like guys said above, these are beta mcus with errata. And not arduino uptodate for the same reason i guess.
                                      I have one 840pdk too. for tests :) with apache mynewt. Because I have only one 840 board I can't tell you about the range because it needs two boards for checking that, two boards with full BLE5 Long range (and 832 is not BLE5 full range).
                                      No idea about 840 vs 832+PA but 840 is already PA integrated which is pretty cool. It also has some other nice features. Range tests regarding BLE5 long range are impressive imho, indoor or not, and from different mcu manufacturers (some have nice parts).
                                      I'm not sure though, if 840, is compatible with NRF24. And, as I'm talking about BLE, I prefer to say it again, for others.. BLE is not MySensors :)
                                        Are there any examples of how to control the potential BLE5 capabilities of this chip using code developed in the Arduino IDE? I recognize that it's presently a separate thing from MySensors, which is using the proprietary modes to ensure backward compatability to the nRF24, but surely getting some hooks into BLE5--even if it's just high level stuff--would be beneficial wouldn't it?
                                          #1154
                                          For instance, how hard would it be to create a simple serial bridge so view serial output on your bluetooth phone, the way @sundberg84 is doing with a specialized bluetooth module: https://forum.mysensors.org/topic/6340/debug-to-a-sd-card-module
                                          d00616D 1 Reply Last reply
