  2. Announcements
  3. 💬 Temperature Sensor
171 Posts 40 Posters 106.6k Views 36 Watching
  • skywatchS
    skywatchS
    skywatch
    OK I'll do that - seems to be sending battery info every minute still though- strange!
    • skywatchS skywatch
      #132
      @skywatch could you post the entire sketch also, to check if something fishy has crept in?
      • skywatchS
        skywatchS
        skywatch
        Here is the sketch, debug will be later today I hope....
        #define MY_RF24_PA_LEVEL (RF24_PA_LOW)
        #define MAX_ATTACHED_DS18B20 3
        #include <OneWire.h>
        int batteryPcnt = 0;
        unsigned long SLEEP_TIME = 2 * 60 * 1000; // 2 minutes Sleep time between reads.
        int numSensors = 0;
        const long interval = 90000;
        unsigned long previousMillis = 0;
        bool receivedConfig = false;
        bool metric = true;
        unsigned int batteryReportFactor = 30*60*1000/SLEEP_TIME; // Only report battery every x SLEEP times (x=15 with current values)
        unsigned int timesSlept = 0;
        MyMessage msg(0, V_TEMP);
        void before()
          sensors.begin();
          analogReference(INTERNAL);
          sendSketchInfo("HW/CH", "0.5");
          for (int i = 0; i < numSensors && i < MAX_ATTACHED_DS18B20; i++) {
            present(i, S_TEMP);
          // get the battery Voltage
          if (timesSlept < batteryReportFactor) {
            timesSlept++;
            timesSlept = 0;
            batteryPcnt = sensorValue / 10;
          sleep(conversionTime);
            float temperature = static_cast<float>(static_cast<int>((getControllerConfig().isMetric ? sensors.getTempCByIndex(i) : sensors.getTempFByIndex(i)) * 10.)) / 10.;
        #if COMPARE_TEMP == 1
              send(msg.setSensor(i).set(temperature, 1));
              lastTemperature[i] = temperature;
          int8_t sleep(1, FALLING, SLEEP_TIME);
          int numSensors = 0;
          bool metric = true;
          void before()
            sensors.begin();
              present(i, S_TEMP);
              timesSlept++;
              timesSlept = 0;
          @skywatch code looks good to me. What type of Arduino are you using?
          • skywatchS
            skywatchS
            skywatch
            #135
            I am using a pro mini 3.3v 8MHz. I would ideally like to get a 1MHZ bootloader onto it but the last try stopped the temperature sensors sending data (although battery levels were still sent!)..... Hope it helps.
              @skywatch could you also print the return value of the sleep function. Maybe that interrupt is triggering it so it returns early?
              • skywatchS
                skywatchS
                skywatch
                #137
                Sorry for the dealy, I have had a week of plumbing problems at home - yuck! :(
                So, I came back fresh to this and noticed that I had put the interrupt into the code ready for the water leak sensor (apt considering this weeks activities!) - BUT, I had not assigned the pin nor initialised it in the code. So maybe it was floating and giving random triggers?
                I tested by changing from int8_t sleep(1, FALLING, SLEEP_TIME); to int8_t sleep(SLEEP_TIME); but now I get battery level sent every single second! - This is making me crazy......
                The log for the gateway has the following.....
                Sep  3 07:00:37 HAAS rsyslogd-2007: action 'action 17' suspended, next retry is Sun Sep  3 07:02:07 2017 [try http://www.rsyslog.com/e/2007 ]
                Sep  3 06:26:28 HAAS rsyslogd0: action 'action 17' resumed (module 'builtin:ompipe') [try http://www.rsyslog.com/e/0 ]
                Sep  3 06:26:28 HAAS rsyslogd-2359: action 'action 17' resumed (module 'builtin:ompipe') [try http://www.rsyslog.com/e/2359 ]
                Not sure what the above is all about. Nor the below....
                7:15:45 HAAS dhcpcd[474]: eth0: Router Advertisement from fe80::3291:8fff:fe06:64bc
                But here is sending data every second.....
                Sep  3 12:46:52 HAAS mysgw: TSF:MSG:READ,5-5-0,s=255,c=3,t=0,pt=1,l=1,sg=0:75
                Sep  3 12:46:53 HAAS mysgw: TSF:MSG:READ,5-5-0,s=255,c=3,t=0,pt=1,l=1,sg=0:75
                Sep  3 12:46:54 HAAS mysgw: TSF:MSG:READ,5-5-0,s=255,c=3,t=0,pt=1,l=1,sg=0:75
                Sep  3 12:46:55 HAAS mysgw: TSF:MSG:READ,5-5-0,s=255,c=3,t=0,pt=1,l=1,sg=0:75
                Sep  3 12:46:56 HAAS mysgw: TSF:MSG:READ,5-5-0,s=255,c=3,t=0,pt=1,l=1,sg=0:75
                Sep  3 12:46:57 HAAS mysgw: TSF:MSG:READ,5-5-0,s=255,c=3,t=0,pt=1,l=1,sg=0:75
                Sep  3 12:46:58 HAAS mysgw: TSF:MSG:READ,5-5-0,s=255,c=3,t=0,pt=1,l=1,sg=0:75
                Sep  3 12:46:59 HAAS mysgw: TSF:MSG:READ,5-5-0,s=255,c=3,t=0,pt=1,l=1,sg=0:75
                Sep  3 12:47:00 HAAS mysgw: TSF:MSG:READ,5-5-0,s=255,c=3,t=0,pt=1,l=1,sg=0:75
                Will try debug on node next....
                • skywatchS
                  skywatchS
                  skywatch
                  I.m sure it is a bug in 2.2.0-beta as I have the same issues with another node sending data whenever it changes and not sleeping.
                  • D
                    dertho
                    is there any known problem / bug with version 2.1.* and the Dallas temp sensor? (I found non in the bug tracker and/or forum)
                    I updated several nodes from 1.5 to 2.1.1 and now no temp sensor is working. No temp sensor DS18B20 is found by the node, therefore -127.0 is returned to the controller. I checked the wiring - as illustrated in this manual, everything seems right; incl. the pull-up with 4,7 k. I use the modified version of the Dallas-Library included in the examples package, as stated out in this manual.
                    Thomas
                    • Mohammed ZamanM
                      Mohammed ZamanM
                      Mohammed Zaman
                      I am not a programmer, but trying to learn by making small projects.
                      I am trying to build a arduino/ESP8266 with temp sensor so that at a particular set temp it sends a single to another arduino/ESP8266 with relay to turn on a cooler/heater. if there is a thread on this, please help me find it.
                      rejoe2R 1 Reply Last reply
                      • Mohammed ZamanM Mohammed Zaman
                        rejoe2R
                        rejoe2R
                        rejoe2
                        @Mohammed-Zaman This seems to be possible, you may find more info wrt your topic using "node to node communication" as a keyword for searching the forum.
                        This might be a good starting point: https://forum.mysensors.org/topic/6386/almost-controller-less-mysensors-switch-light-network/8#
                          https://forum.mysensors.org/topic/7810/alternative-passive-mode if you don't want to use a gateway.
                          • mrwombleM mrwomble
                            Hi there, I'm new to Mysensors and I thought I'd start with a simple DS Temp sensor. However, I'm getting compile errors when I try compile it. Can someone please point me in the right direction?
                            Arduino: 1.6.11 (Windows 7), Board: "Arduino Nano, ATmega328"
                            WARNING: Category 'Sensor' in library DallasTemperature is not valid. Setting to 'Uncategorized'
                            In file included from C:\Users\Admin\Documents\Arduino\Projects\MS Temp sensor node\DallasTemperatureSensor\DallasTemperatureSensor.ino:37:0:
                            C:\Users\Admin\Documents\Arduino\libraries\DallasTemperature/DallasTemperature.h: In function 'void loop()':
                            C:\Users\Admin\Documents\Arduino\libraries\DallasTemperature/DallasTemperature.h:249:13: error: 'int16_t DallasTemperature::millisToWaitForConversion(uint8_t)' is private
                                 int16_t millisToWaitForConversion(uint8_t);
                            DallasTemperatureSensor:85: error: within this context
                            Multiple libraries were found for "DallasTemperature.h"
                             Used: C:\Users\Admin\Documents\Arduino\libraries\DallasTemperature
                             Not used: C:\Users\Admin\Documents\Arduino\libraries\Arduino-Temperature-Control-Library-master
                            exit status 1
                            within this context
                            sjoerd14
                            wrote on last edited by sjoerd14
                            #143
                            regarding error:
                            In the latest version of Miles Burton's the function is public and compiling fine.
                            https://github.com/milesburton/Arduino-Temperature-Control-Library
                            You can import the Lib as zip.
                            You have to remove \ archive the lib: ...\libraries\DallasTemperature
                            • S sjoerd14
                              regarding error:
                              @sjoerd14 yes, thanks to MySensors user David Ducatel. The change is tracked in https://github.com/mysensors/MySensorsArduinoExamples/issues/20 and https://github.com/milesburton/Arduino-Temperature-Control-Library/pull/72 but we're still waiting for an official release of milesburton's library.
                              • nofoxN
                                nofoxN
                                nofox
                                Hi, I have few in wall nodes mounted under the light switches. I have two relays and one DS18B20 in each node. When i'm turning light on, switching the relay, the DS18B20 readings jumping about 0.8 degrees celsius up. When I switch off the relay readings back to normal. Anyone have similar problems ? Sensors are away from from node board, relays etc. so it's not about the heat from atmega or relays.
                                  Is the temperature gradually rising after the relay is activated or it is instantly jumping 0.8°?
                                  • nofoxN
                                    nofoxN
                                    nofox
                                    Jumping 0.8 immediately after switching the relay and sometimes rising very slow during the time when relay is on.
                                      That makes it quite difficult to figure out the problem. Can you make another node with same setup and see if you get the same results and if you do try unplug the relay and see what happens
                                      • skywatchS
                                        skywatchS
                                        skywatch
                                        #149
                                        It's probably a voltage drop from the psu when the relay is engaged and drawing current. That will cause the output voltage to dip slightly.
                                        If it is only momentary you can add a beefy capacitor across the power supply, but if the readings change for the whole time the relay is on, you really need to replace the relay with something that uses less power (triac/mosfet??) - Or get a more stable power supply with good regulation.
                                        A final thing might be more noise on the power line with the psu sending more current with the relay on. again a smoothing capacitor would help if this were the case.
                                        You could also try looking into the wiring and see if the relay cables and the ds18b20 cables are far enough apart, some induction might be going on there between the cables. Also, make sure everything goes back to a single ground point. I can't imagine how an earth loop would cause what you describe, but it's always a good thing to do.....
                                        Another thought to think about is matbe the magnetic field from the relap power cables are inducing into the sensor cables.
                                        • ben999B
                                          ben999B
                                          ben999
                                          Hi
                                          Can we talk about redundancy please? What if one or more sensor fail on a one-wire bus? Would it make the whole line unusable?
                                          As part of a central heating MySensorization i would like to have groups of 3 sensors and have some sort of redundancy check.
                                          Would i be allowed to run multiple one-wire busses on a single arduino?
                                          Thanks a lot foryour help
