  2. Announcements
  3. 💬 Temperature Sensor
171 Posts 40 Posters 106.8k Views 36 Watching
  • skywatchS skywatch
    This can't be right, can it???
    (http://imagebucket.net/7mtp8rcnqss2/BattGraph.jpg)
    @skywatch it looks normal. The precision is probably 1% and the real value close to 100.5%, so sometimes it will be rounded to 101% and sometimes to 100%.
      @mfalkvidd I'm on mobile, I didn't read the code 😇
      @gohan hek has added a great feature that I use a lot on mobile. Click the code box once to maximize it. Super neat!
      • skywatchS
        skywatchS
        skywatch
        @mfalkvidd,
        Did you notice the time line on the bottom of the image. I thought it was supposed to send data once every 30 mins. Seems that something isn't right or I am looking at it from the wrong angle.....?
          @mfalkvidd,
          @skywatch I'm not that versed in c/c++ arithmetic, but I suspect the calculation might overflow. Could you add a debug print to see the value of batteryReportFactor?
          • skywatchS
            skywatchS
            skywatch
            OK I'll do that - seems to be sending battery info every minute still though- strange!
              #132
              @skywatch could you post the entire sketch also, to check if something fishy has crept in?
              • skywatchS
                skywatchS
                skywatch
                Here is the sketch, debug will be later today I hope....
                #define MY_RF24_PA_LEVEL (RF24_PA_LOW)
                #define MAX_ATTACHED_DS18B20 3
                #include <OneWire.h>
                int batteryPcnt = 0;
                unsigned long SLEEP_TIME = 2 * 60 * 1000; // 2 minutes Sleep time between reads.
                int numSensors = 0;
                const long interval = 90000;
                unsigned long previousMillis = 0;
                bool receivedConfig = false;
                bool metric = true;
                unsigned int batteryReportFactor = 30*60*1000/SLEEP_TIME; // Only report battery every x SLEEP times (x=15 with current values)
                unsigned int timesSlept = 0;
                MyMessage msg(0, V_TEMP);
                void before()
                  sensors.begin();
                  analogReference(INTERNAL);
                  sendSketchInfo("HW/CH", "0.5");
                  for (int i = 0; i < numSensors && i < MAX_ATTACHED_DS18B20; i++) {
                    present(i, S_TEMP);
                  // get the battery Voltage
                  if (timesSlept < batteryReportFactor) {
                    timesSlept++;
                    timesSlept = 0;
                    batteryPcnt = sensorValue / 10;
                  sleep(conversionTime);
                    float temperature = static_cast<float>(static_cast<int>((getControllerConfig().isMetric ? sensors.getTempCByIndex(i) : sensors.getTempFByIndex(i)) * 10.)) / 10.;
                #if COMPARE_TEMP == 1
                      send(msg.setSensor(i).set(temperature, 1));
                      lastTemperature[i] = temperature;
                  int8_t sleep(1, FALLING, SLEEP_TIME);
                  int numSensors = 0;
                  bool metric = true;
                  void before()
                    sensors.begin();
                      present(i, S_TEMP);
                      timesSlept++;
                      timesSlept = 0;
                  @skywatch code looks good to me. What type of Arduino are you using?
                  • skywatchS
                    skywatchS
                    skywatch
                    #135
                    I am using a pro mini 3.3v 8MHz. I would ideally like to get a 1MHZ bootloader onto it but the last try stopped the temperature sensors sending data (although battery levels were still sent!)..... Hope it helps.
                      @skywatch could you also print the return value of the sleep function. Maybe that interrupt is triggering it so it returns early?
                      • skywatchS
                        skywatchS
                        skywatch
                        #137
                        Sorry for the dealy, I have had a week of plumbing problems at home - yuck! :(
                        So, I came back fresh to this and noticed that I had put the interrupt into the code ready for the water leak sensor (apt considering this weeks activities!) - BUT, I had not assigned the pin nor initialised it in the code. So maybe it was floating and giving random triggers?
                        I tested by changing from int8_t sleep(1, FALLING, SLEEP_TIME); to int8_t sleep(SLEEP_TIME); but now I get battery level sent every single second! - This is making me crazy......
                        The log for the gateway has the following.....
                        Sep  3 07:00:37 HAAS rsyslogd-2007: action 'action 17' suspended, next retry is Sun Sep  3 07:02:07 2017 [try http://www.rsyslog.com/e/2007 ]
                        Sep  3 06:26:28 HAAS rsyslogd0: action 'action 17' resumed (module 'builtin:ompipe') [try http://www.rsyslog.com/e/0 ]
                        Sep  3 06:26:28 HAAS rsyslogd-2359: action 'action 17' resumed (module 'builtin:ompipe') [try http://www.rsyslog.com/e/2359 ]
                        Not sure what the above is all about. Nor the below....
                        7:15:45 HAAS dhcpcd[474]: eth0: Router Advertisement from fe80::3291:8fff:fe06:64bc
                        But here is sending data every second.....
                        Sep  3 12:46:52 HAAS mysgw: TSF:MSG:READ,5-5-0,s=255,c=3,t=0,pt=1,l=1,sg=0:75
                        Sep  3 12:46:53 HAAS mysgw: TSF:MSG:READ,5-5-0,s=255,c=3,t=0,pt=1,l=1,sg=0:75
                        Sep  3 12:46:54 HAAS mysgw: TSF:MSG:READ,5-5-0,s=255,c=3,t=0,pt=1,l=1,sg=0:75
                        Sep  3 12:46:55 HAAS mysgw: TSF:MSG:READ,5-5-0,s=255,c=3,t=0,pt=1,l=1,sg=0:75
                        Sep  3 12:46:56 HAAS mysgw: TSF:MSG:READ,5-5-0,s=255,c=3,t=0,pt=1,l=1,sg=0:75
                        Sep  3 12:46:57 HAAS mysgw: TSF:MSG:READ,5-5-0,s=255,c=3,t=0,pt=1,l=1,sg=0:75
                        Sep  3 12:46:58 HAAS mysgw: TSF:MSG:READ,5-5-0,s=255,c=3,t=0,pt=1,l=1,sg=0:75
                        Sep  3 12:46:59 HAAS mysgw: TSF:MSG:READ,5-5-0,s=255,c=3,t=0,pt=1,l=1,sg=0:75
                        Sep  3 12:47:00 HAAS mysgw: TSF:MSG:READ,5-5-0,s=255,c=3,t=0,pt=1,l=1,sg=0:75
                        Will try debug on node next....
                        • skywatchS
                          skywatchS
                          skywatch
                          I.m sure it is a bug in 2.2.0-beta as I have the same issues with another node sending data whenever it changes and not sleeping.
                          • D
                            dertho
                            is there any known problem / bug with version 2.1.* and the Dallas temp sensor? (I found non in the bug tracker and/or forum)
                            I updated several nodes from 1.5 to 2.1.1 and now no temp sensor is working. No temp sensor DS18B20 is found by the node, therefore -127.0 is returned to the controller. I checked the wiring - as illustrated in this manual, everything seems right; incl. the pull-up with 4,7 k. I use the modified version of the Dallas-Library included in the examples package, as stated out in this manual.
                            Thomas
                            • Mohammed ZamanM
                              Mohammed ZamanM
                              Mohammed Zaman
                              I am not a programmer, but trying to learn by making small projects.
                              I am trying to build a arduino/ESP8266 with temp sensor so that at a particular set temp it sends a single to another arduino/ESP8266 with relay to turn on a cooler/heater. if there is a thread on this, please help me find it.
                              rejoe2R 1 Reply Last reply
                              • Mohammed ZamanM Mohammed Zaman
                                rejoe2R
                                rejoe2R
                                rejoe2
                                @Mohammed-Zaman This seems to be possible, you may find more info wrt your topic using "node to node communication" as a keyword for searching the forum.
                                This might be a good starting point: https://forum.mysensors.org/topic/6386/almost-controller-less-mysensors-switch-light-network/8#
                                  https://forum.mysensors.org/topic/7810/alternative-passive-mode if you don't want to use a gateway.
                                  • mrwombleM mrwomble
                                    Hi there, I'm new to Mysensors and I thought I'd start with a simple DS Temp sensor. However, I'm getting compile errors when I try compile it. Can someone please point me in the right direction?
                                    Arduino: 1.6.11 (Windows 7), Board: "Arduino Nano, ATmega328"
                                    WARNING: Category 'Sensor' in library DallasTemperature is not valid. Setting to 'Uncategorized'
                                    In file included from C:\Users\Admin\Documents\Arduino\Projects\MS Temp sensor node\DallasTemperatureSensor\DallasTemperatureSensor.ino:37:0:
                                    C:\Users\Admin\Documents\Arduino\libraries\DallasTemperature/DallasTemperature.h: In function 'void loop()':
                                    C:\Users\Admin\Documents\Arduino\libraries\DallasTemperature/DallasTemperature.h:249:13: error: 'int16_t DallasTemperature::millisToWaitForConversion(uint8_t)' is private
                                         int16_t millisToWaitForConversion(uint8_t);
                                    DallasTemperatureSensor:85: error: within this context
                                    Multiple libraries were found for "DallasTemperature.h"
                                     Used: C:\Users\Admin\Documents\Arduino\libraries\DallasTemperature
                                     Not used: C:\Users\Admin\Documents\Arduino\libraries\Arduino-Temperature-Control-Library-master
                                    exit status 1
                                    within this context
                                    sjoerd14
                                    wrote on last edited by sjoerd14
                                    #143
                                    regarding error:
                                    In the latest version of Miles Burton's the function is public and compiling fine.
                                    https://github.com/milesburton/Arduino-Temperature-Control-Library
                                    You can import the Lib as zip.
                                    You have to remove \ archive the lib: ...\libraries\DallasTemperature
                                    • S sjoerd14
                                      regarding error:
                                      @sjoerd14 yes, thanks to MySensors user David Ducatel. The change is tracked in https://github.com/mysensors/MySensorsArduinoExamples/issues/20 and https://github.com/milesburton/Arduino-Temperature-Control-Library/pull/72 but we're still waiting for an official release of milesburton's library.
                                      • nofoxN
                                        nofoxN
                                        nofox
                                        Hi, I have few in wall nodes mounted under the light switches. I have two relays and one DS18B20 in each node. When i'm turning light on, switching the relay, the DS18B20 readings jumping about 0.8 degrees celsius up. When I switch off the relay readings back to normal. Anyone have similar problems ? Sensors are away from from node board, relays etc. so it's not about the heat from atmega or relays.
                                          Is the temperature gradually rising after the relay is activated or it is instantly jumping 0.8°?
