  2. Announcements
  3. 💬 Temperature Sensor
171 Posts 40 Posters 106.8k Views 36 Watching
  • skywatchS skywatch
    @mfalkvidd said in 💬 Temperature Sensor:
    Thank you very much for helping out with this! - I will try it today if I can. I guess I could use the same principle to send sensor data every 2 minutes instead of every 1 minute and further reduce battery draw. I know the DS18B20 sensors are correctly going into sleep mode, but the node itself is still using too much juice.
    @skywatch doing what you want is a bit hard since millis won't update while the node is in power save mode (sleeping).
    There is nothing in the API about this, would be nice if it were added as I don't think I will be the only person with such requirements. Also, what does sleep actually do and are there further things I could do to reduce the power use?
    I don't understand why you're using interrupt to sleep though.
    That is because I haven't finished this node yet.... I am working on it systematically and in future a water leak detector will be added. But only when this part is working correctly and I have good battery life from the node.
    #122
    @skywatch said in 💬 Temperature Sensor:
    Good point. I have added a note on https://www.mysensors.org/download/sensor_api_20#sleeping
    It does a lot of things, but basically it puts the radio and the Arduino in power save mode and uses the Arduino's watchdog timer to roughly keep track of time (exact timing is not possible because exact timing requires power, and power save mode is all about saving power).
    https://www.mysensors.org/build/battery has the official MySensors recommendations on how to save power in battery-operated nodes.
    If you want to dive deeper, start with https://www.gammon.com.au/power
      I'd use the sleep time to 2 minutes and then simply set a counter that every 15 loops of the code sends battery status and resets the counter. Imho 2 minutes are quite often for battery life.
        @gohan wasn't that what I did?
        gohanG 1 Reply Last reply
        • skywatchS
          skywatchS
          skywatch
          This can't be right, can it???
          (http://imagebucket.net/7mtp8rcnqss2/BattGraph.jpg)
            @mfalkvidd I'm on mobile, I didn't read the code 😇
              @skywatch it looks normal. The precision is probably 1% and the real value close to 100.5%, so sometimes it will be rounded to 101% and sometimes to 100%.
                @gohan hek has added a great feature that I use a lot on mobile. Click the code box once to maximize it. Super neat!
                • skywatchS
                  skywatchS
                  skywatch
                  @mfalkvidd,
                  Did you notice the time line on the bottom of the image. I thought it was supposed to send data once every 30 mins. Seems that something isn't right or I am looking at it from the wrong angle.....?
                    @mfalkvidd,
                    @skywatch I'm not that versed in c/c++ arithmetic, but I suspect the calculation might overflow. Could you add a debug print to see the value of batteryReportFactor?
                    • skywatchS
                      skywatchS
                      skywatch
                      OK I'll do that - seems to be sending battery info every minute still though- strange!
                        #132
                        @skywatch could you post the entire sketch also, to check if something fishy has crept in?
                        • skywatchS
                          skywatchS
                          skywatch
                          Here is the sketch, debug will be later today I hope....
                          #define MY_RF24_PA_LEVEL (RF24_PA_LOW)
                          #define MAX_ATTACHED_DS18B20 3
                          #include <OneWire.h>
                          int batteryPcnt = 0;
                          unsigned long SLEEP_TIME = 2 * 60 * 1000; // 2 minutes Sleep time between reads.
                          int numSensors = 0;
                          const long interval = 90000;
                          unsigned long previousMillis = 0;
                          bool receivedConfig = false;
                          bool metric = true;
                          unsigned int batteryReportFactor = 30*60*1000/SLEEP_TIME; // Only report battery every x SLEEP times (x=15 with current values)
                          unsigned int timesSlept = 0;
                          MyMessage msg(0, V_TEMP);
                          void before()
                            sensors.begin();
                            analogReference(INTERNAL);
                            sendSketchInfo("HW/CH", "0.5");
                            for (int i = 0; i < numSensors && i < MAX_ATTACHED_DS18B20; i++) {
                              present(i, S_TEMP);
                            // get the battery Voltage
                            if (timesSlept < batteryReportFactor) {
                              timesSlept++;
                              timesSlept = 0;
                              batteryPcnt = sensorValue / 10;
                            sleep(conversionTime);
                              float temperature = static_cast<float>(static_cast<int>((getControllerConfig().isMetric ? sensors.getTempCByIndex(i) : sensors.getTempFByIndex(i)) * 10.)) / 10.;
                          #if COMPARE_TEMP == 1
                                send(msg.setSensor(i).set(temperature, 1));
                                lastTemperature[i] = temperature;
                            int8_t sleep(1, FALLING, SLEEP_TIME);
                            int numSensors = 0;
                            bool metric = true;
                            void before()
                              sensors.begin();
                                present(i, S_TEMP);
                                timesSlept++;
                                timesSlept = 0;
                            @skywatch code looks good to me. What type of Arduino are you using?
                            • skywatchS
                              skywatchS
                              skywatch
                              #135
                              I am using a pro mini 3.3v 8MHz. I would ideally like to get a 1MHZ bootloader onto it but the last try stopped the temperature sensors sending data (although battery levels were still sent!)..... Hope it helps.
                                @skywatch could you also print the return value of the sleep function. Maybe that interrupt is triggering it so it returns early?
                                • skywatchS
                                  skywatchS
                                  skywatch
                                  #137
                                  Sorry for the dealy, I have had a week of plumbing problems at home - yuck! :(
                                  So, I came back fresh to this and noticed that I had put the interrupt into the code ready for the water leak sensor (apt considering this weeks activities!) - BUT, I had not assigned the pin nor initialised it in the code. So maybe it was floating and giving random triggers?
                                  I tested by changing from int8_t sleep(1, FALLING, SLEEP_TIME); to int8_t sleep(SLEEP_TIME); but now I get battery level sent every single second! - This is making me crazy......
                                  The log for the gateway has the following.....
                                  Sep  3 07:00:37 HAAS rsyslogd-2007: action 'action 17' suspended, next retry is Sun Sep  3 07:02:07 2017 [try http://www.rsyslog.com/e/2007 ]
                                  Sep  3 06:26:28 HAAS rsyslogd0: action 'action 17' resumed (module 'builtin:ompipe') [try http://www.rsyslog.com/e/0 ]
                                  Sep  3 06:26:28 HAAS rsyslogd-2359: action 'action 17' resumed (module 'builtin:ompipe') [try http://www.rsyslog.com/e/2359 ]
                                  Not sure what the above is all about. Nor the below....
                                  7:15:45 HAAS dhcpcd[474]: eth0: Router Advertisement from fe80::3291:8fff:fe06:64bc
                                  But here is sending data every second.....
                                  Sep  3 12:46:52 HAAS mysgw: TSF:MSG:READ,5-5-0,s=255,c=3,t=0,pt=1,l=1,sg=0:75
                                  Sep  3 12:46:53 HAAS mysgw: TSF:MSG:READ,5-5-0,s=255,c=3,t=0,pt=1,l=1,sg=0:75
                                  Sep  3 12:46:54 HAAS mysgw: TSF:MSG:READ,5-5-0,s=255,c=3,t=0,pt=1,l=1,sg=0:75
                                  Sep  3 12:46:55 HAAS mysgw: TSF:MSG:READ,5-5-0,s=255,c=3,t=0,pt=1,l=1,sg=0:75
                                  Sep  3 12:46:56 HAAS mysgw: TSF:MSG:READ,5-5-0,s=255,c=3,t=0,pt=1,l=1,sg=0:75
                                  Sep  3 12:46:57 HAAS mysgw: TSF:MSG:READ,5-5-0,s=255,c=3,t=0,pt=1,l=1,sg=0:75
                                  Sep  3 12:46:58 HAAS mysgw: TSF:MSG:READ,5-5-0,s=255,c=3,t=0,pt=1,l=1,sg=0:75
                                  Sep  3 12:46:59 HAAS mysgw: TSF:MSG:READ,5-5-0,s=255,c=3,t=0,pt=1,l=1,sg=0:75
                                  Sep  3 12:47:00 HAAS mysgw: TSF:MSG:READ,5-5-0,s=255,c=3,t=0,pt=1,l=1,sg=0:75
                                  Will try debug on node next....
                                  • skywatchS
                                    skywatchS
                                    skywatch
                                    I.m sure it is a bug in 2.2.0-beta as I have the same issues with another node sending data whenever it changes and not sleeping.
                                    • D
                                      dertho
                                      is there any known problem / bug with version 2.1.* and the Dallas temp sensor? (I found non in the bug tracker and/or forum)
                                      I updated several nodes from 1.5 to 2.1.1 and now no temp sensor is working. No temp sensor DS18B20 is found by the node, therefore -127.0 is returned to the controller. I checked the wiring - as illustrated in this manual, everything seems right; incl. the pull-up with 4,7 k. I use the modified version of the Dallas-Library included in the examples package, as stated out in this manual.
                                      Thomas
                                      • Mohammed ZamanM
                                        Mohammed ZamanM
                                        Mohammed Zaman
                                        I am not a programmer, but trying to learn by making small projects.
                                        I am trying to build a arduino/ESP8266 with temp sensor so that at a particular set temp it sends a single to another arduino/ESP8266 with relay to turn on a cooler/heater. if there is a thread on this, please help me find it.
                                        rejoe2R 1 Reply Last reply
                                        • Mohammed ZamanM Mohammed Zaman
                                          rejoe2R
                                          rejoe2R
                                          rejoe2
                                          @Mohammed-Zaman This seems to be possible, you may find more info wrt your topic using "node to node communication" as a keyword for searching the forum.
                                          This might be a good starting point: https://forum.mysensors.org/topic/6386/almost-controller-less-mysensors-switch-light-network/8#
