  2. Bug Reports
  3. NRF24L01+ problems in 2.1.1 and 2.2.0 Beta
49 Posts 9 Posters 17.1k Views 12 Watching
    NACK on the gateway usually means that the radio module is not powered correctly or there is a range issue (or you didn't set max tx power on the gateway)
    W 1 Reply Last reply
    • W
      W
      wergeld
      This is getting odder and odder.
      I am running 2.2.1 beta on my RPi2B. It is running on channel 76, with power max, and using ethernet gateway config.
      I have MYSController running on separate laptop and it is seeing updates to temp/hum and/or battery level. However, neither Domoticz or OpenHab2 have seen a change since last night at 9pm.
      In Domoticz - Setup - Hardware - Mysensors 2.2.0 Gateway it shows 2 nodes. First node is the gateway, of course, and the second is the sensor node. The data and the last seen times are correct! But, the Domoticz - Setup - Device list only shows the Temp sesnor and a last seen date of last night at 9pm. There are not other mysensors devices available.
      So, what is different between MYSControler and Domoticz and OpenHab?
        W
        W
        wergeld
        @gohan This doesnt really make sense to me. This happens after I get data from a sensor and the gateway gets stuck in a loop of those messages. MYSControler shows the correct value that triggered these messages while OpenHab and Domoticz do not.
          Do you have capacitors on the radio modules? If you move the node closer to the gateway (3/4 meters apart) , does it work better?
            W
            W
            wergeld
            @gohan Yes, capacitors on both the node(s) and the gateway radios. Moving the nodes closer to gateway has no affect. The gateway is sending out udpates (per MYSControler at least) but Domoticz sees no new devices and OpenHab has not seen an update either. So frustrating.
              Try to stop the gateway and run it with debug from console and c'è if you see any NACK occurring, also on the node if you can, because probably the controller is not accepting messages with NACK. If you can, try to make another arduino based gateway and see if you still get same errors. Keep in mind that if radio modules are not genuine you have to consider they are the cause of your problems.
                W
                W
                wergeld
                @gohan unable to run my node in debug with radio attached at the moment (no 3.3v FTDI or mosfets available right now).
                But, that being said - the MYSControler does get the updated values. Just not Domoticz or OpenHab. So, why does one client connecting to the gateway get data while the other two do not?
                  Myscontroller doesn't see all debug messages. Get a ftdi adapter quickly 😁
                    W
                    W
                    wergeld
                    @gohan Yea, I have one on order taking the slow boat from China. But, it bothers me that MYSControler "gets" the sensor node values and the other controlers do not. Same IP config. And the weird NACK errors. Something just seems screwy as this hardware was working up until about 3 months ago - no changes made.
                    • mfalkviddM
                      #35
                      I have now purchased an extra Raspberry Pi to test the raspberry pi gw.
                      2.1.1 fails with the most basic configure (without any parameters) while the same wiring and configure command works for development (I used commit 901258f16598)
                      git checkout 2.1.1
                      ./configure
                      make
                      sudo ./bin/mysgw -d
                      mysgw: Starting gateway...
                      mysgw: TSM:INIT
                      mysgw: TSF:WUR:MS=0
                      mysgw: !TSM:INIT:TSP FAIL
                      mysgw: TSM:FAIL:CNT=1
                      mysgw: TSM:FAIL:PDT
                      git checkout development
                      ./configure
                      make
                      mysgw: MCO:BGN:INIT GW,CP=RNNGL---,VER=2.2.0-beta
                      mysgw: TSF:LRT:OK
                      mysgw: TSM:INIT
                      mysgw: TSF:WUR:MS=0
                      mysgw: TSM:INIT:TSP OK
                      mysgw: TSM:INIT:GW MODE
                      mysgw: MCO:REG:NOT NEEDED
                      mysgw: MCO:BGN:STP
                      mysgw: MCO:BGN:INIT OK,TSP=1
                      I'm not sure how to proceed though. Is there anything you want me to try?
                      • mfalkviddM
                        This is the verbose rf24 output. Not sure if it helps.
                        2.1.1:
                        ./configure --extra-cxxflags="-DMY_DEBUG -DMY_DEBUG_VERBOSE_RF24" && make && sudo bin/mysgw -d
                        mysgw: TSM:INIT
                        mysgw: TSF:WUR:MS=0
                        mysgw: RF24:write register, reg=0, value=14
                        mysgw: RF24:write register, reg=3, value=3
                        mysgw: RF24:write register, reg=4, value=95
                        mysgw: RF24:write register, reg=5, value=76
                        mysgw: RF24:write register, reg=6, value=39
                        mysgw: RF24:write register, reg=16, value=115
                        mysgw: RF24:write register, reg=29, value=6
                        mysgw: RF24:read register, reg=6, value=0
                        mysgw: RF24:read register, reg=5, value=0
                        mysgw: !RF24:INIT:SANCHK FAIL
                        development:
                        mysgw: TSF:LRT:OK
                        mysgw: TSM:INIT
                        mysgw: TSF:WUR:MS=0
                        mysgw: RF24:INIT
                        mysgw: RF24:INIT:PIN,CE=22,CS=24
                        mysgw: RF24:WBR:REG=0,VAL=14
                        mysgw: RF24:WBR:REG=3,VAL=3
                        mysgw: RF24:WBR:REG=4,VAL=95
                        mysgw: RF24:WBR:REG=5,VAL=76
                        mysgw: RF24:WBR:REG=6,VAL=37
                        mysgw: RF24:WBR:REG=16,VAL=115
                        mysgw: RF24:WBR:REG=29,VAL=4
                        mysgw: RF24:RBR:REG=6,VAL=37
                        mysgw: RF24:RBR:REG=5,VAL=76
                        mysgw: RF24:WBR:REG=2,VAL=2
                        mysgw: RF24:WBR:REG=1,VAL=0
                        mysgw: RF24:WBR:REG=28,VAL=3
                        mysgw: RF24:FRX
                        mysgw: RF24:FTX
                        mysgw: RF24:WBR:REG=7,VAL=112
                        mysgw: RF24:WBR:REG=2,VAL=3
                        mysgw: RF24:WBR:REG=1,VAL=1
                        mysgw: RF24:STL
                        mysgw: RF24:WBR:REG=0,VAL=15
                        mysgw: RF24:WBR:REG=10,VAL=0
                        mysgw: RF24:RBR:REG=23,VAL=17
                        • miljumeM miljume
                          I would like to submit a bug report for these libraries in the use of NRF24L01+ radio
                          I have problems with NRF24L01+ on both 2.1.1 and 2.2.0 Beta
                          I have installed a fresh RPI with all new libraries and trying to make a RPI Serial GW
                          In 2.1.1 it doesn't start at all but in 2.2.0 it starts but in the log I constantly receive the following in the Domoticz log where I have added the GW
                          I2017-10-09 19:25:12.306 MySensors: Gateway Version: 2.2.0-beta
                          2017-10-09 19:25:12.306 Error: Serial Port closed!... Error: End of file
                          2017-10-09 19:25:13.306 MySensors: retrying in 30 seconds...
                          After a while I get the following in the console
                          mysgw: TSF:MSG:READ,0-0-0,s=0,c=3,t=2,pt=0,l=11,sg=0:Get Version
                          mysgw: !TSF:MSG:LEN,0!=18
                          The above points at something wrong with the radio connection
                          I have tried 3 different radios but still no luck so I guess it has something to do with the libraries
                          JokgiJ
                          JokgiJ
                          Jokgi
                          @miljume Are you using modules with the genuine Nordic Devices mounted on them? How do you have it connected? Are you successful with any other "compatible" modules?
                          mfalkviddM miljumeM 2 Replies Last reply
                          • JokgiJ Jokgi
                            @Jokgi to my knowledge, there is no way to know if devices are genuine, besides sending them to Nordic to have them checked. I have not done that, so I don't know whether they are genuine.
                            The radio module is connected using a 2x4 pin jumper wire connector on the nrf24 end and a 2x5 jumper wire connector on the raspberry pi end. Wiring for the nrf end is according to https://www.mysensors.org/build/connect_radio and https://www.mysensors.org/build/raspberry for the raspberry pi end.
                            I don't understand your third question. Could you clarify/rephrase?
                              I think he is asking if you tried other modules from different manufacturer
                                #40
                                Thanks @gohan
                                In that case, the answer is that I don't know. I have ordered through Aliexpress 3-4 times. I don't know which modules came from which order, or if the orders were sourced from different manufacturers.
                                • mfalkviddM
                                  I have now tracked down the commit that makes the default raspberry pi gateway work: https://github.com/mysensors/MySensors/commit/4c31e22d6ff45c3a4f8aa70f915c5f10fe345f64
                                  When using the commit before this (26c237adadda9f79b07d862708d8471285a96905 ) the radio init fails.
                                  So now we at least know why development works and 2.1.1 does not.
                                  git checkout 26c237adadda9f79b07d862708d8471285a96905
                                  mysgw: MCO:BGN:INIT GW,CP=RNNG----,VER=2.2.0-beta
                                  mysgw: TSF:LRT:OK
                                  mysgw: TSM:INIT
                                  mysgw: TSF:WUR:MS=0
                                  mysgw: RF24:INIT
                                  mysgw: RF24:INIT:PIN,CE=9,CS=24
                                  mysgw: RF24:WBR:REG=29,VAL=6
                                  mysgw: RF24:RBR:REG=6,VAL=0
                                  mysgw: RF24:RBR:REG=5,VAL=0
                                  git checkout 4c31e22d6ff45c3a4f8aa70f915c5f10fe345f64 #68
                                  mysgw: TSF:LRT:OK
                                  mysgw: TSM:INIT
                                  mysgw: TSF:WUR:MS=0
                                  mysgw: RF24:INIT
                                  mysgw: RF24:FRX
                                  mysgw: RF24:FTX
                                  mysgw: RF24:STL
                                  miljumeM 1 Reply Last reply
                                  • G
                                    G
                                    GrantsPi
                                    I am glad I'm not the only one having this issue (but hope it will be resolved soon).
                                    I had a RPi3 with the MQTT gateway working well for the past year, until I decided to upgrade to the latest version of Raspbian (and MySensors). I've now tried with a fresh install on both the RPi3 and a RPi2; with the same NRF24 as before (working well in the previous build); I also tried with a different radio using a socket and capacitor.
                                    Looking forward to your progress!
                                    mysgw: TSM:INIT
                                    mysgw: TSF:WUR:MS=0
                                    mysgw: TSM:FAIL:PDT
                                    mysgw: TSM:FAIL:RE-INIT
                                    mysgw: TSM:INIT
                                    mysgw: TSM:FAIL:CNT=2
                                    mysgw: TSM:FAIL:PDT
                                    • JokgiJ Jokgi
                                      miljumeM
                                      miljumeM
                                      miljume
                                      wrote on last edited by miljume
                                      #43
                                      @Jokgi Mots probably they are not genuine (bought from Aliexpress) but these devices themselves have not caused me any issues before. It started when I upgraded to 2.1.1. Although, after a clean install with 2.2.0 Beta it started working again so I am 100% sure that it's not the modules
                                        mysgw: TSF:LRT:OK
                                        mysgw: TSM:INIT
                                        mysgw: TSF:WUR:MS=0
                                        mysgw: RF24:INIT
                                        mysgw: TSF:LRT:OK
                                        mysgw: TSM:INIT
                                        mysgw: TSF:WUR:MS=0
                                        mysgw: RF24:INIT
                                        mysgw: RF24:FRX
                                        mysgw: RF24:FTX
                                        mysgw: RF24:STL
                                        miljumeM
                                        miljumeM
                                        miljume
                                        @mfalkvidd Good! I have now succeded in getting 2.2.0 Beta up and running with Ethernet GW
                                        • W
                                          W
                                          wergeld
                                          @mfalkvidd said in NRF24L01+ problems in 2.1.1 and 2.2.0 Beta:
                                          Okay, this works for me now as well. However, Domoticz still doesn't report any updated data beyond the first seen measurement for the temp portion of the sensors....I am about to see how far these slim nodes can fly...
