  2. Bug Reports
  3. NRF24L01+ problems in 2.1.1 and 2.2.0 Beta
49 Posts 9 Posters 17.1k Views 12 Watching
    Do you have capacitors on the radio modules? If you move the node closer to the gateway (3/4 meters apart) , does it work better?
    W 1 Reply Last reply
      W
      W
      wergeld
      @gohan Yes, capacitors on both the node(s) and the gateway radios. Moving the nodes closer to gateway has no affect. The gateway is sending out udpates (per MYSControler at least) but Domoticz sees no new devices and OpenHab has not seen an update either. So frustrating.
        Try to stop the gateway and run it with debug from console and c'è if you see any NACK occurring, also on the node if you can, because probably the controller is not accepting messages with NACK. If you can, try to make another arduino based gateway and see if you still get same errors. Keep in mind that if radio modules are not genuine you have to consider they are the cause of your problems.
          W
          W
          wergeld
          @gohan unable to run my node in debug with radio attached at the moment (no 3.3v FTDI or mosfets available right now).
          But, that being said - the MYSControler does get the updated values. Just not Domoticz or OpenHab. So, why does one client connecting to the gateway get data while the other two do not?
            Myscontroller doesn't see all debug messages. Get a ftdi adapter quickly 😁
              W
              W
              wergeld
              @gohan Yea, I have one on order taking the slow boat from China. But, it bothers me that MYSControler "gets" the sensor node values and the other controlers do not. Same IP config. And the weird NACK errors. Something just seems screwy as this hardware was working up until about 3 months ago - no changes made.
              • mfalkviddM
                #35
                I have now purchased an extra Raspberry Pi to test the raspberry pi gw.
                2.1.1 fails with the most basic configure (without any parameters) while the same wiring and configure command works for development (I used commit 901258f16598)
                git checkout 2.1.1
                ./configure
                make
                sudo ./bin/mysgw -d
                mysgw: Starting gateway...
                mysgw: TSM:INIT
                mysgw: TSF:WUR:MS=0
                mysgw: !TSM:INIT:TSP FAIL
                mysgw: TSM:FAIL:CNT=1
                mysgw: TSM:FAIL:PDT
                git checkout development
                ./configure
                make
                mysgw: MCO:BGN:INIT GW,CP=RNNGL---,VER=2.2.0-beta
                mysgw: TSF:LRT:OK
                mysgw: TSM:INIT
                mysgw: TSF:WUR:MS=0
                mysgw: TSM:INIT:TSP OK
                mysgw: TSM:INIT:GW MODE
                mysgw: MCO:REG:NOT NEEDED
                mysgw: MCO:BGN:STP
                mysgw: MCO:BGN:INIT OK,TSP=1
                I'm not sure how to proceed though. Is there anything you want me to try?
                • mfalkviddM
                  This is the verbose rf24 output. Not sure if it helps.
                  2.1.1:
                  ./configure --extra-cxxflags="-DMY_DEBUG -DMY_DEBUG_VERBOSE_RF24" && make && sudo bin/mysgw -d
                  mysgw: TSM:INIT
                  mysgw: TSF:WUR:MS=0
                  mysgw: RF24:write register, reg=0, value=14
                  mysgw: RF24:write register, reg=3, value=3
                  mysgw: RF24:write register, reg=4, value=95
                  mysgw: RF24:write register, reg=5, value=76
                  mysgw: RF24:write register, reg=6, value=39
                  mysgw: RF24:write register, reg=16, value=115
                  mysgw: RF24:write register, reg=29, value=6
                  mysgw: RF24:read register, reg=6, value=0
                  mysgw: RF24:read register, reg=5, value=0
                  mysgw: !RF24:INIT:SANCHK FAIL
                  development:
                  mysgw: TSF:LRT:OK
                  mysgw: TSM:INIT
                  mysgw: TSF:WUR:MS=0
                  mysgw: RF24:INIT
                  mysgw: RF24:INIT:PIN,CE=22,CS=24
                  mysgw: RF24:WBR:REG=0,VAL=14
                  mysgw: RF24:WBR:REG=3,VAL=3
                  mysgw: RF24:WBR:REG=4,VAL=95
                  mysgw: RF24:WBR:REG=5,VAL=76
                  mysgw: RF24:WBR:REG=6,VAL=37
                  mysgw: RF24:WBR:REG=16,VAL=115
                  mysgw: RF24:WBR:REG=29,VAL=4
                  mysgw: RF24:RBR:REG=6,VAL=37
                  mysgw: RF24:RBR:REG=5,VAL=76
                  mysgw: RF24:WBR:REG=2,VAL=2
                  mysgw: RF24:WBR:REG=1,VAL=0
                  mysgw: RF24:WBR:REG=28,VAL=3
                  mysgw: RF24:FRX
                  mysgw: RF24:FTX
                  mysgw: RF24:WBR:REG=7,VAL=112
                  mysgw: RF24:WBR:REG=2,VAL=3
                  mysgw: RF24:WBR:REG=1,VAL=1
                  mysgw: RF24:STL
                  mysgw: RF24:WBR:REG=0,VAL=15
                  mysgw: RF24:WBR:REG=10,VAL=0
                  mysgw: RF24:RBR:REG=23,VAL=17
                  • miljumeM miljume
                    I would like to submit a bug report for these libraries in the use of NRF24L01+ radio
                    I have problems with NRF24L01+ on both 2.1.1 and 2.2.0 Beta
                    I have installed a fresh RPI with all new libraries and trying to make a RPI Serial GW
                    In 2.1.1 it doesn't start at all but in 2.2.0 it starts but in the log I constantly receive the following in the Domoticz log where I have added the GW
                    I2017-10-09 19:25:12.306 MySensors: Gateway Version: 2.2.0-beta
                    2017-10-09 19:25:12.306 Error: Serial Port closed!... Error: End of file
                    2017-10-09 19:25:13.306 MySensors: retrying in 30 seconds...
                    After a while I get the following in the console
                    mysgw: TSF:MSG:READ,0-0-0,s=0,c=3,t=2,pt=0,l=11,sg=0:Get Version
                    mysgw: !TSF:MSG:LEN,0!=18
                    The above points at something wrong with the radio connection
                    I have tried 3 different radios but still no luck so I guess it has something to do with the libraries
                    JokgiJ
                    JokgiJ
                    Jokgi
                    @miljume Are you using modules with the genuine Nordic Devices mounted on them? How do you have it connected? Are you successful with any other "compatible" modules?
                    mfalkviddM miljumeM 2 Replies Last reply
                    • JokgiJ Jokgi
                      @Jokgi to my knowledge, there is no way to know if devices are genuine, besides sending them to Nordic to have them checked. I have not done that, so I don't know whether they are genuine.
                      The radio module is connected using a 2x4 pin jumper wire connector on the nrf24 end and a 2x5 jumper wire connector on the raspberry pi end. Wiring for the nrf end is according to https://www.mysensors.org/build/connect_radio and https://www.mysensors.org/build/raspberry for the raspberry pi end.
                      I don't understand your third question. Could you clarify/rephrase?
                        I think he is asking if you tried other modules from different manufacturer
                          #40
                          Thanks @gohan
                          In that case, the answer is that I don't know. I have ordered through Aliexpress 3-4 times. I don't know which modules came from which order, or if the orders were sourced from different manufacturers.
                          • mfalkviddM
                            I have now tracked down the commit that makes the default raspberry pi gateway work: https://github.com/mysensors/MySensors/commit/4c31e22d6ff45c3a4f8aa70f915c5f10fe345f64
                            When using the commit before this (26c237adadda9f79b07d862708d8471285a96905 ) the radio init fails.
                            So now we at least know why development works and 2.1.1 does not.
                            git checkout 26c237adadda9f79b07d862708d8471285a96905
                            mysgw: MCO:BGN:INIT GW,CP=RNNG----,VER=2.2.0-beta
                            mysgw: TSF:LRT:OK
                            mysgw: TSM:INIT
                            mysgw: TSF:WUR:MS=0
                            mysgw: RF24:INIT
                            mysgw: RF24:INIT:PIN,CE=9,CS=24
                            mysgw: RF24:WBR:REG=29,VAL=6
                            mysgw: RF24:RBR:REG=6,VAL=0
                            mysgw: RF24:RBR:REG=5,VAL=0
                            git checkout 4c31e22d6ff45c3a4f8aa70f915c5f10fe345f64 #68
                            mysgw: TSF:LRT:OK
                            mysgw: TSM:INIT
                            mysgw: TSF:WUR:MS=0
                            mysgw: RF24:INIT
                            mysgw: RF24:FRX
                            mysgw: RF24:FTX
                            mysgw: RF24:STL
                            miljumeM 1 Reply Last reply
                            • G
                              G
                              GrantsPi
                              I am glad I'm not the only one having this issue (but hope it will be resolved soon).
                              I had a RPi3 with the MQTT gateway working well for the past year, until I decided to upgrade to the latest version of Raspbian (and MySensors). I've now tried with a fresh install on both the RPi3 and a RPi2; with the same NRF24 as before (working well in the previous build); I also tried with a different radio using a socket and capacitor.
                              Looking forward to your progress!
                              mysgw: TSM:INIT
                              mysgw: TSF:WUR:MS=0
                              mysgw: TSM:FAIL:PDT
                              mysgw: TSM:FAIL:RE-INIT
                              mysgw: TSM:INIT
                              mysgw: TSM:FAIL:CNT=2
                              mysgw: TSM:FAIL:PDT
                              • JokgiJ Jokgi
                                miljumeM
                                miljumeM
                                miljume
                                wrote on last edited by miljume
                                #43
                                @Jokgi Mots probably they are not genuine (bought from Aliexpress) but these devices themselves have not caused me any issues before. It started when I upgraded to 2.1.1. Although, after a clean install with 2.2.0 Beta it started working again so I am 100% sure that it's not the modules
                                  mysgw: TSF:LRT:OK
                                  mysgw: TSM:INIT
                                  mysgw: TSF:WUR:MS=0
                                  mysgw: RF24:INIT
                                  mysgw: TSF:LRT:OK
                                  mysgw: TSM:INIT
                                  mysgw: TSF:WUR:MS=0
                                  mysgw: RF24:INIT
                                  mysgw: RF24:FRX
                                  mysgw: RF24:FTX
                                  mysgw: RF24:STL
                                  miljumeM
                                  miljumeM
                                  miljume
                                  @mfalkvidd Good! I have now succeded in getting 2.2.0 Beta up and running with Ethernet GW
                                  • W
                                    W
                                    wergeld
                                    @mfalkvidd said in NRF24L01+ problems in 2.1.1 and 2.2.0 Beta:
                                    Okay, this works for me now as well. However, Domoticz still doesn't report any updated data beyond the first seen measurement for the temp portion of the sensors....I am about to see how far these slim nodes can fly...
                                    • alowhumA
                                      alowhumA
                                      alowhum
                                      #46
                                      I had the same problem with 2.1.1 on a Raspberry Pi Zero W.
                                      Changing to the development version fixed it.
                                      • alowhumA
                                        alowhumA
                                        alowhum
                                        I'm trying to connect Domoticz to a virtual serial.
                                        ./configure --my-transport=nrf24 --my-rf24-irq-pin=15 --my-rf24-pa-level=RF24_PA_LOW --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/serial2
                                        But while Domoticz sees the serial port, it does not seem to connect. I also see the "end of file" error in the Domoticz logs.
                                        What baudrate should be set in Domoticz?
                                          Compile as ethernet GW, much less problems :D
