  3. nRF5 action!
nRF5 action!
1.9k Posts 49 Posters 2.2m Views 44 Watching
    Of course, I couldn't stop until I tried hooking it up to the 4w boost amplifier:
    Wow! That really kicks tail. I don't think there's a nook or cranny anywhere that I don't get a great signal now, and all from a single gateway. :)
      I just now ordered a number of Fanstel modules to go with the breakout boards I recently posted. It's worth noting that Fanstel's lowest cost nRF52832 module is only $3.75, which is lower than the Ebyte module: http://www.fanstel.com/buy/bt832-ble42-hardware-ready-for-bluetooth-5-module-2fhya
      I ordered one, and I'll see how it compares in actual use.
      scalzS Nca78N 2 Replies Last reply
        #1199
        interesting for US customers only I think. Because last time I looked, shipping were too expensive (plus add extra shipping fee like customs etc.).
          It's woth noting that despite it's "832" name it's in fact an nrf52810 :P
          43$ shipping if you're not in the US. And with DHL meaning (at least for me) 10 extra dollars of DHL fee for custom processing + highest tax possible.
            What are the pin assignments when you have one linear list of pin names next to a double row of pins? In this case: https://www.aliexpress.com/item-img/NRF51822-pa-Bluetooth-module-external-antenna-module-column-industrial-self-timer-heart-rate-meter/32815682890.html?spm=2114.10010108.1000017.2.35e823afSFYACg
            • Nca78N Nca78
              #1202
              It's too bad Fanstel's shipping rates outside the US are high. I received the modules I ordered from Fanstel in just a couple of days. I'll try them out after I receive the PCB's from OSH PARK, which should happen in about another 1-2 weeks. The pinout for Fanstel's "micro" version (BC832) is different, and obviously the land pattern is much smaller, so I just now did a separate breakout board for it and sent it to the fab.
              I'm trying to think now as to whether I'll have any future need for nRF24L01's. The very small and cheap nRF51822 seems to supplant it now with its 4dbm higher Tx power, and the nRF52 affords lower current consumption while in Tx or Rx, because of its DCDC option.
                #1203
                @d00616 Is it still the case that we're limited to a single interrupt? For instance, I'd like to put the nRF52832 to wake-up periodically as a heartbeat where it reports its battery level, and I also want it to wake-up if a particular pin goes HIGH (e.g. if a PIR sensor is triggered). Presently I'm using the RTC to provide the one interrupt, and I use the PPI to create an RTC interrupt if it detects that the PIR sensor pin has gone HIGH. Then the interrupt code must determine the true cause of the interrupt. It would be cleaner if I could separate them into separate interrupts. This is just a simple example to explain what I mean by the question.
                d00616D 1 Reply Last reply
                  Toyman
                  No issue for me as I am a using a mail forwarder(s) and I can highly recommend them to others. Bringing nrf52Dk from Arrow to Russia costed me $10 (inter-US shipping is free at Arrow).
                  I am considering switching to Fanstel modules completely, especially to their PA+LNA ones
                  Nca78N 1 Reply Last reply
                    d00616D
                    d00616D
                    d00616
                    You can wake up the MCU via:
                    • GPIO pin sense; used for sleep()
                    • GPIOTE; consumes less engergy but pin must be dedected in software (0.1µA-0.5µA)
                    • LPCOMP (0.5µA)
                    • QDEC (5µA)
                    The interrupts for LPCOMP and QDEC are not allocated by the arduino-port. I think the LPCOMP is a good point to start with.
                    • T Toyman
                      Do they ask you for shipment fee directly to Russia ?
                      I'm in Vietnam and bringing nrf52DK from Arrow was free, like everything I order from them, and over US$20 it's even express shipment (By the way they have a 25% flash sale right now !)
                      I'm interested on info on your mail forwarder if it's not only for Russia.
                      • Nca78N Nca78
                        Toyman
                        @Nca78 Arrow ships free to Russia, but only to companies, not to direct consumers this is linked to the fact they use couriers (DHL/Fedex) and not vanilla USPS.
                        Have a look at www.shipito.com, it's not the one I am currently using, but Shipito works with the whole world. Pricing might be a bit steep, but I haven't looked at it for a long time.
                        • T
                          Toyman
                          http://blog.nordicsemi.com/getconnected/power-consumption-explained?utm_campaign=Blog update notifications&utm_source=hs_email&utm_medium=email&utm_content=57717514&_hsenc=p2ANqtz-9HxcPCGqL9z_8UZBj38TZu8vg-vE-JmEgmzOlt-uiiGj32PO4Vm0brgVaCxtEly5tGV5aioj1vJezIbGK_-xZVXV6zxQ&_hsmi=57717514
                          • O
                            O
                            Omemanti
                            wrote on last edited by Omemanti
                            #1209
                            Had the nrf52dk shipped from arrow to the Netherlands. Because it was above 22 euro( something like that) DHL had to let it apply tax and some administration cost.
                            The board costed 28 euro(inc shipping). The tax office estimate was that is was around 120 euro??? so they charged me a little to much. I filled in some forms to get some of the taxes back.
                            When the board arrived I had to pay DHL 43 euro . So getting it though customes cost more than the board itself. 😏
                            • O Omemanti
                              @Omemanti said in nRF5 Bluetooth action!:
                              DHL is selling it's shipment service cheaper to shops so the cost seems interesting for buyer. But their trick is to force you to pay some "service fee" when you receive your parcel in addition to custom taxes. This is borderline scam IMHO as this fee is mandatory and has a fixed value for each destination country, so DHL should include it upfront when customer orders.
                              No more DHL shipment for me.
                              • d00616D d00616
                                • LPCOMP (0.5µA)
                                • QDEC (5µA)
                                #1211
                                • LPCOMP (0.5µA)
                                • QDEC (5µA)
                                I have it now where LPCOMP does detect pin AIN1 (i.e. pin P0.03) going HIGH, but it still doesn't wake-up the MCU, and the interrupt code never runs. I could use the PPI to trigger an RTC interrupt when it detects the NRF_LPCOMP->EVENTS_UP event, which would wake up the MCU, but then I'm back to square one. Is that the best that can be done given the current state of the software?
                                #define MY_CORE_ONLY
                                #include <nrf.h>
                                uint32_t blinkCounter=0;
                                uint32_t interruptCounter=0;
                                bool button_pressed=false;
                                  Serial.begin(9600);
                                  Serial.println();
                                  // Enable interrupt
                                  NVIC_EnableIRQ(LPCOMP_IRQn);
                                  hwPinMode(LED_BUILTIN,OUTPUT_H0H1);
                                  //hwPinMode(PIN_BUTTON1,INPUT);
                                  NRF_LPCOMP->PSEL=1; // monitor AIN1 (pin P0.03).
                                  while (!(NRF_LPCOMP->PSEL==1)) {} //wait until confirmed
                                  while (!(NRF_LPCOMP->INTENSET==B0100)) {} //wait until confirmed
                                  Serial.print(blinkCounter++);
                                  Serial.println("HIGH");
                                  delay(20);
                                  if (NRF_LPCOMP->EVENTS_UP) {
                                    delay(2000);
                                    NRF_LPCOMP->EVENTS_UP=0;  //Clear the semaphore
                                  if (button_pressed) {
                                    delay(2000);
                                    button_pressed=false;  //Clear the semaphore
                                  hwSleep(5000);
                                #if __CORTEX_M == 0x04
                                        event = 0;        \
                                        (void)event
                                // This must be in one line
                                //extern "C" { void GPIO_IRQHandler(void) {interruptCounter++; NRF5_RESET_EVENT(NRF_RTC0->EVENTS_OVRFLW); NRF_RTC0->EVENTS_OVRFLW=0; }}
                                extern "C" { void LPCOMP_IRQHandler(void) {button_pressed=true; interruptCounter++; NRF5_RESET_EVENT(NRF_LPCOMP->EVENTS_UP); NRF_LPCOMP->EVENTS_UP=0; }}
                                  • LPCOMP (0.5µA)
                                  • QDEC (5µA)
                                  #include <nrf.h>
                                    Serial.begin(9600);
                                    Serial.println();
                                    // Enable interrupt
                                    delay(20);
                                      delay(2000);
                                      delay(2000);
                                    hwSleep(5000);
                                          event = 0;        \
                                          (void)event
                                  Getting closer... The LPCOMP interrupt code does run, but the main loop doesn't resume until the RTC timer makes it resume because the programmed time interval has expired.
                                  I know this is true because if, during sleep, I make AIN1 go HIGH, and then LOW, then when the MCU later wakes up because of the RTC, it so indicates by making the LED go HIGH for 2 seconds. However, even though there's now solid proof that the LPCOMP interrupt hardware does execute, the main loop doesn't immediately resume, as it does when the RTC times out.
                                  So.... How to make the main loop immediately resume whenever LPCOMP goes UP?
                                    #1213
                                    Well, I have to re-build the timer part of this, and clean up the code, but at least now a PIR sensor trigger will immediately wake-up the MCU. That's progress! Unfortunately, current drawn during sleep is now 456ua, which is much higher than it should be.
                                    #include <nrf.h>
                                    uint32_t rtcInterruptCounter=0;
                                    uint32_t buttonPressInterruptCounter=0;
                                      // Idle serial device
                                      NRF_UART0->TASKS_STOPRX = 1;
                                      NRF_UART0->TASKS_STOPTX = 1;
                                      NRF_UART0->TASKS_SUSPEND = 1;
                                      //NRF_UART0->ENABLE=0;  //disable UART0
                                      NRF_POWER->TASKS_LOWPWR = 1;
                                    // Sleep in System ON mode
                                    inline void doTheSleep()
                                      __WFE();
                                      __SEV();
                                      __WFE();
                                      // Start HFCLK
                                      //if (nrf5_pwr_hfclk) {
                                      if (false) {
                                        //NRF_POWER->TASKS_CONSTLAT = 1;
                                      myHwSleepPrepare(ms);
                                      doTheSleep();
                                      //now sleeping
                                      myHwSleepEnd(ms);
                                      //Serial.begin(9600);
                                      //Serial.println();
                                      //Serial.println("Starting...");
                                        // Enable interrupt
                                      //NRF_PPI->CH[0].EEP = (uint32_t)&NRF_LPCOMP->EVENTS_UP;  //If PIR sensor is triggered
                                      //NRF_PPI->CH[0].TEP = (uint32_t)&NRF_RTC0->TASKS_TRIGOVRFLW;  //make the RTC wake-up the MCU
                                      //NRF_PPI->CHENSET=B00000001; //enable Channel 0.
                                      NRF_RTC0->INTENSET = B10;  //interrupt MCU if an OVRFLW is detected.
                                      while (NRF_RTC0->INTENSET != B10) {}  //wait until confirmed
                                      //Serial.print(blinkCounter++);
                                      //Serial.println("HIGH");
                                      delay(20);
                                        delay(2000);
                                        delay(2000);
                                      myHwSleep(5000);
                                            event = 0;        \
                                            (void)event
                                    extern "C" { void RTC0_IRQHandler(void) {rtcInterruptCounter++; NRF5_RESET_EVENT(NRF_RTC0->EVENTS_OVRFLW); NRF_RTC0->EVENTS_OVRFLW=0; }}
                                    extern "C" { void LPCOMP_IRQHandler(void) {button_pressed=true; buttonPressInterruptCounter++; NRF5_RESET_EVENT(NRF_LPCOMP->EVENTS_UP); NRF_LPCOMP->EVENTS_UP=0; }}
                                      #include <nrf.h>
                                        __WFE();
                                        __SEV();
                                        __WFE();
                                        // Start HFCLK
                                        if (false) {
                                        doTheSleep();
                                        //now sleeping
                                        myHwSleepEnd(ms);
                                        //Serial.println();
                                          // Enable interrupt
                                        delay(20);
                                          delay(2000);
                                          delay(2000);
                                        myHwSleep(5000);
                                              event = 0;        \
                                              (void)event
                                      Aha! Most likely the high current draw is from the high frequency clock, which I need to turn off prior to sleep but haven't done yet.
                                        Anyhow, the basic question remains and boils down to this: Can I have both
                                            // Enable interrupt
                                        AND an equivalent incantation for the RTC both active at the same time? Or am I forced into having it be just one or the other?
                                          @Terrence
                                          Around 30 feet, through some walls, but at 2mbps. I realize that's not very far, but even so the measured packet loss (informal testing) is pretty high at that speed. I can see why most people default to 250kbps instead.
                                          I don't have the 840 dev kit yet, mostly because I don't see anyother 840 modules on the market right now.
                                          ahmedadelhosniA
                                          ahmedadelhosniA
                                          ahmedadelhosni
                                          @NeverDie Did you manage to get more than 10m ? maybe by another modules.
                                          I thought the nrf52 will have better range !
                                          12.5k
