1.1k Posts 105 Posters 792.9k Views 98 Watching
  • R
    R
    robosensor
    Simple RS485 gateway and node for two BME280 sensors:
      Made a small tool to simplify the extraction of serial debug data from a 10-pin IDC connector and reading it from a typical 6-pin FTDI module.
      The 10-pin IDC connector is what's most commonly used for programming nRF5x modules.
      • mfalkviddM
        #26
        Not really MySensors-related, but I found a nice logging library for Arduino that I'm using in a project. The library was orphaned some time ago, but now has a new maintainer. I assisted with an update of the documentation and some source code cleanup.
        0_1509023431067_upload-51ff881d-811a-461d-ab1a-7a6189debe28
          #27
          I made an nRF52832 board today with 5 different colored LED's on it: red, green, yellow, orange, and blue. Mostly I think it may be useful while debugging code. All the LED's except for blue emit light all the way down to 1.8v source voltage, so it's good for battery powered operation also. The blue lights up all the way down to 2.4v, and I had to grapple with a 0403 LED to get that low of a voltage for a blue LED. In the end it was so tiny that I couldn't see the polarity of it, so I hit on the idea of running a blink program and seeing whether it would light up just before I soldered it in place. That worked. :)
          Also, this board channels its serial output over the 10-pin IDC connector, so I used the tool I posted yesterday to read it. Works great, and now I don't have a six pin FTDI connector cluttering up the PCB. :)
            Today my boards for the BT832X (that's an nRF52832 with both PA and LNA) arrived from OSH PARK, so I put one together to try it out:
              sPENKMAN
              A (long) time ago I had my own Android app which talked xmlrpc to a Python script, which talked serial with my Arduino which in his turn talked 433 Mhz to our outlets turning lights on and off. All was dandy until Android 4 came along and something stopped working security wise and we were send back into the middle ages.
              Today I successfully got MySensors working enabling me to read temp/hum from a node and letting me send Elro signals into the air over 433Mhz from OpenHAB2. Now I can scale, extend and upgrade my sensors and actuators I can move forward and start improving our home.
              Arduino Uno r3, 433Mhz transmitter, DHT11 sensor
              • I
                I
                itbeyond
                Today I completed the installation of the first of my 4 channel 240V LED light dimmers. This is installed in the roof and supports 4 buttons to turn on/off/increase/decrease each channel. It uses an AC zero crossing detector circuit and can be configured for leading or trailing edge dimming.
                • dbemowskD
                  dbemowskD
                  Working on a smart clock project. Need to make some major code modifications to the example, but should work. I have a test sketch that just passes the time from the RTC to the display, so I know that is all working.
                  0_1509332623272_upload-b119edce-2231-4ce0-9b9c-c5bd4ca629d5
                  0_1509332689597_upload-2dbe753a-35af-4793-bf46-52669aed4bb0
                  0_1509332950856_upload-a1744ea1-3830-4cf6-816b-f273431a596b
                  • sundberg84S
                    sundberg84S
                    Last night I made a enclosure to my new outdoor weather station/node. It is made from 2x 70mm sewer pipe end caps and a small sewer pipe to keep them together. Works surprisingly great and looks good.
                    Now its painted black and drying - lets hope I can find any daylight this week and mount/deploy it.
                    0_1509350485595_upload-60220e56-06da-42b0-9171-f503ceb23d78
                    0_1509350504395_upload-1b94da77-a353-4562-912b-5dd9ba426169
                    dbemowskD 1 Reply Last reply
                    • sundberg84S sundberg84
                      dbemowskD
                      dbemowskD
                      @sundberg84 If this is going to be out in the sun, I would think you'd want it white. Black is going to heat up your electronics quite a bit.
                      • dbemowskD dbemowsk
                        sundberg84S
                        sundberg84S
                        @dbemowsk - No worries, no sun! All below a roof so I get shade all the day. The roof is black so I need it to blend in as well.
                          SquareKinematics
                          I soldered together the PCB I made for my RFM69 Pi Gateway. Next step is to put it in a nice enclosure
                          • S SquareKinematics
                            A set of Node-Red nodes to decode OpenTherm messages produced by thermostats and Central Heating systems: https://github.com/Yveaux/node-red-contrib-opentherm
                            It can e.g. replace the OpenTherm Monitor software from otgw by InfluxDB/Grafana :+1:
                            0_1509388666269_upload-a041d40e-fb40-4b6b-9c15-4bd8ec44d47f
                            Not a MySensors project, but nice anyway ;-)
                              #37
                              I did a quick port of my earlier project to make a breakout board for the BC832:
                              What's interesting about the BC832 is that it is a complete nRF52832 system: 32-bit ARM Cortex 4, wireless, flash, memory, RTC, and antenna, and the whole thing is smaller than a dime:
                              Of course, my ported breakout board, being as large as it is, doesn't do it justice. That's OK, though, because its main purpose is just to take the BC832 for a test drive.
                              • R
                                R
                                robosensor
                                Power (lower half) and external interfaces (upper half) PCB for my "entrance" MySensors node (unregulated voltage, +5V, +3.3V, doorbell detector, electronic door lock status, temperature, etc). I'm using conventional 220V=>6V transformers as main power supply and as simple 220V presence detector for doorbell.
                                • sundberg84S
                                  sundberg84S
                                  #39
                                  Let me present - How NOT to deploy a MySensors Node! Here is how you do: 1) Skrew everything solid to a wall 2) Power it up and make sure you have shorted a SDA / GND or VCC on your BMP sensor just because you dont doublecheck the colors 3)Forget to enable # My debug 4)Fetch your last BMP sensor but drop it on the lawn (pitch dark outside) 5) Spend 30min with a flashligh in 5dgr C searching for the sensor and try it out once you find it. 6) Nothing works so Un-screw everything and connect it to FTDI inside at your computer, reupload the sketch with debug. - Now everything works fine (with the first sensor) for some unknown reason. 7) Skrew everything back again! 8) Find out the BMP sensor is not working 9) Debug Serial (atleast I got to use my new logger) 10) Find out a short on the MysX connector due to bent wire.
                                  0_1509477265850_upload-4cb4d2db-19b0-4c15-bb7c-85ae142145cc
                                  New and old sensor - side by side.
                                  0_1509477296115_upload-7e59bd8a-9c85-4db3-8a88-c86e21d1c7a4
                                  YveauxY NeverDieN 2 Replies Last reply
                                    @sundberg84 poor guy... +1 for persistence though :smirk:
                                      @sundberg84 Time for you to do a new PCB so you can get rid of all that wiring....
                                        sundberg84S
                                        sundberg84S
                                        @NeverDie Im waiting for someone to create those MysX shields so I just can attach them to my EasyPCB.
                                          @sundberg84 Where is the definitive description of MysX? Perhaps I might have a go at making some shields with it, if I knew what it was.
