1.1k Posts 105 Posters 792.9k Views 98 Watching
    Guys, you are deviating from the OPs thread "rules" ;)
    • sundberg84S
      sundberg84S
      I guess the thread can evolve the way it does - but in the same time, if there are a interesting ongoing discussion all mods are more than welcome to lift that discussion out for a own thread and if so we can keep this thread as intended?
      • micahM
        micahM
        micah
        Here is a project I finished this weekend.... 5m LED strip controller (the cover is off for the photo)
        I think you can say I've come quite far since my first ever arduino build... lol
        • sundberg84S
          sundberg84S
          Last night i continued improving my Logger (mostly protecting the serial input and make sure it can handle incoming serial logic from everything from 2.5v to 5v into my 3.3v system). I finally bought myself a oscilloscope so now I have the longest list possible of things I want to improve... (EasyPCB series, Booster performance?, some relays... the list goes on).
          0_1508830436618_upload-c1713104-7660-4530-b88e-7a8a7cadc109
          • sundberg84S
            sundberg84S
            Tonight I changed the mechanic trigger to a optocoupler on my doorbell node. I went with some sort of half good solution.
            8v AC (Doorbell activated) -> Diode (Not a full bridge, just a support capacitor) -> Voltage divider -> optocoupler > D3. Worked out great, but might be one of the ugliest nodes I have :)
            Testing/Soldering/Deployment:
            0_1508867567585_upload-f1e406e5-6af9-4433-8108-07badff5200d
              I changed the form of my integrated nRF52832-protoboard:
              Previously, I was using: https://www.openhardware.io/view/472/Ebyte-nRF52832-Prototyping-Board
              • sundberg84S
                sundberg84S
                Today I made some small changes to a battery node. Once again I had copy/pasted all battery code but forgot the internalReference in setup() (since I copy from another node sketch). So I now created a dedicated file for battery code I can use to copy from... and once again I remembered I'm not a coder... But it works.
                https://github.com/sundberg84/MySensors2.0.0/blob/master/BatteryMeasurer/BatteryMeasurer.ino
                dbemowskD 1 Reply Last reply
                • sundberg84S sundberg84
                  dbemowskD
                  dbemowskD
                  @sundberg84 Not to be critical or get off topic, but it's percent, not procent
                  • R
                    R
                    robosensor
                    Simple RS485 gateway and node for two BME280 sensors:
                      Made a small tool to simplify the extraction of serial debug data from a 10-pin IDC connector and reading it from a typical 6-pin FTDI module.
                      The 10-pin IDC connector is what's most commonly used for programming nRF5x modules.
                      • mfalkviddM
                        #26
                        Not really MySensors-related, but I found a nice logging library for Arduino that I'm using in a project. The library was orphaned some time ago, but now has a new maintainer. I assisted with an update of the documentation and some source code cleanup.
                        0_1509023431067_upload-51ff881d-811a-461d-ab1a-7a6189debe28
                          #27
                          I made an nRF52832 board today with 5 different colored LED's on it: red, green, yellow, orange, and blue. Mostly I think it may be useful while debugging code. All the LED's except for blue emit light all the way down to 1.8v source voltage, so it's good for battery powered operation also. The blue lights up all the way down to 2.4v, and I had to grapple with a 0403 LED to get that low of a voltage for a blue LED. In the end it was so tiny that I couldn't see the polarity of it, so I hit on the idea of running a blink program and seeing whether it would light up just before I soldered it in place. That worked. :)
                          Also, this board channels its serial output over the 10-pin IDC connector, so I used the tool I posted yesterday to read it. Works great, and now I don't have a six pin FTDI connector cluttering up the PCB. :)
                            Today my boards for the BT832X (that's an nRF52832 with both PA and LNA) arrived from OSH PARK, so I put one together to try it out:
                              sPENKMAN
                              A (long) time ago I had my own Android app which talked xmlrpc to a Python script, which talked serial with my Arduino which in his turn talked 433 Mhz to our outlets turning lights on and off. All was dandy until Android 4 came along and something stopped working security wise and we were send back into the middle ages.
                              Today I successfully got MySensors working enabling me to read temp/hum from a node and letting me send Elro signals into the air over 433Mhz from OpenHAB2. Now I can scale, extend and upgrade my sensors and actuators I can move forward and start improving our home.
                              Arduino Uno r3, 433Mhz transmitter, DHT11 sensor
                              • I
                                I
                                itbeyond
                                Today I completed the installation of the first of my 4 channel 240V LED light dimmers. This is installed in the roof and supports 4 buttons to turn on/off/increase/decrease each channel. It uses an AC zero crossing detector circuit and can be configured for leading or trailing edge dimming.
                                • dbemowskD
                                  dbemowskD
                                  Working on a smart clock project. Need to make some major code modifications to the example, but should work. I have a test sketch that just passes the time from the RTC to the display, so I know that is all working.
                                  0_1509332623272_upload-b119edce-2231-4ce0-9b9c-c5bd4ca629d5
                                  0_1509332689597_upload-2dbe753a-35af-4793-bf46-52669aed4bb0
                                  0_1509332950856_upload-a1744ea1-3830-4cf6-816b-f273431a596b
                                  • sundberg84S
                                    sundberg84S
                                    Last night I made a enclosure to my new outdoor weather station/node. It is made from 2x 70mm sewer pipe end caps and a small sewer pipe to keep them together. Works surprisingly great and looks good.
                                    Now its painted black and drying - lets hope I can find any daylight this week and mount/deploy it.
                                    0_1509350485595_upload-60220e56-06da-42b0-9171-f503ceb23d78
                                    0_1509350504395_upload-1b94da77-a353-4562-912b-5dd9ba426169
                                      dbemowskD
                                      dbemowskD
                                      @sundberg84 If this is going to be out in the sun, I would think you'd want it white. Black is going to heat up your electronics quite a bit.
                                      • dbemowskD dbemowsk
                                        sundberg84S
                                        sundberg84S
                                        @dbemowsk - No worries, no sun! All below a roof so I get shade all the day. The roof is black so I need it to blend in as well.
                                          SquareKinematics
                                          I soldered together the PCB I made for my RFM69 Pi Gateway. Next step is to put it in a nice enclosure
