  3. 2.2.0-rc.1 sleep not working as expected...
9 Posts 4 Posters 2.8k Views 4 Watching
  • skywatchS Offline
    skywatchS Offline
    skywatch
    I have a pro mini with 1MHz bootloader (running at 3.3v to test).
    I am using the door sensor from the 'build' page, with the addition of a sleep function as it will be battery powered.
    Here is the code...
    #define MY_RF24_PA_LEVEL RF24_PA_HIGH   //Options are: RF24_PA_MIN, RF24_PA_LOW, RF24_PA_HIGH or RF24_PA_MAX
    //#define MY_NODE_ID 1
    unsigned long SLEEP_TIME = 0; // Sleep time between reports (in milliseconds)
    #define CHILD_ID 3
    #define BUTTON_PIN  3  // Arduino Digital I/O pin for button/reed switch
    Bounce debouncer = Bounce();
    int oldValue=-1;
      // Setup the button
      pinMode(BUTTON_PIN,INPUT);
      // Activate internal pull-up
      debouncer.attach(BUTTON_PIN);
      debouncer.interval(5);
      Serial.begin(4800);
      sendSketchInfo("Door Sensor", "1.0");
      present(CHILD_ID, S_DOOR);
      debouncer.update();
      // Get the update value
      int value = debouncer.read();
      if (value != oldValue) {
         // Send in the new value
         send(msg.set(value==HIGH ? 1 : 0));
         oldValue = value;
         Serial.print("Value change  ");
         Serial.println(value);
     // sleep(digitalPinToInterrupt(BUTTON_PIN), CHANGE, SLEEP_TIME);
    With this setup it will only work with sleep commented out (ie no sleep function). As soon as I remove the comment from sleep it fails to send on pin change.
    I invite anyone to test this out for themselves and tell me if it works or not for you.
    Thanks for any help....
    • rejoe2R Offline
      rejoe2R Offline
      rejoe2
      Not sure, but your problem may be related to the use of debounce() and sleep().
      As on PINs 2+3 there is already some sort of debouncing from mcu side, you may just use the same code as in the motion sensor example without further debouncing.
      • skywatchS Offline
        skywatchS Offline
        skywatch
        @rejoe2
        Thanks for the reply.
        That is bizzare. I would expect the two sketches to be the same as it is basically the same thing (a button press).
        I modified the motion to report as a door, here is the code.
         * Version 1.0 - Henrik Ekblad
        // Enable debug prints
        // #define MY_DEBUG
        //#define MY_RADIO_NRF5_ESB
        //#define MY_RADIO_RFM95
        uint32_t SLEEP_TIME = 0; // Sleep time between reports (in milliseconds)
        // Initialize motion message
            sendSketchInfo("Door Sensor", "2.0");
            // Read digital motion value
            bool tripped = digitalRead(DIGITAL_INPUT_SENSOR) == HIGH;
            Serial.println(tripped);
        I will try and get more time to test this out again. Maybe tomorrow. I wonder if having the nrf24l01+ irq pin attached to the pro mini has some effect? Again will test out when I can.
        rejoe2R 1 Reply Last reply
        • M Offline
          M Offline
          manutremo
          I have used that same debouncer library but not in a battery powered node. I'm not sure I fully understand how the debouncer library and the sleep in interrupt mode may play together, but I'd bet the problem is there...
          You may want to ask the author on the official questions thread here.
          • skywatchS Offline
            skywatchS Offline
            skywatch
            @manutremo
            Thanks for the input - I did get further with this, but have different issues now. I will get back if I find a solution. I hope to get time this weekend to have a good look into my code and see what the issue might be. Failing this I will post how far I get and ask for more input from the friendly helpful people on here. :)
            • skywatchS skywatch
              @rejoe2
              // #define MY_DEBUG
              rejoe2R Offline
              rejoe2R Offline
              rejoe2
              @skywatch said in 2.2.0-rc.1 sleep not working as expected...:
              The irq@nRF is not used yet within MySensors. Afik this is planned for version 3.0 (don't have any link wrt this at the moment).
              • skywatchS Offline
                skywatchS Offline
                skywatch
                @rejoe2
                Apparently it is implemented....
                https://forum.mysensors.org/topic/7833/do-i-need-to-implement-the-irq-on-future-pcbs-for-nodes/3
                  @rejoe2
                  rejoe2R Offline
                  rejoe2R Offline
                  rejoe2
                  @skywatch Thx for clarification.
                  Seems this is a very recent development (I only knew this to be planed for V3, so things are ahead of theit time..). Nevertheless, most users will not yet have activated the MY_RX_MESSAGE_BUFFER_FEATURE.
                  Y 1 Reply Last reply
                  • rejoe2R rejoe2
                    Y Offline
                    Y Offline
                    @rejoe2 it is a feature currently mainly useful for gateways. Furthermore, only avr is supported, as far as I know.
                    It has been in for over a year iirr.
