  2. Announcements
  • Sergio RiusS Sergio Rius
    Today my rPi gateway (2.1.1 stable) completely stopped working as a service (cli surprisingly worked), I thought that could be some debian update so I switched to devel, but when building it I get this:
    LINUX_ARCH_RASPBERRYPI -DMY_PORT=5003 -DMY_RX_MESSAGE_BUFFER_FEATURE -DMY_RF24_IRQ_PIN=18 -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/BCM/bcm2835.c -o build/drivers/BCM/bcm2835.o
    drivers/BCM/bcm2835.c: In function ‘bcm2835_delayMicroseconds’:
    drivers/BCM/bcm2835.c:441:40: error: expected ‘)’ before ‘PRIu64’
    printf("bcm2835_delayMicroseconds %" PRIu64 "\n", micros);
    drivers/BCM/bcm2835.c:441:40: warning: spurious trailing ‘%’ in format [-Wformat=]
    Makefile:102: recipe for target 'build/drivers/BCM/bcm2835.o' failed
    make: *** [build/drivers/BCM/bcm2835.o] Error 1
    Is this normal? I used the same configure was working before.
    @Sergio-Rius a fix is available at https://github.com/mysensors/MySensors/pull/983
    It is a one line change so you can just add it manually
    • Sergio RiusS
      Sergio RiusS
      Sergio Rius
      #674
      Thaaanksss! I'll give it a go :)
      • Sergio RiusS
        Sergio RiusS
        Sergio Rius
        @mfalkvidd Mmmmm... that worked, but now I'm always getting "mysgw: !TSM:INIT:TSP FAIL" as stated avobe. But I'm on development.
        Wait, seems that after the 8'th intent it's working. I'll let him go and see.
        • Sergio RiusS
          Sergio RiusS
          Sergio Rius
          #676
          I'm afraid that after some time it stops working. I get in Domoticz:
          2017-11-12 19:17:01.744 MySensors: trying to connect to: 127.0.0.1:5003
          2017-11-12 19:17:02.744 TCP: Connection problem (Unable to connect to specified IP/Port)
          2017-11-12 19:17:02.744 TCP: Reconnecting in 30 seconds...
          Over and over again.
          $ sudo systemctl status mysgw.service
          ● mysgw.service - MySensors Gateway daemon
          Loaded: loaded (/etc/systemd/system/mysgw.service; enabled)
          Active: failed (Result: signal) since dom 2017-11-12 19:16:53 CET; 5min ago
          Process: 491 ExecStart=/usr/local/bin/mysgw (code=killed, signal=SEGV)
          Main PID: 491 (code=killed, signal=SEGV)
          nov 12 19:16:47 Domoticz systemd[1]: Started MySensors Gateway daemon.
          nov 12 19:16:48 Domoticz mysgw[491]: Starting gateway...
          nov 12 19:16:48 Domoticz mysgw[491]: Protocol version - 2.2.0-rc.1
          nov 12 19:16:53 Domoticz systemd[1]: mysgw.service: main process exited, code=killed, status=11/SEGV
          nov 12 19:16:53 Domoticz systemd[1]: Unit mysgw.service entered failed state.
          But it seems Domoticz being crashing it.
          If I do restart the service, Domoticz picks it and works for a while.
          2017-11-12 19:24:17.562 TCP: Connection problem (Unable to connect to specified IP/Port)
          2017-11-12 19:24:17.562 TCP: Reconnecting in 30 seconds...
          2017-11-12 19:24:47.565 TCP: Reconnecting...
          2017-11-12 19:24:47.565 MySensors: connected to: 127.0.0.1:5003
          2017-11-12 19:24:48.566 MySensors: Gateway Ready...
          2017-11-12 19:24:48.566 MySensors: Gateway Version: 2.2.0-rc.1
          2017-11-12 19:24:49.566 MySensors: Gateway Version: 2.2.0-rc.1
          Is there any further log for exactly seeing what is the crash cause?
          EDIT: Also it seems that there's any comunication at all. I only get internal heartbeats on MysController.
            Did you get the latest version from development branch?
              Sergio RiusS
              Sergio RiusS
              Sergio Rius
              #678
              @gohan Yep! I exactly ran this command:
              git clone https://github.com/mysensors/MySensors.git --branch development && cd MySensors
              I'm now powering off my rPi for changing the PA+LNA radio for a standard one and bypassing the power regulator.
              EDIT: I've done the above tasks and still getting strange things. It may be Domoticz as:
              2017-11-12 19:44:37.634 MySensors: trying to connect to: 127.0.0.1:5003
              2017-11-12 19:44:37.638 RFXCOM: Using serial port: /dev/ttyUSB0
              2017-11-12 19:44:38.213
              2017-11-12 19:44:38.288 Error: RFXCOM: Invalid data received!....
              2017-11-12 19:44:38.635 MySensors: connected to: 127.0.0.1:5003
              2017-11-12 19:44:38.635 MySensors: Gateway Ready...
              2017-11-12 19:44:39.635 MySensors: Gateway Version: 2.2.0-rc.1
              2017-11-12 20:26:00.153 Error: Scheduler thread seems to have ended unexpectedly
              2017-11-12 20:26:00.154 Error: MySGW_NRF hardware (9) thread seems to have ended unexpectedly
              2017-11-12 20:26:00.154 Error: RFXCOM hardware (15) thread seems to have ended unexpectedly
              2017-11-12 20:26:00.154 Error: RFXCOM hardware (15) nothing received for more than 30 Minutes!....
              2017-11-12 20:26:01.155 Error: Restarting: RFXCOM
              2017-11-12 20:26:01.707 RFXCOM: Serial Worker stopped...
              2017-11-12 20:26:02.722 RFXCOM: Using serial port: /dev/ttyUSB0
              2017-11-12 20:26:03.297
              2017-11-12 20:26:03.372 Error: RFXCOM: Invalid data received!....
              2017-11-12 20:26:16.745 (RFXCOM) Temp + Humidity (Biblioteca [TH])
              2017-11-12 20:26:48.745 Error: PROXY: timeout occurred, reconnecting
              2017-11-12 20:26:54.716 (MySGW_NRF) Temp (Temp)
              2017-11-12 20:26:54.717 (MySGW_NRF) Temp + Humidity (TempHum)
              and stabilized
                If you keep a myscontroller connected to the gateway, does it stays connected or does it get disconnected at the same time as domoticz? Also try to run the gateway from console with debug enabled so you can actually see what it is doing
                • alowhumA
                  alowhumA
                  alowhum
                  #680
                  Possibly same problem with Domoticz here too. Using a directly attached NRF24 radio to a Raspberry Pi Zero W.
                  I tried to remake using the latest dev code, and got this error:
                  gcc -MT build/drivers/BCM/bcm2835.o -MMD -MP -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_PORT=5003 -DMY_RF24_PA_LEVEL=RF24_PA_LOW  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/BCM/bcm2835.c -o build/drivers/BCM/bcm2835.o
                  // commenting out the problem allowed make to finish:
                  	//if (debug) {
                  	//	/* Cant access sytem timers in debug mode */
                  	//	printf("bcm2835_delayMicroseconds %" PRIu64 "\n", micros);
                  	//	return;
                  This is my config:
                  ./configure --my-transport=nrf24 --my-rf24-pa-level=RF24_PA_LOW --my-gateway=ethernet --my-port=5003
                  • A
                    aglock
                    Hello all!
                    I'm trying to build a gateway with a Raspberry pi2, ethernet and Domoticz.
                    It looks like the gateway is beeing built ok and seems to run fine but nodes can not communicate with it.
                    I have read most of the postings here but I can not find any solution.
                    Hope you guys can help? Please!
                    I run raspbian (Jessie)
                    pi@raspberrypi:~/MySensors/bin $ uname -a
                    Linux raspberrypi 4.9.35-v7+ #1014 SMP Fri Jun 30 14:47:43 BST 2017 armv7l GNU/Linux
                    Using master branch
                    https://www.mysensors.org/build/raspberry
                    Configuring like this
                    pi@raspberrypi:~/MySensors $ ./configure --my-gateway=ethernet --my-port=5003 --my-transport=nrf24 --my-rf24-ce-pin=22 --my-rf24-cs-pin=24
                    [OK] Finished.
                    Obs! No Raspberry identification, why not? Maybe that is the culprit?
                    After make I start the gateway and get this:
                    pi@raspberrypi:~/MySensors $ cd bin
                    pi@raspberrypi:~/MySensors/bin $ sudo ./mysgw -d
                    mysgw: Starting gateway...
                    mysgw: TSM:INIT
                    mysgw: TSF:WUR:MS=0
                    mysgw: TSM:INIT:TSP OK
                    mysgw: TSM:INIT:GW MODE
                    mysgw: MCO:REG:NOT NEEDED
                    mysgw: MCO:BGN:STP
                    mysgw: MCO:BGN:INIT OK,TSP=1
                    mysgw: Client 0 connected
                    mysgw: Client 0: 0;0;3;0;2;
                    Seems nice and dandy and Domoticz connecting fine.
                    Trying with this example node:
                    #define MY_NODE_ID 42
                    #define MY_BAUD_RATE 9600
                    #include<Arduino.h>
                    #define OPEN 1
                    #define CLOSE 0
                    #define CHILD_ID 1
                    uint8_t value = OPEN;
                      Serial.print("setup()\n");
                      sendSketchInfo("Door", "2.1.1");
                      present(CHILD_ID, S_DOOR);
                      Serial.print("presentation()\n");
                      value = value == OPEN ? CLOSE : OPEN;
                      send(msg.set(value));
                      Serial.print("message sent");
                      Serial.print(value + "\n");
                      sleep(1000);
                    And recieve this when running:
                    --- Miniterm on /dev/ttyUSB0 9600,8,N,1 ---
                    --- Quit: Ctrl+C | Menu: Ctrl+T | Help: Ctrl+T followed by Ctrl+H ---
                    40 TSM:INIT
                    55 TSF:WUR:MS=0
                    77 TSM:INIT:TSP OK
                    96 TSM:INIT:STATID=42
                    120 TSF:SID:OK,ID=42
                    141 TSM:FPAR
                    190 TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    2267 !TSM:FPAR:NO REPLY
                    2291 TSM:FPAR
                    2340 TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    4417 !TSM:FPAR:NO REPLY
                    4442 TSM:FPAR
                    4491 TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    6569 !TSM:FPAR:NO REPLY
                    6594 TSM:FPAR
                    6643 TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    8720 !TSM:FPAR:FAIL
                    8740 TSM:FAIL:CNT=1
                    8761 TSM:FAIL:PDT
                    And no output in gateway either.
                    Both radio modules using capacitors.
                    What have I missed?
                    Thanks, Andreas!
                    gohanG 1 Reply Last reply
                    • skywatchS
                      skywatchS
                      skywatch
                      I tried for months to get a stable working nrf24 attached to pi to act as a gw and controller.
                      In the end I gave up and now have a 3.3V 8MHz pro mini gw attached to the pi. I took 0v and 5v from the pi (via a 3.3v buck converter) and serial tx and rx. Only 4 wires needed and has been as stable as can be for over a week now.
                      Maybe help someone with the same unsolveable problems?
                      • A aglock
                        Hello all!
                        Using master branch
                        [OK] Finished.
                        mysgw: TSM:INIT
                        mysgw: TSF:WUR:MS=0
                        mysgw: MCO:BGN:STP
                        #include<Arduino.h>
                        #define OPEN 1
                        #define CLOSE 0
                        #define CHILD_ID 1
                          sleep(1000);
                        40 TSM:INIT
                        55 TSF:WUR:MS=0
                        77 TSM:INIT:TSP OK
                        141 TSM:FPAR
                        2291 TSM:FPAR
                        4442 TSM:FPAR
                        6594 TSM:FPAR
                        8720 !TSM:FPAR:FAIL
                        8740 TSM:FAIL:CNT=1
                        8761 TSM:FAIL:PDT
                        What have I missed?
                        Thanks, Andreas!
                        @aglock I put a note on the raspberry gateway page to use latest development in case of problems with stable. Did you try?
                        A 2 Replies Last reply
                          aglock
                          @gohan yes. Interesting though when I used git to switch between branches it said all files where the same?
                          Do you think the fault is in the gateway somehow?
                            aglock
                            @gohan Tried it again
                            configure now recognizes the rpi:
                            pi@raspberrypi:~/mys_dev $ ./configure --my-gateway=ethernet --my-port=5003 --my-transport=nrf24 --my-rf24-ce-pin=22 --my-rf24-cs-pin=24
                              [OK] machine detected: SoC=BCM2836, Type=rpi2, CPU=armv7l.
                              [OK] SPI driver detected:BCM.
                            [OK] Finished.
                            But make fails with the following error:
                            What to do about it?
                            • A aglock
                              [OK] Finished.
                              @aglock see https://forum.mysensors.org/post/79403
                              A 1 Reply Last reply
                                aglock
                                @mfalkvidd Wow, thanks that works! :D
                                • WoekaW
                                  WoekaW
                                  Woeka
                                  Got mysensors gateway working on gpio of my Pi again using ./configure --my-transport=nrf24 --my-rf24-irq-pin=15 --my-leds-err-pin=12 --my-leds-rx-pin=16 --my-leds-tx-pin=18 --my-gateway=ethernet --my-port=5003
                                  However on tx or tx always the two leds connected to pin 16 and 18 are lit. More people with the same problem?
                                  • WoekaW Woeka
                                    sineverba
                                    @Woeka There is (on Arduino Gateway) a function named "DEFINE INVERSE BLINK". Try to search for same for PI....
                                    • R
                                      R
                                      romeo01
                                      wrote on last edited by romeo01
                                      #690
                                      Can we use the "debug ota log" features with the raspberryPi gateway ??
                                      My node is not accessible and runs MYSBootloader.
                                      My gateway is raspberryPI.
                                      Now, I need to update the firmware on my node. Via MYSController, no problems, upload runs like a charm.
                                      But how to do for debugging my sketch ? Some bugs appear...... , I need to take a look on some vars values.
                                      Usually, I use the serial port with serial.print(some vars).
                                      Which alternative I have to use without serial port, only OTA features ?
                                      Thanks for the great work !!
                                        Unless you are using an esp8266, I don't think you can remote debug a pro mini. @sundberg84 is working on a serial logger to microsd card, maybe it could help you in some way
                                        • R
                                          R
                                          romeo01
                                          In fact, I do not need to log, but need to look what's happen in my sketch.
                                          The new "OTALog" function, MY_OTA_LOG_SENDER_FEATURE or MY_DEBUG_OTA seems to be the good way.
                                          From the docs, it allows to send a debug message to another node or gateway via OTA.
                                          But how to got the debug message from OTA node, on the gateway side (RaspberryPi) ?
