  3. Recommendation for PCB fab?
71 Posts 13 Posters 28.1k Views 14 Watching
  • gerritvG
    gerritvG
    gerritv
    The default surface finish at Elecrow is HASL. ENIG is goldie colour but more expensive. There are a few others as well.
    Good explanation of differences: http://www.epectec.com/articles/pcb-surface-finish-advantages-and-disadvantages.html
    OSH might be using OSP / Entek coating.
    IMHO it is an appearance thing for us hobbyists. As long as it is not bare copper it should be ok.
      @gohan Third sentence immediately above.
      @NeverDie I actually meant the costs split
      • gerritvG
        gerritvG
        gerritv
        US4.90 for 10 boards (100x50) on special, US4.85 shipping to Canada.
          Today I received another order from Elecrow. This time it took 18 days to receive from the date of order. However, they did send me 12 boards instead of 10, so that's nice. :)
          Nca78N 1 Reply Last reply
            @NeverDie said in Recommendation for PCB fab?:
            That is still pretty quick if you selected the cheap shipping option !
            NeverDieN mtiutiuM 2 Replies Last reply
            • Nca78N Nca78
              #35
              @Nca78 said in Recommendation for PCB fab?:
              Yup, it was this board here: https://www.openhardware.io/view/472/Ebyte-nRF52832-Prototyping-Board
              Shipped using the cheapest shipping option.
              • Nca78N Nca78
                mtiutiuM
                mtiutiuM
                mtiutiu
                @Nca78
                Elecrow is a good fab imho and yes they are very generous - I received too my boards today and instead of 5pcs I received 11pcs !!!. And this is not the first time they deliver more than requested. The price - 5$ for boards and 3.5$ shipping(standard mail) - 8.5$ in total. And yes they are the cheapest and pretty good quality pcbs - I'm very pleased about their services so far. They beat all the Chinese fabs including shipping so far(and the quality is pretty good - at least for what I need my pcbs for it's well beyond my expectations).
                  #37
                  At the moment I'm getting a PCB fabricated by pcbway (my fist time using them). They give tracking info which (allegedly) shows exactly where your PCB is in the manufacturing process. For example, here's the status of my board at this very moment:
                  MI (Manufacture Instruction)	 	 11/13/2017 10:04:37 AM
                  Cut Lamination	 	 11/13/2017 11:41:12 AM
                  Drill	 	 11/13/2017 11:44:05 AM
                  Plated Through Hole
                  Circuit
                  Etching
                  AOI
                  Solder Mask
                  Silkscreen
                  Surface Treatment
                  Double Drilling
                  Routing
                  Testing
                  Package
                  Delivery Ready
                  i.e. the first drilling is finished, and the next step for it is the thru-hole plating. They update the status once every 5 minutes.
                  The other interesting thing is that they have a chat window, so you can chat with them anytime about your order. I asked them a question at about 4am China time, and within about a minute or two I got an answer.
                  • dbemowskD
                    dbemowskD
                    I designed and fabricated my light switch boards at EasyEDA. the board quality was excellent, and they were fast.
                      In case anyone is interested, here's a record of how much time each step in the fabrication took:
                      Plated Through Hole	 	 11/13/2017 3:12:32 PM
                      Circuit	 	 11/13/2017 4:07:36 PM
                      Etching	 	 11/13/2017 6:03:07 PM
                      AOI	 	 11/13/2017 7:33:56 PM
                      Solder Mask	 	 11/13/2017 7:34:02 PM
                      Silkscreen	 	 11/13/2017 9:20:59 PM
                      Surface Treatment	 	 11/13/2017 10:36:35 PM
                      Double Drilling	 	 11/14/2017 12:48:23 AM
                      Routing	 	 11/14/2017 4:23:57 AM
                      Testing	 	 11/14/2017 4:50:50 AM
                      Package	 	 11/14/2017 7:56:46 AM
                      I had thought that maybe they could fabricate and ship on the same day, but apparently fabrication takes too long for that.
                        #40
                        I've started a second order through PCBway, and it appears that they start fabrication on a batch each day around 10 or 11am China time. If you get your order in and it passes their review before then, then most likely they'll start fabricating it that day. Otherwise, it appears that the order rolls over to the next day.
                        One nice feature is that you can keep adding new items to the order even after fabrication has started on some of them. In this case, the shipping cost on all the items is combined and the shipping deadline for the entire order is governed by the last item ordered.
                          FWIW, I received this micro-USB test board from PCBway today:
                          As you can plainly see, it appears they had no difficulty fabricating the plated slots. In fact, they didn't even flag it as a possible issue.
                          • Nca78N
                            It seems there's a fast + good (enough) + cheap options now, AllPCB asks 5$ for 10 boards up to 100*100mm, it's limited to 1.6mm, green or white color (take the green, quality of the white silkscreen is not good, not fitting between pads of an atmega328 for example).
                            Doesn't sound like a great offer now, but there are some insane things :
                            • the "top speed" option is included meaning your board are done in 2-3days after order
                            • there is free shipping with HK Post
                            • there is free shipping ... with DHL :open_mouth:
                            Result is boards received 6 days after placing orders, very impressive !
                            And good point I order 10 but for the biggest bord (98*98mm) I received 12, and for the smallest I received... 34 while with another small board I received around 20.
                            So if you want to test your boards quickly and don't mind the 1.6mm thickness in green color, this is the perfect offer. Every option that you will select (color, thickness, panelization,...) will make the price increase quickly, but it's a good way to test functionality of your board quickly then order fancy colors/thickness etc from another fab when your board is completely designed.
                            • Nca78N Nca78
                              #43
                              @Nca78 Great post! Thank you. I ordered a PCB from them to see if they can handle plated slots. So far it appears they can: it passed their review without comment, and it's now in fabrication.
                              Just curious: is there any particular reason to think 1.6mm isn't thick enough for the final board rather than just a test board? I mean, maybe for BGA, but I don't think anyone here is using that.
                              • Nca78N
                                Warning: do NOT make boards with white solder mask at AllPCB, keep the green color as it's the only cheap color available.
                                I had all sorts of problems with boards made in white, I probably have a design problem with that board but the solder mask that peels away too easily (and pads following closely !) make it hard to solder a QFN component correctly.
                                No problem with green color until now.
                                • Nca78N Nca78
                                  #45
                                  @nca78 It was great while it lasted. They just raised their rates from $5 to $20, including the DHL shipping. :sob:
                                  I could place my order on Monday and receive it on Friday, all for $5. Knew it wouldn't last though. Like you say, their pricing was "insane." In a way, I suppose it still is.
                                  [Edit: Correction, the old deal is still good. :) It's for 5 pieces now instead of 10. Get it while it lasts!]
                                  S 1 Reply Last reply
                                    sineverba
                                    @neverdie Limited 50mm x 50mm at 5$, 100x100 15$. So, for small pcb price is same. For bigger, price is insane bytheway including DHL ship. From China to Italy, 3 days. Fantastic!
                                    • S sineverba
                                      @sineverba said in Recommendation for PCB fab?:
                                      Looks like a strategy for them. Start with extremely low price, then add restrictions in a progressive way, and people will accept to pay more and more because "it's still cheap" for the DHL version. But right now there is no "cheap" option, and if you order 3 PCBs bigger than 5*5cm you're at the same price than other manufacturers, even including the DHL shipping.
                                      And if you're not in a hurry it's way cheaper to select HK Post with Elecrow from the first PCB.
                                        #48
                                        Argh. AllPCB raised their prices again. Looks like the $5 deal is totally gone now. Now it's $12-14 for 5 small PCB's.
                                          sineverba
                                          @neverdie Yes :( Fortunately shipment is very, very fast and free (for the moment) :(
