  3. Easy/Newbie PCB for MySensors
257 Posts 37 Posters 180.4k Views 38 Watching
  • sundberg84S sundberg84
    @sincze - so it sounds like you have issues between pcb connector and A0 pin on the atmega328. You could try to do a continuitytest between that - and check soldering job on the MysX connector and on the back on the pro mini (A0)
    0_1510823476205_upload-31f0d5a6-9fc8-42a1-bf58-2a6d7f490457
    sinczeS
    sinczeS
    sincze
    MySensors Evangelist
    @sundberg84 Just for the check A0 or D3 (temp sensor)?
    As A0 is working, I have a relais attached to it. ;)
    • sinczeS sincze
      sundberg84S
      sundberg84S
      @sincze sorry - my misstake, D3 offcourse. You can do if from D3 on the MysX connector to D3 on the atmega chip. D3 on the cjip is the upper left pin on the image.
      0_1510831452813_upload-0d859cac-e93c-40ad-9f2f-f68ddcd6fdeb
      sinczeS 1 Reply Last reply
        sinczeS
        sinczeS
        sincze
        wrote on last edited by sincze
        #188
        @sundberg84 yes, I have a 'beep' pffffff would a double resistor hurt ?? 1 on pcb the other one in the cable?
        I tried connecting it directly to pin 3 on the arduino, no detection, I tried replacing the resistor. nothing. I tried a different temp sensors.. No detection. I moved the new temp sensor to the nano... detected.
        I tried an empty Dallas temp only sketch on the mini... no detection. Well Now I'm lost ;-)
        dbemowskD sundberg84S 2 Replies Last reply
        • sinczeS sincze
          dbemowskD
          dbemowskD
          @sincze Can you possibly send pictures with how you have it connected both on the nano and on the mini? I am thinking that it is something obvious that is being missed.
          • sinczeS sincze
            sundberg84S
            sundberg84S
            @sincze - and you use the right power source on the PCB? (VCC = 5v and 3.3v = Well... 3.3v) Please send pictures of both setup as mentioned.
            • BarnaB
              BarnaB
              Barna
              Hi Sundberg84,
              I have some v8 and now enough time for playing.
              I setup with v3.3 2xAA, booster, NRF24, simple door sensor or DHT.
              1-2 week and the batteries are discharged, I hear little buzz from the mini or other components.
              This is the 2nd built where I meet this problem.
              Do you have any idea what component is the failed ?
              thanks
              Barna
              sundberg84S dbemowskD 2 Replies Last reply
                Did you remove the regulator and LED from the pro mini? Have you tried a different booster?
                • BarnaB Barna
                  Hi Sundberg84,
                  thanks
                  Barna
                  sundberg84S
                  sundberg84S
                  @Barna as @gohan said I suspect the booster as well. A small buzz is normally from that hardware.
                  Also did you implement sleep() ?
                  BarnaB 1 Reply Last reply
                    BarnaB
                    BarnaB
                    Barna
                    @sundberg84 this is not normal buzz, stronger than before.
                    I have used this source only: https://www.ebay.com/itm/mini-DC-DC-0-8-3-3V-to-DC-3-3V-Step-UP-Boost-Power-Module-For-Breadboard-Arduino-/281556288481?hash=item418e1003e1
                    which another part could make the buzz ?
                    yes, I use sleep
                    sleep(1, CHANGE, SLEEP_TIME); SLEEP_TIME is 900000 , but the node does not wake up and send the battery status, only when door sensor changes.
                    No, I have not removed the led and regulator, this is the testing period only :)
                      Those draw quite some energy, you'd better remove them and see from there
                      • BarnaB Barna
                        Hi Sundberg84,
                        thanks
                        Barna
                        dbemowskD
                        dbemowskD
                        @Barna What if you used a setup like this:
                        0_1510936047717_upload-c0db2caa-660d-4a18-a9a9-c9c2cf96935c
                        The 3volt tap can be used to power the arduino, and the DHT can be run from the 4.5v. With that you wouldn't need the step up booster.
                          sinczeS
                          sinczeS
                          sincze
                          @sundberg84 @dbemowsk Thank you guys for still trying to help me. I almost gave up on using a Dallas Termp sensor o n a pro mini. As said I even tried connecting the temp sensor directly to the pins with same results. If I connect the pins to my nano, it is being detected and transmitting temp values. I even used a different sketch.. Just for the temp sensor. link found_here. Changed it to use Pin 3 ofcourse. I even connected the whole thing to D2 (resistor back in the wires)... without being succesful either.
                          dbemowskD 1 Reply Last reply
                          • sinczeS sincze
                            dbemowskD
                            dbemowskD
                            @sincze Are you sure you sure you got correct power on the GND and VCC pins on the MySX connector?
                            • dbemowskD dbemowsk
                              sinczeS
                              sinczeS
                              sincze
                              @dbemowsk I had those thoughts as well.
                              The voltage should be okay. I can solder a new Arduino Pro Mini and see if that one wants to work with me ;-)
                              • sundberg84S
                                sundberg84S
                                Dallas temp sensors needs 3.3v VCC if I remember right. Not 5v.
                                  sinczeS
                                  sinczeS
                                  sincze
                                  #201
                                  @sundberg84 haha yes i was wondering that myself so tried it connecting it to 3,3v as well. However on the 5v nano working just fine. Technical specs tell me: Power supply range is 3.0V to 5.5V
                                  also mysensors link
                                  Pretty strange huh.
                                  sundberg84S zboblamontZ 2 Replies Last reply
                                  • sinczeS sincze
                                    also mysensors link
                                    Pretty strange huh.
                                    sundberg84S
                                    sundberg84S
                                    @sincze my mistake. Really strange this... Should work just fine. Can you upload a better resolution picture of your hardware and the sketch you are using?
                                    • sinczeS sincze
                                      also mysensors link
                                      Pretty strange huh.
                                      zboblamontZ
                                      zboblamontZ
                                      zboblamont
                                      @sincze I have 10 of these DS18B20s strung over approximately 12m monitoring all rooms on both floors of my house and two side lofts, all running on 3.22v from a Pro-Mini. Never have skipped a beat, reporting every 5 minutes, well, aside from a telephone socket which pins went walkabout (the chips are crimped to RJ11s).
                                      There is something not right with the physical arrangement if you can get the same circuit to report at 5v...
                                        sinczeS
                                        sinczeS
                                        sincze
                                        #204
                                        @sundberg84 I just soldered a myself a new out of the box pro mini using the same sketch..
                                        10246 TSF:MSG:SEND,8-8-25-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=4,st=OK:21.0
                                        250560 TSF:MSG:SEND,8-8-25-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:21.1
                                        255019 TSF:MSG:SEND,8-8-25-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:22.3
                                        259476 TSF:MSG:SEND,8-8-25-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:23.8
                                        263934 TSF:MSG:SEND,8-8-25-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:25.3
                                        268393 TSF:MSG:SEND,8-8-25-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:26.5
                                        272851 TSF:MSG:SEND,8-8-25-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:27.6
                                        277310 TSF:MSG:SEND,8-8-25-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:28.1
                                        281768 TSF:MSG:SEND,8-8-25-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:28.4
                                        290677 TSF:MSG:SEND,8-8-25-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:28.3
                                        295136 TSF:MSG:SEND,8-8-25-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:28.1
                                        299594 TSF:MSG:SEND,8-8-25-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:27.8
                                        304053 TSF:MSG:SEND,8-8-25-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:27.6
                                        308511 TSF:MSG:SEND,8-8-25-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:27.3
                                        312970 TSF:MSG:SEND,8-8-25-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:27.1
                                        317428 TSF:MSG:SEND,8-8-25-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:26.8
                                        321887 TSF:MSG:SEND,8-8-25-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:26.6
                                        326345 TSF:MSG:SEND,8-8-25-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:26.4
                                        Victory... :)
                                          Was the pro mini defective or just the pin you were using?
                                          12.5k
