  2. Feature Requests
  3. Is OpenThread a good fit?
Scheduled Pinned Locked Moved Feature Requests
7 Posts 3 Posters 4.2k Views 3 Watching
  • janaka_aJ Offline
    janaka_aJ Offline
    janaka_a
    wrote on last edited by janaka_a
    Has anybody considered https://openthread.io/ as an alternative protocol? It's designed for low power and a mesh topology. It isn't arduino compatible is a downside. However, the ecosystem isn't very mature and has a higher barrier to entry hence a project like mysensors.org can add a lot of value.
    N 1 Reply Last reply
    • janaka_aJ janaka_a
      N Offline
      N Offline
      @janaka_a it seems like a nice protocol but ... not arduino compatible, not compatible with the hardware used in MySensors, it doesn't look like something that could integrate with MySensors ?
      S janaka_aJ 2 Replies Last reply
      • N Nca78
        @janaka_a - First time poster linking to another site/project? One could think its only for advertising... using this method always sets me to a negative attitude about the project even before i started reading.
        Maybe you should look at the forum guidelines as well?
        • janaka_aJ Offline
          janaka_aJ Offline
          janaka_a
          Hey @sundberg84, apologies if the question is inappropriate here. I'm definitely not trying to advertise. It's a genuine question. My interests in IoT is purely a hobby I have no affiliation with Thread/Nest/Google. I've followed the Thread protocol from when it got announced as I was researching a stack that would allow me to build connected devices for home automation that communicates wirelessly over IP/TCP on a local areas network, supported peer-to-peer, and low power consumption. For some reason back then I hadn't understood that MySensors ticked most/all of those boxes although from what I understand Thread hardware consumes less power and uses TCP/IP.
          The downside to Thread is that the ecosystem is immature hence a high barrier to entry and I think the hardware is currently more expensive.
          It seemed like MySensors objectives were to build a platform and ecosystem to hack on top of hence thought there was alignment and a topic to discuss.
          S 1 Reply Last reply
          • N Nca78
            janaka_aJ Offline
            janaka_aJ Offline
            janaka_a
            @Nca78 correct it's a hardware stack of it's own.
              @janaka_a nice to hear and let's hope you find the answers. To many fake accounts today so it's hard to know true intentions.
              janaka_aJ 1 Reply Last reply
              • S sundberg84
                janaka_aJ Offline
                janaka_aJ Offline
                janaka_a
                @sundberg84 I understand (ordered myself a couple of Nrf24l01+ in the meantime).
                12.2k
