  3. HC-SR501 3.3V randomly sends tripped when radio is on
39 Posts 8 Posters 16.2k Views 8 Watching
    Or put the wire between the battery and spring/contact
    • B burningstone
      @mfalkvidd
      And how can i tape the wire on the side of the battery holder? My battery holder package already has two wires connected like in the fritzing pictures.
      @burningstone tape a wire directly on the battery, or solder to the battery or the holder.
      Look what you have lying around and be creative!
      That's what MySensors is about!
      B 1 Reply Last reply
      • YveauxY Yveaux
        B
        B
        burningstone
        @Yveaux
        Sorry I have been a long time away due to exams.
        Now I finally have time to spend for mysensors :)
        I tried your approach with the three batteries. My setup looks like this:
        I modified the HC-SR501 as shown below:
        The sketch is pretty simple, it sends the motion and the light level and then goes to sleep with interrupt for 30 minutes. I still get the false positives whenever the arduino doesn't wake up from intrerrupt.
        What am I doing wrong?
        YveauxY m26872M 2 Replies Last reply
          Try adding a cap on the power of the pir sensor, start from 10uf and try to increase up to 100uf and see if it gets better
          • B burningstone
            @Yveaux
            @burningstone what MySensors version are you running? I did solve an issue with waking from interrupts in 2.2 beta, that's still present in 2.1.x. This might be what's bothering you...
            • B burningstone
              @Yveaux
              m26872M
              m26872M
              m26872
              @burningstone You probably want to find the root cause to this but, as a quick fix, have you tried software-blocking the false trip with an additional sleep before the interrupt-activating sleep? Something like sleep(3000); before the last sleep(...). I do it with success for my mini-pirs.
              nagelcN 1 Reply Last reply
              • B
                B
                burningstone
                @Yveaux @gohan
                I updated the library to 2.2 and I put a 47uf cap between ground and vcc of the pir (hope that's what you mean't) and now it works.
                Thanks for your help!
                I soldered now everything onto a pcb and now the pir doesn't work. I feel like giving up, didn't think that it would be that hard for me to build one stable node. I spent almost 2 hours soldering and assembling and now it doesn't work :(
                dbemowskD 1 Reply Last reply
                • m26872M m26872
                  nagelcN
                  nagelcN
                  nagelc
                  @m26872 Thanks for this suggestion. I have had some PIR sensors that work normally and others that always trip immediately after going to sleep. It was really frustrating me. Adding the short sleep without interrupts solved this for me.
                    the standard cheap PIR sensors are known to trigger false positives because of power fluctuations
                    • B burningstone
                      @Yveaux @gohan
                      dbemowskD
                      dbemowskD
                      @burningstone Check connections with a continuity tester and measure your voltages coming to the arduino and PIR. When checking continuity, check directly from the jack on the PIR and/or temp sensor to the pro mini terminals, and also check pins near the connections for any possible shorts.
