  3. Problem with ethernet gateway
ethernetgateway
10 Posts 4 Posters 5.1k Views 2 Watching
  • O
    O
    oded00
    Hello all
    After many hours with my ethernet gateway I give up and ask for help
    when I starting the gateway the serial monitor state '0;0;3;0;14;Gateway startup complete.' but I cant ping to the gateway address.
    I try different ethernet sketch to eliminate hardware problem and all of them works good.
    what else can I check?
    working with 1.4 library on windows 7 OS with 1.0.6 IDE
      Is only ping a problem or can't you even connect to it?
      • O
        O
        oded00
        wrote on last edited by oded00
        From Vera side I get 'MySensors plugin : Cannot send command - communications error'
        telnet to 5003 port responds connect failed
          Ok.. then you got more than a ping problem.
          First, you have to tell us which ethernet module you use...
          Did you enabled SOFT-SPI for radio?
          • O
            O
            oded00
            The ethernet module is wiznet 5100
            softspi is enable in RF24_config.h
            • O
              O
              oded00
              I guess im not the only one with this problem
              http://forum.mysensors.org/topic/737/uno-w5100-shield-not-pinging/5
              • O
                O
                oded00
                problem slove
                • D
                  Dean
                  I had the same problem, I asked for help but no one seemed to know what the problem was. After following the above link and changing the sketch as suggested, it looks like it all is working!
                  • bocmauB
                    bocmauB
                    bocmau
                    hello.
                    i had a similar problem.
                    I replaced the network switch
                    And then the ping worked
                    • bocmauB
                      bocmauB
                      bocmau
                      Hello.
