  3. 💬 MySensors NRF5 Platform
contest2017nrf52mysensorsnrf5nrf51
210 Posts 20 Posters 88.8k Views 18 Watching
    #97
        #99
        Is it just me, or does the myBoardNrf5 cause I2c to fail during initialization? I have code which worked fine on mNrf5Board but which now hangs during initialization when using myBoardNrf5. :( Is it working for anyone else?
          #100
          @NeverDie said in 💬 MySensors NRF5 Platform:
          I've re-installed everything and am still getting no joy using I2C currently. The non-I2C stuff seems to be working fine though.
          So, before I spin more cycles trying to figure it out, is i2c working for anyone else right now using the latest builds and myBoardNrf5? Or, is I2C currently broken?
            #101
            It appears that the place where it hangs is this line here in Wire_nRF52.cpp:
              while(!_p_twim->EVENTS_LASTTX && !_p_twim->EVENTS_ERROR);
            This is too bad, as I2C seemed to work fine prior to around a couple weeks ago. I think maybe (?) the latest update somehow broke it.
            Please advise.
              #102
              Well, since I'm dead in the water as things stand, I moved the code over to run on an nRF52 DK. Then, usingy Sandeep's code and none of the mysensors code, I was able to get the nRF52 DK to read an attached Si7021 temperature-humidity sensor. i.e. that worked without hanging.
              So, it would appear that there's something about the mysensors code that is causing the problems. @d00616 Can we please get it fixed?
              d00616D 1 Reply Last reply
                d00616D
                d00616D
                d00616
                I have no I2C Hardware for testing, but I take a look into the I2C and MySensors code soon.
                  #104
                  The sooner the better. I'm pretty much stuck until it gets fixed.
                  rmtuckerR 1 Reply Last reply
                    rmtuckerR
                    rmtuckerR
                    rmtucker
                    @neverdie
                    I have been using The NRF5 with mysensors for a number of weeks with the si7021.
                    So it must be just a recent problem with the mysensors code?
                    • rmtuckerR rmtucker
                      @neverdie
                      #106
                      @rmtucker said in 💬 MySensors NRF5 Platform:
                      @neverdie
                      I think so. Are you running the most current version? si7021 was working for me too on earlier versions. The latest update seems to have broken it. It's the one that uses myBoardNrf5 instead of myNrf5Board.
                        @neverdie
                        #107
                        @neverdie
                        Would you mind trying the most recent version also to see if it breaks on you too? That would at least confirm it.
                        Right now my only alternative is to roll-back to the earlier version and just never upgrade again.
                          @neverdie
                          rmtuckerR
                          rmtuckerR
                          rmtucker
                          @neverdie
                          Where is myBoardNrf5 so i can check?
                          NeverDieN d00616D 2 Replies Last reply
                            @neverdie
                            @neverdie
                            https://github.com/d00616/ArduinoHwNRF5
                              @neverdie
                              rmtuckerR
                              rmtuckerR
                              rmtucker
                              @neverdie
                              That explains it i am not using code from d00616.
                              I am only using the mysensors library and sandeeps stuff.
                              Sorry mate.
                              scalzS 1 Reply Last reply
                                #111
                                Well, in general, it's very handy for handling the pin mappings. Up until the latest release, it has worked fine. It still works fine now, except for the I2C pin mappings.
                                  rmtuckerR
                                  rmtuckerR
                                  rmtucker
                                  @neverdie
                                  Hmmm at what cost?
                                  Maybe i will stick with what i have got as it just works.:relaxed:
                                    @d00616 Maybe you can just make it like it was before, where there was only one pair of I2c pins, not two as in your upgraded version? Maybe then it would work again.
                                      @neverdie
                                      Sorry mate.
                                      #114
                                      Sorry mate.
                                      If you're using mysensors, then you're using d00616 code :) (i'm kidding)
                                      @NeverDie I can only confirm, it is related to the ArduinoHwNRF5 code as I have not the problem (I'm not using this part yet. I'm still using my own custom board definitions for the moment).
                                      This should be fixed soon (december can be a busy month..)
                                        @neverdie
                                        d00616D
                                        d00616D
                                        d00616
                                        This is the better repository: https://github.com/mysensors/ArduinoHwNRF5
                                        @neverdie said in 💬 MySensors NRF5 Platform:
                                        Please give me some time. After an debug session with @scalz and @Yveaux, I think this is a tool chain (GCC 5.3) problem. The pin mapping array is part of the binary, but the Wire constructor gets an array with 0 while the Wire instance has pin mapping information.
                                        Yesterday, I had a try to port ArduinoHwNRF5 back to the same tool chain (GCC 4.8) used by Arduino Primo and SAMD boards. I think for compatibility, this is the best option.
                                        If I have no luck, I either remove the option of the pin remapping table or I go back to the old version. I think going back is no good idea, because the NRF52840 has more than one 32 GPIO, which requires advanced parameters.
                                        • d00616D d00616
                                          d00616D
                                          d00616D
                                          d00616
                                          Back from the compiler hell. There is no chance getting the GCC 4.8 to work without forking the arduino-nrf5 code. Compiling with GCC 4.8 has the same result.
                                          I have changed the templates a little bit and moved the code for pin mapping generation. Now it works for me. Please give me some time to clear the code and create a new package (0.3.0). With the new package, you have to add '#include <compat_pin_mapping.h>' before '#end" in MyBoardNRF5.cpp. You have to rename the '#ifdefs' and '#define' in both board files to match MYBOARDNRF5 instead of MYNRF5BOARD.
