  3. 💬 MySensors NRF5 Platform
contest2017nrf52mysensorsnrf5nrf51
210 Posts 20 Posters 88.8k Views 18 Watching
    #88
    I tried toying around with it a bit, and I got a useful result:
    #define MY_CORE_ONLY
    #include <nrf.h>
    const byte ledPin = LED_BUILTIN;
    const byte interruptPin = 3;
    volatile byte state = LOW;
        for (int i=0;i<pulses;i++) {
          wait(20);
          wait(100);
          wait(500);
      hwPinMode(interruptPin, INPUT);
      attachInterrupt(digitalPinToInterrupt(interruptPin), blink, RISING);
      blinkityBlink(2,1);  //signify power-on and start of main loop
    volatile bool buttonPressed=false;
      state = !state;
      digitalWrite(ledPin, state);
      sleep(digitalPinToInterrupt(interruptPin), RISING, 3000);
      wait(20);  //wait 20 milliseconds for button to debounce if it was pressed
      if (digitalRead(interruptPin)) { //if button is pressed
        blinkityBlink(2,1);
      if (buttonPressed) {
        blinkityBlink(20,1);
    void blink() {
      buttonPressed=true;
    So, with this approach, pushing the button on pin 3 does wake up the nRF52 from sleep, whereupon the button press can still be detected and serviced, but it also demonstrates that the ISR per se isn't working.
    Anyhow, with this I'm able to get the PIR or leak sensor or magnet sensor or light sensor doing useful things in a timely manner, even if it isn't ideal. That puts me further ahead than I was before. :)
    rmtuckerR 1 Reply Last reply
      #include <nrf.h>
            wait(20);
            wait(100);
            wait(500);
        state = !state;
          blinkityBlink(2,1);
      void blink() {
        buttonPressed=true;
      rmtuckerR
      rmtuckerR
      rmtucker
      This is a test program that wakes up from either that i was using some time ago.
         REVISION HISTORY
         Version 1.0 - Henrik EKblad
         DESCRIPTION
         This sketch provides an example how to implement a distance sensor using HC-SR04
         Use this sensor to measure KWH and Watt of your house meeter
         You need to set the correct pulsefactor of your meeter (blinks per KWH).
         The sensor starts by fetching current KWH value from gateway.
         Reports both KWH and Watt back to gateway.
         Unfortunately millis() won't increment when the Arduino is in
         sleepmode. So we cannot make this sensor sleep if we also want
         to calculate/report watt-number.
         http://www.mysensors.org/build/pulse_power
      // Enable debug prints
      //#define MY_RADIO_NRF24
      #define MY_RADIO_NRF5_ESB
      //#define MY_RADIO_RFM95
      #include <Wire.h> // must be included here so that Arduino library object file references work
      #include <RtcDS3231.h>
      RtcDS3231<TwoWire> Rtc(Wire);
      #define DIGITAL_INPUT_SENSOR 2  // The digital input you attached your light sensor.  (Only 2 and 3 generates interrupt!)
      //#define SLEEP_MODE false        // Watt-value can only be reported when sleep mode is false.
      unsigned long SEND_FREQUENCY = 20000; // Minimum time between send (in milliseconds). We don't wnat to spam the gateway.
      double ppwh = ((double)PULSE_FACTOR) / 1000; // Pulses per watt hour
      //bool pcReceived = false;
      volatile unsigned long kwh = 0;
      unsigned long oldWatt = 0;
      double oldKwh;
      unsigned long lastSend;
      MyMessage wattMsg(CHILD_ID, V_WATT);
      MyMessage kwhMsg(CHILD_ID, V_KWH);
        Rtc.Begin();
        Rtc.Enable32kHzPin(false);
        Rtc.SetSquareWavePinClockFrequency(DS3231SquareWaveClock_1Hz);
        Rtc.SetSquareWavePin(DS3231SquareWavePin_ModeClock);
        attachInterrupt(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), onPulse, FALLING);
        //pcReceived = true;
        lastSend = millis();
        present(CHILD_ID, S_POWER);
        unsigned long now = millis();
        if (sendTime) {
          if (watt != oldWatt) {
            if (watt < ((unsigned long)MAX_WATT)) {
            Serial.print("Watt:");
            Serial.println(watt);
            oldWatt = watt;
          // Pulse count has changed
          //kwh = pulseCount;
          //double kwh = ((double)pulseCount / ((double)PULSE_FACTOR));
          send(kwhMsg.set(pulseCount));  // Send kwh value to gw
          Serial.print("Wh = ");
          Serial.println(pulseCount);
          pulseCount = 0;
          lastSend = now;
        sleep(SEND_FREQUENCY);
      void onPulse()
        unsigned long interval = newBlink - lastBlink;
        if (interval < 50000L) { // Sometimes we get interrupt on RISING
          return;
        watt = (3600000000.0 / interval) / ppwh;
        lastBlink = newBlink;
        pulseCount++;
        #90
        Well, that's interesting. In the sketch I posted, I invoked sleep with:
        which caused the mcu to wake up immediately after I press the button, but it didn't process the ISR.
        Using an invocation like yours in the sketch you just posted above:
          sleep(3000);
        the ISR executes and then terminates when I press the button, but the MCU doesn't wake and continue with the loop as it did with the prior incantation. Instead, it has to wait for the timer cycle to finish.
        What I want is for it to wake up, do the ISR, and continue with the loop where it left off until it is explicitly put back to sleep again. How do I do that?
        • d00616D
          d00616D
          d00616
          @NeverDie I have checked the sleep routine in all three variants. It's working with my setup.
          There is no API stopping the sleep() by another ISR. Sleep only ends at one of the given conditions.
          When you use the MY_CORE_ONLY define, please add "hwInit();" into the setup() routine.
          • d00616D d00616
            Would you please post the three demo code examples that you tested?
              OK, I just now did that, but I'm not getting any difference in the results.
                In any case, I'm sure the question will ultimately turn from "How do I wake up based on a pin change?" to "How do I wake up based on the LPCOMP output, which has that pin as its input?" The reason: as covered earlier in this thread, much lower current consumption while sleeping if doing it via LPCOMP rather than the more straightforward pin monitoring.
                d00616D 1 Reply Last reply
                  d00616D
                  d00616D
                  d00616
                  @NeverDie said in 💬 MySensors NRF5 Platform:
                  It's a good question about, how to design the API to do this. I have no good idea.
                  Until an API, you can set MY_HW_RTC->CC[0] to (MY_HW_RTC->COUNTER+2). This ends sleep with some latency.
                    #96
                      #97
                          #99
                          Is it just me, or does the myBoardNrf5 cause I2c to fail during initialization? I have code which worked fine on mNrf5Board but which now hangs during initialization when using myBoardNrf5. :( Is it working for anyone else?
                            #100
                            I've re-installed everything and am still getting no joy using I2C currently. The non-I2C stuff seems to be working fine though.
                            So, before I spin more cycles trying to figure it out, is i2c working for anyone else right now using the latest builds and myBoardNrf5? Or, is I2C currently broken?
                              #101
                              It appears that the place where it hangs is this line here in Wire_nRF52.cpp:
                                while(!_p_twim->EVENTS_LASTTX && !_p_twim->EVENTS_ERROR);
                              This is too bad, as I2C seemed to work fine prior to around a couple weeks ago. I think maybe (?) the latest update somehow broke it.
                              Please advise.
                                #102
                                Well, since I'm dead in the water as things stand, I moved the code over to run on an nRF52 DK. Then, usingy Sandeep's code and none of the mysensors code, I was able to get the nRF52 DK to read an attached Si7021 temperature-humidity sensor. i.e. that worked without hanging.
                                So, it would appear that there's something about the mysensors code that is causing the problems. @d00616 Can we please get it fixed?
                                  d00616D
                                  d00616D
                                  d00616
                                  I have no I2C Hardware for testing, but I take a look into the I2C and MySensors code soon.
                                    #104
                                    The sooner the better. I'm pretty much stuck until it gets fixed.
                                      rmtuckerR
                                      rmtuckerR
                                      rmtucker
                                      @neverdie
                                      I have been using The NRF5 with mysensors for a number of weeks with the si7021.
                                      So it must be just a recent problem with the mysensors code?
                                      • rmtuckerR rmtucker
                                        @neverdie
                                        #106
                                        @rmtucker said in 💬 MySensors NRF5 Platform:
                                        @neverdie
                                        I think so. Are you running the most current version? si7021 was working for me too on earlier versions. The latest update seems to have broken it. It's the one that uses myBoardNrf5 instead of myNrf5Board.
                                          @neverdie
                                          #107
                                          @neverdie
                                          Would you mind trying the most recent version also to see if it breaks on you too? That would at least confirm it.
                                          Right now my only alternative is to roll-back to the earlier version and just never upgrade again.
