  3. 💬 MySensors NRF5 Platform
contest2017nrf52mysensorsnrf5nrf51
210 Posts 20 Posters 88.4k Views 18 Watching
    @rmtucker said in 💬 MySensors NRF5 Platform:
    @neverdie
    Where is myBoardNrf5 so i can check?
    https://github.com/d00616/ArduinoHwNRF5
    rmtuckerR
    rmtuckerR
    rmtucker
    @neverdie
    That explains it i am not using code from d00616.
    I am only using the mysensors library and sandeeps stuff.
    Sorry mate.
    scalzS 1 Reply Last reply
      #111
      Well, in general, it's very handy for handling the pin mappings. Up until the latest release, it has worked fine. It still works fine now, except for the I2C pin mappings.
      rmtuckerR 1 Reply Last reply
        rmtuckerR
        rmtuckerR
        rmtucker
        @neverdie
        Hmmm at what cost?
        Maybe i will stick with what i have got as it just works.:relaxed:
          @d00616 Maybe you can just make it like it was before, where there was only one pair of I2c pins, not two as in your upgraded version? Maybe then it would work again.
          • rmtuckerR rmtucker
            @neverdie
            Sorry mate.
            #114
            Sorry mate.
            If you're using mysensors, then you're using d00616 code :) (i'm kidding)
            @NeverDie I can only confirm, it is related to the ArduinoHwNRF5 code as I have not the problem (I'm not using this part yet. I'm still using my own custom board definitions for the moment).
            This should be fixed soon (december can be a busy month..)
              @neverdie
              d00616D
              d00616D
              d00616
              This is the better repository: https://github.com/mysensors/ArduinoHwNRF5
              @neverdie said in 💬 MySensors NRF5 Platform:
              Please give me some time. After an debug session with @scalz and @Yveaux, I think this is a tool chain (GCC 5.3) problem. The pin mapping array is part of the binary, but the Wire constructor gets an array with 0 while the Wire instance has pin mapping information.
              Yesterday, I had a try to port ArduinoHwNRF5 back to the same tool chain (GCC 4.8) used by Arduino Primo and SAMD boards. I think for compatibility, this is the best option.
              If I have no luck, I either remove the option of the pin remapping table or I go back to the old version. I think going back is no good idea, because the NRF52840 has more than one 32 GPIO, which requires advanced parameters.
              d00616D 1 Reply Last reply
              • d00616D d00616
                d00616D
                d00616D
                d00616
                Back from the compiler hell. There is no chance getting the GCC 4.8 to work without forking the arduino-nrf5 code. Compiling with GCC 4.8 has the same result.
                I have changed the templates a little bit and moved the code for pin mapping generation. Now it works for me. Please give me some time to clear the code and create a new package (0.3.0). With the new package, you have to add '#include <compat_pin_mapping.h>' before '#end" in MyBoardNRF5.cpp. You have to rename the '#ifdefs' and '#define' in both board files to match MYBOARDNRF5 instead of MYNRF5BOARD.
                • d00616D d00616
                  d00616D
                  d00616D
                  d00616
                  Now, there is a new Version 0.3.0 for MyBoardNRF5 available. It can be installed via the Board Manager. Please change the templates like described above. I think, now the board definition is stable and ready to support other Arduino variants without changing the board definition.
                  • d00616D d00616
                    @d00616
                    I think I made the changes you recommended, but now I'm getting:
                    Board MyBoard_nRF51822 (platform nRF5, package MySensors) is unknown
                    Error compiling for board MyBoardNRF5 nRF51822.
                      @d00616
                      d00616D
                      d00616D
                      d00616
                      I had the same message. In my case, I have uninstalled arduino-nrf5, cleared files, which are not removed from packages directory (the 0.2.1 MyBoard files) and reinstalled arduino-nrf5. After restarting Arduino it was fine.
                      • d00616D d00616
                        #120
                        @d00616
                        I'm still getting the error. I tried deleting arduino-nrf5 library and re-installing it fresh, but I don't know how, on Windows, to clear files and remove them from the packages directory. I'm not even aware of their being a "packages directory." Sorry.
                          #121
                          @d00616 You mentioned that it works only with a particular version of GCC. Does that mean I need to have a particular version of the Arduino IDE installed? I'm currently running the latest version of Windows Arduino IDE, which is 1.8.5.
                            #122
                            The irony of it all is that the earlier setup from 3 or so weeks ago seemed to work just fine. Unfortunately, I no longer have any idea how to get back to that. :sob:
                              #123
                              C:\Users...\AppData\Local\Arduino15\packages\MySensors\
                              • scalzS scalz
                                #124
                                @scalz said in 💬 MySensors NRF5 Platform:
                                The good news is that it compiles now. Also, the pin mapping for an LED is working. However, the bad news is that pin mapping for Serial Rx and Tx doesn't seem to be working, so I can't read any serial debug messages. Therefore, not sure if I2C is working or not.
                                  I did another purge and reinsatall of the boards, and now serial is working. :)
                                    Unfortunately, it does not appear that I2C is working.
                                      Curiously, I2c does seem to work on a nRF52 DK using the myboard board definition.
                                        However, it doesn't seem to be working on the nrf51.
                                          d00616D
                                          d00616D
                                          d00616
                                          The GCC version is part of the arduino-nrf5 distribution.
                                          I have I2C and serial running with a NRF52832.
                                          You can try to remove the compat_pin_mapping line and add the 0.1.0 pin map at this place. Then the board definition is nearly the 0.1.0 version.
                                          I check the NRF51 board. What do you mean with no working?
                                          NeverDieN 4 Replies Last reply
