  3. 💬 MySensors NRF5 Platform
contest2017nrf52mysensorsnrf5nrf51
210 Posts 20 Posters 88.8k Views 18 Watching
  • d00616D d00616
    @neverdie said in 💬 MySensors NRF5 Platform:
    I think I made the changes you recommended, but now I'm getting:
    Board MyBoard_nRF51822 (platform nRF5, package MySensors) is unknown
    Error compiling for board MyBoardNRF5 nRF51822.
    I had the same message. In my case, I have uninstalled arduino-nrf5, cleared files, which are not removed from packages directory (the 0.2.1 MyBoard files) and reinstalled arduino-nrf5. After restarting Arduino it was fine.
    #120
    @d00616
    I'm still getting the error. I tried deleting arduino-nrf5 library and re-installing it fresh, but I don't know how, on Windows, to clear files and remove them from the packages directory. I'm not even aware of their being a "packages directory." Sorry.
      #121
      @d00616 You mentioned that it works only with a particular version of GCC. Does that mean I need to have a particular version of the Arduino IDE installed? I'm currently running the latest version of Windows Arduino IDE, which is 1.8.5.
      d00616D 1 Reply Last reply
        #122
        The irony of it all is that the earlier setup from 3 or so weeks ago seemed to work just fine. Unfortunately, I no longer have any idea how to get back to that. :sob:
          #123
          C:\Users...\AppData\Local\Arduino15\packages\MySensors\
          • scalzS scalz
            #124
            @scalz said in 💬 MySensors NRF5 Platform:
            The good news is that it compiles now. Also, the pin mapping for an LED is working. However, the bad news is that pin mapping for Serial Rx and Tx doesn't seem to be working, so I can't read any serial debug messages. Therefore, not sure if I2C is working or not.
              I did another purge and reinsatall of the boards, and now serial is working. :)
                Unfortunately, it does not appear that I2C is working.
                  Curiously, I2c does seem to work on a nRF52 DK using the myboard board definition.
                    However, it doesn't seem to be working on the nrf51.
                      d00616D
                      d00616D
                      d00616
                      The GCC version is part of the arduino-nrf5 distribution.
                      I have I2C and serial running with a NRF52832.
                      You can try to remove the compat_pin_mapping line and add the 0.1.0 pin map at this place. Then the board definition is nearly the 0.1.0 version.
                      I check the NRF51 board. What do you mean with no working?
                      NeverDieN 4 Replies Last reply
                        I hope that narrows down the likely cause of the problem. The fact that it's working on the nRF52 gives me some hope it can be made to work on the nRF51.
                        • d00616D d00616
                          The nRF51 can't find the si7021 device, even though it's connected.
                          • d00616D d00616
                            Yes, it does seem to work on the nRF52832. Just not presently on the nRF51822.
                            • d00616D d00616
                              #133
                              I'm running the sparkfun si7021 code. When I run it on the nrf52832, it yields:
                              Si7021 Found
                              Temp:70.51F, Humidity:40.71%
                              which is correct, but when I run it on the nRF51822, the result is:
                              No Devices Detected
                              Temp:-51.85F, Humidity:-5.81%
                              which is incorrect.
                                d00616D
                                d00616D
                                d00616
                                wrote on last edited by d00616
                                #134
                                Can you check, if the device works with the "Generic NRF51822" board? You can edit the variant files in the arduino-nrf5\variants directory.
                                C:\Users...\AppData\Local\Arduino15\packages\sandeepmistry\hardware\nRF5\0.4.0\variants\Generic
                                • d00616D d00616
                                  I tried, but I guess I'm not doing it right. I couldn't even get it to blink an LED that way.
                                  • d00616D d00616
                                    So, I take it you are suggesting that in myboardnrf5.cpp, where it says:
                                    #ifdef MYBOARDNRF5
                                    #include <variant.h>
                                    #include <compat_pin_mapping.h>
                                    I replace
                                    with what exactly? At this point I'm not even sure where 0.1.0 pin-map is, or even what it's called.
                                      #137
                                      After I modify the generic variant board definition, is there some trick to making it go "live"?
                                        #138
                                        there is no trick.. it should work.
                                        d00616 said, for a test, to not use his defines, the method that you're used to.
                                        So change the defines you need in the generic variant file, then in arduino:
                                          I think this must be where the disconnect is happening. Where do I find the files or directory for Generic nRF51? The closest I see is a directory called just "Generic":
                                          That's the one I tried modifying:
                                          and it had no effect. So, I suspect there must be a different "generic nRF51" somewhere which is closely tied with the menu item you show the picture of. However, I don't see where.
                                          Nca78N 1 Reply Last reply
