  3. Easy/Newbie PCB for MySensors
257 Posts 37 Posters 177.4k Views 38 Watching
  • BarnaB
    BarnaB
    Barna
    Hi Sundberg84,
    What could you advise for battery powering (remove led and regulator too) if I would like to use Mini 5V and measure the battery level too ?
    thx
    Barna
    sundberg84S gohanG 2 Replies Last reply
    • BarnaB Barna
      Hi Sundberg84,
      thx
      Barna
      sundberg84S
      sundberg84S
      @Barna the 5v pro mini are running a 16mhz crystal as default and this needs higher voltage to be stable compred to 8mhz (3.3v pro mini).
      I have never tried this so can't give much advice but I would probably take the effort of reprogramming the fuses and bootloader to a internal 1mhz and run the hardware as that (the hardware is the same on 5v except the regulator and crystal )
      • BarnaB Barna
        Hi Sundberg84,
        thx
        Barna
        @Barna why do you want to use a 5v arduino?
        • BarnaB
          BarnaB
          Barna
          Hi Sundberg84,
          I have used this step up booster
          https://www.ebay.com/itm/181612513907?rmvSB=true
          but found this (2nd),
          https://www.ebay.com/itm/10Pcs-Mini-2-in-1-1-8V-5V-to-3-3V-DC-Step-Down-Step-Up-Converter-Power-For-Ardu/182793323053?hash=item2a8f54c22d:g:PJMAAOSwYL9ZzAXC
          It has lower noise, so I could connect the radio to the Mini. What do you think ?
          • BarnaB Barna
            Hi Sundberg84,
            sundberg84S
            sundberg84S
            #214
            @barna lower noice is better but I can not confirm this module is better. You have to try. Yes you can connect this to EasyPCB just like the first one.
            • T
              Tommas
              Hi All!
              Could someone suggest me an elegant way to extend the mysx connector? SO i would like to multiple the A4 A5 pins onto another prototype board to use more I2C devices....
              • T Tommas
                Hi All!
                sundberg84S
                sundberg84S
                @tommas just add a wire on the back side to the prototyping area ? You could design a MysX daughter board as well 😉
                T 2 Replies Last reply
                • sundberg84S sundberg84
                  Tommas
                  @sundberg84
                  Unofrtunately i havent got the skills and free time for a daughter board.:(. But doesnt have someone else a daughterboard?:)
                    Tommas
                    @sundberg84
                    Or have you got any suggestion expansion board for arduino mini pro ? Something like this: arduino-pro-mini-undershield (but it can not buy on ebay)
                    sundberg84S dbemowskD 2 Replies Last reply
                    • T Tommas
                      @sundberg84
                      sundberg84S
                      sundberg84S
                      @tommas how about a wire to the prototyping area ?
                      • T Tommas
                        @sundberg84
                        dbemowskD
                        dbemowskD
                        @tommas you could easily take a piece of prototyping PCB like this and create your own daughter/prototyping board if you need more space than the prototyping area has.
                        Use a set of connectors like this to connect to the MysX connector on the easy newbie board.
                        • Nca78N
                          I have plans for MYSX connector daughter boards, maybe if you tell me more about what you are planning to use I can adapt.
                          • H
                            H
                            helvetian
                            Hi community!
                            i just got to fiddle around with my new newbie pcb and i ran into some problems.
                            I am already quite familiar with mysensors as i have built quite a couple of different nodes which are working very well (all on bread boards or selfmade pcb boards)
                            No i wanted to step up a bit and bought the newbie pcb boards.
                            I want to have a battery powered setup. So i did solder all the parts on the board. checked my wiring many times and also checked all components. I even did check the whole pcb board if every line is ok with a multimeter.
                            So my problem is:
                            all the time i debug my node (mockup sketch) with the Arduino IDE powered by battery, stable power source etc i end up having the error TSP failed.
                            when i leave my set up as is (i solders headers to the board to conveniently change the components ) and only power the NRF24 seperatly i get no errors. So it must be something with my power ?
                            but i don't get it where exactly my problem lies.
                            Could somebody help me?
                            • H helvetian
                              Hi community!
                              So my problem is:
                              sundberg84S
                              sundberg84S
                              #223
                              @helvetian - hi, sure we can help!
                              But it would be much easier if you described your hardware setup (picture?) and logs.
                              The EasyPCB is versatile so you can use it in many ways, but a wrong combination can make it not work.
                              Do you use a DC-DC booster? Batteries? Which jumpters did you solder? And so on...
                              Did you by any chance connect both batteries and ftdi Vcc at the same time?
                              • H
                                H
                                helvetian
                                thx for your fast reply. i'm in the train right now. so i can't provide you now with any pics. as soon as possible i will do that!
                                I am using a battery booster (as it seems the same as you use), i have the battery jumpers connected, all the resistors and caps for the battery measurement.
                                It is just wired that it functions while the nrf24 is powered separately. maybe i got some bad radios?
                                One more question: the cap just below the booster. is this necessary to reduce the noice for the radio? might that help and if yes what size do you recommend? i didn't solder any cap yet there.
                                "Did you by any chance connect both batteries and ftdi Vcc at the same time?"
                                Yes! I did try this as well. Same results...
                                I should also mention i got my Arduino Pro mini battery powered hacked. So no more LED and Voltage regulator. But then again i also tried it with a untouched one.
                                  I am using 2 10uF ceramic caps both on booster and radio side, so I strongly recommend to get a bunch of those as they are working better than the electrolics and can be used in many ways.
                                  • H helvetian
                                    sundberg84S
                                    sundberg84S
                                    #226
                                    @helvetian - good, sounds like a good start.
                                    If you have a booster + battery jumper in place this powers the radio separately. The most critical capacitor is the one close to VCC/GND on the Nrf24 radio. What value do you use here? Sometimes it helps to try higher values. I use 4,7 in normal cases but sometimes I either replace it or add in parallel a 47uF as well.
                                    This is not uncommon... noice from the booster (also common) combined with a bad radio might do this.
                                    Yes and No - I dont have any hard evidence (there are caps on the booster itself) but I have had good results with a 0,1 cheramic cap for a node that didnt work. It doesnt hurt to add.
                                    Dont do this - only 1 Vcc allowed :)
                                    When you have the time, upload a picture - it will probably help us more to help you.
                                    • H
                                      H
                                      helvetian
                                      here are some pics form my pcb board!
                                      0_1516654067507_20180122_213519.jpg 0_1516654074837_20180122_213527.jpg 0_1516654086429_20180122_213538.jpg
                                      • H helvetian
                                        sundberg84S
                                        sundberg84S
                                        @helvetian looks good! Nice work.
                                        I would start by soldering in/change capacitor on the radio and booster as mentioned. Try some other radio of you have. I have never connected the jumper for irq so just to test of nothing else works you can de-solder the irq jumper.
                                        • H
                                          H
                                          helvetian
                                          ok. thanks for the tips and your promt assistance! such a great community!
                                          i will try to experiment with some caps.
                                          i tested already a couple of different radios. but maybe i will get once a decent one which will work
                                          gohanG 1 Reply Last reply
