  3. Easy/Newbie PCB for MySensors
257 Posts 37 Posters 177.4k Views 38 Watching
  • sinczeS sincze
    @sundberg84 haha yes i was wondering that myself so tried it connecting it to 3,3v as well. However on the 5v nano working just fine. Technical specs tell me: Power supply range is 3.0V to 5.5V
    also mysensors link
    Pretty strange huh.
    zboblamontZ
    zboblamontZ
    zboblamont
    @sincze I have 10 of these DS18B20s strung over approximately 12m monitoring all rooms on both floors of my house and two side lofts, all running on 3.22v from a Pro-Mini. Never have skipped a beat, reporting every 5 minutes, well, aside from a telephone socket which pins went walkabout (the chips are crimped to RJ11s).
    There is something not right with the physical arrangement if you can get the same circuit to report at 5v...
    • sundberg84S sundberg84
      @sincze my mistake. Really strange this... Should work just fine. Can you upload a better resolution picture of your hardware and the sketch you are using?
      sinczeS
      sinczeS
      sincze
      MySensors Evangelist
      wrote on last edited by sincze
      #204
      @sundberg84 I just soldered a myself a new out of the box pro mini using the same sketch..
      10246 TSF:MSG:SEND,8-8-25-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=4,st=OK:21.0
      250560 TSF:MSG:SEND,8-8-25-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:21.1
      255019 TSF:MSG:SEND,8-8-25-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:22.3
      259476 TSF:MSG:SEND,8-8-25-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:23.8
      263934 TSF:MSG:SEND,8-8-25-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:25.3
      268393 TSF:MSG:SEND,8-8-25-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:26.5
      272851 TSF:MSG:SEND,8-8-25-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:27.6
      277310 TSF:MSG:SEND,8-8-25-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:28.1
      281768 TSF:MSG:SEND,8-8-25-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:28.4
      290677 TSF:MSG:SEND,8-8-25-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:28.3
      295136 TSF:MSG:SEND,8-8-25-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:28.1
      299594 TSF:MSG:SEND,8-8-25-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:27.8
      304053 TSF:MSG:SEND,8-8-25-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:27.6
      308511 TSF:MSG:SEND,8-8-25-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:27.3
      312970 TSF:MSG:SEND,8-8-25-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:27.1
      317428 TSF:MSG:SEND,8-8-25-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:26.8
      321887 TSF:MSG:SEND,8-8-25-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:26.6
      326345 TSF:MSG:SEND,8-8-25-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:26.4
      Victory... :)
        Was the pro mini defective or just the pin you were using?
        sinczeS 1 Reply Last reply
          sinczeS
          sinczeS
          sincze
          @gohan Don't know. Pin3 could be used to drive the led tx without problems. It only did not work with the temp sensors. I moved the temp sensor to d2.... modified the sketch and it did not work as well. and d2 was driveing rx led. So well root cause unknown... solution: solder a new pro mini and keep the other one for different purpose.
          • sinczeS sincze
            zboblamontZ
            zboblamontZ
            zboblamont
            @sincze Did you use D2+D3 on all the same devices?
              I'd try the other digital pins too
              • zboblamontZ zboblamont
                sinczeS
                sinczeS
                sincze
                @zboblamont @gohan The Sensor with the replaced Pro Mini is in production now ;-). I'll start soldering a new Easy/Newbie PCB, because once you know how to do it... it is Easy and test the individual pins with a door/window sensor.
                • BarnaB
                  BarnaB
                  Barna
                  Hi Sundberg84,
                  What could you advise for battery powering (remove led and regulator too) if I would like to use Mini 5V and measure the battery level too ?
                  thx
                  Barna
                  sundberg84S gohanG 2 Replies Last reply
                  • BarnaB Barna
                    Hi Sundberg84,
                    thx
                    Barna
                    sundberg84S
                    sundberg84S
                    @Barna the 5v pro mini are running a 16mhz crystal as default and this needs higher voltage to be stable compred to 8mhz (3.3v pro mini).
                    I have never tried this so can't give much advice but I would probably take the effort of reprogramming the fuses and bootloader to a internal 1mhz and run the hardware as that (the hardware is the same on 5v except the regulator and crystal )
                    • BarnaB Barna
                      Hi Sundberg84,
                      thx
                      Barna
                      @Barna why do you want to use a 5v arduino?
                      • BarnaB
                        BarnaB
                        Barna
                        Hi Sundberg84,
                        I have used this step up booster
                        https://www.ebay.com/itm/181612513907?rmvSB=true
                        but found this (2nd),
                        https://www.ebay.com/itm/10Pcs-Mini-2-in-1-1-8V-5V-to-3-3V-DC-Step-Down-Step-Up-Converter-Power-For-Ardu/182793323053?hash=item2a8f54c22d:g:PJMAAOSwYL9ZzAXC
                        It has lower noise, so I could connect the radio to the Mini. What do you think ?
                        • BarnaB Barna
                          Hi Sundberg84,
                          sundberg84S
                          sundberg84S
                          #214
                          @barna lower noice is better but I can not confirm this module is better. You have to try. Yes you can connect this to EasyPCB just like the first one.
                          • T
                            Tommas
                            Hi All!
                            Could someone suggest me an elegant way to extend the mysx connector? SO i would like to multiple the A4 A5 pins onto another prototype board to use more I2C devices....
                            • T Tommas
                              Hi All!
                              sundberg84S
                              sundberg84S
                              @tommas just add a wire on the back side to the prototyping area ? You could design a MysX daughter board as well 😉
                              T 2 Replies Last reply
                                Tommas
                                @sundberg84
                                Unofrtunately i havent got the skills and free time for a daughter board.:(. But doesnt have someone else a daughterboard?:)
                                  Tommas
                                  @sundberg84
                                  Or have you got any suggestion expansion board for arduino mini pro ? Something like this: arduino-pro-mini-undershield (but it can not buy on ebay)
                                  sundberg84S dbemowskD 2 Replies Last reply
                                  • T Tommas
                                    @sundberg84
                                    sundberg84S
                                    sundberg84S
                                    @tommas how about a wire to the prototyping area ?
                                    • T Tommas
                                      @sundberg84
                                      dbemowskD
                                      dbemowskD
                                      @tommas you could easily take a piece of prototyping PCB like this and create your own daughter/prototyping board if you need more space than the prototyping area has.
                                      Use a set of connectors like this to connect to the MysX connector on the easy newbie board.
                                      • Nca78N
                                        I have plans for MYSX connector daughter boards, maybe if you tell me more about what you are planning to use I can adapt.
                                        • H
                                          H
                                          helvetian
                                          Hi community!
                                          i just got to fiddle around with my new newbie pcb and i ran into some problems.
                                          I am already quite familiar with mysensors as i have built quite a couple of different nodes which are working very well (all on bread boards or selfmade pcb boards)
                                          No i wanted to step up a bit and bought the newbie pcb boards.
                                          I want to have a battery powered setup. So i did solder all the parts on the board. checked my wiring many times and also checked all components. I even did check the whole pcb board if every line is ok with a multimeter.
                                          So my problem is:
                                          all the time i debug my node (mockup sketch) with the Arduino IDE powered by battery, stable power source etc i end up having the error TSP failed.
                                          when i leave my set up as is (i solders headers to the board to conveniently change the components ) and only power the NRF24 seperatly i get no errors. So it must be something with my power ?
                                          but i don't get it where exactly my problem lies.
                                          Could somebody help me?
