  3. Domoticz
  4. V_LEVEL in Domoticz [resolved]
15 Posts 4 Posters 4.0k Views 4 Watching
  • alexsh1A Offline
    alexsh1A Offline
    alexsh1
    Does anyone know if V_LEVEL (lux) in MySensors 2.0 is supported in Domoticz?
    Alex
    • alexsh1A alexsh1
      Alex
      M Offline
      M Offline
      manutremo
      @alexsh1 yes it is.
      • fernando alvarez buyllaF Offline
        yes
        • YFandSY Offline
          YFandSY Offline
          YFandS
          and another yes:
          from the history:
          Changed: MySensors, now treating V_LIGHT_LEVEL as Perecentage (V_LEVEL with type=S_LIGHT_LEVEL = Lux)
          regards,
          Frank
          alexsh1A 1 Reply Last reply
          • YFandSY YFandS
            and another yes:
            from the history:
            regards,
            Frank
            alexsh1A Offline
            alexsh1A Offline
            alexsh1
            @yfands
            @fernando-alvarez-buylla
            Any ideas why when the sensor is reporting V_LEVEL/S_LIGHT_LEVEL I still get percentage? I am using the latest beta Domoticz.
            • alexsh1A alexsh1
              @yfands
              M Offline
              M Offline
              manutremo
              @alexsh1 did you delete the device in the hardware tab of domoticz?
              • M Offline
                M Offline
                manutremo
                And it might be necessary to delete the device too.
                • M manutremo
                  alexsh1A Offline
                  alexsh1A Offline
                  alexsh1
                  @manutremo I did both. The node has come back, but the device does not display correctly.
                  • M Offline
                    M Offline
                    manutremo
                    It works for me. Can you show a capture of the device and the sketch? The node log wold be useful too.
                    • M Offline
                      M Offline
                      manutremo
                      Version of domoticz?
                      • M manutremo
                        alexsh1A Offline
                        alexsh1A Offline
                        alexsh1
                        @manutremo said in V_LEVEL in Domoticz:
                        V3.8775
                        • alexsh1A alexsh1
                          V3.8775
                          M Offline
                          M Offline
                          manutremo
                          @alexsh1 Weird... it works perfect in my 3.8770:
                          So you mean that it the node sends a let's say value of 67, domoticz shows a 67%?
                          • M manutremo
                            alexsh1A Offline
                            alexsh1A Offline
                            alexsh1
                            @manutremo
                            Correct.
                            5091 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                            5138 TSF:MSG:READ,0-0-6,s=255,c=3,t=17,pt=6,l=25,sg=1:9E33298D49F4A46C7EABCD392B5796BA3D5A529489DBB68092
                            5269 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=0,pt=1,l=1,sg=1,ft=0,st=OK:100
                            5382 TSF:MSG:SEND,6-6-0-0,s=1,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                            5427 TSF:MSG:READ,0-0-6,s=255,c=3,t=17,pt=6,l=25,sg=1:B988626FE976407B4B8F037F16F7A061A65EFC53A2A3B9ABF3
                            5558 TSF:MSG:SEND,6-6-0-0,s=1,c=1,t=38,pt=7,l=5,sg=1,ft=0,st=OK:3.30
                            abs(lux - oldLux)=9709; lux =9709; oldLux =0
                            5685 TSF:MSG:SEND,6-6-0-0,s=4,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                            5730 TSF:MSG:READ,0-0-6,s=255,c=3,t=17,pt=6,l=25,sg=1:57745AED2BAB9EED21EC110284CF1456693A42A0E9B775509F
                            5863 TSF:MSG:SEND,6-6-0-0,s=4,c=1,t=37,pt=0,l=5,sg=1,ft=0,st=OK: 9709
                            However, it does display as 9709% rather than 9709 lux.
                            I'll try to delete everything again tomorrow and reboot Domoticz.
                            Not sure where the issue is as your setup works fine.
                            • M manutremo
                              alexsh1A Offline
                              alexsh1A Offline
                              alexsh1
                              @manutremo OK, sorted now. What I have done so far:
                              1. deleted a node and all associated devices
                              2. rebooted Domoticz
                              3. reflashed my VELM6075 mote with the same version of MySensors as the GW
                              It started working straight away.
                              • alexsh1A alexsh1
                                M Offline
                                M Offline
                                manutremo
                                @alexsh1 Great! Many thanks for reporting back!
