  3. Domoticz
  4. V_LEVEL in Domoticz [resolved]
15 Posts 4 Posters 4.2k Views 4 Watching
  • YFandSY YFandS
    and another yes:
    from the history:
    Changed: MySensors, now treating V_LIGHT_LEVEL as Perecentage (V_LEVEL with type=S_LIGHT_LEVEL = Lux)
    regards,
    Frank
    alexsh1A
    alexsh1A
    alexsh1
    @yfands
    @fernando-alvarez-buylla
    Any ideas why when the sensor is reporting V_LEVEL/S_LIGHT_LEVEL I still get percentage? I am using the latest beta Domoticz.
    • alexsh1A alexsh1
      @yfands
      manutremo
      @alexsh1 did you delete the device in the hardware tab of domoticz?
        manutremo
        And it might be necessary to delete the device too.
        alexsh1A 1 Reply Last reply
        • M manutremo
          alexsh1A
          alexsh1A
          alexsh1
          @manutremo I did both. The node has come back, but the device does not display correctly.
            manutremo
            It works for me. Can you show a capture of the device and the sketch? The node log wold be useful too.
              manutremo
              Version of domoticz?
              • M manutremo
                alexsh1A
                alexsh1A
                alexsh1
                @manutremo said in V_LEVEL in Domoticz:
                V3.8775
                • alexsh1A alexsh1
                  V3.8775
                  manutremo
                  @alexsh1 Weird... it works perfect in my 3.8770:
                  So you mean that it the node sends a let's say value of 67, domoticz shows a 67%?
                  • M manutremo
                    alexsh1A
                    alexsh1A
                    alexsh1
                    @manutremo
                    Correct.
                    5091 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                    5138 TSF:MSG:READ,0-0-6,s=255,c=3,t=17,pt=6,l=25,sg=1:9E33298D49F4A46C7EABCD392B5796BA3D5A529489DBB68092
                    5269 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=0,pt=1,l=1,sg=1,ft=0,st=OK:100
                    5382 TSF:MSG:SEND,6-6-0-0,s=1,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                    5427 TSF:MSG:READ,0-0-6,s=255,c=3,t=17,pt=6,l=25,sg=1:B988626FE976407B4B8F037F16F7A061A65EFC53A2A3B9ABF3
                    5558 TSF:MSG:SEND,6-6-0-0,s=1,c=1,t=38,pt=7,l=5,sg=1,ft=0,st=OK:3.30
                    abs(lux - oldLux)=9709; lux =9709; oldLux =0
                    5685 TSF:MSG:SEND,6-6-0-0,s=4,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                    5730 TSF:MSG:READ,0-0-6,s=255,c=3,t=17,pt=6,l=25,sg=1:57745AED2BAB9EED21EC110284CF1456693A42A0E9B775509F
                    5863 TSF:MSG:SEND,6-6-0-0,s=4,c=1,t=37,pt=0,l=5,sg=1,ft=0,st=OK: 9709
                    However, it does display as 9709% rather than 9709 lux.
                    I'll try to delete everything again tomorrow and reboot Domoticz.
                    Not sure where the issue is as your setup works fine.
                    • M manutremo
                      alexsh1A
                      alexsh1A
                      alexsh1
                      @manutremo OK, sorted now. What I have done so far:
                      1. deleted a node and all associated devices
                      2. rebooted Domoticz
                      3. reflashed my VELM6075 mote with the same version of MySensors as the GW
                      It started working straight away.
                      • alexsh1A alexsh1
                        manutremo
                        @alexsh1 Great! Many thanks for reporting back!
