  3. CNC PCB milling
CNC PCB milling
933 Posts 28 Posters 766.8k Views 27 Watching
    #106
    I just realized: is it flatcam that does the auto-leveling? In which case, it would need to run on the Pi (or whatever the answer is to my earlier question) too.
      correction: I guess it's bCNC that does the auto-leveling.
      andrewA 1 Reply Last reply
      • zboblamontZ zboblamont
        @mfalkvidd Is this AFTER mapping the surface ?
        @zboblamont no, before. To my knowledge, it would be hard to map the surface without connecting the alligator clip.
          zboblamontZ
          zboblamontZ
          zboblamont
          @mfalkvidd :joy: Touche...
          • E
            E
            executivul
            I hate bCNC, looks like Win95 era software and I hate chilipeppr even though looks like iOS 19, it's online only and the main dev, John Lauer, is a tinyg guy as he states so grbl workspace is neglected quite a lot. A tinyg is too expensive to bother, and even though an Arduino Due can run tinyg code (g2core project) probing is unreliable and I've tried getting help from the devs on git but couldn't solve the issues.
            Another alternative would be OpenCNCPilot but haven't tested it enough, one good thing about it is that it can split long gcode movements, which is VERY important, chilipeppr does the grid mapping and then compensates for the z-height at start and end of a line, but if the board has a bump/dip to be traversed then the milling won't be ok, if you split long moves then and then import in chilipeppr then it can compensate for each segment and you get a much better engraving.
            • ben999B
              ben999B
              ben999
              Anything similar to OctoPrint, but for CNC ?
                andrewA
                andrewA
                andrew
                @NeverDie the autoleveling is the g code sender tool's responsibility, so from the mentioned toolsets chilipeppr or bcnc could do it. the given sw tool controls the cnc to probe the pcb's surface, measures when the given bit touches the pcb then makes a 3d map from the pcb roughness. later this 3d map is aligned to the g code which you get from other tools (from my mentioned example, it is exported from flatcam, which processes the gerber files exported from the pcb design software).
                @ben999 this is the way how "bed compensation" could be done, and for precise isolation milling it is essential. for drilling it is enough if you just set an approximately zero on z axis, which could be also result of a manual setup or the g code sender tools also could handle the single touch probe.
                this is the case when your mentioned touch probe could help, but without touch plate it is possible to do the probing the same way like in case of the autoleveling measurement but with one touch only.
                • andrewA andrew
                  #113
                  chilipeppr or bcnc
                  Which of the two do you recommend for beginners like me?
                  Also, is a raspberry pi sufficient for running it, or do you recommend something with more oomph like a PC?
                  Looks like I'll be getting the CNC2418 on Monday rather than this Friday because the twits at Jack's store didn't physically ship it until today (before that, it was evidently just a mailing label). Also, if anyone cares, the weight is 7.2kg, as measured by Fedex, not 5 kilograms, as entered by Jack.
                  • andrewA
                    andrewA
                    andrew
                    to drive/control these CNCs a simple Pi is powerful enough, but it is not necessary to use a separated computer for that.
                    chilipeppr runs in a browser (just open chilipeppr.com/grbl). it needs a "remote" serial service to connect over the network (on your local lan/wifi) as from the browser it cannot directly interface with usb. this remote serial service is just an additional software, which should run on a host what is connected to the CNC. this could be the same where you run the browser or really a "remote" host (e.g. a pi). chilipeppr also could stream webcam picture, so if you have one installed to the cnc then you can get realtime remote video as well.
                    it is nice, "modern", but online.
                    although bcnc isn't that nice as @executivul also mentioned, but I like it. it should run on that host which is connected to the CNC. I didn't have any issues with it so far, single touch z probing and autoleveling worked fine for me. this is what I use now.
                    both of them are cross platform tools.
                    as I work on os x and linux I did not tested windows tools. there are several more other options both for *nix like systems and for windows as well, but I don't have experience with them, so I cannot recommend anything else.
                    I don't use separated computer for the controlling sw, I use my laptop for this job. you can't leave the cnc alone for a long time, the whole process needs multiple manual activities, so from this perspective the "remote" controlling solution maybe not the best idea.
                      #115
                      Sorry for all the noob questions, but maybe others can learn from this as well.
                      How do I know when a bit has become worn-out enough that it should be replaced with a newer, sharper bit? Does the software provide any feedback (e.g. maybe the motors are drawing more current than expected due to dullness)?
                      Or do you just wait for a bit to completely fail (i.e. snap or shatter), then insert a new one, and then re-run the job from the beginning when that bit was first used?
                      Also, do you have a particular test board you like to use to check out the system and see if it's running up to snuff? i.e. something that would challenge the system to surface problems in advance of trying it on a a more serious board.
                      And is feedrate arrived at purely by trial and error, or are there good magic numbers to use for that? Since we're running the same system, maybe I could use your magic numbers (i.e. the hardware-specific constants which must be entered into the software)? If so, what are they?
                      sundberg84S E 2 Replies Last reply
                        sundberg84S
                        sundberg84S
                        @neverdie I'm saving up some money for a CNC as well and I would love if you have time to document your process. Might be to much to ask but I guess many newbie errors could be avoided. I know there are some on YouTube but I have not found any which address the questions we have had above in this thread.
                          E
                          E
                          executivul
                          How do you know when you shaver is going dull? You inspect the result using a maginfying glass or microscope (I have at least one of my usb microscopes next to the cnc, if the edges are getting worse I replace the bit
                          No, maybe when milling metal that would be detectable, for pcb milling the forces are very low
                          yes, just to mention you can resharpen the bit. If it's Ti coated you lose that, but normal bits can be resharpened using a stone, then tested for width since you change that when resahrpening
                          LEARN GCODE, I can not emphasize it enough, half an hour taken to understand 5-10 commands is all it takes, G90/G91/G92; G0/G1 is all you need! Than you can take your time and write small scripts, for eg. that do a zigzag like pattern with passes at increasing distances and you can check your actual bit size
                          Mostly yes, read the comment above, and your script just change the F parameter of the G1 moves and see for yourself using your microscope which speed yelds the best results
                          **Steps/mm for a certain machine is the only hard-coded magic number, if you don't know it you can throw the machine into trash for milling wrong dimensions!!!!! (or use a caliper and calculate that number yourself, but don't tell that to anyone) **
                          • E
                            E
                            executivul
                            Example script:
                            Manually written gcode for good feedrate discovery
                            DON'T run it on your machine untill you understand exactly what each line of code does!
                            G21 (Unit of Measure - millimeter)
                            G90 (Set to Absolute Positioning)
                            G94 (Feed Mode - Units per minute)
                            F200.00 (feed rate mm/min)
                            G00 Z0.5000
                            M03 (start spindle)
                            G4 P1 (Dwell/Pause)
                            G01 Z-0.1000
                            G4 P0.5 (Dwell/Pause)
                            (test 1)
                            G01 X10.0000Y5.0000
                            G01 X0.0000Y10.0000
                            F400.00 (feed rate mm/min)
                            G01 X10.0000Y15.0000
                            G01 X0.0000Y20.0000
                            F600.00 (feed rate mm/min)
                            G01 X10.0000Y25.0000
                            G01 X0.0000Y30.0000
                            F800.00 (feed rate mm/min)
                            G01 X10.0000Y35.0000
                            G01 X0.0000Y40.0000
                            F1000.00 (feed rate mm/min)
                            G01 X10.0000Y45.0000
                            G01 X0.0000Y50.0000
                            (test2)
                            G00 Z1.5000 (raise spindle)
                            G00 X5Y0 (go right)
                            G01 Z-0.1000 (down spindle)
                            F1200.00 (feed rate mm/min)
                            G01 X15.0000Y5.0000
                            G01 X5.0000Y10.0000
                            F1400.00 (feed rate mm/min)
                            G01 X15.0000Y15.0000
                            G01 X5.0000Y20.0000
                            F1600.00 (feed rate mm/min)
                            G01 X15.0000Y25.0000
                            G01 X5.0000Y30.0000
                            F1800.00 (feed rate mm/min)
                            G01 X15.0000Y35.0000
                            G01 X5.0000Y40.0000
                            F2000.00 (feed rate mm/min)
                            G01 X15.0000Y45.0000
                            G01 X5.0000Y50.0000
                            G00 Z1.5000
                            G00 X0Y0
                            M05 (stop spindle)
                            • E
                              E
                              executivul
                              wrote on last edited by executivul
                              #119
                              Manually written gcode to determine milling bit width
                              G21
                              G90
                              G94
                              F1400.00
                              G00 Z0.5000
                              M03
                              G4 P1
                              G01 Z-0.1000
                              G4 P0.5
                              (test 0.1mm)
                              G01 X0.0000Y5.0000
                              G01 X0.1000Y5.0000
                              G01 X0.1000Y0.0000
                              G01 X0.2000Y0.0000
                              G01 X0.2000Y5.0000
                              G01 X0.3000Y5.0000
                              G01 X0.3000Y0.0000
                              G01 X0.4000Y0.0000
                              G01 X0.4000Y5.0000
                              G01 X0.5000Y5.0000
                              G01 X0.5000Y0.0000
                              G01 X0.6000Y0.0000
                              G01 X1.6000Y0.0000
                              (test 0.2mm)
                              G01 X1.6000Y5.0000
                              G01 X1.8000Y5.0000
                              G01 X1.8000Y0.0000
                              G01 X2.0000Y0.0000
                              G01 X2.0000Y5.0000
                              G01 X2.2000Y5.0000
                              G01 X2.2000Y0.0000
                              G01 X2.4000Y0.0000
                              G01 X2.4000Y5.0000
                              G01 X2.6000Y5.0000
                              G01 X2.6000Y0.0000
                              G01 X2.8000Y0.0000
                              G01 X3.8000Y0.0000
                              (test 0.3mm)
                              G01 X3.8000Y5.0000
                              G01 X4.1000Y5.0000
                              G01 X4.1000Y0.0000
                              G01 X4.4000Y0.0000
                              G01 X4.4000Y5.0000
                              G01 X4.7000Y5.0000
                              G01 X4.7000Y0.0000
                              G01 X5.0000Y0.0000
                              G01 X5.0000Y5.0000
                              G01 X5.3000Y5.0000
                              G01 X5.3000Y0.0000
                              G01 X5.6000Y0.0000
                              G01 X6.6000Y0.0000
                              (test 0.4mm)
                              G01 X6.6000Y5.0000
                              G01 X7.0000Y5.0000
                              G01 X7.0000Y0.0000
                              G01 X7.4000Y0.0000
                              G01 X7.4000Y5.0000
                              G01 X7.8000Y5.0000
                              G01 X7.8000Y0.0000
                              G01 X8.2000Y0.0000
                              G01 X8.2000Y5.0000
                              G01 X8.6000Y5.0000
                              G01 X8.6000Y0.0000
                              G01 X9.0000Y0.0000
                              G01 X10.0000Y0.0000
                              (test 0.5mm)
                              G01 X10.0000Y5.0000
                              G01 X10.5000Y5.0000
                              G01 X10.5000Y0.0000
                              G01 X11.0000Y0.0000
                              G01 X11.0000Y5.0000
                              G01 X11.5000Y5.0000
                              G01 X11.5000Y0.0000
                              G01 X12.0000Y0.0000
                              G01 X12.0000Y5.0000
                              G01 X12.5000Y5.0000
                              G01 X12.5000Y0.0000
                              G01 X13.0000Y0.0000
                              G01 X14.0000Y0.0000
                              (test 0.6mm)
                              G01 X14.0000Y5.0000
                              G01 X14.6000Y5.0000
                              G01 X14.6000Y0.0000
                              G01 X15.2000Y0.0000
                              G01 X15.2000Y5.0000
                              G01 X15.8000Y5.0000
                              G01 X15.8000Y0.0000
                              G01 X16.4000Y0.0000
                              G01 X16.4000Y5.0000
                              G01 X17.0000Y5.0000
                              G01 X17.0000Y0.0000
                              G01 X17.6000Y0.0000
                              G01 X18.6000Y0.0000
                              (test 0.7mm)
                              G01 X18.6000Y5.0000
                              G01 X19.3000Y5.0000
                              G01 X19.3000Y0.0000
                              G01 X20.0000Y0.0000
                              G01 X20.0000Y5.0000
                              G01 X20.7000Y5.0000
                              G01 X20.7000Y0.0000
                              G01 X21.4000Y0.0000
                              G01 X21.4000Y5.0000
                              G01 X22.1000Y5.0000
                              G01 X22.1000Y0.0000
                              G00 Z1.5000
                              G00 X0Y0
                              M05
                              When you see copper "silvers" between the passes you know your bit is 0.1mm narrower than the corresponding width :sunglasses:
                              • E executivul
                                G21
                                G90
                                G94
                                F1400.00
                                G00 Z0.5000
                                M03
                                G4 P1
                                G01 Z-0.1000
                                G4 P0.5
                                (test 0.1mm)
                                G01 X0.0000Y5.0000
                                G01 X0.1000Y5.0000
                                G01 X0.1000Y0.0000
                                G01 X0.2000Y0.0000
                                G01 X0.2000Y5.0000
                                G01 X0.3000Y5.0000
                                G01 X0.3000Y0.0000
                                G01 X0.4000Y0.0000
                                G01 X0.4000Y5.0000
                                G01 X0.5000Y5.0000
                                G01 X0.5000Y0.0000
                                G01 X0.6000Y0.0000
                                G01 X1.6000Y0.0000
                                (test 0.2mm)
                                G01 X1.6000Y5.0000
                                G01 X1.8000Y5.0000
                                G01 X1.8000Y0.0000
                                G01 X2.0000Y0.0000
                                G01 X2.0000Y5.0000
                                G01 X2.2000Y5.0000
                                G01 X2.2000Y0.0000
                                G01 X2.4000Y0.0000
                                G01 X2.4000Y5.0000
                                G01 X2.6000Y5.0000
                                G01 X2.6000Y0.0000
                                G01 X2.8000Y0.0000
                                G01 X3.8000Y0.0000
                                (test 0.3mm)
                                G01 X3.8000Y5.0000
                                G01 X4.1000Y5.0000
                                G01 X4.1000Y0.0000
                                G01 X4.4000Y0.0000
                                G01 X4.4000Y5.0000
                                G01 X4.7000Y5.0000
                                G01 X4.7000Y0.0000
                                G01 X5.0000Y0.0000
                                G01 X5.0000Y5.0000
                                G01 X5.3000Y5.0000
                                G01 X5.3000Y0.0000
                                G01 X5.6000Y0.0000
                                G01 X6.6000Y0.0000
                                (test 0.4mm)
                                G01 X6.6000Y5.0000
                                G01 X7.0000Y5.0000
                                G01 X7.0000Y0.0000
                                G01 X7.4000Y0.0000
                                G01 X7.4000Y5.0000
                                G01 X7.8000Y5.0000
                                G01 X7.8000Y0.0000
                                G01 X8.2000Y0.0000
                                G01 X8.2000Y5.0000
                                G01 X8.6000Y5.0000
                                G01 X8.6000Y0.0000
                                G01 X9.0000Y0.0000
                                G01 X10.0000Y0.0000
                                (test 0.5mm)
                                G01 X10.0000Y5.0000
                                G01 X10.5000Y5.0000
                                G01 X10.5000Y0.0000
                                G01 X11.0000Y0.0000
                                G01 X11.0000Y5.0000
                                G01 X11.5000Y5.0000
                                G01 X11.5000Y0.0000
                                G01 X12.0000Y0.0000
                                G01 X12.0000Y5.0000
                                G01 X12.5000Y5.0000
                                G01 X12.5000Y0.0000
                                G01 X13.0000Y0.0000
                                G01 X14.0000Y0.0000
                                (test 0.6mm)
                                G01 X14.0000Y5.0000
                                G01 X14.6000Y5.0000
                                G01 X14.6000Y0.0000
                                G01 X15.2000Y0.0000
                                G01 X15.2000Y5.0000
                                G01 X15.8000Y5.0000
                                G01 X15.8000Y0.0000
                                G01 X16.4000Y0.0000
                                G01 X16.4000Y5.0000
                                G01 X17.0000Y5.0000
                                G01 X17.0000Y0.0000
                                G01 X17.6000Y0.0000
                                G01 X18.6000Y0.0000
                                (test 0.7mm)
                                G01 X18.6000Y5.0000
                                G01 X19.3000Y5.0000
                                G01 X19.3000Y0.0000
                                G01 X20.0000Y0.0000
                                G01 X20.0000Y5.0000
                                G01 X20.7000Y5.0000
                                G01 X20.7000Y0.0000
                                G01 X21.4000Y0.0000
                                G01 X21.4000Y5.0000
                                G01 X22.1000Y5.0000
                                G01 X22.1000Y0.0000
                                G00 Z1.5000
                                G00 X0Y0
                                M05
                                #120
                                @executivul Good stuff! I imagine I'll get there eventually, but on Day 1 I'd rather start with some reasonable magic constants that at least put me in the ballpark.
                                • sundberg84S sundberg84
                                  @sundberg84 said in CNC PCB milling:
                                  Yes, that's what I'm attempting to do on this thread. :)
                                  • andrewA
                                    andrewA
                                    andrew
                                    JFYI: CNC 2418 assembly by me :)
                                    https://www.youtube.com/watch?v=T2_18-ObvP0
                                    I'll try to make a blog to describe the whole pcb cnc milling, tools etc, as well as other diy projects. I'll let you know if there is any notable progress...
                                    • andrewA andrew
                                      #123
                                      @andrew Nice. How long did that take in earth minutes?
                                      • andrewA
                                        andrewA
                                        andrew
                                        wrote on last edited by andrew
                                        #124
                                        @NeverDie about 6 hours, in two nights
                                        • E
                                          E
                                          executivul
                                          Best way to get rid of the dust seems to be not making dust to start with.
                                          Enjoy!
                                          https://youtu.be/PpXG1X9yoxs
