  3. CNC PCB milling
CNC PCB milling
933 Posts 28 Posters 817.1k Views 27 Watching
    Sorry for all the noob questions, but maybe others can learn from this as well.
    How do I know when a bit has become worn-out enough that it should be replaced with a newer, sharper bit? Does the software provide any feedback (e.g. maybe the motors are drawing more current than expected due to dullness)?
    Or do you just wait for a bit to completely fail (i.e. snap or shatter), then insert a new one, and then re-run the job from the beginning when that bit was first used?
    Also, do you have a particular test board you like to use to check out the system and see if it's running up to snuff? i.e. something that would challenge the system to surface problems in advance of trying it on a a more serious board.
    And is feedrate arrived at purely by trial and error, or are there good magic numbers to use for that? Since we're running the same system, maybe I could use your magic numbers (i.e. the hardware-specific constants which must be entered into the software)? If so, what are they?
    sundberg84S
    sundberg84S
    @neverdie I'm saving up some money for a CNC as well and I would love if you have time to document your process. Might be to much to ask but I guess many newbie errors could be avoided. I know there are some on YouTube but I have not found any which address the questions we have had above in this thread.
      E
      E
      executivul
      How do you know when you shaver is going dull? You inspect the result using a maginfying glass or microscope (I have at least one of my usb microscopes next to the cnc, if the edges are getting worse I replace the bit
      No, maybe when milling metal that would be detectable, for pcb milling the forces are very low
      yes, just to mention you can resharpen the bit. If it's Ti coated you lose that, but normal bits can be resharpened using a stone, then tested for width since you change that when resahrpening
      LEARN GCODE, I can not emphasize it enough, half an hour taken to understand 5-10 commands is all it takes, G90/G91/G92; G0/G1 is all you need! Than you can take your time and write small scripts, for eg. that do a zigzag like pattern with passes at increasing distances and you can check your actual bit size
      Mostly yes, read the comment above, and your script just change the F parameter of the G1 moves and see for yourself using your microscope which speed yelds the best results
      **Steps/mm for a certain machine is the only hard-coded magic number, if you don't know it you can throw the machine into trash for milling wrong dimensions!!!!! (or use a caliper and calculate that number yourself, but don't tell that to anyone) **
      • E
        E
        executivul
        Example script:
        Manually written gcode for good feedrate discovery
        DON'T run it on your machine untill you understand exactly what each line of code does!
        G21 (Unit of Measure - millimeter)
        G90 (Set to Absolute Positioning)
        G94 (Feed Mode - Units per minute)
        F200.00 (feed rate mm/min)
        G00 Z0.5000
        M03 (start spindle)
        G4 P1 (Dwell/Pause)
        G01 Z-0.1000
        G4 P0.5 (Dwell/Pause)
        (test 1)
        G01 X10.0000Y5.0000
        G01 X0.0000Y10.0000
        F400.00 (feed rate mm/min)
        G01 X10.0000Y15.0000
        G01 X0.0000Y20.0000
        F600.00 (feed rate mm/min)
        G01 X10.0000Y25.0000
        G01 X0.0000Y30.0000
        F800.00 (feed rate mm/min)
        G01 X10.0000Y35.0000
        G01 X0.0000Y40.0000
        F1000.00 (feed rate mm/min)
        G01 X10.0000Y45.0000
        G01 X0.0000Y50.0000
        (test2)
        G00 Z1.5000 (raise spindle)
        G00 X5Y0 (go right)
        G01 Z-0.1000 (down spindle)
        F1200.00 (feed rate mm/min)
        G01 X15.0000Y5.0000
        G01 X5.0000Y10.0000
        F1400.00 (feed rate mm/min)
        G01 X15.0000Y15.0000
        G01 X5.0000Y20.0000
        F1600.00 (feed rate mm/min)
        G01 X15.0000Y25.0000
        G01 X5.0000Y30.0000
        F1800.00 (feed rate mm/min)
        G01 X15.0000Y35.0000
        G01 X5.0000Y40.0000
        F2000.00 (feed rate mm/min)
        G01 X15.0000Y45.0000
        G01 X5.0000Y50.0000
        G00 Z1.5000
        G00 X0Y0
        M05 (stop spindle)
        • E
          E
          executivul
          wrote on last edited by executivul
          #119
          Manually written gcode to determine milling bit width
          G21
          G90
          G94
          F1400.00
          G00 Z0.5000
          M03
          G4 P1
          G01 Z-0.1000
          G4 P0.5
          (test 0.1mm)
          G01 X0.0000Y5.0000
          G01 X0.1000Y5.0000
          G01 X0.1000Y0.0000
          G01 X0.2000Y0.0000
          G01 X0.2000Y5.0000
          G01 X0.3000Y5.0000
          G01 X0.3000Y0.0000
          G01 X0.4000Y0.0000
          G01 X0.4000Y5.0000
          G01 X0.5000Y5.0000
          G01 X0.5000Y0.0000
          G01 X0.6000Y0.0000
          G01 X1.6000Y0.0000
          (test 0.2mm)
          G01 X1.6000Y5.0000
          G01 X1.8000Y5.0000
          G01 X1.8000Y0.0000
          G01 X2.0000Y0.0000
          G01 X2.0000Y5.0000
          G01 X2.2000Y5.0000
          G01 X2.2000Y0.0000
          G01 X2.4000Y0.0000
          G01 X2.4000Y5.0000
          G01 X2.6000Y5.0000
          G01 X2.6000Y0.0000
          G01 X2.8000Y0.0000
          G01 X3.8000Y0.0000
          (test 0.3mm)
          G01 X3.8000Y5.0000
          G01 X4.1000Y5.0000
          G01 X4.1000Y0.0000
          G01 X4.4000Y0.0000
          G01 X4.4000Y5.0000
          G01 X4.7000Y5.0000
          G01 X4.7000Y0.0000
          G01 X5.0000Y0.0000
          G01 X5.0000Y5.0000
          G01 X5.3000Y5.0000
          G01 X5.3000Y0.0000
          G01 X5.6000Y0.0000
          G01 X6.6000Y0.0000
          (test 0.4mm)
          G01 X6.6000Y5.0000
          G01 X7.0000Y5.0000
          G01 X7.0000Y0.0000
          G01 X7.4000Y0.0000
          G01 X7.4000Y5.0000
          G01 X7.8000Y5.0000
          G01 X7.8000Y0.0000
          G01 X8.2000Y0.0000
          G01 X8.2000Y5.0000
          G01 X8.6000Y5.0000
          G01 X8.6000Y0.0000
          G01 X9.0000Y0.0000
          G01 X10.0000Y0.0000
          (test 0.5mm)
          G01 X10.0000Y5.0000
          G01 X10.5000Y5.0000
          G01 X10.5000Y0.0000
          G01 X11.0000Y0.0000
          G01 X11.0000Y5.0000
          G01 X11.5000Y5.0000
          G01 X11.5000Y0.0000
          G01 X12.0000Y0.0000
          G01 X12.0000Y5.0000
          G01 X12.5000Y5.0000
          G01 X12.5000Y0.0000
          G01 X13.0000Y0.0000
          G01 X14.0000Y0.0000
          (test 0.6mm)
          G01 X14.0000Y5.0000
          G01 X14.6000Y5.0000
          G01 X14.6000Y0.0000
          G01 X15.2000Y0.0000
          G01 X15.2000Y5.0000
          G01 X15.8000Y5.0000
          G01 X15.8000Y0.0000
          G01 X16.4000Y0.0000
          G01 X16.4000Y5.0000
          G01 X17.0000Y5.0000
          G01 X17.0000Y0.0000
          G01 X17.6000Y0.0000
          G01 X18.6000Y0.0000
          (test 0.7mm)
          G01 X18.6000Y5.0000
          G01 X19.3000Y5.0000
          G01 X19.3000Y0.0000
          G01 X20.0000Y0.0000
          G01 X20.0000Y5.0000
          G01 X20.7000Y5.0000
          G01 X20.7000Y0.0000
          G01 X21.4000Y0.0000
          G01 X21.4000Y5.0000
          G01 X22.1000Y5.0000
          G01 X22.1000Y0.0000
          G00 Z1.5000
          G00 X0Y0
          M05
          When you see copper "silvers" between the passes you know your bit is 0.1mm narrower than the corresponding width :sunglasses:
          • E executivul
            G21
            G90
            G94
            F1400.00
            G00 Z0.5000
            M03
            G4 P1
            G01 Z-0.1000
            G4 P0.5
            (test 0.1mm)
            G01 X0.0000Y5.0000
            G01 X0.1000Y5.0000
            G01 X0.1000Y0.0000
            G01 X0.2000Y0.0000
            G01 X0.2000Y5.0000
            G01 X0.3000Y5.0000
            G01 X0.3000Y0.0000
            G01 X0.4000Y0.0000
            G01 X0.4000Y5.0000
            G01 X0.5000Y5.0000
            G01 X0.5000Y0.0000
            G01 X0.6000Y0.0000
            G01 X1.6000Y0.0000
            (test 0.2mm)
            G01 X1.6000Y5.0000
            G01 X1.8000Y5.0000
            G01 X1.8000Y0.0000
            G01 X2.0000Y0.0000
            G01 X2.0000Y5.0000
            G01 X2.2000Y5.0000
            G01 X2.2000Y0.0000
            G01 X2.4000Y0.0000
            G01 X2.4000Y5.0000
            G01 X2.6000Y5.0000
            G01 X2.6000Y0.0000
            G01 X2.8000Y0.0000
            G01 X3.8000Y0.0000
            (test 0.3mm)
            G01 X3.8000Y5.0000
            G01 X4.1000Y5.0000
            G01 X4.1000Y0.0000
            G01 X4.4000Y0.0000
            G01 X4.4000Y5.0000
            G01 X4.7000Y5.0000
            G01 X4.7000Y0.0000
            G01 X5.0000Y0.0000
            G01 X5.0000Y5.0000
            G01 X5.3000Y5.0000
            G01 X5.3000Y0.0000
            G01 X5.6000Y0.0000
            G01 X6.6000Y0.0000
            (test 0.4mm)
            G01 X6.6000Y5.0000
            G01 X7.0000Y5.0000
            G01 X7.0000Y0.0000
            G01 X7.4000Y0.0000
            G01 X7.4000Y5.0000
            G01 X7.8000Y5.0000
            G01 X7.8000Y0.0000
            G01 X8.2000Y0.0000
            G01 X8.2000Y5.0000
            G01 X8.6000Y5.0000
            G01 X8.6000Y0.0000
            G01 X9.0000Y0.0000
            G01 X10.0000Y0.0000
            (test 0.5mm)
            G01 X10.0000Y5.0000
            G01 X10.5000Y5.0000
            G01 X10.5000Y0.0000
            G01 X11.0000Y0.0000
            G01 X11.0000Y5.0000
            G01 X11.5000Y5.0000
            G01 X11.5000Y0.0000
            G01 X12.0000Y0.0000
            G01 X12.0000Y5.0000
            G01 X12.5000Y5.0000
            G01 X12.5000Y0.0000
            G01 X13.0000Y0.0000
            G01 X14.0000Y0.0000
            (test 0.6mm)
            G01 X14.0000Y5.0000
            G01 X14.6000Y5.0000
            G01 X14.6000Y0.0000
            G01 X15.2000Y0.0000
            G01 X15.2000Y5.0000
            G01 X15.8000Y5.0000
            G01 X15.8000Y0.0000
            G01 X16.4000Y0.0000
            G01 X16.4000Y5.0000
            G01 X17.0000Y5.0000
            G01 X17.0000Y0.0000
            G01 X17.6000Y0.0000
            G01 X18.6000Y0.0000
            (test 0.7mm)
            G01 X18.6000Y5.0000
            G01 X19.3000Y5.0000
            G01 X19.3000Y0.0000
            G01 X20.0000Y0.0000
            G01 X20.0000Y5.0000
            G01 X20.7000Y5.0000
            G01 X20.7000Y0.0000
            G01 X21.4000Y0.0000
            G01 X21.4000Y5.0000
            G01 X22.1000Y5.0000
            G01 X22.1000Y0.0000
            G00 Z1.5000
            G00 X0Y0
            M05
            #120
            @executivul Good stuff! I imagine I'll get there eventually, but on Day 1 I'd rather start with some reasonable magic constants that at least put me in the ballpark.
            • sundberg84S sundberg84
              @sundberg84 said in CNC PCB milling:
              Yes, that's what I'm attempting to do on this thread. :)
              • andrewA
                andrewA
                andrew
                JFYI: CNC 2418 assembly by me :)
                https://www.youtube.com/watch?v=T2_18-ObvP0
                I'll try to make a blog to describe the whole pcb cnc milling, tools etc, as well as other diy projects. I'll let you know if there is any notable progress...
                • andrewA andrew
                  #123
                  @andrew Nice. How long did that take in earth minutes?
                  • andrewA
                    andrewA
                    andrew
                    wrote on last edited by andrew
                    #124
                    @NeverDie about 6 hours, in two nights
                    • E
                      E
                      executivul
                      Best way to get rid of the dust seems to be not making dust to start with.
                      Enjoy!
                      https://youtu.be/PpXG1X9yoxs
                      • E executivul
                        Enjoy!
                        @executivul Which car shampoo?
                        How well does it work? Would it work better if you flooded it a bit more so that it was sitting, say, a couple mm under shampoo solution?
                          I suppose your etching bit might last longer too, since maybe the liquid would help cool it.
                          • E
                            E
                            executivul
                            Unfortunately I can not disclose this secret recipe, all I can tell you is that s some cationic surfactant mixed with some dihydrogen peroxide :sunglasses:
                            To be honest I don't know the brand, I've first tried liquid soap undiluted but was to thick and was gathering around the bit like a small tornado and splashing everywhere, decided to add some water and went looking for a spray bottle, found one with some handwriting "car shampoo", it is thicker than plain water, but not as thick as liquid soap, so it might be diluted, I still have some for a few more boards then I'll go by trial and error with dish/hand/car wash and water.
                            So much better not to have windows open at 0C(32F) and the vacuum howling. Only the 2.0mm endmill still creates dust, normal engraving and drilling do not.
                            Don't forget to mill on acrylic/plastic as mdf will swell if wet.
                              #129
                              Looks like my CNC2418 is on track to be delivered this Monday. It has already cleared customs.
                              So, since it will be arriving well ahead of all the various bits and such, I'm guessing that just a few etching bits will be enough to get me started and confirm whether my machine can route 6 mil isolation.
                              The kit itself includes 0.1mm bits (Diameter: 3.175mm tip: 0.1mm length: 30mm).
                                It arrived!
                                YveauxY andrewA 2 Replies Last reply
                                  It arrived!
                                  @neverdie Yay! Where can we find the live stream of the build process? ;-)
                                    It arrived!
                                    andrewA
                                    andrewA
                                    andrew
                                    @neverdie so, I expect your first boards tomorrow :)
                                    • andrewA andrew
                                      #133
                                      But wait, I'm still waiting for the magic numbers from you. :) Otherwise, I'll be all dressed with nowhere to go.
                                      andrewA 1 Reply Last reply
                                        andrewA
                                        andrewA
                                        andrew
                                        #134
                                        @neverdie once the assembly is done, you should adjust the stepper drivers' current limiting as well.
                                        then, it is always good idea to have the basic settings exported from the board, just in case... you can do it by "$$" command sent from the g code sender gui or directly from the serial terminal.
                                        currently I use the following settings, the machine might be able to create nice results with higher feed rates, but I did not have enough time to test it and I sticked to the current working config.
                                        isolation routing with 2001 bits:
                                        • z cut: -0.05mm
                                        • feed rate: 200
                                        you can calculate the V carving bit's tool width for the given milling depth with the following formula:
                                        tan(bit angle/2) * milling depth * 2 + bit's end width
                                        for excel formula the bit angle should be provided in radians, so it should look like this
                                        tan(radians(bit angle/2)) * milling depth * 2 + bit's end width
                                        edge cut or hole milling with the 0.8mm endmill:
                                        • feed rate: 170
                                        • z cut: -1.7mm
                                        • multi depth, depth/pass: 0.2mm
                                        drilling:
                                        • feed rate: 130
                                        • z cut: -1.8
                                        the spindle should be 1000 everywhere.
                                        most probably your board will not have a bootloader, so it will not be possible to update the firmware via usb serial connection (with avrdude), but it is worth to try it. for me it did not work, so I traced back the MCU pins to the pin rows and used ISP to upgrade the firmware to grbl v1.1f (the board will come with 0.9j if I remember correctly). do not forget to export the gerber settings before you upgrade the firmware, as it will loose those, and you have to re-assign the given values again, after the update.
                                        the ISP pinout (from the pin row's top left corner):
                                        Reset -> pin 2
                                        SCK -> pin 3
                                        MISO -> pin 12
                                        MOSI -> pin 13
                                        5v -> pin1
                                        gnd-> bottom row(!) e.g. pin 1
                                        NeverDieN rmtuckerR B 4 Replies Last reply
                                          #135
                                          The assembly instructions came as a file on a mini CD. Attached for anyone who is interested.
                                          [0_1513463653125_2418-Assembly instructions - English.doc](Uploading 100%)
                                          Hmmm.. I guess the forum only lets me upload photos. Sorry.
