  3. Combining relay and temperature sketch
76 Posts 9 Posters 24.1k Views 12 Watching
  • B
    B
    bluezr1
    wrote on last edited by bluezr1
    #55
    This is where I'm currently at, it seems to be working really well. Thanks rejoe2
     * Version 1.0: Henrik EKblad
     * sensor using a DHT11/DHT-22.
    // Enable debug prints
    //#define MY_RS485
    #define MY_NODE_ID 19
    #define DHT_DATA_PIN 3
    #define SENSOR_TEMP_OFFSET 0
    static const uint64_t UPDATE_INTERVAL = 60000;
    #define CHILD_ID_HUM 10
    #define CHILD_ID_TEMP 11
    float lastTemp;
    float lastHum;
    uint8_t nNoUpdatesTemp;
    uint8_t nNoUpdatesHum;
    bool metric = true;
    DHT dht;
    #define RELAY_PIN 4  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    #define NUMBER_OF_RELAYS 2 // Total number of attached relays
    void before()
        for (int sensor=1, pin=RELAY_PIN; sensor<=NUMBER_OF_RELAYS; sensor++, pin++) {
            pinMode(pin, OUTPUT);
            digitalWrite(pin, loadState(sensor)?RELAY_OFF:RELAY_ON);
      sendSketchInfo("TempRELAY", "1.1");
      present(CHILD_ID_HUM, S_HUM);
            present(sensor, S_BINARY);
      wait(dht.getMinimumSamplingPeriod());
      dht.readSensor(true);
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        // Reset no updates counter
        nNoUpdatesTemp = 0;
        #ifdef MY_DEBUG
        Serial.print("T: ");
        nNoUpdatesTemp++;
      if (isnan(humidity)) {
        lastHum = humidity;
        nNoUpdatesHum = 0;
        #ifdef MY_DEBUG
        Serial.print("H: ");
        Serial.println(humidity);
        nNoUpdatesHum++;
      wait(UPDATE_INTERVAL);
        if (message.type==V_STATUS) {
            // Change relay state
            digitalWrite(message.sensor-1+RELAY_PIN, message.getBool()?RELAY_OFF:RELAY_ON);
            // Store state in eeprom
    rejoe2R 1 Reply Last reply
    • B bluezr1
      //#define MY_RS485
      float lastTemp;
      float lastHum;
      bool metric = true;
      DHT dht;
      void before()
          if (!metric) {
          nNoUpdatesTemp = 0;
          #ifdef MY_DEBUG
          nNoUpdatesTemp++;
          lastHum = humidity;
          nNoUpdatesHum = 0;
          #ifdef MY_DEBUG
          nNoUpdatesHum++;
      rejoe2R
      rejoe2R
      rejoe2
      @bluezr1 Looks already really good.
      Question: does the receive() work while the loop does the wait()? I'm not sure about that, because I am used to do the millis()-nonblocking-loop.
      B 1 Reply Last reply
      • rejoe2R rejoe2
        B
        B
        bluezr1
        @rejoe2 I hope that this answers your question. I use Vera as my home controller and tried multiple times turning (sometimes randomly) on and off both relays without any misses as soon as Vera allowed me. Meaning, Vera won’t let you instantly turn a device on and then off or vise versa.
        Do you think I’ll be ok the way it is or should I keep working on this project?
        • B bluezr1
          rejoe2R
          rejoe2R
          rejoe2
          @bluezr1 As it seems to work to your satisfaction, you may leave it as is.
          FHEM as a controller allows direct interaction with switching devices, and it is really astonishing to hear Vera may have some restrictions wrt. that.
          But I didn't test your code in my setup, this is why I asked about your observations.
          I may be wrong, but imo, the code isn't yet perfect, so you might keep that in mind for the future in case you run into trouble. In case you need some sort of timer for other projects, you would miss the opportunity to learn how to use this...
          • rejoe2R rejoe2
            B
            B
            bluezr1
            #59
            @rejoe2 It's working
            Although I'm not sure if this part makes sense?
            unsigned long interval = 60000;
            unsigned long previousMillis = 0;```
            //#define MY_RS485
            #define MY_NODE_ID 20
            float lastTemp;
            float lastHum;
            bool metric = true;
            DHT dht;
            void before()
              // wait(dht.getMinimumSamplingPeriod());
             if ((unsigned long)(currentMillis - previousMillis) >= interval) {
                if (!metric) {
                nNoUpdatesTemp = 0;
                #ifdef MY_DEBUG
                nNoUpdatesTemp++;
                lastHum = humidity;
                nNoUpdatesHum = 0;
                #ifdef MY_DEBUG
                nNoUpdatesTemp++;
              previousMillis = millis();
            • B bluezr1
              //#define MY_RS485
              float lastTemp;
              float lastHum;
              bool metric = true;
              DHT dht;
              void before()
                  if (!metric) {
                  nNoUpdatesTemp = 0;
                  #ifdef MY_DEBUG
                  nNoUpdatesTemp++;
                  lastHum = humidity;
                  nNoUpdatesHum = 0;
                  #ifdef MY_DEBUG
                  nNoUpdatesTemp++;
              rejoe2R
              rejoe2R
              rejoe2
              @bluezr1 Looks like you did a working non-blocking loop :grin:
              Didn't do a too close look to all things, but the only header definition that seems to be no longer necessary is the UPDATE_INTERVAL, as this variable isn't used any longer.
              But beside that small remark: :clap:
              • B
                B
                bluezr1
                #61
                <<edit>>It was me, my bad, it's working.
                For some reason if I pull a wire for the relay it'll still show a change within Vera. I can turn them on and off and they'll show up as if they were turned on and off. Before if I pulled a wire to the relays vera wouldn't show any changes.
                Thank you so much rejoe2 for not just giving me the answers but by pushing me to do it myself. You pointed me to where I needed to be and I thank you for that.
                Now you got me wanting to learn even more. :)
                • B
                  B
                  bluezr1
                  Wanted to post it incase someone else wants to use it.
                  //#define MY_RS485
                  //static const uint64_t UPDATE_INTERVAL = 60000;
                  float lastTemp;
                  float lastHum;
                  bool metric = true;
                  DHT dht;
                  void before()
                    //if (UPDATE_INTERVAL <= dht.getMinimumSamplingPeriod()) {
                     // Serial.println("Warning: UPDATE_INTERVAL is smaller than supported by the sensor!");
                      if (!metric) {
                      nNoUpdatesTemp = 0;
                      #ifdef MY_DEBUG
                      nNoUpdatesTemp++;
                      lastHum = humidity;
                      nNoUpdatesHum = 0;
                      #ifdef MY_DEBUG
                      nNoUpdatesTemp++;
                          digitalWrite(message.sensor-1+RELAY_PIN, message.getBool()?RELAY_ON:RELAY_OFF);
                  • B bluezr1
                    rejoe2R
                    rejoe2R
                    rejoe2
                    @bluezr1 said in Combining relay and temperature sketch:
                    Thanks also a lot for your positive feedback - seems there are more and more people interested in quick fixes, but imo, it's by far better to "learn how to fish".
                    For the next steps, I'd recommend to do some more "combinded sketching", based on the existing build examples - but you'll find that easy once you did the next two of them :grin:
                    One more interesting thing may be working with interrups in non-blocking sketches - please mind the needed type of variable definition to avoid irritating effects ;-)
                    Then you might run into trouble as combining things needs more PINs - then you are forced to have a look on the next level of abstraction: array functions ;-) . For a start, you may analyse the multi-button-relay-sketch somwhere around here in the forum.
                    Then you are at least on my level of knowledge within one week :grin:
                    • pepsonP
                      pepsonP
                      pepson
                      Hi
                      I need help... I want use sketch for 2 relay and sensor temp Dallas SD18b20.
                      I have working sketch for 2xrelay and put to it sketch from mysensors
                      https://www.mysensors.org/build/temp
                      for Dallas but it not working. Not showing temp from Dallas. In DOmotcz on Gateway show only Binary from relay. Not Show Temp.
                         DESCRIPTION
                         Sketch for 2x relay with buttons monostable. After back power all relays set OFF and send correct status OFF to controller.
                      #define MY_RADIO_RFM69
                      #define MY_RFM69_FREQUENCY RF69_868MHZ
                      #define MY_IS_RFM69HW
                      #define MY_REPEATER_FEATURE
                      // Node id defaults to AUTO (tries to fetch id from controller)
                      #define MY_NODE_ID AUTO
                      #include <OneWire.h>
                      // Define Relays
                      // Define Sensor ID's
                      #define SSR_A_ID 1   // Id of the sensor child
                      #define SSR_B_ID 2   // Id of the sensor child
                      // Define buttons and relays
                      const int buttonPinA = 3;
                      const int buttonPinB = 4;
                      const int relayPinA = 5;
                      const int relayPinB = 6;
                      // Define Variables
                      int oldValueA = 0;
                      int oldValueB = 0;
                      bool stateA = false;
                      bool stateB = false;
                      int trigger = 0;
                      // Define Sensors Temperature
                      int numSensors=0;
                      bool receivedConfig = false;
                      bool metric = true;
                      Bounce debouncerA = Bounce();
                      Bounce debouncerB = Bounce();
                      MyMessage msgA(SSR_A_ID, V_STATUS);
                      MyMessage msgB(SSR_B_ID, V_STATUS);
                      MyMessage msg(0,V_TEMP);
                      void before()
                        sensors.begin();
                        pinMode(buttonPinA, INPUT_PULLUP); // Setup the button Activate internal pull-up
                        pinMode(buttonPinB, INPUT_PULLUP); // Setup the button Activate internal pull-up
                        // After setting up the buttons, setup debouncer
                        debouncerA.attach(buttonPinA);
                        debouncerA.interval(5);
                        debouncerB.attach(buttonPinB);
                        debouncerB.interval(5);
                        digitalWrite(relayPinA, RELAY_OFF);
                        digitalWrite(relayPinB, RELAY_OFF);
                        pinMode(relayPinA, OUTPUT);
                        pinMode(relayPinB, OUTPUT);
                      void presentation()  {
                        sendSketchInfo("2xRelay monostable + temp. DS18b20", "2.1.1");
                        present(SSR_A_ID, S_LIGHT);
                        present(SSR_B_ID, S_LIGHT);
                           present(i, S_TEMP);
                      if (trigger == 0){
                        send(msgA.set(false)); // Send off state for relayA to ensure controller knows the switch is off
                        send(msgB.set(false)); // Send off state for relayB to ensure controller knows the switch is off
                        trigger = 1;
                        debouncerA.update();
                        // Get the update value
                        int valueA = debouncerA.read();
                        if (valueA != oldValueA && valueA == 0) {
                          send(msgA.set(stateA ? false : true), true); // Send new state and request ack back
                        oldValueA = valueA;
                        debouncerB.update();
                        int valueB = debouncerB.read();
                        if (valueB != oldValueB && valueB == 0) {
                          send(msgB.set(stateB ? false : true), true); // Send new state and request ack back
                        oldValueB = valueB;
                        sleep(conversionTime);
                          #if COMPARE_TEMP == 1
                        sleep(SLEEP_TIME);
                          switch (message.sensor) {
                            case 1:
                              stateA = message.getBool();
                              digitalWrite(message.sensor + 4, stateA ? RELAY_ON : RELAY_OFF);
                            case 2:
                              stateB = message.getBool();
                              digitalWrite(message.sensor + 4, stateB ? RELAY_ON : RELAY_OFF);
                          Serial.print("from node:");
                          Serial.println(message.sender);
                      Please help me
                      • pepsonP pepson
                        Hi
                           DESCRIPTION
                        // Define Relays
                        // Define Variables
                        int oldValueA = 0;
                        int oldValueB = 0;
                        int trigger = 0;
                        int numSensors=0;
                        bool metric = true;
                        void before()
                          sensors.begin();
                             present(i, S_TEMP);
                        if (trigger == 0){
                          trigger = 1;
                          oldValueA = valueA;
                          oldValueB = valueB;
                          sleep(SLEEP_TIME);
                              case 1:
                              case 2:
                        Please help me
                        rejoe2R
                        rejoe2R
                        rejoe2
                        @pepson
                        Imo there are several things to look at:
                        1. Pin 3 seems to be used for button a + 1-wire? -> use a different one
                        2. How many DS18B20 do you have attached?
                          a) In case it's up to three, you try to report Relay and Temp info partly under the same Child_ID (1+2). Imo, it's better to chose a different starting Child ID, something like "present(i+10, S_TEMP)" or use a variable like "FIRST_TEMP_CHILD" (also use the same scheme for sending).
                          b) You may also suffer from a wiring problem, if you are able to compile and flash this sketch. Just for testing you could add a debugg-message to serial with the numSensors
                        3. Combining relays, debounced buttons and sleep() most likely will cause problems. Better use a non-blocking loop as described in post #45 and following.
                        • pepsonP
                          pepsonP
                          pepson
                          wrote on last edited by pepson
                          #66
                          I use one temp sensor. Ok i try correct but i dont know how correct it for send...please help me for sending...
                          And please help me with this:
                             DESCRIPTION
                          // Define Relays
                          // Define Variables
                          int oldValueA = 0;
                          int oldValueB = 0;
                          int trigger = 0;
                          #define ONE_WIRE_BUS 7 // Pin where dallase sensor is connected
                          int numSensors=0;
                          bool metric = true;
                          void before()
                            sensors.begin();
                               present(i+10, S_TEMP);
                          if (trigger == 0){
                            trigger = 1;
                            oldValueA = valueA;
                            oldValueB = valueB;
                            sleep(SLEEP_TIME);
                                case 1:
                                case 2:
                          • rejoe2R
                            rejoe2R
                            rejoe2
                            1. Wrt sending: your controller should show one temperature sensor with Child ID 10. As a consequence, the temp value should also be reported using this ID. So you should adopt this line appropriately, just use the same logic as in presentation() :grin: .
                            1. For the non-blocking loop: As already mentionned, within this thread you just should follow @bluezr1 steps and some of my remarks :grinning: .
                              The sketch in #63 should be a working solution, but when using dallas temp instead of the DHT, you have also to change the sleep(conversionTime) to wait().
                            • pepsonP
                              pepsonP
                              pepson
                              I am begginer. Can you give me ready sketch for dallas with one relay ? Please
                              • pepsonP pepson
                                rejoe2R
                                rejoe2R
                                rejoe2
                                @pepson Especially as a beginner you really should try to follow the necessary steps to develop combined sketches - it's easier than you may think by now.
                                Otherwise you may run into the next unexpected trouble without any idea, how things fit together and - even more important - how to debug (or even where to attach what). So asking for ready sketches is not the best idea.
                                If you are still convinced about the need of a ready sketch: There's - amongst others - a sketch with #101 using DS18B20 and 4 relays in my repo (link is already available in this thread). , BUT: this is work in progress, may use a modified version of the dallas lib and reports temperatures and relays under the same ChildID - my controller (FHEM) seems not to care about that...
                                As I changed communication to RS485 last weekend, I most likely will not do any update, if there are issues or further enhancements on the code (I plan to do some).
                                • pepsonP
                                  pepsonP
                                  pepson
                                  @rejoe2 said in Combining relay and temperature sketch:
                                  I try also ready sketch for only dallas fom mysensors.rg but it also not working:
                                  int numSensors=0;
                                  bool metric = true;
                                  void before()
                                    sensors.begin();
                                       present(i, S_TEMP);
                                    sleep(SLEEP_TIME);
                                  • rejoe2R rejoe2
                                    @pepson
                                    rejoe2R
                                    rejoe2R
                                    rejoe2
                                    Did you follow the instructions as described in the "build" section, attached the data line to PIN3 and used an appropriate resistor (measure it's value) ? Then it's most likely a damaged sensor...
                                    pepsonP 1 Reply Last reply
                                    • rejoe2R rejoe2
                                      pepsonP
                                      pepsonP
                                      pepson
                                      @rejoe2
                                      Yes i connected my sensors to PIN 3 and use resistor 4.7
                                      But in Domoticz on gateway not show any CHILDS for this NODE.
                                      • pepsonP pepson
                                        @rejoe2
                                        rejoe2R
                                        rejoe2R
                                        rejoe2
                                        @pepson Seems like the sensor is not detected, so the presentation() will have zero sensors to present...
                                        If you do not want to follow the proposal to print the numSensors to serial (most likely: 0) you should try to test the DS18B20-Hardware by using an example sketch (e.g. Simple.pde) from the dallas temperature lib (without the MySensors-framework) and have a look on the serial console of the IDE. Be aware: "as is", it uses PIN2 and a different baudrate.
                                        If there are no temperature values printed, it's either still a wiring problem or the sensor's just broken.
                                        • MGHaffM
                                          MGHaffM
                                          MGHaff
                                          Has anyone had any progress on sensor node with mysensors + multiple dallas temp sensors and multiple relays, combining the two codes? Any help would be greatly appreciated. I have been playing with this for a little more than a week, have tried everything suggested but still not working. A push in the right direction would be great!
