  3. Combining relay and temperature sketch
76 Posts 9 Posters 24.1k Views 12 Watching
  • rejoe2R rejoe2
    @bluezr1 Looks already really good.
    Question: does the receive() work while the loop does the wait()? I'm not sure about that, because I am used to do the millis()-nonblocking-loop.
    B
    B
    bluezr1
    @rejoe2 I hope that this answers your question. I use Vera as my home controller and tried multiple times turning (sometimes randomly) on and off both relays without any misses as soon as Vera allowed me. Meaning, Vera won’t let you instantly turn a device on and then off or vise versa.
    Do you think I’ll be ok the way it is or should I keep working on this project?
    rejoe2R 1 Reply Last reply
    • B bluezr1
      rejoe2R
      rejoe2R
      rejoe2
      @bluezr1 As it seems to work to your satisfaction, you may leave it as is.
      FHEM as a controller allows direct interaction with switching devices, and it is really astonishing to hear Vera may have some restrictions wrt. that.
      But I didn't test your code in my setup, this is why I asked about your observations.
      I may be wrong, but imo, the code isn't yet perfect, so you might keep that in mind for the future in case you run into trouble. In case you need some sort of timer for other projects, you would miss the opportunity to learn how to use this...
      B 1 Reply Last reply
      • rejoe2R rejoe2
        B
        B
        bluezr1
        wrote on last edited by bluezr1
        #59
        @rejoe2 It's working
        Although I'm not sure if this part makes sense?
        static const uint64_t UPDATE_INTERVAL = 60000;
        unsigned long interval = 60000;
        unsigned long previousMillis = 0;```
         * Version 1.0: Henrik EKblad
         * sensor using a DHT11/DHT-22.
        // Enable debug prints
        //#define MY_RS485
        #define MY_NODE_ID 20
        #define DHT_DATA_PIN 3
        #define SENSOR_TEMP_OFFSET 0
        #define CHILD_ID_HUM 10
        #define CHILD_ID_TEMP 11
        float lastTemp;
        float lastHum;
        uint8_t nNoUpdatesTemp;
        uint8_t nNoUpdatesHum;
        bool metric = true;
        DHT dht;
        #define RELAY_PIN 4  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
        #define NUMBER_OF_RELAYS 2 // Total number of attached relays
        void before()
            for (int sensor=1, pin=RELAY_PIN; sensor<=NUMBER_OF_RELAYS; sensor++, pin++) {
                pinMode(pin, OUTPUT);
                digitalWrite(pin, loadState(sensor)?RELAY_OFF:RELAY_ON);
          sendSketchInfo("TempRELAY", "1.1");
          present(CHILD_ID_HUM, S_HUM);
                present(sensor, S_BINARY);
          // wait(dht.getMinimumSamplingPeriod());
         if ((unsigned long)(currentMillis - previousMillis) >= interval) {
          dht.readSensor(true);
          if (isnan(temperature)) {
            lastTemp = temperature;
            if (!metric) {
            // Reset no updates counter
            nNoUpdatesTemp = 0;
            #ifdef MY_DEBUG
            Serial.print("T: ");
            nNoUpdatesTemp++;
          if (isnan(humidity)) {
            lastHum = humidity;
            nNoUpdatesHum = 0;
            #ifdef MY_DEBUG
            Serial.print("H: ");
            Serial.println(humidity);
            nNoUpdatesTemp++;
          previousMillis = millis();
            if (message.type==V_STATUS) {
                // Change relay state
                digitalWrite(message.sensor-1+RELAY_PIN, message.getBool()?RELAY_OFF:RELAY_ON);
                // Store state in eeprom
        • B bluezr1
          //#define MY_RS485
          float lastTemp;
          float lastHum;
          bool metric = true;
          DHT dht;
          void before()
              if (!metric) {
              nNoUpdatesTemp = 0;
              #ifdef MY_DEBUG
              nNoUpdatesTemp++;
              lastHum = humidity;
              nNoUpdatesHum = 0;
              #ifdef MY_DEBUG
              nNoUpdatesTemp++;
          rejoe2R
          rejoe2R
          rejoe2
          @bluezr1 Looks like you did a working non-blocking loop :grin:
          Didn't do a too close look to all things, but the only header definition that seems to be no longer necessary is the UPDATE_INTERVAL, as this variable isn't used any longer.
          But beside that small remark: :clap:
          • B
            B
            bluezr1
            #61
            <<edit>>It was me, my bad, it's working.
            For some reason if I pull a wire for the relay it'll still show a change within Vera. I can turn them on and off and they'll show up as if they were turned on and off. Before if I pulled a wire to the relays vera wouldn't show any changes.
            Thank you so much rejoe2 for not just giving me the answers but by pushing me to do it myself. You pointed me to where I needed to be and I thank you for that.
            Now you got me wanting to learn even more. :)
            • B
              B
              bluezr1
              Wanted to post it incase someone else wants to use it.
              //#define MY_RS485
              //static const uint64_t UPDATE_INTERVAL = 60000;
              float lastTemp;
              float lastHum;
              bool metric = true;
              DHT dht;
              void before()
                //if (UPDATE_INTERVAL <= dht.getMinimumSamplingPeriod()) {
                 // Serial.println("Warning: UPDATE_INTERVAL is smaller than supported by the sensor!");
                  if (!metric) {
                  nNoUpdatesTemp = 0;
                  #ifdef MY_DEBUG
                  nNoUpdatesTemp++;
                  lastHum = humidity;
                  nNoUpdatesHum = 0;
                  #ifdef MY_DEBUG
                  nNoUpdatesTemp++;
                      digitalWrite(message.sensor-1+RELAY_PIN, message.getBool()?RELAY_ON:RELAY_OFF);
              • B bluezr1
                rejoe2R
                rejoe2R
                rejoe2
                @bluezr1 said in Combining relay and temperature sketch:
                Thanks also a lot for your positive feedback - seems there are more and more people interested in quick fixes, but imo, it's by far better to "learn how to fish".
                For the next steps, I'd recommend to do some more "combinded sketching", based on the existing build examples - but you'll find that easy once you did the next two of them :grin:
                One more interesting thing may be working with interrups in non-blocking sketches - please mind the needed type of variable definition to avoid irritating effects ;-)
                Then you might run into trouble as combining things needs more PINs - then you are forced to have a look on the next level of abstraction: array functions ;-) . For a start, you may analyse the multi-button-relay-sketch somwhere around here in the forum.
                Then you are at least on my level of knowledge within one week :grin:
                • pepsonP
                  pepsonP
                  pepson
                  Hi
                  I need help... I want use sketch for 2 relay and sensor temp Dallas SD18b20.
                  I have working sketch for 2xrelay and put to it sketch from mysensors
                  https://www.mysensors.org/build/temp
                  for Dallas but it not working. Not showing temp from Dallas. In DOmotcz on Gateway show only Binary from relay. Not Show Temp.
                     DESCRIPTION
                     Sketch for 2x relay with buttons monostable. After back power all relays set OFF and send correct status OFF to controller.
                  #define MY_RADIO_RFM69
                  #define MY_RFM69_FREQUENCY RF69_868MHZ
                  #define MY_IS_RFM69HW
                  #define MY_REPEATER_FEATURE
                  // Node id defaults to AUTO (tries to fetch id from controller)
                  #define MY_NODE_ID AUTO
                  #include <OneWire.h>
                  // Define Relays
                  // Define Sensor ID's
                  #define SSR_A_ID 1   // Id of the sensor child
                  #define SSR_B_ID 2   // Id of the sensor child
                  // Define buttons and relays
                  const int buttonPinA = 3;
                  const int buttonPinB = 4;
                  const int relayPinA = 5;
                  const int relayPinB = 6;
                  // Define Variables
                  int oldValueA = 0;
                  int oldValueB = 0;
                  bool stateA = false;
                  bool stateB = false;
                  int trigger = 0;
                  // Define Sensors Temperature
                  int numSensors=0;
                  bool receivedConfig = false;
                  bool metric = true;
                  Bounce debouncerA = Bounce();
                  Bounce debouncerB = Bounce();
                  MyMessage msgA(SSR_A_ID, V_STATUS);
                  MyMessage msgB(SSR_B_ID, V_STATUS);
                  MyMessage msg(0,V_TEMP);
                  void before()
                    sensors.begin();
                    pinMode(buttonPinA, INPUT_PULLUP); // Setup the button Activate internal pull-up
                    pinMode(buttonPinB, INPUT_PULLUP); // Setup the button Activate internal pull-up
                    // After setting up the buttons, setup debouncer
                    debouncerA.attach(buttonPinA);
                    debouncerA.interval(5);
                    debouncerB.attach(buttonPinB);
                    debouncerB.interval(5);
                    digitalWrite(relayPinA, RELAY_OFF);
                    digitalWrite(relayPinB, RELAY_OFF);
                    pinMode(relayPinA, OUTPUT);
                    pinMode(relayPinB, OUTPUT);
                  void presentation()  {
                    sendSketchInfo("2xRelay monostable + temp. DS18b20", "2.1.1");
                    present(SSR_A_ID, S_LIGHT);
                    present(SSR_B_ID, S_LIGHT);
                       present(i, S_TEMP);
                  if (trigger == 0){
                    send(msgA.set(false)); // Send off state for relayA to ensure controller knows the switch is off
                    send(msgB.set(false)); // Send off state for relayB to ensure controller knows the switch is off
                    trigger = 1;
                    debouncerA.update();
                    // Get the update value
                    int valueA = debouncerA.read();
                    if (valueA != oldValueA && valueA == 0) {
                      send(msgA.set(stateA ? false : true), true); // Send new state and request ack back
                    oldValueA = valueA;
                    debouncerB.update();
                    int valueB = debouncerB.read();
                    if (valueB != oldValueB && valueB == 0) {
                      send(msgB.set(stateB ? false : true), true); // Send new state and request ack back
                    oldValueB = valueB;
                    sleep(conversionTime);
                      #if COMPARE_TEMP == 1
                    sleep(SLEEP_TIME);
                      switch (message.sensor) {
                        case 1:
                          stateA = message.getBool();
                          digitalWrite(message.sensor + 4, stateA ? RELAY_ON : RELAY_OFF);
                        case 2:
                          stateB = message.getBool();
                          digitalWrite(message.sensor + 4, stateB ? RELAY_ON : RELAY_OFF);
                      Serial.print("from node:");
                      Serial.println(message.sender);
                  Please help me
                  • pepsonP pepson
                    Hi
                       DESCRIPTION
                    // Define Relays
                    // Define Variables
                    int oldValueA = 0;
                    int oldValueB = 0;
                    int trigger = 0;
                    int numSensors=0;
                    bool metric = true;
                    void before()
                      sensors.begin();
                         present(i, S_TEMP);
                    if (trigger == 0){
                      trigger = 1;
                      oldValueA = valueA;
                      oldValueB = valueB;
                      sleep(SLEEP_TIME);
                          case 1:
                          case 2:
                    Please help me
                    rejoe2R
                    rejoe2R
                    rejoe2
                    @pepson
                    Imo there are several things to look at:
                    1. Pin 3 seems to be used for button a + 1-wire? -> use a different one
                    2. How many DS18B20 do you have attached?
                      a) In case it's up to three, you try to report Relay and Temp info partly under the same Child_ID (1+2). Imo, it's better to chose a different starting Child ID, something like "present(i+10, S_TEMP)" or use a variable like "FIRST_TEMP_CHILD" (also use the same scheme for sending).
                      b) You may also suffer from a wiring problem, if you are able to compile and flash this sketch. Just for testing you could add a debugg-message to serial with the numSensors
                    3. Combining relays, debounced buttons and sleep() most likely will cause problems. Better use a non-blocking loop as described in post #45 and following.
                    • pepsonP
                      pepsonP
                      pepson
                      wrote on last edited by pepson
                      #66
                      I use one temp sensor. Ok i try correct but i dont know how correct it for send...please help me for sending...
                      And please help me with this:
                         DESCRIPTION
                      // Define Relays
                      // Define Variables
                      int oldValueA = 0;
                      int oldValueB = 0;
                      int trigger = 0;
                      #define ONE_WIRE_BUS 7 // Pin where dallase sensor is connected
                      int numSensors=0;
                      bool metric = true;
                      void before()
                        sensors.begin();
                           present(i+10, S_TEMP);
                      if (trigger == 0){
                        trigger = 1;
                        oldValueA = valueA;
                        oldValueB = valueB;
                        sleep(SLEEP_TIME);
                            case 1:
                            case 2:
                      • rejoe2R
                        rejoe2R
                        rejoe2
                        1. Wrt sending: your controller should show one temperature sensor with Child ID 10. As a consequence, the temp value should also be reported using this ID. So you should adopt this line appropriately, just use the same logic as in presentation() :grin: .
                        1. For the non-blocking loop: As already mentionned, within this thread you just should follow @bluezr1 steps and some of my remarks :grinning: .
                          The sketch in #63 should be a working solution, but when using dallas temp instead of the DHT, you have also to change the sleep(conversionTime) to wait().
                        • pepsonP
                          pepsonP
                          pepson
                          I am begginer. Can you give me ready sketch for dallas with one relay ? Please
                          • pepsonP pepson
                            rejoe2R
                            rejoe2R
                            rejoe2
                            @pepson Especially as a beginner you really should try to follow the necessary steps to develop combined sketches - it's easier than you may think by now.
                            Otherwise you may run into the next unexpected trouble without any idea, how things fit together and - even more important - how to debug (or even where to attach what). So asking for ready sketches is not the best idea.
                            If you are still convinced about the need of a ready sketch: There's - amongst others - a sketch with #101 using DS18B20 and 4 relays in my repo (link is already available in this thread). , BUT: this is work in progress, may use a modified version of the dallas lib and reports temperatures and relays under the same ChildID - my controller (FHEM) seems not to care about that...
                            As I changed communication to RS485 last weekend, I most likely will not do any update, if there are issues or further enhancements on the code (I plan to do some).
                            • pepsonP
                              pepsonP
                              pepson
                              @rejoe2 said in Combining relay and temperature sketch:
                              I try also ready sketch for only dallas fom mysensors.rg but it also not working:
                              int numSensors=0;
                              bool metric = true;
                              void before()
                                sensors.begin();
                                   present(i, S_TEMP);
                                sleep(SLEEP_TIME);
                              • rejoe2R rejoe2
                                @pepson
                                rejoe2R
                                rejoe2R
                                rejoe2
                                Did you follow the instructions as described in the "build" section, attached the data line to PIN3 and used an appropriate resistor (measure it's value) ? Then it's most likely a damaged sensor...
                                pepsonP 1 Reply Last reply
                                • rejoe2R rejoe2
                                  pepsonP
                                  pepsonP
                                  pepson
                                  @rejoe2
                                  Yes i connected my sensors to PIN 3 and use resistor 4.7
                                  But in Domoticz on gateway not show any CHILDS for this NODE.
                                  • pepsonP pepson
                                    @rejoe2
                                    rejoe2R
                                    rejoe2R
                                    rejoe2
                                    @pepson Seems like the sensor is not detected, so the presentation() will have zero sensors to present...
                                    If you do not want to follow the proposal to print the numSensors to serial (most likely: 0) you should try to test the DS18B20-Hardware by using an example sketch (e.g. Simple.pde) from the dallas temperature lib (without the MySensors-framework) and have a look on the serial console of the IDE. Be aware: "as is", it uses PIN2 and a different baudrate.
                                    If there are no temperature values printed, it's either still a wiring problem or the sensor's just broken.
                                    • MGHaffM
                                      MGHaffM
                                      MGHaff
                                      Has anyone had any progress on sensor node with mysensors + multiple dallas temp sensors and multiple relays, combining the two codes? Any help would be greatly appreciated. I have been playing with this for a little more than a week, have tried everything suggested but still not working. A push in the right direction would be great!
                                      • rejoe2R
                                        rejoe2R
                                        rejoe2
                                        @mghaff said in Combining relay and temperature sketch:
                                        Some older code; some rework might be necessary: https://github.com/rejoe2/MySensors_Small/blob/master/MyS101/MyS101.ino
                                        There are some more DS18B20 examples in the repo, just have a look around...
                                        MGHaffM 1 Reply Last reply
                                        • rejoe2R rejoe2
                                          MGHaffM
                                          MGHaffM
                                          MGHaff
                                          @rejoe2 Thanks! I will do that. the code i used was from the examples. My relays work fine but my temp sensors never register. Even in serial. but if i run the Dallas temp my-sensors code separate i always get reading. Its just been mind boggling. :)
